Loral Air Max System 1000 2000 Parts Catalog 507663D1
Brand: Loral
Type of Machine: Air Max System
Model:
Loral 1000 Air Max System
Loral 2000 Air Max System
Part Number: 507663D1
Number of Pages: 1037 Pages
Publication Information
Box And Conveyor Group
Bumper Instl-Rear
Bumper Taillight Asm-Rear
Lamp Cluster Rear Rh
Lamp Cluster Rear Lh
Cover Instl-Bin F E
Sleeper Instl-Bolted, Plastic
Sleeper-Plastic, 3.50x.75x135
Mudflap Instl-Am12k,Loral
Lamp-Warning,Amber
Sensor Instl-Application Rate
Sensor-Application Rate,Rvn
Tarp Instl-Roll
Kit-Tarp,Roll,144x96
Belt Instl-Conveyor,Lower
Belt Asm-Conveyor,15.75,Lower
Belt Instl-Conveyor,Upper
Belt Asm-Conveyor,15.75,Upper
Sprocket Instl-Conveyor,Front
Rod Asm-Threaded,Take Up
Clutch-Conveyor,Air Max
Sprocket Instl-Rear Bin,Front
Hardware Grp-Dummy,Lift Hole
Plate Instl-Serial,Loral
Hood Instl-V,Lengthwise
Bracket Instl-Gauge
Window Instl-A M 1-2000
Hood Instl-V,A M 1000
Screen Instl-Front,W O Tank
Hood Instl-V,Dual Bin
Floor Instl-False
Ladder Instl-Rear,W Gran
Divider Instl-Riser
Riser Instl-9103
Spacer Instl-Fan,Am12k
Divider Instl-9103,Dual Bin
Screen Instl
Holddown Asm-A M 2000,8104
Panel Instl-Flip
Screen Instl-A M 1000
Cover- Install, Front Bulkhead
Ladder- Front, Am 1000 2000
Product Distribution Group
Fan Instl
Fan Asm-1.83 Cir
Motor Asm-Hyd,Fan,1.83cir
Motor-Hyd,1.83 Cir
Cooler Asm-Oil,Hyd
Fan Guard Instl
Precleaner Instl
Precleaner-Rh,Fan,Am12k
Precleaner-Lh,Fan,Am12k
Manifold Funnel Instl
Gate Instl-Metering
Manifold Asm
Chute Instl-Unloading,Am1 2000
Outlet Deflector Instl-Am12k
Sight Gauge- Instl, Spraymax
Product Pump And Pressure Plumbing Group
Flowmeter-2.00,140ppg,12v
Boom Group
Rack Instl-Boom,Am12k,Loral
Rack Asm-Boom,Am12k,Loral
Cylinder Asm-Rack,Am12k
Boom Instl-70ft,Am12k,Loral
Boom Asm-70ft,Am12k,Lh
Boom Wldmt-Inner,Lh,70ft
Boom Wldmt-Tip,Lh,70ft
Cyl Asm-Hyd,Tip Fold
Cyl-Hyd,2.00x8.00x1.00
Boom Asm-70ft,Am12k,Rh
Boom Wldmt-Inner,Rh,70ft
Boom Wldmt-Tip,Rh,70ft
Pivot Instl-Airmax 1 2000
Cyl Asm-Hyd,Boom Fold
Cyl-Hyd,3.50x8.00x1.38
Suspension Instl-Bm,A M,Loral
Cylinder Asm-Suspension,Boom
Adap Str 0.37mo-R X 0.37mjic
Cyl-Hyd,3.50x15.65x1.50,Lift
Tube Instl-Product,Center,70ft
Boom Plumbing Group
Triple Nozzle Holder .75 Pipe
Single Nozzle Holder-.75 Pipe
Valve 144a
Hydraulic Group
Valve Asm-Hyd,Spraymax
Valve-Hyd,Shutoff
Valve Instl-Hyd,A M 1000
Valve Asm-Hyd,A M 1000
Valve Block-Hyd,Hyd,Conveyor,Booms
Valve Instl-Hyd,A M 2000
Valve Asm-Hyd,A M 2000
Hose Instl-Hyd
Tank Asm-Hyd
Cover Asm-Hyd Tank
Valve Asm-Hyd,Fan Speed,Servo
Valve-Hyd,50gpm,Servo,Mt
Filter Asm-Hyd,High Pressure
