Loral Air Max System 1000 2000 Parts Catalog WR125487
Brand: Loral
Type of Machine: Air Max System
Model:
Loral 1000 Air Max System
Loral 2000 Air Max System
Part Number: WR125487
Number of Pages: 601 Pages
Publication Information
Box And Conveyor Group
Hardware Grp-Dummy,Lift Hole
Sleeper Install-Bolted, Plastic
Plate Install-Serial,Loral
Hood Install-V,A M 1000
Hood Install-V,Lengthwise
Bracket Install-Gauge
Mudflap Install-A M 1000 2000,Loral
Window Install-A M 1000 2000
Cover Install-Bin F E
Screen Install-Front,W O Tan
Hood Install-V,Dual Bin
Sensor Install-Application Rate
Floor Install-False
Ladder Install-Rear,W Gran
Divider Install-Riser
Riser Install-9103
Spacer Ladder Install-W O Gran
Divider Install-9103,Dual Bin
Valve Asm-Boom,Lh
Rework Transducer 0-100 Psi
Screen Install
Holddown Asm-A M 2000,8104
Belt Install-Conveyor,Lower
Belt Install-Conveyor,Upper
Panel Install-Flip
Sprocket Install-Conveyor,Front
Bumper Install-Rear
Bumper Taillight Asm-Rear
Sprocket Install-Conveyor Drive
Sprocket Install-Rear Bin,Front
Screen Install-A M 1000
Cover- Install, Front Bulkhead
Gran Bin- Install, Sng Door
Ladder- Front, A M 1000 2000
Product Distribution Group
Gate Install-Metering
Manifold Asm
Manifold Funnel Install
Fan Install
Fan Asm-183 Cir
Motor Asm-Hyd,Fan,183cir
Cooler Asm-Oil,Hyd
Chute Install-Unloading,Am1 2000
Sight Gauge- Install, Spraymax
Boom Group
Pivot Install-A M 1 2000
Cylinder Asm-Hyd,Boom Fold
Rack Asm-Boom,A M 1000 2000
Rack Install-Boom,A M 1000 2000,Loral
Tube Install-Product,Center,70ft
Suspension Install-Boom
Cylinder Asm-Hyd,Boom Lift
Boom Install-A M 1 2000,Loral
Boom Asm-Rh,A M 1 2000,Loral
Cylinder Asm-Hyd,Tip Fold
Boom Asm-Lh,A M 1 2000,Loral
Hydraulic Group
Guard Asm-Pto,6300
Hose Install-Hyd,A M 1000 2000,6300
Pump Asm-Hyd,A M 1000 2000,6300
Pump Driveline Install-Hyd,6300
Valve Install-Hyd,A M 1000
Valve Asm-Hyd,A M 1000
Valve Block-Hyd,Conveyor,Booms
Valve Install-Hyd,A M 2000
Valve Asm-Hyd,A M 2000
Hose Install-Hyd
Tank Asm-Hyd
Cover Asm-Hyd Tank
Valve Asm-Hyd,Fan Speed,Servo
Motor Asm-Hyd,Conveyor,Lower
Fitting Asm-Hyd,Boom Seq Blk
Valve Asm-Check,Fan Motor
Filter Asm-Hyd,High Pressure
Filter Asm-Oil,Hyd
Valve- Asm, Pressure Reducing
Motor Asm-Hyd,Conveyor,Upper
Tank Valve Filter Install-Hyd
Hose Install-Hyd,A M 1000 2000,6400
Pump- Asm, Hyd, A M 2000
Pump Driveline Install-Hyd,6400
Gearbox Install-Conveyor,Lower
Gearbox Install-Conveyor,Upper
Heater Install-Tank,Hyd,120v
Block Install-Seq,Boom,Hyd
Valve Install-Boom
Tee Asm-Boom
Valve Asm-Boom,Rh
Hyd Install-Spraymax
Valve Asm-Hyd,Spraymax
Valve Shuttle Asm
Electrical Group
Switch Install-A M 1000 2000
Light Install-Work,A M 1000 2000
Roll Tarp, Loral
Harness Install-Coap Node
Electric Install-System,S M 1 2
Harness Install-A M 1000 2000,Loral
Sensor Install-Bin F E
Box Install-Electrical
Box Asm-Enclosure,Electric
Relay Install-Granular
Harness Install-Node,1 Bin
Harness Install-Node,2 Bin
Harness Install-Node,Granular
Cable Install-Network,Dual Bin
Cable Install-Network,Granular
Controller Group
Node Install-Bin
Node Driver Install-Granular
Cable Install- Power Dist
Air System Group
Valve Install-Quick Release,Air
Tank Install-Foam Marker
Tank Asm-Foam Marker,60gl,Ss
Valve Hose Install-Air
Box Asm-Air
Valve Asm-Air,Clutch,Conveyor
Foam Marker Group
Hose Regulator Install-Air,F M
F M
Decal Group
Decal Install-System, A M 1000 2000
Decal Install-A M 1000,Loral
Decal Install-A M 2000, Loral
Decal Install-Spraymax,Eng
Pressure Washer And Head Rinse Group
Cap Tube Install,No Pressure Washer
Pressure Washer- Airmax 1000 2000
Pump- Asm, 98 Pressure Washer
Valve- On Off, Asm Pressure Washer
Valve,Flow Control Asm
Tank-Install,Rinse Spraymax
Rinse- W Pressure Washer
Granular Application Group
Deflector Install-Sgl,Prod,Boom
Metering Wheel Install-Maxirate High
Metering Wheel Asm-Maxirate
Metering Wheel Install-Standard
Metering Wheel Asm-Standard
Spacer Install 225 Wheel
Metering Wheel Install-Low Rate
Metering Wheel Asm-Low Rate
Housing Install-Metering,Gran
Housing Asm-Metering,Gran
Hsg Install Mtr Gran Max Rate
Hsg Asm-Mtr,Gran,Maxirate
Spraymax Group
Spraybar And Plumbing Install-Triple
Spraybar Asm-C Section,Triple
Spraybar Asm-B Section,Rh,Triple
Spraybar Asm-B Section,Lh,Triple
Spraybar Asm-A Section,Rh,Triple
Spraybar Asm-A Section,Lh,Triple
Spraybar Asm-Center,Rh,Triple
Spraybar Asm-Center,Lh,Triple
Plug Install-Plumbing,W O Eductor
Hose Install-Product,No Inj
Tank Install-Spraymax
Tank Asm-Spraymax
Pump Reload And Valve Install
Valve Asm-Fill Spray
Plumbing Asm-Flowmeter
Station Asm-Pump And Reload
Pump Asm-Prod,Fitting,Hyd
Eductor Install-Spray Max
Eductor Asm-Frame And Band
Eductor Asm-Chemical
Hose Install-Pump Station
Nozzle Instl-Enr Rpr,A M 1000 2000
Spraybar Asm-C Section,70ft
Spraybar And Plumbing Install-70ft
Spraybar Asm-Center,Rh,70ft
Spraybar Asm-Center,Lh,70ft
Spraybar Asm-B Section,70ft,Rh
Spraybar Asm-B Section,70ft,Lh
Spraybar Asm-A Section,Rh,70ft
Spraybar Asm-A Section,Lh,70ft
Option Group
System Install-Legacy,A M 1k
Tarp Install-Roll
