New Idea Combine 7800 Parts Catalog W448067
Brand: New Idea
Type of Machine: Combine
Model: New Idea 7800 Combine
Part Number: W448067
Number of Pages: 319 Pages
Drives, Left Hand Side
Drives, Right Hand Side
Header Body
Knife And Guards
Sickle Pitman And Drive
Header Countershaft And Drive
Header Auger - (No Suffix N On Serial No.)
Header Auger - (Suffix N On Serial No.)
Auger Drive And Supports
Plain Bat Reel
Pick-Up Reel, Medium Duty
Pick-Up Reel, Heavy Duty
Reel Drive
Sprocket And Slip Clutch - (Heavy Duty Reel)
Sheave And Hub, Reel Drive
Feeder Drive
Feeder Housing
Feeder Conveyor
Chain Tension Adjustment, Feeder
Rasp Bar Cylinder
Spike Tooth Cylinder (Rice Model)
Rasp Bar Concave And Controls
Spike Tooth Concave And Finger Grate
Stone Trap
Beater
Straw Walkers And Drive
Walker Return Pan And Pitman
Grain Pan
Shaker Pitman And Drive
Shoe
Fan And Housing
Fan Drive And Controls
Grain Elevator
Return Elevator
Unloader Declutch
Unloader Gear Box
Grain Bin
Rotary Valve (Main Unloading Auger)
Bin Unloading Augers And Drive
Unloader Tube
Platform And Control Box - (Used Serial -30100)
Platform And Control Box - (Used Serial 30101-)
Instrument Panel And Wiring - (Used Serial -30100)
Instrument Panel And Wiring - (Used Serial 30101-)
Throttle And Gear Shifting Controls
Propulsion Control Linkage, Hydrostatic
Brake Linkage
Cab (Shallow Roof)
Glass Specifications (Shallow Roof Cab)
Glass Specifications (Deep Roof Cab)
Cab (Deep Roof)
Seat And Back Rest
Front Fixed Ladder And Handrails - (Use Serial -30100)
Swing-Away Ladder - (Used Serial 30101-)
Rear Ladder
Hydraulic Tank And Lines
Basic Hydraulic Pump
Control Valve, Standard Header
Header Cylinder And Lines
Mechanical Propulsion Cyl. And Lines
Power Steering Lines, Wheel And - Components
Power Steering Hydraguide - (Used Serial 1- For Adjustable
Power Steering Hydramotor - Non-Adjustable (Used Serial
Power Steering Cylinder And Lines
Hydraulic Lines, Reel Lift
Master Cylinder (Reel Lift)
Slave Cylinder (Reel Lift)
Drives, Variable Speed Reel
Hydraulic Lines, Variable Speed Reel
Control Lever, Variable Speed Reel
Hydraulic Pump, Variable Speed Reel
Orbit Motor, Variable Speed Reel
Flow Control Valve, Variable Speed Reel
Automatic Header Height Control Assembly
Control Valve - Automatic Header Height
Cylinder Head And Camshaft (383 And 400)
Cylinder Block (383 And 400)
Pistons (383 And 400)
Crankshaft (383 And 400)
Oil Pump (383 And 400)
Water Pump (383 And 400)
Fan Drive And Idler (383 And 400)
Radiator And Rotary Screen (383 And 400)
Fuel Pump, Tanks, Filter And Lines - (383 And 400)
Carburetor (383 And 400)
Governor (383 And 400)
Distributor (383 And 400)
Starter (383 And 400)
Alternator (383 And 400) - (Used Serial -25885)
Alternator (400) - (Used Serial 25886-)
Ignition Coil And Wires (383 And 400)
Air Cleaner (383 And 400)
Exhaust System (383 And 400)
Motor Shaft, Base And - Propulsion Drive Idler (383 And 400)
Main Countershaft, Left Hand