Filter Asm-Hyd,3000 Psi
Motor-Hyd,8.6 Cir,1.0 Keyed
Motor Asm-Hyd,Conveyor,Upper
Filter Asm-Oil,Hyd
Filter Asm-Hyd,Low Press
Fitting Asm-Hyd,Boom Seq Blk
Block-Hyd,Boom,Sequence
Cyl Asm-Hyd,Boom Lift
Cyl-Hyd,3.00x5.00x1.50,Rod
Valve- Assy, Press Reducing
Valve Asm-Check,Fan Motor
Cylinder,Hyd,1.0x3.00x.50
Motor Asm-Hyd,Conveyor,Lower
Tank Valve Filter Instl-Hyd
Gearbox Instl-Conveyor,Lower
Gearbox-5 1 (Rtg)
Gearbox Instl-Conveyor,Upper
Blk Instl-Seq,Boom,Hyd
Hyd Instl-Spraymax
Guard Asm-Pto,6300
Hose Instl-Hyd,Am12k,6300
Pump Asm-Hyd,A M,12k,6300
Pump Driveline Instl-Hyd,6300
Driveline Asm-Pto,6300
Hose Instl-Hyd,Am12k,6400
Pump- Assy, Hyd, Am2000
Pump Driveline Instl-Hyd,6400
Valve-Hyd,Conveyor
Heater Instl-Tank,Hyd,120v
Electrical Group
Solenoid
Valve Solenoid
Elec Instl-Sys,S M 1 2k
Valve-Solenoid,25npt,12v
Switch Instl-A M,1 2k
Decal Group-Rh Control Panel
Roll Tarp, Loral
Box-Elec,Roll Tarp
Harness Instl-Coap Node
Rework Transducer 0-100 Psi
Harness Instl-Ext,Er,Coap
Sensor Instl-Bin F E
Box Instl-Electrical
Box Asm-Enclosure,Elec
Relay Instl-Granular
Harn Instl-Node,1 Bin
Harn Instl-Node,2 Bin
Harn Instl-Node,Granular
Light Instl-Work,Am12k, Loral
Switch Instl-End Row, Loral
Elec Instl-S M,Loral (Cab)
Harness Instl-Am12k,Loral
Cable Instl-Network,Dual Bin
Cable Instl-Network,Granular
Controller Group
Sys Instl-Rvn 4000,A M 1k
Sys Instl-Rvn 4000,S M
Cable Instl- Power Dist
Cable- Electrical, Ground
Cable- Electrical, Power
Node Instl-Bin 1
Harness Instl-Node,Radar,Loral
Harness Cap Instl-No Raven Ctl
Node Instl-Bin 2
Node Driver Instl-Granular
Air System Group
Valve Hose Instl-Air
Box Asm-Air
Valve Asm-Air,Clutch,Conveyor
Valve Rwk-Air,2 Section
Valve Instl-Quick Release,Air
Foam Marker Group
Tank Instl-Foam Marker,Am12k
Tank Asm-Foam Marker,60gl,Ss
Vlv Ball 2.00 Poly
Regulator Asm-Foam Marker
Coupler Instl-Hose,Air
Decal Group
Decal Instl-System, A M 1-2000
Decal Instl-A M 1000,Loral
Decal Instl-A M 2000, Loral
Decal Instl-Spraymax,Eng
Pressure Washer And Head Rinse Group
Tank-Instl,Rinse Spraymax
Valve 0.75 Npt Ball Union Poly
Cap Tube Instl,No Press Wash
Granular Application Group
Metering Wheel Asm-Standard
Shaft Asm-Metering Wheel
Housing Instl-Metering,Gran
Housing Asm-Metering,Gran
Hsg Instl-Mtr,Gran,Max Rate
Hsg Asm-Mtr,Gran,Maxirate
Kit-Precleaner,Air Max 1-2000
Mtr Whl Instl-Maxirate High
Metering Wheel Asm-Maxirate
Metering Wheel Asm-Low Rate
Bin Instl-Granular,Am 1 2k
Plate Instl-Product Deflector
Spacer Instl-2.25 Wheel
Spraymax Group
Pump Reload And Valve Instl
Pump Asm-Prod,Fitting,Hyd
Pump-Cntfgl,2.0x1.5,1.42hydmtr
Plumbing Asm-Flowmeter
