New Idea Combine 5542 Parts Catalog W448068B
Brand: New Idea
Type of Machine: Combine
Model: New Idea 5542 Combine
Part Number: W448068B
Number of Pages: 331 Pages
Illustrated Group Index
Ready Reference Chart - Drives - Left Hand Side
Ready Reference Chart - Drives - Right Hand Side
Section 1 - Cutting - Head Body (12' 3.66m, 13' 3.96m,
Section 1 - Cutting - Knife And Guards (12' 3.66m,
Section 1 - Cutting - Sickle Pitman (12' 3.66m, 13' 3.96m,
Section 1 - Cutting - Head Countershaft (12' 3.66m,
Section 1 - Cutting - Head Auger (12' 3.66m, 13' 3.96m,
Section 1 - Cutting - Auger Drive And Supports (12' 3.66m,
Section 1 - Cutting - Standard Reel (12' 3.66m, 13' 3.96m,
Section 1 - Cutting - Cam Action Reel - Medium Duty
Section 1 - Cutting - Cam Action Reel - Heavy Duty
Section 1 - Cutting - Sprocket And Slip Clutch - Heavy Duty
Section 1 - Cutting - Sheave And Hub - Reel Drive (Serial
Section 1 - Cutting - Sprockets And Slip Clutch - Medium
Section 1 - Cutting - Reel Drive - Belt Or Chain (Serial
Section 1 - Cutting - Reel Drive - Belt And Chain (Serial
Section 2 - Feeding - Feeder Housing (Serial No. 1-)
Section 2 - Feeding - Feeder Conveyor (Grain Model) (Serial
Section 2 - Feeding - Feeder Conveyor (Rice Model) (Serial
Section 3 - Threshing - Rasp Bar Cylinder (Serial No. 1-)
Section 3 - Threshing - Rasp Bar Concave (Serial No. 1-)
Section 3 - Threshing - Spike Tooth Cylinder And Concave
Section 4 - Separating - Beater (Serial No. 1-)
Section 4 - Separating - Straw Walkers (Serial No. 1-)
Section 5 - Cleaning - Grain Pan (Serial No. 1-)
Section 5 - Cleaning - Shoe Pitman Fan Drive (Serial No. 1-)
Section 5 - Cleaning - Shoe (Serial No. 1-)
Section 5 - Cleaning - Shoe Screens (Accessory)
Section 5 - Cleaning - Fan And Housing (Serial No. 1-)
Section 6 - Elevating - Grain Elevator (Serial No. 1-)
Section 6 - Elevating - Return Elevator (Serial No. 1-)
Section 6 - Elevating - Top Auger (Return Elevator)
Section 7 - Grain Bin - Grain Bin (Serial No. 1-)
Section 7 - Grain Bin - Grain Bin Unloader (Serial No. 1-)
Section 7 - Grain Bin - Unloader Drive (Serial No. 1-)
Section 8 - Platform And Controls - Operator's Platform
Section 8 - Platform And Controls - Control Tower
Section 8 - Platform And Controls - Control Tower (6 Cyl.)
Section 8 - Platform And Controls - Agristeel Cab
Section 8 - Platform And Controls - Dome Light And
Section 8 - Platform And Controls - George White Cab
Section 8 - Platform And Controls - Glass Specifications -
Section 8 - Platform And Controls - Weather Strip And Seals
Section 8 - Platform And Controls - Hadco-Tiffin & Sims
Section 8 - Platform And Controls - Convcave Control Lever
Section 8 - Platform And Controls - Gear Shift
Section 8 - Platform And Controls - Head And Thresher
Section 8 - Platform And Controls - Brake Linkage
Section 8 - Platfo0m And Controls - Steering Gear (Used
Section 9 - Hydraulic - Hydraulic Tank And Miscellaneous
Section 9 - Hydraulic - Hydraulic Pump, Flow Divider And
Section 9 - Hydraulic - Hydraulic Lines (Power Steering)
Section 9 - Hydraulic - Valve (Power Steering) (Used
Section 9 - Hydraulic - Cylinder (Power Steering) (Used
Section 9 - Hydraulic - Drag Links (Power Steering) (Used
Section 9 - Hydraulic - Basic Hydraulic Hoses (Used Serial
Section 9 - Hydraulic - Power Steering Wheel, Lines And
Section 9 - Hydraulic - Power Steering Hydraguide (Used
Section 9 - Hydraulic - Power Steering Cylinder And Lines
Section 9 - Hydraulic - Hydraulic Pump (Used Serial 55001-)
Section 9 - Hydraulic - Main Control Valve (Serial No. 1-)
Section 9 - Hydraulic - Head Cylinders And Lines (Serial No.
Section 9 - Hydraulic - Hydraulic Line To Variable Speed
Section 9 - Hydraulic - Master Cylinder - Reel Lift (Serial
Section 9 - Hydraulic - Hydraulic Lines (Reel Left) (Serial
Section 9 - Hydraulic - Lever Control, Reservoir And Lines
Section 9 - Hydraulic - Flow Control Valve (Variable Speed
Section 9 - Hydraulic - Orbit Motor (Variable Speed Reel)
Section 9 - Hydraulic - Orbit Motor (Char-Lyn) - Variable
Hydraulic - Section 9 - Hydraulic Pump - Variable Speed Reel
Section 9 - Hydraulic - Reel Drive, Filter And Lines
Section 10 - Engine - Cylinder Block (6 Cyl.)
Section 10 - Engine - Pistons (6 Cyl.)
Section 10 - Engine - Crankshaft (6 Cyl.)
Section 10 - Engine - Camshaft (6 Cyl.)
Section 10 - Engine - Oil Pump (6 Cyl.)
