Loral Dry Spreader System L2020G4 L3020G4 Parts Catalog WR123020
Brand: Loral
Type of Machine: Dry Spreader System
Model:
Loral L2020G4 Dry Spreader System
Loral L3020G4 Dry Spreader System
Part Number: WR123020
Number of Pages: 196 Pages
Chassis Hyd- New Ldr, 3000ss
Block- Hyd, Instl,Pump Shutoff
Block- Hyd Assy,Nl,Pumpshutoff
Pump- Assy, 4.7 Cir, Nl G4
Chassis Hyd- New Ldr, 4000ss
Guard- Assy, Pto, 4000ss
Hyd Pkg- New Leader G4, '01
Guard- Assy, Pto, 3000ss
Guard- Assy, Pto, 2700 '00
Cntrl- Flcn Ii, Common Parts
Falcon Ii- Install,Cntrl Cmpnt
Cntrl- Nl, Falc Ii, Dj Servo
Cntrl- Nl, Mt 6100, Dj Servo
Cntrl- Nl, Falc Ii, Mkiv Servo
Radar Installation
Taillight- Install, New Leader
Cntrl- Nl G4, Mt6100 Mrkiv.4
Gps- Trimble 132 W Falcon
Gps- Starlink 1hz W Falcon
Gps- Trimble W Mt
Gps- Starlink 10hz W Mt
Gps- Starlink 10hz W Falcon
Parallel Swathing- Falcon Trac
Parallel Swathing- Trimble
Parallel Swathing- Starlink
Foamer Pkg- Frame Mnt '00 Chas
Tank- Foamer Assy Spinner
Solenoid- Single Assy Foamer
Tarp Pkg- Roll, 95.5 X 144 Nl
Crank Pkg- Elec Tarp, New Lead
Crank Pkg- Manual, 18' Srt
Decal Pkg- New Ldr G4, Lor-Al
Mudflap- Assy, New Leader W Ss
Window- Glass, Install, White
Final- Nl, Common Parts '01
Final- New Ldr G4, 3000, Mt
Final- New Ldr G4, 4000, Mt
Final- New Ldr G4, 2700ci, Mt
Final- New Ldr G4, 2700ci, Fii
Final- New Ldr G4, 3000, Falii
Final- New Ldr G4, 4000, Falii
Fenders-Super Flotation Tires
Conveyor Drive,L2020g4
Conveyor Idler,L2020g4
Conveyor Bottom # 5
Conveyor Chain,L2020g4
Conveyor Chain Oiler
Sealer & Wiper Belts
Chain Shield,L2020g4
Inverted Vee
Material Divider,L2020g4
Hillside Flow Divider,L2020g4
Spinner Guard & Shield L2020g4
Feedgate & Jack-L2020g4
Kit Valve Adapter
Idler Assembly
Valve Block Asm
Dickey-John Hyd-Single Pinion
Mk Iv.4 Control Hyd-Single Pin
Mark Iv.2 Ctrl Valv & Gearcase
Mark Iv.2 Ctrl Vlv Asm-Valve
Gear Case Asm
Gear Case 6.1
Radar Asm
Reservoir Hydraulics-L2020g4
Reservoir,23 Gallon-L2020g4
Hydraulic Fans,24 L2020g4
Motor Hyd Spinner Nl
Motor 1.50
Valve Flow Control O-Ring Thds
Decals-L2020g4
Conveyor Drive, L3020g4
Conveyor Idler, L3020g4
#4 Belt Over Pintle Chain Conv
#2 Pintle Chain Conveyor
Wiper Belt
Chain Shield
Divider-Material Assy
Spinner Guard And Shields
Feedgate And Jack
Gearcase, Dickey John
Mark Iv.4 Control Hydraulics
Control Hydraulics
Gear Case-Dual Pinion
Reservoir And Hydraulics
Reservoir, Hydraulic-40 Gallon
Twin Spinner Hydraulics
Hydraulic Fans, 24 Inch
Motor Spinner Nl
1.25 Inch
Control Valve
Decals, L3020g4
Brand: Loral
Model:
Radar Installation
Gps- Trimble W Mt
Conveyor Bottom # 5
Inverted Vee
Kit Valve Adapter
Idler Assembly
Valve Block Asm
Gear Case Asm
Gear Case 6.1
Radar Asm
Motor 1.50
Decals-L2020g4
Wiper Belt
Chain Shield
Feedgate And Jack
Control Hydraulics
Motor Spinner Nl
1.25 Inch
Control Valve
Decals, L3020g4
- Loral Air Max 1998 Parts Catalog L043921
- Loral Air Max System 1000 2000 Parts Catalog 503598D1
- Loral Air Max System 1000 2000 Parts Catalog 507663D1
- Loral Air Max System 1000 2000 Parts Catalog L044831
- Loral Air Max System 1000 2000 Parts Catalog WR121613
- Loral Air Max System 1000 2000 Parts Catalog WR125487
- Loral Air Max System 1000 2000 Parts Catalog WR128708
- Loral Air Max V System 1997 Parts Catalog L043449
- Loral Air Max V System 2000 Parts Catalog L044714
- Loral Air Spreader System 1998 Parts Catalog L043331
- Loral Applicators 1999-2006 Parts Documents AG333084
- Loral Big Wheels Pressure Vacuum System 2000 Parts Catalog L044985
- Loral Chassis 6300 Parts Manual WR124922
- Loral Chassis 6300 Parts Manual WR128394
- Loral Chassis 6400 Parts Manual WR125446
