Loral Air Max System 1000 2000 Parts Catalog L044831
Brand: Loral
Type of Machine: Air Max System
Model:
Loral 1000 Air Max System
Loral 2000 Air Max System
Part Number: L044831
Number of Pages: 2499 Pages
Publication Information
Product Containment
Box-Airmax 1000, Weldment
Box-Airmax 2000, Weldment
Panel-Flip,Install,A M2000
Screen Install-Front,W O Tank
Ladder Install-Rear,W Granular
Divider Install-Riser
Riser Install
Divider Install-9103,Dual Bin
Tarp Package- Electric Roll
Ladder- Front
Spacer Ladder- Install,W O Granular
Cover Install-Bin Full Empty
Granular Bin- Install, Single Door
Cover-Install, Front Bulkhead
Window-Glass, Install
Chute-Unload, Install Am2000
Screen-Install
Vhood-Install, A M 2000
Panel Install- Flip
Airmax 1000- 2001 Basic System
Sprocket-Install, Conveyor Drive
Brace-Clutch,Assembly
Clutch-Superceded By 128593
Sprocket-Install, Conveyor Front
Bearing-Take-Up, Assembly
Rod Assembly-Threaded,Take Up
Belt Install-Conveyor,Lower
Belt Assembly-Conveyor,15.75,Lower
Bumper-Installation
Bumper-Rear
Gearbox- Install,Conveyor Low
Motor-Hydraulic,8.6 Cir,1.0 Keyed
Gearbox-5 1
Sensor-Install,Rate
Sensor-Application Rate,Raven
Manifold Funnel Install
Manifold-Assembly
Fan-Install
Fan-Assembly, 1.83 Cir
Gate Install, Metering, A M 1000
Tank Valve Filter- Install 2001
Filter Assembly-Oil,Hydraulic
Filter Assembly-Hydraulic,Low Pressure
Tank- Hydraulic Assembly, 01
Pivot Arm-Install, R B 123777
Cylinder Assembly-Hydraulic,Boom Fold
Cylinder-Hydraulic,3.50x8.00x1.38
Suspension Install-Boom
Cylinder Assembly-Hydraulic,Boom Lift
Cylinder-Hydraulic,2.00x6.00x1.00
Cradle-Boom, Install
Block Install-Seq,Boom,Hydraulic
Fitting Assembly-Hydraulic,Boom Seq Blk
Block-Hydraulic,Boom,Sequence
Adapter Straight 0.37mo-R X 0.37mjic
Valve- Hydraulic Install, 01 A M 1000
Valve- Hydraulic Assembly, 01
Valve- Install, Pres Reducer
Valve- Assembly, Press Reducing
Hose Install- Hydraulic, 01
Cylinder- Assembly, Brk R B 260802
Cylinder-Hydraulic,2.00x8.00x1.00
Hose Kit- 01 Airmax 1000
Valve- Assembly, Fan Speed 01
Valve Ball
Valve- Hydraulic Assembly, 01 A M 2000
Heater Install-Tank,Hydraulic,120v
Harness Install-Boom,F M(Sys)
Box-Electric,Roll Tarp
Valve Hose- Install, Air
Decal-Install, 01 Airmax 1000
Airmax 2000- 2001 Basic System
Conveyor-Assembly, Front, Rear Bin
Motor Assembly-Hydraulic,Conveyor,Lower
Belt Install-Conveyor,Upper
Belt Assembly-Conveyor,15.75,Upper
Gearbox- Install,Conveyor Up
Motor- Assembly, Hydraulic, Conveyor Up
Gate-Install, Metering 2001 A M 2000
Valve- Hydraulic Install, 01 A M 2000
Valve Install-Quick Release,Air
Decal-Install, 01 Airmax 2000
Airmax 1000- 2002 Basic System
Suspension- Boom, Install, 02 Granular
Cylinder-Hydraulic,3.00x5.00x1.50,Rod
Airmax 2000- 2002 Basic System
Granular Bin
Relay Install Granular
Box Install-Electrical
Cable Install- Power Dist
Cable- Electrical, Ground
Cable- Electrical, Power
Bank-Grease, Install, Fender
Primary Product Distribution
Tube Install-Product
Air Tube-Rear Nozzle, Weld,Rh
Air Tube-Rear Nozzle, Weld,Lh
Pump- Reload And Valve Install
Valve Assembly-Fill Spray
