New Idea Combine 7300 Parts Catalog W448069B
Brand: New Idea
Type of Machine: Combine
Model: New Idea 7300 Combine
Part Number: W448069B
Number of Pages: 392 Pages
Publication Information
Illustrated Group Index
Drives - Left Hand Side
Drives - Right Hand Side
Head Body
Knife And Guards - Fixed Cut Bar
Sickle Pitman And Drive
Head Countershaft Drive
Head Auger
Auger Drive And Supports
Standard Reel
Cam Action Reel - Medium Duty (Optional)
Cam Action Reel - Heavy Duty (Optional)
Sprocket And Slip Clutch - Heavy Duty
Reel Drive
Reel Drive Shields - (Used Serial 85301-)
Feeder Housing
Feeder Conveyor
Safety Clutch - Top Feeder Shaft
Cylinder Cover
Rasp Bar Cylinder
Spike Tooth Cylinder
Concave And Grid Grate
Spike Tooth Concave
Beater
Straw Walker And Drive
Grain Pan
Shoe Pitman And Fan Drive
Shoe
Fan And Housing
Grain Elevator - (Lower Section)
Grain Elevator - (Centre Section)
Grain Elevator - (Upper Section)
Return Elevator - (Lower Half)
Return Elevator - (Upper Half)
Unloader Drive
Grain Bin And Cross Auger
Grain Bin Loader
Grain Bin Unloader
Cab - (Serial -33307), (George White, Ansel And Crown Fab
Cab - (Serial 33308 - 53200), (Hadco Tiffin Cabs)
Glass Specifications - Cab, (Used Serial -53200)
Glass Specifications - Cab, (Used Serial 53201-)
Cab - (Serial 53201 - 85300), (Tiffin And Teledyne)
Cabinet - Air Filter (Serial No. 85301-) - (Serial 85301-),
Blower - (Used Serial 85301-)
Operator's Platform
Weatherstrip And Seals For Cab
Control Tower
Gear Shift
Head And Thresher Declutch
Concave Control Lever
Brake Linkage And Pedals
Hydraulic Tank And Lines
Main Hydraulic Pump Drive - (Diesel)
Control Valve And Repair Kits
Head Cylinders And Lines
Hydraulic Cylinder - Propulsion Drive
Power Steering Lines, Wheels - And Components, (Used Serial
Power Steering Hydramotor - (Used Serial -12564)
Power Steering Hydraguide - (Used Serial 12565-)
Power Steering Cylinder And Lines
Hydraulic Lines - Reel Lift
Master Cylinder (Reel Lift)
Slave Cylinder (Reel Lift)
Drives - Variable Speed Reel
Hydraulic Lines
Control Lever - Variable Speed Reel
Hydraulic Pump - Variable Speed Reel
Orbit Motor - Variable Speed Reel
Flow Control Valve - Variable Speed Reel
Control Valve - (Automatic Head Height Control)
Cylinder Head And Camshaft
Pistons
Oil Pump
Water Pump (318) - (Used Serial -63100)
Front Engine Drive (318) - (Used Serial 63101-)
Fuel Pump, Filters And Lines
Carburetor (318) - (Used Serial -53220)
Carburetor (318) - (Used Serial 53221-)
Governor (318) - (Used Serial -63100)
Governor (318) - (Used Serial 63101-)
Distributor (318) - (Used Serial -53006)
Distributor And Electronic Ignition 318 - (Used Serial
Starter (318) - (Used Serial -43000)
Starter (318) - (Used Serial 43001-)
Alternator (318) - (Used Engine Serial -E162461)
Alternator (318) - (Used Engine Serial E 162462-)
Alternator (318) - (Used Serial 53007-)
Ignition Coil And Wires
Air Cleaner
De-Icer
Exhaust System
Motor Shaft And Base
Gaskets (Diesel) - (Used Serial -33005 And 3331
Gaskets (Diesel) - (Used Serial 33006 - 33317)
Cylinder Head Cover (Diesel) - (Used Serial -33005 And
Cylinder Head Cover (Diesel) - (Used Serial 33006 - 33317)
Cylinder Head (Diesel)
Cylinder Block (Diesel) - (Used Serial -33005 And 3331
Cylinder Block (Diesel) - (Used Serial 333006 - 33317)
Crankshaft And Pistons (Diesel)
Timing Gear And Auxiliary Drive
Oil Pump And Pan (Diesel)
Oil Filter, Cooler And Lines (Diesel) - (Used Serial -3305
Oil Filter (Diesel) - (Used Serial 33006 - 33317)
Fuel Tank And Lines (Diesel)
Fuel Lift Pump (Diesel)
Fuel Filters And Lines (Diesel) - (Used Serial -33005 And 33318 - 63100)
Fuel Filters And Lines (Diesel) - (Used Serial 33006 - 33317)
