Loral Air Spreader System 1998 Parts Catalog L043331
Brand: Loral
Type of Machine: Air Spreader System
Model: Loral 1998 Air Spreader System
Part Number: L043331
Number of Pages: 241 Pages
System Mounts
Conveyor Assembly
Gate Control Assembly
Low Rate Flow Gate
Hood Assembly
Grid Screen Assembly
Window Assembly
Rear Bulkhead Cover
Ladder Assembly
Lower Ladder Assembly
Cage Assembly
L.H. Catwalk Assembly
R.H. Catwalk Assembly
L.H. Front Splash Guard Assembly
R.H. Front Splash Guard Assembly
L.H. Rear Mudflap Assembly
R.H. Rear Mudflap Assembly
Auger Assembly
Distributor Assembly W Boom Shut-Off
Drop Hose Assembly
L.H. Fan Assembly
R.H. Fan Assembly
Manifold- Venturi Assembly L.H.
Manifold- Venturi Assembly R.H.
Venturi Tube Locator Lock Assembly
Center Section Assembly
Center Boom Pivot Assembly
Center Boom Slider & Stop Assembly
Hydraulic Cylinder Assembly
L.H. Non-Retractable 60ft Boom Assembly
R.H. Non-Retractable 60ft Boom Assembly
L.H. Non-Retractable 70ft Boom Assembly
R.H. Non-Retractable 70ft Boom Assembly
L.H. Non-Retractable Boom Cradle Assembly
R.H. Non-Retractable Boom Cradle Assembly
L.H. Retractable Boom Assembly
R.H. Retractable Boom Assembly
Retractable Boom Cradle Assembly L.H. & R.H.
Hydraulic Plumbing Retractable Booms
Dickey John, Basic Air Spread With Manual Transmission
Dickey John, Basic Air Spread With Automatic Transmission
Midtech, Basic Air Spread
Midtech, Basic Air Spread Liquid Impregnation
Midtech, Basic Air Spread Granular Bin
Radar Installation
Ball Valve Control Assembly
Rear Tail Light Assembly
Hydraulic Pump Assembly
Hydraulic Pump Driveline Assembly All Chassis Except 3310
Hydraulic Pump Driveline Assembly 3310 Chassis Only
System
Hydraulic Tank Assembly
Flow Control Valve Assembly
Valve Bank Assembly
Hyd. Filter Assy., 750 Psi
Hyd. Valves Assy.
Oil Cooler Plumbing, L.H.
Oil Cooler Plumbing, R.H.
L.H. Fan Motor Assembly
R.H. Fan Motor Assembly
Horizontal Auger Motor Assy.
Vertical Auger Motor Assy.
Servo Valve Assembly
Conveyor Motor Assy.
Check Valve Assy., 5 Psi
Divider Valve Assy.
Hydraulic Cylinder Assembly Hydraulic Cylinder Assembly Retractable Booms
Decal Package
Boom Shut-Off Butterfly Valve L.H. And R.H.
Air Cylinder Assembly L.H.
Air Cylinder Assembly R.H.
Boom Shut-Off Butterfly Valve Center L.H.
Boom Shut-Off Butterfly Valve Center R.H.
Air Cylinder Assembly Center L.H.
Air Cylinder Assembly Center R.H.
Air System Assembly
Boom Shut-Off Air Relay Valve
Solenoid Assy. L.H.
Solenoid Assy. R.H.
Foamer Package
Foamer Tank Assembly
Solenoid Valve Asm.
Granular System
L.H. Motor Assembly
R.H. Motor Assembly
Gran Bin Lid Assembly
L.H. & R.H. Dispenser Assembly, Dry Impregnation
Drain Valve Assembly
Rain Tarp
Bin Fill Cover Assembly
Bin Fill Assembly
Flip Tarp Package W O Riser Assembly (Optional)
Flip Tarp Package W Riser Assembly (Optional)
Hand Gun And Mounting
Reel Assembly
62 Gal. Tank Assembly
Assembly
Head Rinse Pump & Box Assembly
Head Rinse Assembly
Head Rinse Wiring Assembly
Pressure Washer Pump & Box Assembly
Pressure Washer Head Rinse Pump & Box Assembly
110 Gallon Tank Assy.
110 Gallon Head Rinse Assy.
110 Gallon Pressure Washer Assy.
110 Gal. Pressure Washer Hydraulic Plumbing
62 Gal. Pressure Washer Hydraulic Plumbing
Pressure Washer Pump Assembly
Pressure Washer On Off Valve Assembly
Shuttle Valve
35 Gallon Tank Assembly
62 Gallon Tank Assembly
62 Gallon Tank Sub-Assembly
Pump Assembly
Valve Assembly
Spraybar Assembly
Rear Box Assembly
