Loral Air Max System 1000 2000 Parts Catalog 503598D1
Brand: Loral
Type of Machine: Air Max System
Model:
Loral 1000 Air Max System
Loral 2000 Air Max System
Part Number: 503598D1
Number of Pages: 529 Pages
Publication Information
Tank And Saddle Group
Tank Instl-Spraymax
Tank Asm-Spraymax
Box And Conveyor Group
Bumper Instl-Rear
Bumper Taillight Asm-Rear
Lamp Cluster Rear Rh
Lamp Cluster Rear Lh
Cover Instl-Bin F E
Sleeper Instl-Bolted, Plastic
Sleeper-Plastic, 3.50x.75x135
Mudflap Instl-Am12k,Loral
Lamp-Warning,Amber
Gearbox-5 1 (Rtg)
Sensor Instl-Application Rate
Sensor-Application Rate,Rvn
Tarp Instl-Roll
Kit-Tarp,Roll,144x96
Belt Instl-Conveyor,Lower
Belt Asm-Conveyor,15.75,Lower
Belt Instl-Conveyor,Upper
Belt Asm-Conveyor,15.75,Upper
Sprocket Instl-Conveyor,Front
Rod Asm-Threaded,Take Up
Sprocket Instl-Rear Bin,Front
Hardware Grp-Dummy,Lift Hole
Plate Instl-Serial,Loral
Hood Instl-V,Lengthwise
Bracket Instl-Gauge
Window Instl-A M 1-2000
Hood Instl-V,A M 1000
Screen Instl-Front,W O Tank
Hood Instl-V,Dual Bin
Floor Instl-False
Ladder Instl-Rear,W Gran
Divider Instl-Riser
Riser Instl-9103
Spacer Ladder Instl-W O Gran
Divider Instl-9103,Dual Bin
Screen Instl
Holddown Asm-A M 2000,8104
Panel Instl-Flip
Screen Instl-A M 1000
Cover- Install, Front Bulkhead
Ladder- Front, Am 1000 2000
Product Distribution Group
Fan Instl
Fan Asm-1.83 Cir
Motor Asm-Hyd,Fan,1.83cir
Motor-Hyd,1.83 Cir
Cooler Asm-Oil,Hyd
Fan Guard Instl
Precleaner Instl
Precleaner-Rh,Fan,Am12k
Precleaner-Lh,Fan,Am12k
Gate Instl-Metering
Manifold Asm
Manifold Funnel Instl
Chute Instl-Unloading,Am1 2000
Outlet Deflector Instl-Am12k
Sight Gauge- Instl, Spraymax
Product Pump And Pressure Plumbing Group
Pump Reload And Valve Instl
Pump Asm-Prod,Fitting,Hyd
Pump-Cntfgl,2.0x1.5,1.42hydmtr
Plumbing Asm-Flowmeter
Flowmeter-2.00,140ppg,12v
Valve Asm-Fill Spray
Station Asm-Pump And Reload
Eductor Asm-Frame And Band
Eductor Asm-Chemical
Kit-Eductor,Chemical
Kit-Eductor,Lance And Plunger
Hose Instl-Pump Station
Spraybar And Plmb Instl-70ft
Spraybar Asm-B Section,70ft,Rh
Single Nozzle Holder-.75 Pipe
Spraybar Asm-B Section,70ft,Lh
Spraybar Asm-C Section,70ft
Spraybar Asm-Center,Rh,70ft
Spraybar Asm-Center,Lh,70ft
Spraybar Asm-A Section,Rh,70ft
Spraybar Asm-A Section,Lh,70ft
Valve Asm-Boom,Lh
Valve 0.75 Npt Ball Union Poly
Hose Instl-Product,No Inj
Boom Group
Boom Instl-70ft,Am12k,Loral
Boom Asm-70ft,Am12k,Lh
Cyl Asm-Hyd,Tip Fold
Cyl-Hyd,2.00x8.00x1.00
Boom Asm-70ft,Am12k,Rh
Pivot Instl-Airmax 1 2000
Cyl Asm-Hyd,Boom Fold
Cyl-Hyd,3.50x8.00x1.38
Rack Instl-Boom,Am12k,Loral
Rack Asm-Boom,A M 1-2000
Cylinder,Hyd,1.0x3.00x.50
Suspension Instl-Boom
Cyl Asm-Hyd,Boom Lift
Cyl-Hyd,3.00x5.00x1.50,Rod
Boom Plumbing Group
Spraybar And Plmb Instl-Triple
Spraybar Asm-C Sect,Triple
Triple Nozzle Holder .75 Pipe
Spraybar Asm-B Sect,Rh,Triple
Spraybar Asm-B Sect,Lh,Triple
Spraybar Asm-A Sect,Rh,Triple
Spraybar Asm-A Sect,Lh,Triple
Spraybar Asm-Center,Rh,Triple
Spraybar Asm-Center,Lh,Triple
Nozzle Instl-Er,S M,A M 1 2000
Valve 144a
Valve Instl-Boom,Sections
Tee Asm-Boom
Valve Asm-Boom,Rh
Hydraulic Group
Valve Asm-Hyd,Spraymax
Valve-Hyd,Shutoff
Hose Instl-Hyd
Tank Asm-Hyd
Cover Asm-Hyd Tank
Valve Asm-Hyd,Fan Speed,Servo
Valve-Hyd,50gpm,Servo,Mt
Filter Asm-Hyd,High Pressure
Filter Asm-Hyd,3000 Psi
Motor-Hyd,8.6 Cir,1.0 Keyed
Motor Asm-Hyd,Conveyor,Upper
Filter Asm-Oil,Hyd
Filter Asm-Hyd,Low Press
Fitting Asm-Hyd,Boom Seq Blk
Block-Hyd,Boom,Sequence
Valve Asm-Hyd,A M 1000
Valve Block-Hyd,Hyd,Conveyor,Booms
Valve Asm-Hyd,A M 2000
Valve Asm-Check,Fan Motor
Valve- Assy, Press Reducing