Valve Asm-Fill Spray
Station Asm-Pump And Reload
Eductor Asm-Frame And Band
Eductor Asm-Chemical
Kit-Eductor,Chemical
Kit-Eductor,Lance And Plunger
Hose Instl-Pump Station
Tank Asm-Spraymax
Spraybar And Plmb Instl-Triple
Spraybar Asm-C Sect,Triple
Spraybar Asm-B Sect,Rh,Triple
Spraybar Asm-B Sect,Lh,Triple
Spraybar Asm-A Sect,Rh,Triple
Spraybar Asm-A Sect,Lh,Triple
Spraybar Asm-Center,Rh,Triple
Spraybar Asm-Center,Lh,Triple
Nozzle Instl-Er,S M,A M 1 2000
Spraybar Asm-C Section,70ft
Spraybar And Plmb Instl-70ft
Spraybar Asm-Center,Rh,70ft
Spraybar Asm-Center,Lh,70ft
Spraybar Asm-B Section,70ft,Rh
Spraybar Asm-B Section,70ft,Lh
Spraybar Asm-A Section,Rh,70ft
Spraybar Asm-A Section,Lh,70ft
Valve Instl-Boom,Sections
Valve Asm-Boom,Lh
Tee Asm-Boom
Valve Asm-Boom,Rh
Tank Instl-Spraymax
Hose Instl-Product,No Inj
Option Group
Sys Instl-Legacy,A M 1k
Funnel Wldmt-Lower
Guard Instl-Pto,6400
Recommended Dealer Stock
Brand: Loral
Model:
Bumper Instl-Rear
Cover Instl-Bin F E
Lamp-Warning,Amber
Tarp Instl-Roll
Bracket Instl-Gauge
Floor Instl-False
Divider Instl-Riser
Riser Instl-9103
Screen Instl
Panel Instl-Flip
Fan Instl
Fan Asm-1.83 Cir
Motor-Hyd,1.83 Cir
Cooler Asm-Oil,Hyd
Fan Guard Instl
Precleaner Instl
Gate Instl-Metering
Manifold Asm
Boom Group
Boom Plumbing Group
Valve 144a
Hydraulic Group
Valve-Hyd,Shutoff
Hose Instl-Hyd
Tank Asm-Hyd
Cover Asm-Hyd Tank
Filter Asm-Oil,Hyd
Gearbox-5 1 (Rtg)
Hyd Instl-Spraymax
Guard Asm-Pto,6300
Valve-Hyd,Conveyor
Electrical Group
Solenoid
Valve Solenoid
Roll Tarp, Loral
Box-Elec,Roll Tarp
Controller Group
Node Instl-Bin 1
Node Instl-Bin 2
Air System Group
Box Asm-Air
Foam Marker Group
Vlv Ball 2.00 Poly
Decal Group
Spraymax Group
Tank Asm-Spraymax
Valve Asm-Boom,Lh
Tee Asm-Boom
Valve Asm-Boom,Rh
Tank Instl-Spraymax
Option Group
Funnel Wldmt-Lower
- Loral Air Max 1998 Parts Catalog L043921
- Loral Air Max System 1000 2000 Parts Catalog 503598D1
- Loral Air Max System 1000 2000 Parts Catalog L044831
- Loral Air Max System 1000 2000 Parts Catalog WR121613
- Loral Air Max System 1000 2000 Parts Catalog WR125487
- Loral Air Max System 1000 2000 Parts Catalog WR128708
- Loral Air Max V System 1997 Parts Catalog L043449
- Loral Air Max V System 2000 Parts Catalog L044714
- Loral Air Spreader System 1998 Parts Catalog L043331
- Loral Applicators 1999-2006 Parts Documents AG333084
- Loral Big Wheels Pressure Vacuum System 2000 Parts Catalog L044985
- Loral Chassis 6300 Parts Manual WR124922
- Loral Chassis 6300 Parts Manual WR128394
- Loral Chassis 6400 Parts Manual WR125446
- Loral Chassis 6400 Parts Manual WR128395
