Loral Air Max System 1000 2000 Parts Catalog WR128708
Brand: Loral
Type of Machine: Air Max System
Model:
Loral 1000 Air Max System
Loral 2000 Air Max System
Part Number: WR128708
Number of Pages: 639 Pages
Publication Information
Box And Conveyor Group
Screen Install-A M 1000
Cover Install-Bin F E
Hardware Group-Dummy,Lift Hole
Sleeper Install-Bolted, Plastic
Sleeper-Plastic, 350 X 75 X 135
Plate Install-Serial,Loral
Holddown Assembly-A M 2000,8104
Screen Install
Belt Install-Conveyor,Lower
Belt Install-Conveyor,Upper
Sprocket Install-Conveyor,Front
Sprocket Install-Rear Bin,Front
Sprocket Install-Conveyor Drive
Clutch-Conveyor,Air Max
Sensor Install-Application Rate
Bracket Install-Gauge
Cover- Install, Front Bulkhead
Hood Install-V,Dual Bin
Hood Install-V,A M 1000
Hood Install-V,Lengthwise
Screen Install-Front,W O Tank
Bumper Install-Rear
Bumper Taillight Assembly-Rear
Ladder- Front, A M 1000 2000
Ladder Install-Rear,W Gran
Spacer Ladder Install-W O Gran
Panel Install-Flip
Mudflap Install-A M 1 2k,Loral
Window Install-A M 1-2000
Floor Install-False
Riser Install-9103
Divider Install-9103,Dual Bin
Divider Install-Riser
Product Distribution Group
Gate Install-Metering
Manifold Funnel Install
Manifold Assembly
Chute Install-Unloading,A M 1000 2000
Sight Gauge- Install, Spraymax
Fan Install
Fan Assembly-183 Cir
Motor Assembly-Hydraulic,Fan,183cir
Motor-Hydraulic,183 Cir
Cooler Assembly-Oil,Hydraulic
Fan Guard Install
Precleaner Install
Granular Application Group
Housing Assembly-Metering,Granular
Housing Install-Metering,Granular
Metering Wheel Install-Maxirate High
Metering Wheel Assembly-Maxirate
Metering Wheel Install-Standard
Metering Wheel Assembly-Standard
Metering Wheel Install-Low Rate
Metering Wheel Assembly-Low Rate
Bin Install-Granular,A M 1000 2000
Spacer Install-225 Wheel
Housing Install-Mtr,Granular,Max Rate
Housing Assembly-Mtr,Granular,Maxirate
Boom Group
Pivot Install-Airmax 1 2000
Cylinder Assembly-Hydraulic,Boom Fold
Boom Install-A M 1000 2000,Loral
Boom Assembly-Lh,A M 1000 2000,Loral
Cylinder Assembly-Hydraulic,Tip Fold
Boom Assembly-Rh,A M 1000 2000,Loral
Rack Install-Boom,A M 1000 2000,Loral
Rack Assembly-Boom,A M 1000 2000
Suspension Install-Boom
Cylinder Assembly-Hydraulic,Boom Lift
Deflector Install-Sgl,Prod,Boom
Tube Install-Product,Center,70ft
Spray Max Group
Tank Install-Spraymax
Tank Assembly-Spraymax
Tank-Install,Rinse Spraymax
Eductor Assembly-Chemical
Eductor Assembly-Frame And Band
Eductor Install-Spray Max
Valve Install-Boom,Sections
Valve Assembly-Boom,Lh
Valve Assembly-Boom,Rh
Tee Assembly-Boom
Valve Assembly-Fill Spray
Pump Reload And Valve Install
Station Assembly-Pump And Reload
Pump Assembly-Prod,Fitting,Hydraulic
Plumbing Assembly-Flowmeter
Hose Install-Pump Station
Hose Install-Product,No Inj
Plug Install-Plumbing,W O Eductor
Spraybar And Plumbing Install-Triple
Spraybar Assembly-C Section,Triple
Spraybar Assembly-B Section,Rh,Triple
Spraybar Assembly-B Section,Lh,Triple