Main Countershaft, Right Hand - (Cylinder Chain Drive)
Main Countershaft, Right Hand - (Cylinder V.S. Belt Drive)
Controls, Cylinder V.S. Belt Drive
Gear Box, Cylinder V.S. Belt Drive - (Used Serial -25800)
Gear Box, Cylinder V.S. Belt Drive - (Used Serial 25801-)
Thresher Declutch
Mechanical Propulsion Drive
Clutch And V.S. Sheaves - Mechanical Propulsion Drive, (Used
Clutch Housing And Linkage
Hydrostatic Drive
Pump And Motor, Hydrostatic - (Serial -40100)
Hydrostatic Tank And Lines - (Used Serial -40100)
Hydrostatic Tank And Lines - (Serial 40101-)
Hydrostatic Unit
Charge Pump And Drive, Hydrostatic - (Serial 40101-)
Disc Brakes
Final Drive
Non-Adjustable Rear Axle
Main Body
Shields, Right Hand
Shields, Left Hand
Lights
Chaffers, Shoe - (Used Serial -30100)
Chaffers, Shoe - (Used Serial 30101-)
Cleaning Screens, Shoe - (Used Serial -30100)
Cleaning Screens, Shoe - (Used Serial 30101-)
Floating Cutter Bar
Straw Spreader
Front Axle Extension
Rotor Assembly, Crop Chopper
Drive Assembly, Crop Chopper
Housing And Spreader Assembly - Crop Chopper
Corn Kit, Crop Chopper
Windshield Wiper, Cab
Propulsion Drive Shields - (Accessory Grain Models)
Engine Hourmeter
Tachometer, Rivet Extractor
Feeder Stand Assembly
Muffler Field Kit
Monitor System
Cab Air Conditioner
Compressor Mounting And Hoses
Wiring (Air Conditioner)
Cab Heater
7800 Decals
Paint
Brand: New Idea
Header Body
Knife And Guards
Plain Bat Reel
Reel Drive
Feeder Drive
Feeder Housing
Feeder Conveyor
Rasp Bar Cylinder
Stone Trap
Beater
Grain Pan
Shoe
Fan And Housing
Grain Elevator
Return Elevator
Unloader Declutch
Unloader Gear Box
Grain Bin
Unloader Tube
Brake Linkage
Cab (Shallow Roof)
Cab (Deep Roof)
Seat And Back Rest
Rear Ladder
Thresher Declutch
Hydrostatic Drive
Hydrostatic Unit
Disc Brakes
Final Drive
Main Body
Shields, Right Hand
Shields, Left Hand
Lights
Floating Cutter Bar
Straw Spreader
Engine Hourmeter
Muffler Field Kit
Monitor System
Cab Air Conditioner
Cab Heater
7800 Decals
Paint
- New Idea Air Planter 9000 Series Parts Catalog 988014A
- New Idea Combine 525 2890 Parts Catalog W448076
- New Idea Combine 545 4296 Parts Catalog W448070
- New Idea Combine 5542 Parts Catalog W448068B
- New Idea Combine 555 5555 5297 Parts Catalog W448078
- New Idea Combine 710 Edible Bean Harvester 712 Grain Platform 711 Parts Catalog 986330
- New Idea Combine 7300 Parts Catalog W448069B
- New Idea Combine 7600 Parts Catalog W448064A
- New Idea Corn Head 720 723 724 725 728 730 731 733 734 735 738 Parts Catalog US61
- New Idea Corn Picker 300 Two-Row 10 One-Row 302 One-Row Snapper Parts Catalog 986344
- New Idea Corn Picker 6 6A 6 Special 7 8 Parts Catalog 986342
- New Idea Double Frame Pull Type Planter And Row Units 900 Series Parts Catalog 986680
- New Idea Draper Header 5000 18-22-25-30-36 CTR 22-25-30 DBL SW Parts Catalog 00732147
- New Idea Forage Harvester 760 Superchopper 767 Pickup 761 766 Parts Catalog 986334
- New Idea Forward Fold Pull Type Planter 900 Series Parts Catalog 986780