Pump Station- Assembly, Spraymax
Valve- 3 Way, 2.00 Bottom Load
Valve- 3 Way, 1.50 Bottom Load
Pump- Assembly Product, Fitting, Hydraulic
Pump-Centrifugal,2.0x1.5,1.42 Hydraulic Motor
Pump-Chemical Inj,3.00 Gpm
Agitator Chemical Inject
Plumbing Install-Carrier,Inj,Mixer
Nozzle Assembly-Inj,1.50npt
Mixer Assembly-1.50npt,Acid
Flowmeter Assembly-Chemical,High Volume
Flowmeter-2.00,140ppg,12v
Strainer Body Assembly 1.00
Box Assembly-Talon,Single Module
Agitator Rework-Tank,26.00l
Agitator Install-Tank,Talon,Right Hand
Agitator Rework-Tank,23.00l
Secondary Product Distribution
Metering Wheel Install-Standard
Metering Wheel Assembly-Standard
Shaft Assembly-Metering Wheel
Metering Wheel Install-Low Rate
Metering Wheel Assembly-Low Rate
Metering Whl Install-Maxirate High
Metering Wheel Assembly-Maxirate
Mtrg Hsg-Install, Std
Mtrg Hsg- Assembly
Motor-Electric, Twin Output
Hsg Install- Gran Metering,Maxi Rate
Hsg Assembly- Mtr, Gran, Maxirate
Spacer Install- 2.25 Wheel
Talon Inj- Loop 1, Lh 60gal
Module Install- 3 Gpm, Talon, Lh
Module Assembly- Talon, 3.00gpm
Pump Assembly- Talon, 3.00 Gpm
Motor Pump Chemical Inject
Plumbing Assembly- Talon Inject
Box Assembly- Talon, Single Module
Tank Install- Talon,60gl,Lh
Tank- Assembly, 60gl, Talon
Tank Weldment-60gl,304ss
Plumbing Install- Talon, Loop 1, Lh
Relay Install- Talon 1
Flowmeter Install- Gear, Talon
Harness Install-Network,Out
Module Assembly-Talon,3.00gpm
Pump Assembly-Talon,3.00gpm
Plumbing Assembly-Talon Inject
Valve-Ball, 0.50npt Union, Poly
Harness Install-Talon,Loop 1
Harness-Power Network,Inject,Falcon
Calibration Assembly-Talon
Talon Inj- Loop 2, Rh 40gal
Module Install-3.0gpm,Talon,Rh
Tank Install- Talon,40gl,Rh
Tank Assembly- 40gl, Talon
Tank Weldment-40gl,304ss
Plumbing Install- Talon,Loop 2,Rh
Relay Install- Talon 2
Plumbing Install-Inj,Loop2,Talon
Harness Install-Talon,Loop 2
Spraymax- Basic System
Spraybar- Install And Plumbing, 2002
Spraybar Assembly-C Section,70ft
Spraybar Assembly-A Section,Rh,70ft
Spraybar Assembly-A Section,Lh,70ft
Spraybar- B Sect,Assembly,Rh 70 Ft. Ft.
Single Nozzle Holder-.75 Pipe
Spraybar- B Sect,Assembly,Lh 70 Ft. Ft.
Spraybar- Center Sect,Assembly,Rh 70 Ft. Ft.
Spraybar- Center Sect,Assembly,Lh 70 Ft. Ft.
Valve- Install, Boom, Spraymax
Tee Assembly-Boom
Valve- Assembly, Lh Boom, Spraymax
Valve-Electric, 2 Way, 1.00 With Connector
Valve- Rh Assembly, Boom Spraymax
Plug Install-Plumbing,W O Eductor
Tank- Install, Spraymax
Hose Install- Pump Station
Sight Gauge- Install, Spraymax
Hydraulic Install- Spraymax
Valve Assembly- Hydraulic, Spraymax
Decal-Install, Spraymax
Eductor Install- Spraymax
Eductor Assembly-Frame And Band
Eductor Assembly-Chemical
Kit-Eductor,Chemical
Kit-Eductor,Lance And Plunger
Valve-Ball, 0.75 Poly, Ff
Control- A M 1000, Falcon Ii, Spraymax
Switch- Assembly, Spraymax, Am2000
Valve-Hydraulic,Shutoff
Valve-Hydraulic,Conveyor
Sensor Install-Bin Full Empty
Control- Install, Falcon Ii
Valve,Flow Control Assembly
Tank Assembly-Spraymax
Agitator Install-Tank,Talon,Lh
End Row Nozzle Option
Booms
Boom Package- 70 Ft. Ft.
Boom-Install, 70 Ft. Ft.
