Loral Dry Spreader System NLL2020G4 Parts Catalog WR128710
Brand: Loral
Type of Machine: Dry Spreader System
Model: Loral NLL2020G4 Dry Spreader System
Part Number: WR128710
Number of Pages: 184 Pages
Publication Information
Box And Conveyor Group
Sleeper Instl-Bolted, Plastic
Sleeper-Plastic, 3.50x.75x135
Inverted Vee-L
Conveyor Bottom # 5 L2020g4
Mudflap Instl-Nl,Loral
Conveyer Idler
Conveyer Chain Oiler
Oiler Conveyor Chain
Conveyer Drive
Front Wiper
Conveyer Chain
Chain-#4 Boc Asm
Fenders-Super Float Tires
Roll Trpr 12 Ft Ft Nl Asm 92-
Holddown Asm-A M 2000,8104
Valve Flow Control O-Ring Thds
Window- Glass, Install
Product Distribution Group
Material Divider,L2020g4
Hillside Flow Divider,L2020g4
Spinner Guard And Shield L2020g4
Feedgate And Jack
Hydraulic Group
Guard Asm-Pto,6300
Pump Instl-Hyd,L2020g4,6300
Pump Asm-Hyd,L2020g4,Loral
Driveline Asm-Pto,6300
Pump Instl-L2020g4,6400
Hydraulic Fans,24 In L2020g4
Reservoir,23 Gallon-L2020g4
Gauge Instl-Hyd,Nl
Hose Instl-Hyd,L3020g4,6300
Hose Instl-Hyd,Nl,6400
Reservoir
Twin Spinner Hydraulics
Super Valve Hydraulics
Valve-Hydr,40gpm,Integrated
Gear Case
Rework Kit-Relief Valve
Motor Hyd Spinner Nl
Motor 1.50
Valve Servo Control
Electrical Group
Solenoid
Valve Solenoid
Valve-Solenoid,25npt,12v
Afwl, A M 1-2000
Lamp-Warning,Amber,Dual Lens
Light Instl-Work,Nl,Loral
Lamp-Work,Oval,Trap Lens
Switch Instl-Nl
Decal Group-Rh Control Panel
Taillight Instl-Nl
Lamp Cluster Rear Rh
Lamp Cluster Rear Lh
Harness Instl-Nl,Loral
Elec Instl-Sys,Nl,Loral
Controller Group
Sensor Instl-Rate,Rear,Nl
Sensor-Application Rate,Rvn
Sys Instl-Flcn Ii,Nl,Loral
Software Instl-Ini,Pwm Spinner
Sys Instl-Rvn 4000,Nl
Foam Marker Group
Foam Marker Instl-Nl
Tank Asm-Foam Marker,60gl,Nl
Hose Regulator Instl-Air,F M
Carrier Instl-F M,Loral
Step Asm 60 Gal F M
Decal Group
Decal Instl-L2020 L3020,Loral
Decals-L2020g4
Option Group
Guard Instl-Pto,6400