Fuel Filters And Lines (Diesel) - (Used Serial 63101-)
Fuel Injection Lines And Fittings - (Diesel), (Used Serial -33005 And 3331
Fuel Injection Lines And Fittings - (Diesel), (Used Serial 33006 - 33317)
Fuel Injection Pump (Diesel)
Fuel Injector (Diesel) - (Used Serial -33005 And 3331
Water Pump And Thermostat Housing - (Diesel), (Used Serial -33005 And 3331
Water Pump And Thermostat Housing - (Diesel), (Used Serial 33006 - 33317)
Radiator (Diesel)
Starter (Diesel)
Alternator (32 Amp.) (Diesel) - (Used Serial -22100)
Alternator (61 Amp.) (Diesel) - (Used Serial 22101 - 71100)
Alternator (61 Amp.) (Diesel) - (Used Serial 71101-)
Manifolds And Exhaust System (Diesel)
Motor Shaft And Base (Diesel)
Air Cleaner (Diesel)
Fuel Stop And Controls (Diesel)
Quick Start (Accessory) (Diesel)
Thermostart (Accessory)
Variable Speed Propulsion Drive
Torsional Vibration Package - Traction Belt Drive (Diesel
Variable Speed Unit - Rear
Variable Speed Unit - Front
Clutch
Clutch Housing And Linkage
Disc Brakes
Final Drive
Rear Axle
Front Wheels
Miscellaneous Parts
Lights
Safety Shields
Floating Cutter Bar - (Rivetted Sickle Head)
Floating Cutter Bar - (Bolted Sickle Head)
Straw Spreader
Chaffer And Shoe Cleaning Screens
Shields And Stubble Guard
Fan Housing Shields
Rear Ladder
Scourkleen Housing And Screens
Scourkleen Drives And Dockage Tube
Windshield Wiper - Cab
Heater - Cab - (Used Serial -85300)
Heater - Cab - (Used Serial 85301-)
Cab Air Conditioner - (Used Serial 85301-)
Compressor Mounting And Hoses - (Used Serial 85301-)
Compressor And Drive Pulley - (Tecumseh), (Used Serial
Compressor And Drive Pulley - (York), (Used Serial 85301-)
Rotor Assembly - Crop Chopper - (Used Serial -63100)
Housing And Spreader Asy. - Crop Chopper - (Used Serial
Drive Assembly - Crop Chopper - (Used Serial -63100)
Corn Kit - Crop Chopper - (Used Serial -63100)
Housing, Spreader And Rotor Assembly - Crop Chopper, (Used
Drive Assembly - Crop Chopper - (Used Serial 63101-)
Engine Hourmeter (Accessory)
Warning Lamp
Tachometer, Rivet Extractor
Feeder Stand (Accessory)
Paint (Not Illustrated)
7300 Decals (Not Illustrated)
Brand: New Idea
Head Body
Head Auger
Standard Reel
Reel Drive
Feeder Housing
Feeder Conveyor
Cylinder Cover
Rasp Bar Cylinder
Spike Tooth Concave
Beater
Grain Pan
Shoe
Fan And Housing
Unloader Drive
Grain Bin Loader
Grain Bin Unloader
Operator's Platform
Control Tower
Gear Shift
Hydraulic Lines
Pistons
Oil Pump
Air Cleaner
De-Icer
Exhaust System
Radiator (Diesel)
Starter (Diesel)
Clutch
Disc Brakes
Final Drive
Rear Axle
Front Wheels
Miscellaneous Parts
Lights
Safety Shields
Straw Spreader
Fan Housing Shields
Rear Ladder
Warning Lamp
- New Idea Air Planter 9000 Series Parts Catalog 988014A
- New Idea Combine 525 2890 Parts Catalog W448076
- New Idea Combine 545 4296 Parts Catalog W448070
- New Idea Combine 5542 Parts Catalog W448068B
- New Idea Combine 555 5555 5297 Parts Catalog W448078
- New Idea Combine 710 Edible Bean Harvester 712 Grain Platform 711 Parts Catalog 986330
- New Idea Combine 7600 Parts Catalog W448064A
- New Idea Combine 7800 Parts Catalog W448067
- New Idea Corn Head 720 723 724 725 728 730 731 733 734 735 738 Parts Catalog US61
- New Idea Corn Picker 300 Two-Row 10 One-Row 302 One-Row Snapper Parts Catalog 986344
- New Idea Corn Picker 6 6A 6 Special 7 8 Parts Catalog 986342
- New Idea Double Frame Pull Type Planter And Row Units 900 Series Parts Catalog 986680
- New Idea Draper Header 5000 18-22-25-30-36 CTR 22-25-30 DBL SW Parts Catalog 00732147
- New Idea Forage Harvester 760 Superchopper 767 Pickup 761 766 Parts Catalog 986334
- New Idea Forward Fold Pull Type Planter 900 Series Parts Catalog 986780
