Loral Dry Spreader System NLL2020G4 Parts Catalog 507645D1
Brand: Loral
Type of Machine: Dry Spreader System
Model: Loral NLL2020G4 Dry Spreader System
Part Number: 507645D1
Number of Pages: 254 Pages
Publication Information
Box And Conveyor Group
Sleeper Instl-Bolted, Plastic
Sleeper-Plastic, 3.50x.75x135
Inverted Vee-L
Conveyor Bottom # 5 L2020g4
Mudflap Instl-Nl,Loral
Conveyor Idler
Conveyor Chain Oiler
Oiler Conveyor Chain
Conveyor Drive
Gearcase-Single Pinion 1.5 In
Front Wiper
Conveyor Chain
Chain-#4 Boc 13 In Asm
Fenders-Super Float Tires
Roll Trpr 12 Ft Ft Nl Asm 92-
Holddown Asm-A M 2000,8104
Window- Glass, Install
Drive-Asm 24 In Conv Lh Spgc
Idler-24 In 6-Bolt Frm
Shield-Chain Grp 13 Ft Ft #4
Feedgate-Jack Asm
Spinner-Twin G4 Asm 24 In
Drive-Asm 24 In Conv Lh Spgc 409
Idler-24 In 6-Bolt Frm Ss
Shield-Chain Grp 13 Ft Ft #4 409
Feedgate-Jack Asm 409
Spinner-Twin G4 Asm 24 In Ss
Shield-Chain Grp 13 Ft Ft #4 304
Feedgate-Jack Asm 304
Product Distribution Group
Material Divider,L2020g4
Hillside Flow Divider,L2020g4
Spinner Guard And Shield L2020g4
Kit-Guards Shields And Divider 304 304
Feedgate And Jack
Hydraulic Group
Guard Asm-Pto,6300
Pump Instl-Hyd,L2020g4,6300
Pump Asm-Hyd,L2020g4,Loral
Driveline Asm-Pto,6300
Pump Instl-L2020g4,6400
Hydraulic Fans,24 In L2020g4
Reservoir,23 Gallon-L2020g4
Gauge Instl-Hyd,Nl
Hose Instl-Hyd,L3020g4,6300
Hose Instl-Hyd,Nl,6400
Reservoir
Twin Spinner Hydraulics
Super Valve Hydraulics
Valve-Hydr,40gpm,Integrated
Gear Case
Rework Kit-Relief Valve
Motor Hyd Spinner Nl
Valve Flow Control O-Ring Thds
Motor 1.50
Valve Control Servo
Tank And Filter-Hyd 23 Gal
Tubes-Hyd 13 Ft Ft 24 In Btm
Hydraulics-Controls
Valve-Relief Unloader 3100psi
Electrical Group
Solenoid
Valve Solenoid
Valve-Solenoid,25npt,12v
Afwl, A M 1-2000
Lamp-Warning,Amber,Dual Lens
Light Instl-Work,Nl,Loral
Lamp-Work,Oval,Trap Lens
Switch Instl-Nl
Decal Group-Rh Control Panel
Taillight Instl-Nl
Lamp Cluster Rear Rh
Lamp Cluster Rear Lh
Harness Instl-Nl,Loral
Elec Instl-Sys,Nl,Loral
Sensor Instl-Spinner,Nl
Controller Group
Sensor Instl-Rate,Rear,Nl
Sensor-Application Rate,Rvn
Sys Instl-Flcn Ii,Nl,Loral
Software Instl-Ini,Pwm Spinner
Sys Instl-Rvn 4000,Nl
Foam Marker Group
Foam Marker Instl-Nl
Tank Asm-Foam Marker,60gl,Nl
Hose Regulator Instl-Air,F M
Carrier Instl-F M,Loral
Step Asm 60 Gal F M
Decal Group
Decal Instl-L2020 L3020,Loral
Decals-L2020g4
Option Group
Guard Instl-Pto,6400
Tarp Instl-13ft,Nl,2020
Kit-Guards Shields And Dividers
Kit-Divider Hillside
Kit-Inverted V 13 Ft Ft -14 Ft Ft
Kit-Fenders 13 Ft Ft 132 In (96+6)
Kit-Inverted V 13 Ft Ft -14 Ft Ft 409
Kit-Fenders 13 Ft Ft 132 In 409(96+6)
Kit-Inverted V 13 Ft Ft -14 Ft Ft 304
Kit-Fenders 13 Ft Ft 132 In 304(96+6)
Recommended Dealer Stock
Brand: Loral
Inverted Vee-L
Conveyor Idler
Conveyor Drive
Front Wiper
Conveyor Chain
Feedgate-Jack Asm
Feedgate And Jack
Hydraulic Group
Guard Asm-Pto,6300
Gauge Instl-Hyd,Nl
Reservoir
Gear Case
Motor 1.50
Valve Control Servo
Hydraulics-Controls
Electrical Group
Solenoid
Valve Solenoid
Afwl, A M 1-2000
Switch Instl-Nl
Taillight Instl-Nl
Controller Group
Foam Marker Group
Step Asm 60 Gal F M
Decal Group
Decals-L2020g4
Option Group
- Loral Air Max 1998 Parts Catalog L043921
- Loral Air Max System 1000 2000 Parts Catalog 503598D1
- Loral Air Max System 1000 2000 Parts Catalog 507663D1
- Loral Air Max System 1000 2000 Parts Catalog L044831
- Loral Air Max System 1000 2000 Parts Catalog WR121613
- Loral Air Max System 1000 2000 Parts Catalog WR125487
- Loral Air Max System 1000 2000 Parts Catalog WR128708
- Loral Air Max V System 1997 Parts Catalog L043449
- Loral Air Max V System 2000 Parts Catalog L044714
- Loral Air Spreader System 1998 Parts Catalog L043331
- Loral Applicators 1999-2006 Parts Documents AG333084
- Loral Big Wheels Pressure Vacuum System 2000 Parts Catalog L044985
- Loral Chassis 6300 Parts Manual WR124922
- Loral Chassis 6300 Parts Manual WR128394
- Loral Chassis 6400 Parts Manual WR125446
