Loral Air Max 1998 Parts Catalog L043921
Brand: Loral
Type of Machine: Air Max
Model: Loral 1998 Air Max
Part Number: L043921
Number of Pages: 337 Pages
System Mounts
Box, Front Assembly
Conveyor, Front Assembly
Take-Up, Outer Assembly (Serial No. Thru H1087)
Take-Up, Assembly
Conveyor, Rear Assembly
Rear Drive Roller Assembly
Sensor Drive Roller Assembly
Sensor Drive Roller Assembly Conveyor Belt
Tailhousing Assembly
Product Deflector Shield
Unloading Chute
Ladder Assembly
Servo Valve Installation
Air Ducting Assembly
Screen & Upper V-Hood Assembly
Lower V-Hood Installation
Box Windows
Lh & Rh Catwalk Cover
Mudflap Assembly
Taillight Assembly
Rh Taillight & Back-Up Alarm Assembly, Ih
Bumper Installation
Product Distribution Assembly
Manifold Assembly
Fan Assembly W Bondioli Fan Motor (Serial No H930-H937, H944-H951, H976-H987, And H105
Fan Assembly W Volvo Fan Motor (Serial No. H1072 & Up)
Swaybar Assembly
Boom Pivot Assembly
Boom Leveler Assembly
Boom Cradle Assembly
Lh Cradle Mount Latch Assembly
Rh Cradle Mount Latch Assembly
H1103)
Lh Boom Sub-Assembly (Serial No H1104 & Up)
Rh Boom Sub-Assembly (Serial No H1104 & Up)
Boom Breakaway Latch Assembly
Center Nozzles Assembly
Lh Nozzle Kit-Replacement Nozzles
Rh Nozzle Kit-Replacement Nozzles
Controls- Dickey John, Basic Air-Max W 2710 Cf, 3000, Or Mag Ci Chassis
Controls- Dickey John, Basic Air-Max W 3010 Or 3310 Chassis
Controls- Mid-Tech Arc-6000, Basic Air-Max
Controls- Mid-Tech 6500, Basic Air-Max
Controls- Mid-Tech 6500, Basic Air-Max 1 Granular Bin
Control- Mid-Tech 6500, Basic Air-Max 2 Granular Bin
Controls- Mid-Tech 6200, Basic Air-Max Spray-Max
Controls- Mid-Tech 6500, Basic Air-Max Spray-Max
Controls- Mid-Tech 6500, Basic Air-Max Spray-Max Spray-N-Ject
Controls- Mid-Tech 6500, Basic Air-Max Spray-Max Spray-N-Ject (Raven)
Controls- Mid-Tech 6500, Basic Air-Max Spray-Max 2 Spray-N-Ject
Controls- Mid-Tech 6500, Basic Air-Max Spray-Max 2 Spray-N-Ject (1 Raven)
Controls- Mid-Tech 6500, Basic Air-Max Spray-Max 2 Spray-N-Ject (2 Raven)
Controls- Mid-Tech 6500, Basic Air-Max Spray-Max 1 Granular Bin
Controls- Mid-Tech 6500, Basic Air-Max Spray-Max 2 Granular Bins
Controls- Mid-Tech 6500, Basic Air-Max Spray-Max Spray-N-Ject 1 Granular Bin
Controls- Mid-Tech 6500, Basic Air-Max Spray-Max Spray-N-Ject 2 Granular Bins
Controls- Mid-Tech 6500, Basic Air-Max Spray-Max 2 Spray-N-Ject 1 Granular Bin
Controls- Falcon Md, Basic Air-Max (Non-Vrt Vrt)
Controls- Falcon Md, Basic Air-Max 1 Granular Bin (Non-Vrt Vrt)
Controls- Falcon Md, Basic Air-Max 2 Granular Bins (Non-Vrt Vrt)
Controls- Falcon Md, Basic Air-Max Spray-Max (Non-Vrt Vrt)
Controls- Falcon Cd, Basic Air-Max Spray-Max Non-Vrt
Controls- Falcon Cd, Basic Air-Max Spray-Max 1 Granular Bin Vrt
Radar Installation
Valve Block Wiring Diagram
Hydraulic Plumbing- Chassis
Hydraulic Pump Sub-Assembly
Hydraulic Pump & Driveline Assembly
Hydraulic Pump Support Assembly
Basic System Hydraulics W Bondioli Fan Motor (Serial No H930-H937, H944-H951, H976-H987, And H105
Basic System Hydraulics W Volvo Fan Motor (Serial No H1072 And Up)
Hydraulic Tank Assembly
Fan Control Assembly
Anti-Cavitational Check Valve Assembly
Pump Motor Assembly
Fan Motor & Cover Sub-Assembly W Bondioli Fan Motor (Serial No H930-H937, H944-H951, H976-H987, A
Fan Motor & Cover Sub-Assembly W Volvo Fan Motor (Serial No H1072 And Up)
Single Filter Assembly
Dual Filter Assembly
Hydraulic Valve Block Assembly
Hydraulic Manifold Assembly
Thermal Valve Assembly
Servo Valve Assembly
Oil Cooler Assembly
Hydraulic Cylinder Assembly-Boom In Out
Hydraulic Cylinder Assembly-Boom Leveler
Hydraulic Motor Assembly, Lh
Hydraulic Motor Assembly, Rh
Vrt Hydraulic Plumbing (W Falcon Controls 1.7 & Earlier Versions)
Dump Valve Assembly
Decal Locations
Foam Marker Installation
Foam Marker Tank Assembly
