New Idea Combine 525 2890 Parts Catalog W448076
Brand: New Idea
Type of Machine: Combine
Model:
New Idea 525 Combine
New Idea 2890 Combine
Part Number: W448076
Number of Pages: 288 Pages
Ready Reference Chart - Drives - Right Hand Side
Ready Reference Chart - Drives - Left Hand Side
Cutting - Section 1 - Header Body (Serial -40110) (11', 13')
Cutting - Section 1 - Header Body (Serial 40111-)
Cutting - Section 1 - Knife And Guards (Serial -40110)
Cutting - Section 1 - Knife And Guards (Serial 40111-)
Cutting - Section 1 - Sickle Pitman (Serial -40110)
Cutting - Section 1 - Sickle Pitman (Serial 40111-) (11') (1
Cutting - Section 1 - Header Countershaft (Serial No. -40110)
Cutting - Section 1 - Header Countershaft (Serial No. 40111-)
Cutting - Section 1 - Header Auger (Serial No. -40110)
Cutting - Section 1 - Header Auger (Serial No. 40111-)
Cutting - Section 1 - Auger Drive And Supports (Serial
Cutting - Section 1 - Standard Reel (11', 12', 13') (Serial
Cutting - Section 1 - Cam Action Reel - Brantford (Optional)
Cutting - Section 1 - Cam Action Reel - Hume (Optional)
Cutting - Section 1 - Reel Sheaves, Sprockets And Slip
Cutting - Section 1 - Reel Drive (Serial -40110) (11', 13')
Cutting - Section 1 - Reel Drive (Serial 40111-)
Feeding - Section 2 - Feeder Housing (Serial -40110)
Feeding - Section 2 - Feeder Housing (Serial 40111-)
Feeding - Section 2 - Feeder Conveyor (Serial -40110)
Feeding - Section 2 - Feeder Conveyor (Serial 40111-)
Feeding - Section 2 - Rasp Bar Cylinder (Serial No. 1-)
Threshing - Section 3 - Rasp Bar Concave
Threshing - Section 3 - Spike Tooth Cylinder And Concave
Threshing - Section 3 - Spring Tooth Cylinder And Concave
Separating Section 4 - Beater
Separating Section 4 - Straw Walkers And Drive (Serial
Cleaning Section 5 - Grain Pan
Cleaning Section 5 - Shoe Pitman And Fan Drive
Cleaning Section 5 - Shoe Screens (Accessory)
Cleaning Section 5 - Fan And Housing
Elevating - Section 6 - Grain Elevator (Lower Section)
Elevating - Section 6 - Grain Elevator (Centre Section)
Elevating - Section 6 - Grain Elevator (Upper Section)
Elevating - Section 6 - Return Elevator (Lower Half)
Elevating - Section 6 - Return Elevator (Upper Half)
Grain Bin - Section 7 - Unloader Drive (Serial -11120)
Grain Bin - Section 7 - Unloader Drive (Serial 11121-)
Grain Bin - Section 7 - Grain Bin (Serial No. 1-)
Grain Bin - Section 7 - Grain Bin Loader
Grain Bin - Section 7 - Grain Bin Unloader
Platform And Controls - Section 8 - Operator's Platform
Platform And Controls - Section 8 - Control Tower (Serial
Platform And Controls - Section 8 - Gear Shift (Serial
Platform And Controls - Section 8 - Header And Thresher
Platform And Controls - Section 8 - Brake Linkage (Serial
Platform And Controls - Section 8 - Concave Control Lever
Hydraulic - Section 9 - Hydraulic Tank And Miscellaneous
Hydraulic - Section 9 - Hydraulic Pump And Filter (Serial
Hydraulic - Section 9 - Main Control Valve (Standard Header)
Hydraulic - Section 9 - Header Cylinders And Lines (Serial
Hydraulic - Section 9 - Hydraulic Line To Variable Speed
Hydraulic - Section 9 - Steering Wheel And Jacket (Serial
Hydraulic - Section 9 - Hydraulic Lines - Power Steering
Hydraulic - Section 9 - Power Steering Hydramotor
Hydraulic - Section 9 - Flow Divider
Hydraulic - Section 9 - Power Steering Cylinder
Hydraulic - Section 9 - Hydraulic Lines - Reel Lift
Hydraulic - Section 9 - Hyrdaulic Lines - Reel Lift
Hydraulic - Section 9 - Master Cylinder - Reel Lift
Hydraulic - Section 9 - Slave Cylinder - Reel Lift
Hydraulic - Section 9 - Main Control Valve (Automatic Header)
Hydraulic - Section 9 - Automatic Header Assembly
Hydraulic - Section 9 - Lever Control, Reservoir And Lines
Hydraulic - Section 9 - Flow Control Valve
Hydraulic - Section 9 - Orbit Motor (Variable Speed Reel)
Hydraulic - Section 9 - Reel Drive, Filter And Lines
Engine - Section 10 - Cylinder Block (6 Cyl).
