New Idea Windrower Tractor 5840 Parts Catalog 00721023
Brand: New Idea
Type of Machine: Windrower Tractor
Model: New Idea 5840 Windrower Tractor
Part Number: 00721023
Number of Pages: 262 Pages
Publication Information
Drives - Engine Accessories
Drives - Radiator And Mounting
Drives - Muffler And Exhaust Mounting
Drives - Engine Accessories (Front)
Drives - U-Joint Assembly (Front), (700708536 U-Joint Assembly)
Drives - Engine Accessories (Rear)
Drives - U-Joint Assembly (Rear), (700708535 U-Joint Assembly)
Drives - Throttle, Linkage And Mounting
Fuel And Air - Fuel Tank And Mounting
Fuel And Air - Fuel Lines
Fuel And Air - Air Cleaner Mounting
Fuel And Air - Air Cleaner Assembly, (700715500 Air Cleaner Assembly)
Electrical - Steering Column And Monitor
Electrical - Control Console
Electrical - Console Wire Harness
Electrical - Console Panel
Electrical - Console Panel (Continued)
Electrical - Handle Mounting
Electrical - Handle Assembly
Electrical - Control Panel
Electrical - Cab Lights (Upper Front)
Electrical - Cab Light-Rear
Electrical - Engine Wiring
Electrical - Engine Wiring (Continued)
Electrical - Hydraulic Valve Wiring Harness
Electrical - Flasher Light Assemblies
Electrical - Electrical Harness Service Parts
Electrical - Electrical Harness Service Parts-Cont.
Brakes And Steering - Brake And Neutral Lock
Brakes And Steering - Neutral Lock
Brakes And Steering - Transmission Controls
Brakes And Steering - Brakes (Left And Right)
Brakes And Steering - Tensioner
Brakes And Steering - Hydraulic Servo-Control Assembly, (700715442 Servo-Control Assembly)
Brakes And Steering - Transmission Controls (Continued)
Brakes And Steering - Steering Assembly, (700726288 U-Joint Assembly-Steering)
Power Train - Chain Case And Axle (Left)
Power Train - Chain Case And Axle (Right)
Power Train - Planetary Gear Assembly, (700721101 Planetary Gear Assembly)
Mainframe, Cab, Wheels And Shields - Front Shields
Mainframe, Cab, Wheels And Shields - Platform And Handrail (Right)
Mainframe, Cab, Wheels And Shields - Tool Box
Mainframe, Cab, Wheels And Shields - Platform, Handrail And Step (Left)
Mainframe, Cab, Wheels And Shields - Cab Frame, Mirror And Shields
Mainframe, Cab, Wheels And Shields - Front Glass
Mainframe, Cab, Wheels And Shields - Door
Mainframe, Cab, Wheels And Shields - Glass (Right And Rear)
Mainframe, Cab, Wheels And Shields - Cab Frame And Glass Assembly, (700150295 Cab And Glass Assembly)
Mainframe, Cab, Wheels And Shields - Cap And Mounting
Mainframe, Cab, Wheels And Shields - Headliner And Hinges
Mainframe, Cab, Wheels And Shields - Steering Post
Mainframe, Cab, Wheels And Shields - Steering Column
Mainframe, Cab, Wheels And Shields - Windshield Wiper
Mainframe, Cab, Wheels And Shields - Upholstery
Mainframe, Cab, Wheels And Shields - Insulation
Mainframe, Cab, Wheels And Shields - Auxiliary Seat
Mainframe, Cab, Wheels And Shields - Seat Assembly
Mainframe, Cab, Wheels And Shields - Air Conditioner
Mainframe, Cab, Wheels And Shields - Air Conditioner And Heater
Mainframe, Cab, Wheels And Shields - Condenser And Compressor
Mainframe, Cab, Wheels And Shields - Filter And Mounting
Mainframe, Cab, Wheels And Shields - Radio And Speaker Mounting
Mainframe, Cab, Wheels And Shields - Radiator Panel
Mainframe, Cab, Wheels And Shields - Hood
Mainframe, Cab, Wheels And Shields - Hood (Continued)
Mainframe, Cab, Wheels And Shields - Door Mounting
Mainframe, Cab, Wheels And Shields - Door Assembly, (700152508 Door Assembly)
