Loral Air Max System 1000 2000 Parts Catalog WR121613
Brand: Loral
Type of Machine: Air Max System
Model:
Loral 1000 Air Max System
Loral 2000 Air Max System
Part Number: WR121613
Number of Pages: 286 Pages
Hood Instl-V,Dual Bin
Gate Instl-Metering
Panel Instl-Flip
Sprocket Instl-Conveyor Drive
Sprocket Instl-Rear Bin,Front
Sprocket Instl-Conveyor,Front
Hood Instl-V,A M 1000
Ladder- Front, Am 1000 2000
Screen Instl-A M 1000
Screen Instl
Screen Instl-Front,W O Tank
Divider Instl-Riser
Divider Instl-9103,Dual Bin
Hardware Grp-Dummy,Lift Hole
Gearbox Instl-Conveyor,Upper
Gearbox Instl-Conveyor,Lower
Belt Instl-Conveyor,Upper
Belt Instl-Conveyor,Lower
Cradle Window Instl-A M 1-2000
Carrier Asm-Boom,A M 1-2000
Mudflap- Instl,'01 Am1000 2000
Plate Instl-Serial,Loral
Floor Instl-False
Sleeper Instl-Bolted, Plastic
Guard Asm-Pto,6300
Holddown Asm-A M 2000,8104
Manifold Funnel Instl
Manifold Asm
Chute Instl-Unloading,Am1 2000
Valve Hose Instl-Air
Box Asm-Air
Valve Asm-Air,Clutch,Conveyor
Valve Instl-Quick Release,Air
Hose Regulator Instl-Air,F M
Tube Instl-Product,Center,70ft
Boom Instl-A M 1 2000,Loral
Boom Asm-Rh,A M 1 2000,Loral
Boom Asm-Lh,A M 1 2000,Loral
Deflector Instl-Product,Boom
Suspension Instl-Boom
Pivot Arm- Instl, '01 Am 1 2
Cable Instl- Power Dist
Box Instl-Electrical
Box Asm-Enclosure,Elec
Relay Instl-Granular
Sensor Instl-Application Rate
Elec Instl-A M 1 2k,Loral
Switch Instl-A M,1 2k
Light Instl-Work,Am12k, Loral
Afwl, A M 1-2000
Roll Tarp, Loral
Sys Instl-Legacy,A M 1k
Tank Instl-Spraymax
Tank Asm-Spraymax
Pump Reload & Valve Instl
Valve Asm-Fill Spray
Plumbing Asm-Flowmeter
Station Asm-Pump & Reload
Valve Instl-Boom
Tee Asm-Boom
Valve Asm-Boom,Lh
Valve Asm-Boom,Rh
Hose Instl-Pump Station
Sight Gauge- Instl, Spraymax
Eductor Instl-Spray Max
Eductor Asm-Frame & Band
Eductor Asm-Chemical
Cover- Install, Front Bulkhead
Plug Instl-Plmb,W O Eductor
Hose Instl-Product,No Inj
Pump Asm-Prod,Fitting,Hyd
Spraybar & Plmb Instl-70ft
Spraybar Asm-Center,Rh,70ft
Spraybar Asm-Center,Lh,70ft
Spraybar & Plmb Instl-Triple
Spraybar Asm-C Sect,Triple
Spraybar Asm-B Sect,Rh,Triple
Spraybar Asm-B Sect,Lh,Triple
Spraybar Asm-A Sect,Rh,Triple
Spraybar Asm-A Sect,Lh,Triple
Spraybar Asm-Center,Rh,Triple
Spraybar Asm-Center,Lh,Triple
Cyl Asm-Hyd,Tip Fold
Heater Instl-Tank,Hyd,120v
Motor Asm-Hyd,Conveyor,Lower
Motor Asm-Hyd,Conveyor,Upper
Blk Instl-Seq,Boom,Hyd
Fitting Asm-Hyd,Boom Seq Blk
Cooler Asm-Oil,Hyd
Valve Asm-Check,Fan Motor
Filter Asm-Hyd,High Pressure
Valve Asm-Ball,Fan Speed
Filter Asm-Oil,Hyd
Tank Asm-Hyd
Cover Asm-Hyd Tank
Cyl Asm-Hyd,Boom Lift
Valve- Assy, Press Reducing
Hose Instl-Hyd
Cyl Asm-Hyd,Boom Fold
Motor Asm-Hyd,Fan,1.83cir
Valve Instl-Hyd,A M 1000
Valve Asm-Hyd,A M 1000
Valve Instl-Hyd,A M 2000
Valve Asm-Hyd,A M 2000
Valve Asm-Hyd,Spraymax
Hyd
Valve Asm-Hyd, Fan Speed,Servo
Hyd,Am12k,Loral
Hose Instl-Hyd,Am12k,6300
Pump Asm-Hyd,A M,12k,6300
Pump Driveline Instl-Hyd,6300
Hyd Instl-Spraymax
Decal Instl-Spraymax,Eng
Decal Instl-System, A M 1-2000
Decal Instl-A M 1000,Loral
Decal Instl-A M 2000, Loral
Tank Asm-Foam Marker,60gl,Ss
F M
Tarp Instl-Roll
Press Wash- Airmax 1000 2000
Valve,Flow Control Assy
Pump- Assy, 98 Press Wash
Valve- On Off, Assy Press Wash
Valve Shuttle Asm
Tank-Instl,Rinse Spraymax
Cap Tube Instl,No Press Wash
Housing Instl-Metering,Gran
Housing Asm-Metering,Gran
Ladder Instl-Rear,W Gran
Gran Bin- Instl, Sng Door
Hsg Asm-Mtr,Gran,Maxirate
Mtr Whl Instl-Maxirate High
Metering Wheel Asm-Maxirate
Mtr Wheel Instl-Standard
Metering Wheel Asm-Standard
Metering Wheel Instl-Low Rate
Metering Wheel Asm-Low Rate
