702,019
New Idea Combine 555 5555 5297 Parts Catalog W448078
Brand: New Idea
Type of Machine: Combine
Model:
New Idea 555 Combine
New Idea 5555 Combine
New Idea 5297 Combine
Part Number: W448078
Number of Pages: 303 Pages
Drives - Left Hand Side (Serial No. 1-)
Drives - Right Hand Side (Serial No. 1-)
Header Body (Serial No. 1-)
Knife And Guards (Serial No. 1-)
Sickle Pitman (Serial No. 1-)
Header Countershaft (Serial No. 1-)
Header Auger (Serial No. 1-)
Auger Drive And Supports
Standard Reel (Serial No. 1-)
Cam Action Reel - Brantford (Optional) (Serial No. 1-)
Cam Action Reel - Hume (Optional) (Serial No. 1-)
Reel Sheaves, Sprockets And Slip Clutches (Serial No. 1-)
Reel Drive (Serial No. 1-)
Feeder Housing (Serial No. 1-)
Feeder Conveyor (Serial No. 1 -)
Rasp Bar Cylinder
Concave And Controls
Stone Trap (Serial No. 1-)
Beater (Serial No. 1-)
Straw Walkers And Drive (Serial No. 1-)
Walker Return Pan And Pitman
Grain Pan
Shaker Pitman & Drive
Shoe (Serial No. 1-)
Fan And Housing (Serial No. 1-)
Fan Drive And Controls
Grain Elevator (Serial No. 1-)
Return Elevator
Unloader Declutch (Serial No. 1-)
Unloader Gear Box (Serial No. 1-)
Grain Bin
Main Unloading Auger (Serial No. 1-)
Bin Unloading Augers And Drive (Serial No. 1-)
Unloader Tube (Serial No. 1-)
Platform And Control Box
Engine Covers (Serial No. 1-)
Instrument Panel And Wiring (Serial No. 1-)
Throttle And Gear Shifting Mechanism (Serial No. 1-)
Propulsion Control Linkage - Hydrostatic
Brake Linkage
Cab - Operators (Serial No. 1-)
Seat And Back Rest (Serial 10201-)
Seat And Back Rest (Serial -10200)
Front Ladder And Handrails (Serial No. 1-)
Rear Ladder (Serial No. 1-)
Hydraulic Tank And Lines (Serial No. 1-)
Power Steering Hydraguide (Serial No. 1-)
Hydraulic Pump (Serial No. 1-)
Control Valve - Basic Hydraulic
Header Cylinders And Lines (Serial No. 1-)
Variable Speed Cylinders And Lines (Serial No. 1-)
Power Steering Lines, Wheel And Components
Power Steering Hydramotor (Serial No. 1-)
Power Steering Cylinder And Lines (Serial No. 1-)
Hydraulic Lines (Reel Lift) (Serial No. 1-)
Master Cylinder (Reel Lift)
Slave Cylinder (Reel Lift) (Serial No. 1-)
Hydraulic Pump (Variable Speed Reel) (Serial No. 1-)
Lever Control, Reservoir And Lines (Variable Speed Reel)
Flow Control Valve (Variable Speed Reel) (Serial No. 1-)
Orbit Motor (Variable Speed Reel) (Serial No. 1-)
Reel Drive, Filter And Lines (Variable Speed Reel) (Serial
Automatic Header Height Control Assembly (Serial No. 1-)
Control Valve - Automatic Header Height
Cylinder Head And Camshaft (318) (Serial No. 1-)
Cylinder Block (318) (Serial No. 1-)
Pistons
Oil Pump (318) (Serial No. 1-)
Radiator And Rotary Screen
Fuel Pump, Tanks, Filter And Lines (318) (Serial No. 1-)
Carburetor (318) (Serial No. 1-)
Governor (318) (Used Serial -25200)
Governor (318) (Used Serial 25201-)
Distributor (318) (Serial No. 1-)
Starter (318) (Serial No. 1-)
Alternator (318) (Serial No. 1-)
Ignition Coil And Wires (318) (Serial No. 1-)
Air Cleaner
Exhaust System (318) (Serial No. 1-)
Motor Shaft, Base And Propulsion Drive Idler (Serial No. 1-)
Main Countershaft - Left Hand (Serial No. 1-)
Main Countershaft - Right Hand (Standard Cylinder Drive)
Cylinder Drive - Standard (Serial No. 1-)
Main Countershaft - Right Hand (Variable Speed Cylinder
Controls - Right Hand Main Countershaft (Serial No. 1-)
Cylinder Drive And Countershaft - Variable Speed (Serial No.
Thresher Declutch
Variable Speed Unit
Clutch And Variable Speed Sheaves (Serial No. 1-)
Clutch Housing And Linkage (Serial No. 1-)
Hydrostatic Drive - 383 Engine (Serial No. 1-)
Hydrostatic Drive - 318 Engine
Pump And Motor - Hydrostatic (Serial No. 1-)
Hydrostatic Tank And Lines (Serial -10200)
Hydrostatic Tank And Lines (Serial 10201-)
Transmission (Serial No. 1-)
Differential (Serial No. 1-)
Disc Brakes (Serial No. 1-)
Final Drive (Serial No. 1-)
Rear Axle (Serial No. 1-)
Main Body (Serial No. 1-)
Shields - Right Hand
Shields - Left Hand
Lights
Chaffers - Shoe (Accessory) (Serial No. 1-)
Cleaning Screens - Shoe (Accessory) (Serial No. 1-)
Corn Cob Mix Attachment (Accessory) (Serial No. 1-)
Straw Spreader (Serial No. 1-)
Front Axle Extension (Accessory) (Serial No. 1-)
Rotor Assembly - Crop Chopper (Serial No. 1-)
Drive Assembly - Crop Chopper (Serial No. 1-)
Housing And Spreader Assembly - Crop Chopper (Serial No. 1-)
Corn Kit - Crop Chopper (Serial No. 1-)
Windshield Wiper - Cab (Serial No. 1-)
Glass Specifications - Cab (Serial No. 1-)
Rotary Valve (Main Unloading Auger) (Serial No. 1-)
Engine Hourmeter (Accessory) (Serial No. 1-)
Tachometer And Rivet Extractor (Serial No. 1-)
Grain Header Support Jacks (Ezi-Change And Drive In Feeder
Frame Extensions And Pivot Angles (Ezi-Change And Drive In
Muffler Field Kit (Serial No. 1-)
Cylinder Head And Camshaft (383) (Serial No. 1-)
Cylinder Block (383) (Serial No. 1-)
Pistons (383) (Serial No. 1-)
Crankshaft (383) (Serial No. 1-)
Oil Pump (383) (Serial No. 1-)
Fan Drive And Idler
Radiator And Rotary Screen (383) (Serial No. 1-)
Fuel Pump, Tanks, Filter And Lines (383) (Serial No. 1-)
Carburetor (383) (Serial No. 1-)
Governor (383) (Serial No. 1-)
Distributor (383) (Serial No. 1-)
Starter (383) (Serial No. 1-)
Alternator (383) (Serial No. 1-)
Ignition Coil And Wires (383) (Serial No. 1-)
Air Cleaner (383) (Serial No. 1-)
Exhaust Sytem (383) (Serial No. 1-)
Decals - Oliver And Minneapolis Moline, Complete Set Of
Paint (Serial No. 1-)
Decals (Cockshutt) Complete Set Of Decals - See 1548763