Solenoid Valve Assembly
Bin Extension
Tank Installation
Tank Assembly
Tank Assembly Manifold Pump Assembly
Product Pump Assembly
Distribution Manifold Assembly
Flowmeter Installation (Optional)
Eductor Strainer Assembly
Suction Tee Assembly
Strainer Assembly
Front Assembly
Riser Divider Assembly
Hopper Level Sensor Relocation
Spraybar Plumbing
Lh Ball Valve Assembly
Rh Ball Valve Assembly
Lh Spraybar Center Asm. Rh Spraybar Center Asm. (Not Shown)
Lh Spraybar A Section Asm. Rh Spraybar A Section Asm. (Not Shown)
Lh Spraybar B Section Asm. Rh Spraybar B Section Asm. (Not Shown)
Lh Spraybar C Section Asm. Rh Spraybar C Section Asm. (Not Shown)
Lh Spraybar Mount Locations Rh Spraybar Mount Locations (Not Shown)
Skid Plate Installation
Hydraulic Plumbing (W Mid-Tech Controls)
Hydraulic Plumbing (W Falcon Controls 1.8 & Later Versions)
Solenoid Relief Valve Assembly
Spray-N-Ject, Single Mid-Tech Pump Pump Plumbing
Spray-N-Ject, Single Mid-Tech Pump Ball Valve Mount Assembly
Spray-N-Ject, Single Mid-Tech Pump Injection Point And Check Valve Assembly
Spray-N-Ject, Single Mid-Tech Pump Pump Installation
Spray-N-Ject, Double Mid-Tech Pump Pump Plumbing
Spray-N-Ject, Double Mid-Tech Pump Ball Valve Mount Assembly
Spray-N-Ject, Double Mid-Tech Pump Injection Point And Check Valve Assembly
Spray-N-Ject, Double Mid-Tech Pump Pump Installation
Spray-N-Ject, Single Raven Pump
Spray-N-Ject, Double Raven Pump
Agitation Kit (Optional)
Granular Bin Assembly (W O Metering Housing)
Single Metering Housing Installation (For Dickey-John Or Mid-Tech Controls)
Single Metering Housing Installation (For Falcon Controls)
Single Metering Housing Assembly (W O Metering Wheels)
Double Metering Housing Installation (For Dickey-John Or Mid-Tech Controls)
Double Metering Housing Installation (For Falcon Controls)
Double Metering Housing Assembly (W O Metering Wheels)
Low Rate Metering Wheel Assy. (One Wheel Two Wheels)
High Rate Metering Wheel Assy. (One Wheel Two Wheels)
Tarp Package W O Bin Extensions
Tarp Package W Bin Extensions
Pressure Washer Assembly
Pump Assembly
Pump Assembly Pump Sub-Assembly
Trigger Gun Assembly
Hose Assembly W Quick Coupler
Flow Control Valve
Shuttle Valve
Ball Valve Assembly
Wedge Tank Assembly
Wedge Tank Sub-Assembly
Wedge Tank Vent Assembly
Front Wedge Tank Mounting
Rear Wedge Tank Mounting
Dual Boom Shut-Off Installation
Roller- Rate Sensor, Assembly
Roller- Rear Drive, Assembly W Dual Clutch
Controls- Mid-Tech 6500, Basic Air-Max, Dual Boom Shut-Off
Dual Clutch Solenoid Assembly
Brand: Loral
System Mounts
Box, Front Assembly
Take-Up, Assembly
Unloading Chute
Ladder Assembly
Box Windows
Mudflap Assembly
Taillight Assembly
Bumper Installation
Manifold Assembly
Swaybar Assembly
Boom Pivot Assembly
H1103)
Radar Installation
Pump Motor Assembly
Oil Cooler Assembly
Dump Valve Assembly
Decal Locations
Bin Extension
Tank Installation
Tank Assembly
Strainer Assembly
Front Assembly
Spraybar Plumbing
Pump Assembly
Flow Control Valve
Shuttle Valve
Ball Valve Assembly
Wedge Tank Assembly
- Loral Air Max System 1000 2000 Parts Catalog 503598D1
- Loral Air Max System 1000 2000 Parts Catalog 507663D1
- Loral Air Max System 1000 2000 Parts Catalog L044831
- Loral Air Max System 1000 2000 Parts Catalog WR121613
- Loral Air Max System 1000 2000 Parts Catalog WR125487
- Loral Air Max System 1000 2000 Parts Catalog WR128708
- Loral Air Max V System 1997 Parts Catalog L043449
- Loral Air Max V System 2000 Parts Catalog L044714
- Loral Air Spreader System 1998 Parts Catalog L043331
- Loral Applicators 1999-2006 Parts Documents AG333084
- Loral Big Wheels Pressure Vacuum System 2000 Parts Catalog L044985
- Loral Chassis 6300 Parts Manual WR124922
- Loral Chassis 6300 Parts Manual WR128394
- Loral Chassis 6400 Parts Manual WR125446
- Loral Chassis 6400 Parts Manual WR128395