Mainframe, Cab, Wheels And Shields - Rotary Screen
Mainframe, Cab, Wheels And Shields - Rotary Screen (Continued)
Mainframe, Cab, Wheels And Shields - Battery Boxes And Mounting
Mainframe, Cab, Wheels And Shields - Lift Arm And Flotation (Left)
Mainframe, Cab, Wheels And Shields - Lift Arm And Flotation (Right)
Mainframe, Cab, Wheels And Shields - Rear Wheel (Left)
Mainframe, Cab, Wheels And Shields - Rear Wheel (Right)
Mainframe, Cab, Wheels And Shields - Wheel And Tire (Left And Right)
Hydraulics - Hydraulic Drive (2 Speed)
Hydraulics - Pump Assembly (Double), (700719771 Hydraulic Pump Assembly)
Hydraulics - Hydraulic Gear Pump Assembly, (700718753 Hydraulic Gear Pump Assembly)
Hydraulics - Brake Assemblies (2 Speed)
Hydraulics - Hydraulic Motor Assembly, (700725726 Hydraulic Motor Assembly)
Hydraulics - Hydraulic Valve Assembly (2 Speed), (700725727 Valve-2 Speed Assembly)
Hydraulics - Hydraulic Cooler
Hydraulics - Hydraulic Cooler (Continued)
Hydraulics - Manifold And Oil Filter
Hydraulics - Hydraulic Cooler And Mounting
Hydraulics - Header Lift Hydraulic
Hydraulics - Header Lift Hydraulic (Continued)
Hydraulics - Hydraulic Accumulator Assembly, (700713363 Hydraulic Accumulator Assembly)
Hydraulics - Hydraulic Valve Assembly, (700715639 Hydraulic Valve Assembly)
Hydraulics - Hydraulic Cylinder Assembly-Right, (700728107 Hydraulic Cylinder Assembly)
Hydraulics - Hydraulic Cylinder Assembly-Left, (700728108 Hydraulic Cylinder Assembly)
Hydraulics - Hydraulic Slave Cylinder Assembly-Right, (700719601 Hydraulic Cylinder Assembly)
Hydraulics - Hydraulic Master Cylinder Assembly-Left, (700719600 Hydraulic Cylinder Assembly)
Hydraulics - Oil Reservoir And Mounting
Hydraulics - Header Drive Hydraulic
Hydraulics - Header Drive Hydraulic (Continued)
Hydraulics - Header Drive Hydraulic Pump Assembly, (700706979 Hydraulic Pump Assembly)
Hydraulics - Header Drive Hydraulic Motor Assembly, (700706977 Hydraulic Motor Assembly)
Hydraulics - Header Control With Reverse
Hydraulics - Header Control With Reverse (Continued)
Hydraulics - Header Control (Standard)
Hydraulics - Hydraulic Control Valve Assembly, (700715996 Control Valve Assembly)
Hydraulics - Actuator Assembly
Hydraulics - Hydraulic Cylinder Assembly (Actuator), (700725130 Hydraulic Cylinder Assembly)
Hydraulics - Hydraulic Header Angle Tilt
Hydraulics - Hydraulic Cylinder Assembly, (700728106 Hydraulic Cylinder Assembly)
Hydraulics - Hydraulic Cylinder Assembly, (700721577 Hydraulic Cylinder Assembly)
Decals And Kits - Decals And Location Diagram
Decals And Kits - Decals And Location Diagram, (Operational)
Decals And Kits - Decals And Location Diagram-Continued, (Operational)
Decals And Kits - Control Panel Decals
Decals And Kits - Windshield Wiper Kit, (Nk60908 Windshield Wiper Kit)
Decals And Kits - Windshield Wiper Kit, (Nk61083 Windshield Wiper Kit)
Decals And Kits - Auxiliary Seat Kit, (Nk60916 Auxiliary Seat Kit)
Decals And Kits - Header Reverse Kit, (Nk60907 Header Reverse Kit)
Decals And Kits - Draper Adapter Kit, (Nk60922 Draper Adapter Kit)
Decals And Kits - Hydraulic Manifold Assembly, (700715325 Hydraulic Manifold Assembly)
Decals And Kits - 5000 Header Adapter Kit, (Nk61035 5000 Header Apapter Kit)
Decals And Kits - 5000 Header Adapter Kit-Continued, (Header Pump Stop Assembly)
Decals And Kits - Manifold Assembly, (700726384 Manifold Assembly)
Decals And Kits - Weight Kit, (Nk61154 Weight Kit)
Decals And Kits - Recommended Dealer Stock