Engine - Section 10 - Pistons (6 Cyl)
Engine - Section 10 - Crankshaft (6 Cyl)
Engine - Section 10 - Camshaft (6 Cyl)
Engine - Section 10 - Oil Pump (6 Cyl)
Engine - Section 10 - Oil Filter (6 Cyl)
Engine - Section 10 - Manifold And Exhaust (6 Cyl)
Engine - Section 10 - Radiator ( 6 Cyl)
Engine - Section 10 - Fuel Pump, Filters And Line (6 Cyl)
Engine - Section 10 - Carburetor (6 Cyl).
Engine - Section 10 - Linkage - Governor To Carburetor (6 Cy
Engine - Section 10 - Air Cleaner (6 Cyl.)
Engine - Section 10 - Variable Speed Governor
Engine - Section 10 - Constant Speed Governor (6 Cyl.)
Engine - Section 10 - Generator (6 Cyl.)
Engine - Section 10 - Distributor (6 Cyl.)
Engine - Section 10 - Starter (6 Cyl.)
Engine - Section 10 - Ignition Coil And Wires (6 Cyl.)
Engine - Section 10 - Water Pump (6 Cyl.)
Drive - Section 11 - Motor Shaft And Base
Drive - Section 11 - Variable Speed Shaft
Drive - Section 11 - Clutch And Variable Speed Sheaves
Drive - Section 11 - Clutch Housing And Linkage
Drive - Section 11 - Transmission
Drive - Section 11 - Differential (Serial No. 1-)
Drive - Section 11 - Disc Brakes (Serial No. 1-)
Drive - Section 11 - Final Drive
Axles And Wheels - Section 12 - Rear Axle (Serial -31100)
Axles And Wheels - Section 12 - Rear Axle (Serial -31101)
Axles And Wheels - Section 12 - Front Wheels
Miscellaneous - Section 13 - Miscellaneous Parts
Miscellaneous - Section 13 - Lights
Miscellaneous - Section 13 - Safety Shields
Accessories - Section 14 - Straw Spreader (Serial No. 1-)
Accessories - Section 14 - Rear Ladder (Serial No. 1-)
Accessories - Section 14 - Air Cleaner Stack Extension
Accessories - Section 14 - Tachometer, Rivet Extractor
Accessories - Section 14 - Scourkleen Housing And Screens
Accessories - Section 14 - Scourkleen Drives And Dockage Tube
Accessories - Section 14 - Warning Lamp (Serial No. 1-)
Accessories - Section 14 - Rotor Assembly - Crop Chopper
Accessories - Section 14 - Drive Assembly - Crop Chopper
Accessories - Section 14 - Housing And Spreader Assembly
Accessories - Section 14 - Corn Kit - Crop Chopper
Accessories - Section 14 - Cab (Ansel) (Serial No. 1-)
Accessories - Section 14 - Glass Specifications (Ansel Cab)
Accessories - Section 14 - Cab (George White, Serial -55755)
Accessories - Section 14 - Glass Specifications (George Whit
Accessories - Section 14 - Cab (George White, Serial 55756-)
Accessories - Section 14 - Windshield Wiper - Cab
Accessories - Section 14 - Heater - Cab (Serial No. 1-)
Accessories - Section 14 - Cab Weatherstrip (Serial No. 1-)
Accessories - Section 14 - Thresher Declutch (Serial No. 1-)
Accessories - Section 14 - Feeder Stand And Support Jacks
Accessories - Section 14 - Frame Extensions And Pivot Angles
Accessories - Section 14 - Paint
Accessories - Section 14 - 525 Decals (Common)
Accessories - Section 14 - Cockshutt Decals
Accessories - Section 14 - Oliver Decals
Accessories - Section 14 Minneapolis Moline Decals
Brand: New Idea
Model:
- New Idea Air Planter 9000 Series Parts Catalog 988014A
- New Idea Combine 545 4296 Parts Catalog W448070
- New Idea Combine 5542 Parts Catalog W448068B
- New Idea Combine 555 5555 5297 Parts Catalog W448078
- New Idea Combine 710 Edible Bean Harvester 712 Grain Platform 711 Parts Catalog 986330
- New Idea Combine 7300 Parts Catalog W448069B
- New Idea Combine 7600 Parts Catalog W448064A
- New Idea Combine 7800 Parts Catalog W448067
- New Idea Corn Head 720 723 724 725 728 730 731 733 734 735 738 Parts Catalog US61
- New Idea Corn Picker 300 Two-Row 10 One-Row 302 One-Row Snapper Parts Catalog 986344
- New Idea Corn Picker 6 6A 6 Special 7 8 Parts Catalog 986342
- New Idea Double Frame Pull Type Planter And Row Units 900 Series Parts Catalog 986680
- New Idea Draper Header 5000 18-22-25-30-36 CTR 22-25-30 DBL SW Parts Catalog 00732147
- New Idea Forage Harvester 760 Superchopper 767 Pickup 761 766 Parts Catalog 986334
- New Idea Forward Fold Pull Type Planter 900 Series Parts Catalog 986780