Engine - Section 10 - Oil Filter (6 Cyl.)
Section 10 - Engine - Manifold (6 Cyl.)
Engine - Section 10 - Water Pump (6 Cyl.)
Section 10 - Engine - Radiator (6 Cyl.)
Section 10 - Engine - Fuel Pump, Filters And Line (6 Cyl.)
Section 1-0 - Engine - Carburetor (6 Cyl.)
Section 10 - Engine - Linkage (Governor To Carburetor)
Engine - Section 10 - Air Cleaner (6 Cyl.)
Section 10 - Engine - Constant Speed Governor (6 Cyl.)
Section 10 - Engine - Generator (6 Cly.) (Serial No. 1-)
Section 10 - Engine - Distributor (6 Cyl.) (Serial No. 1-)
Section 10 - Engine - Starter (6 Cyl.) (Serial No. 1-)
Section 10 - Engine - Ignition Coil And Wires (6 Cyl.)
Section 10 - Engine - Motor Shaft And Base (6 Cyl.) (Serial
Section 10 - Engine - Cylinder Head And Camshaft
Engine - Section 10 - Pistons
Engine - Section 10 - Crankshaft
Engine - Section 10 - Oil Pump
Engine - Section 10 - Water Pump (318 (Used Serial -76000)
Engine - Section 10 - Front Engine Drive (318) (Used Serial
Engine - Section 10 - Radiator
Engine - Section 10 - Fuel, Pump, Filters And Lines
Engine - Section 10 - Carburetor (318) (Used Serial -65000)
Engine - Section 10 - Carburetor (318) (Used Serial 65001-)
Engine - Section 10 - Governor (318) (Used Serial -20100)
Engine - Section 10 - Governor (318) (Used Serial 76001-)
Engine - Section 10 - Distributor (318) (Used Serial -10500)
Engine - Section 10 - Distributor And Electronic Ignition
Engine - Section 10 - Starter (318) (Used Serial -55000)
Engine - Section 10 - Starter (318) (Used Serial 55001-)
Engine - Section 10 - Alternator (318) (Used Engine Serial
Engine - Section 10 - Alternator (318) (Used Serial 65001-)
Engine - Section 10 - Ignition Coil And Wires
Engine - Section 10 - Air Cleaner (318) (Serial No. 1-)
Engine - Section 10 - Exhaust System (318) (Serial No. 1-)
Engine - Section 10 - Motor Shaft And Base
Engine - Section 10 - Separator Body And Battery
Section 11 - Drive - Variable Speed Shaft (Serial No. 1-)
Section 11 - Drive - Clutch And Variable Speed Sheaves
Section 11 - Drive - Clutch Housing And Linkage
Section 11 - Drive - Transmission (Serial No. 1-)
Section 11 - Drive - Differential
Section 11 - Drive - Disc Brakes (Serial No. 1-)
Section 11 - Drive - Final Drive (Serial No. 1-)
Section 12 - Axles And Wheels - Rear Axle (Serial No. 1-)
Section 12 - Axles And Wheels - Front Wheels (Serial No. 1-)
Section 13 - Miscellaneous - Miscellaneous Parts
Section 13 - Miscellaneous - Lights (Serial No. 1-)
Section 13 - Miscellaneous - Shields - Right Hand
Section 13 - Miscellaneous - Shields - Left Hand
Section 13 - Miscellaneous - Reel Drive Shields
Section 14 - Accessories - Rotor Assembly - Crop Chopper
Section 14 - Accessories - Housing And Spreader Assembly -
Section 14 - Accessories - Drive Assembly (Crop Chopper)
Section 14 - Accessories - Straw Spreader (Serial No. 1-)
Section 14 - Accessories - Shields (Serial No. 1-)
Section 14 - Accessories - Warning Lamps (Serial No. 1-)
Section 14 - Accessories - Warning Lamp (Serial No. 1-)
Section 14 - Accessories - Operator's Canopy (Rice Models
Section 14 - Accessories - Engine Hourmeter (Acessory)
Section 14 - Accessories - Windshield Wiper - Cab (Serial
Section 14 - Accessories - Heater Cab (Serial No. 1-)
Section 14 - Accessories - Scourkleen (Serial No. 1-)
Section 14 - Accessories - Tachometer, Rivet Extractor
Section 14 - Accessories - Paint (Serial No. 1-)
5542 Decals
Brand: New Idea
5542 Decals
- New Idea Air Planter 9000 Series Parts Catalog 988014A
- New Idea Combine 525 2890 Parts Catalog W448076
- New Idea Combine 545 4296 Parts Catalog W448070
- New Idea Combine 555 5555 5297 Parts Catalog W448078
- New Idea Combine 710 Edible Bean Harvester 712 Grain Platform 711 Parts Catalog 986330
- New Idea Combine 7300 Parts Catalog W448069B
- New Idea Combine 7600 Parts Catalog W448064A
- New Idea Combine 7800 Parts Catalog W448067
- New Idea Corn Head 720 723 724 725 728 730 731 733 734 735 738 Parts Catalog US61
- New Idea Corn Picker 300 Two-Row 10 One-Row 302 One-Row Snapper Parts Catalog 986344
- New Idea Corn Picker 6 6A 6 Special 7 8 Parts Catalog 986342
- New Idea Double Frame Pull Type Planter And Row Units 900 Series Parts Catalog 986680
- New Idea Draper Header 5000 18-22-25-30-36 CTR 22-25-30 DBL SW Parts Catalog 00732147
- New Idea Forage Harvester 760 Superchopper 767 Pickup 761 766 Parts Catalog 986334
- New Idea Forward Fold Pull Type Planter 900 Series Parts Catalog 986780