Spraybar Assembly-A Section,Rh,Triple
Spraybar Assembly-A Section,Lh,Triple
Spraybar Assembly-Center,Rh,Triple
Spraybar Assembly-Center,Lh,Triple
Spraybar And Plumbing Install-70 Ft
Spraybar Assembly-C Section,70 Ft
Spraybar Assembly-Center,Rh,70 Ft
Spraybar Assembly-Center,Lh,70 Ft
Spraybar Assembly-B Section,70 Ft,Rh
Spraybar Assembly-B Section,70 Ft,Lh
Spraybar Assembly-A Section,Rh,70 Ft
Spraybar Assembly-A Section,Lh,70 Ft
System Install-Legacy,A M 1000
Kit-Precleaner,Air Max 1-2000
Nozzle Install-Er,S M,A M 1 2000
Hydraulic Group
Pump Assembly-Hydraulic,A M 1000 2000,6300
Pump- Assembly, Hydraulic, A M 2000
Valve Assembly-Hydraulic,Spraymax
Valve Install-Hydraulic,A M 1000
Valve Assembly-Hydraulic,A M 1000
Valve Install-Hydraulic,A M 2000
Valve Assembly-Hydraulic,A M 2000
Motor Assembly-Hydraulic,Conveyor,Lower
Motor Assembly-Hydraulic,Conveyor,Upper
Block Install-Seq,Boom,Hydraulic
Fitting Assembly-Hydraulic,Boom Sequence Block
Hose Install-Hydraulic
Valve Assembly-Hydraulic,Fan Speed,Servo
Valve Assembly-Check,Fan Motor
Tank Assembly-Hydraulic
Cover Assembly-Hydraulic Tank
Filter Assembly-Hydraulic,High Pressure
Filter Assembly-Oil,Hydraulic
Valve- Assembly, Pressure Reducing
Hose Install-Hydraulic,A M 1000 2000,6400
Hose Install-Hydraulic,A M 1000 2000,6300
Heater Install-Tank,Hydraulic,120v
Tank Valve Filter Install-Hydraulic
Gearbox Install-Conveyor,Lower
Gearbox Install-Conveyor,Upper
Pump Driveline Install-Hydraulic,6300
Guard Assembly-Pto,6300
Pump Driveline Install-Hydraulic,6400
Hydraulic Install-Spraymax
Electrical Group
Harness Install-Coap Node
Harness Install-A M 1000 2000,Loral
Electric Install Roll Tarp, Loral
Electric Install-System,A M 1000 2000
Sensor Install-Bin F E
Harness Install-Node,1 Bin
Harness Install-Extension,Er,Coap
Switch Install-End Row, Loral
Electric Install-S M,Loral (Cab)
Switch Install-A M 1000 2000
Light Install-Work,A M 1000 2000, Loral
Controller Group
System Install-Raven 4000,A M 1000
System Install-Raven 4000,S M
Harness Cap Install-No Raven Ctl
Cable Install-Network,Dual Bin
Cable Install- Power Dist
Cable- Electrical, Ground
Cable- Electrical, Power
Box Install-Electrical
Box Assembly-Enclosure,Electric
Harness Install-Node,Radar,Loral
Node Driver Install-Granular
Harness Install-Node,2 Bin
Node Install-Bin 1
Node Install-Bin 2
Harness Install-Node,Granular
Cable Install-Network,Granular
Relay Install-Granular
Air System Group
Box Assembly-Air
Valve Assembly-Air,Clutch,Conveyor
Valve Hose Install-Air
Valve Install-Quick Release,Air
Foam Marker Group
Carrier Install
Tank Install-Foam Marker,A M 1000 2000
Tank Assembly-Foam Marker,60 Gl,Ss
Regulator Assembly-Foam Marker
Hose Regulator Install-Air,F M
Coupler Install-Hose,Air
Decal Group
Decal Install-A M 1000,Loral
Decal Install-A M 2000, Loral
Decal Install-Spraymax,Eng
Decal Install-System, A M 1000 2000
Pressure Washer And Head Rinse Group
Cap Tube Install,No Pressure Washer
Option Group
Tarp Install-Roll