Boom-Rh Assembly, 70 Ft. Ft.
Boom-Lh Assembly, 70 Ft. Ft.
Deflector-Install, Boom
Boom-70 Ft. Ft. , Package
Boom-Assembly, Rh 70 Ft. Ft.
Boom-Inner,Rh,70ft
Cradle-Boom Tip, Rh
Boom-Assembly, Lh 70 Ft. Ft.
Boom-Inner,Lh,70ft
Cradle-Boom Tip, Lh
Pivot Install
Foam Marker
Foamer Package
Tank Assembly-Foam Marker,60gl,Ss
Solenoid
Valve Solenoid
Valve-Ball, 2.00 Poly
Valve-Stainless Steel, 0.375
Cylinder Asm-Hyd,Tip Fold
Hose Install-Hydraulic
Cylinder Assembly- Boom Suspension
Cylinder Assembly-Hydraulic,Boom Cradle
Cylinder-Hydraulic,1.50x6.00x1.00
Filter Assembly-Hydraulic,High Pressure
Filter Assembly-Hydraulic,3000 Psi
Motor Assembly-Hydraulic,Conveyor,Upper
Valve Assembly-Ball,Fan Speed
Motor Assembly-Hydraulic,Fan,1.83cir
Motor-Hydraulic,1.83 Cir
Tank Assembly-Hydraulic
Cover Assembly-Hydraulic Tank
Valve Assembly-Hydraulic,A M 1000
Valve Block-Hydraulic,Conveyor,Booms
Valve Assembly-Hydraulic,A M 2000
Valve Assembly-Check,Fan Motor
Cooler Assembly-Oil,Hydraulic
Chassis Hydraulic-3000ss
Pump- Assembly, Hydraulic, A M 2000
Pump-Rexroth, 6.1 W A Pad, Rh
Compensator Pressure
Chassis Hydraulic-4000ss
Valve Shuttle Assembly
Guard- Assembly, Pto, 3000ss
Guard- Assembly, Pto, 4000ss
Heater Install-Tank,Talon
Motor Rework
Taillight- Install
Alarm-Backup,Assembly,Take Off Part
Relay Install-Agitate 1
Box Assembly-Enclosure,Electric
Relay Install-Agitate 2
Cable- Power, Ignition
1051 Controller System
Control- A M 1000, Mt6500, Spraymax
Control- A M 1000, Mt W Gran And Wet
Final- A M 1000 W 3000 Midtech
Console- Cover, Mag Ci W Midtec
Decal Package-Chassis Final 3000
Final- A M 1000 W 4000 Midtech
Decal Package-Chassis Final 4000
Final- W 4000 Falcon Ii
Falcon Ii- Install,Control Component
Keyboard Assembly-Falcon Ii
Final- A M 2000 W 3000 Falcon Ii
Control- A M 2000, Falcon Ii, Wetboom
Control- A M 2000, Wet Granular Bin
Control- A M 1000, Falcon Ii,Wet,Granular
Radar Installation
Control- A M 1000, Mt6500 W Granular
Control- A M 1000, Mt6100 Basic
Control- A M 1000, Mt6500 Basic
Control-A M 2000, Falcon Ii, Granular Bin
Control- A M 2000, Falcon Ii, Bsc
Control- Falcon Ii, Common Parts
Harness- Power, Falcon Ii
Control- A M 1000, Falcon Ii, Bsc
Control- A M 1000, Falcon Ii, Granular
Parallel Swathing- Starlink
Kit-Lightbar,Rgl 600
Parallel Swathing- Falcon Trac
Harness- Power Ext, Gps
Gps- Trimble 132 W Falcon
Parallel Swathing- Trimble
Gps- Starlink 1hz W Falcon
Gps- Trimble W Mt
Gps- Starlink 10hz W Mt
Gps- Starlink 10hz W Falcon
1212 Air System
Valve Assembly-Air,Clutch,Conveyor
Valve Rework-Air,2 Section
Valve-Air, 2 Section
Clutch-Conveyor
1223 Pressure Washer And Rinse System
Pressure Washer
Pump Assembly-Water, Pressure Washer
Valve- On Off, Assembly Pressure Washer
Gun-Trigger Assembly W Nozzle
Hose-Assembly W Quick Coupler
Cap Tube Install,No Pressure Washer
Tank-Install,Rinse Spraymax
Valve-Ball, 0.75npt Union, Poly
Rinse- W Pressure Washer
1245 Decals
1251 Attachments
Mudflap-Install
