New Idea Combine 7600 Parts Catalog W448064A
Brand: New Idea
Type of Machine: Combine
Model: New Idea 7600 Combine
Part Number: W448064A
Number of Pages: 326 Pages
Ready Reference Chart - Drives - Left Hand Side
Ready Reference Chart - Drives - Right Hand Side
Cutting - Section 1 - Head Body
Knife And Guards (11' 3.35m, 13' 3.96m, 15' 4.57m, 18' 5.49m
Cutting - Section 1 - Sickle Pitman And Drive
Cutting - Section 1 - Head Countershaft And Drive
Cutting - Section 1 - Head Auger (No Suffix N In Head
Cutting - Section 1 - Head Auger (Suffix N In Head Serial
Cutting - Section 1 - Auger Drive And Supports
Plain Bat Reel (11' 3.35m, 13' 3.96m, 15' 4.57m, 18' 5.49m,
Cutting - Section 1 - Pick-Up Reel - Medium Duty
Cutting - Section 1 - Pick-Up Reel - Heavy Duty
Cutting - Section 1 - Reel Drive (Serial No. 1-)
Cutting - Section 1 - Sprocket And Slip Clutch - Heavy Duty
Cutting - Section 1 - Sheave And Hub - Reel Drive
Feeding - Section 2 - Feeder Drive (Serial No. 1-)
Feeding - Section 2 - Feeder Housing
Feeding - Section 2 - Feeder Conveyor
Feeding - Section 2 - Chain Tension Adjustment - Feeder
Threshing - Section 3 - Rasp Bar Cylinder
Threshing - Section 3 - Spike Tooth Cylinder
Threshing - Section 3 - Rasp Bar Concave And Controls
Threshing - Section 3 - Spike Tooth Concave And Finger Grate
Threshing - Section 3 - Stone Trap
Separating - Section 4 - Beater (Serial No. 1-)
Separating - Section 4 - Straw Walkers And Drive
Separating - Section 4 - Walker Return Pan And Pitman
Cleaning - Section 5 - Grain Pan (Serial No. 1-)
Cleaning - Section 5 - Shaker Pitman And Drive
Cleaning - Section 5 - Shoe (Serial No. 1-)
Cleaning - Section 5 - Fan And Housing
Cleaning - Section 5 - Fan Drive And Controls
Elevating - Section 6 - Grain Elevator (Serial No. 1-)
Elevating - Section 6 - Return Elevator (Serial No. 1-)
Grain Bin - Section 7 - Unloader Declutch
Grain Bin - Section 7 - Unloader Gear Box (Serial No. 1-)
Grain Bin - Section 7 - Grain Bin
Grain Bin - Section 7 - Rotary Valve (Main Unloading Auger)
Grain Bin - Section 7 - Main Unloading Auger (Serial No. 1-)
Grain Bin - Section 7 - Bin Unloading Augers And Drive
Grain Bin - Section 7 - Unloader Tube (Serial No. 1-)
Platform And Controls - Section 8 - Platform And Control Box
Platform And Controls - Section 8 - Instrument Panel And
Platform And Controls - Section 8 - Throttle And Gear
Platform And Controls - Section 8 - Propulsion Control
Platform And Controls - Section 8 - Brake Linkage
Platform And Controls - Section 8 - Cab (Shallow Roof)
Platform And Controls - Section 8 - Glass Specifications
Platform And Controls - Section 8 - Cab (Deep Roof)
Platform And Controls - Section 8 - Seat And Back Rest
Platform And Controls - Section 8 - Swing Away Ladder
Hydraulic - Section 9 - Hydraulic Tank And Lines
Hydraulic - Section 9 - Basic Hydraulic Pump (Serial No. 1-)
Hydraulic - Section 9 - Control Valve (Standard Header)
Hydraulic - Section 9 - Header Cylinders And Lines
Hydraulic - Section 9 - Mechanical Propulsion Cylinders And
Hydraulic - Section 9 - Power Steering Lines, Wheel And
Hydraulic - Section 9 - Power Steering Hydraguide
Hydraulic - Section 9 - Power Steering Cylinder And Lines
Hydraulic - Section 9 - Hydraulic Lines - Reel Lift
Hydraulic - Section 9 - Master Cylinder (Reel Lift)
Hydraulic - Section 9 - Slave Cylinder (Reel Lift)
Hydraulic - Section 9 - Drives - Variable Speed Reel
Hydraulic - Section 9 - Hydraulic Lines - Variable Speed Reel
Hydraulic - Section 9 - Control Lever - Variable Speed Reel
Hydraulic - Section 9 - Hydraulic Pump - Variable Speed Reel
Hydraulic - Section 9 - Orbit Motor - Variable Speed Reel
Hydraulic - Section 9 - Flow Control Valve - Variable Speed
Hydraulic - Section 9 - Automatic Head Height Control
Hydraulic - Section 9 - Control Valve - Automatic Head
Hydraulic - Section 9 - Hydraulic Swing Kit - Unloading
Hydraulic - Section 9 - Cylinder - Hydraulic Swing Unloading
Hydraulic - Section 9 - Valve - Hydraulic Swing Unloading
Engine - Section 10 - Cylinder Head And Camshaft (318 Gas)
Engine - Section 10 - Cylinder Block
Engine - Section 10 - Pistons
Engine - Section 10 - Crankshaft
Engine - Section 10 - Oil Pump
Engine - Section 10 - Water Pump (318) (Serial No. 1-)
Engine - Section 10 - Radiator And Rotary Screen
Engine - Section 10 - Fuel Pump, Tanks, Filter, And Lines
Engine - Section 10 - Carburetor (318) (Serial No. 1-)
Engine - Section 10 - Carburetor (318 V-8) (Alternate To
Engine - Section 10 - Governor (318) (Serial No. 1-)
Engine - Section 10 - Distributor (318) (Serial No. 1-)
Engine - Section 10 - Starter (318) (Serial No. 1-)
Engine - Section 10 - Alternator (318) (Serial No. 1-)
Engine - Section 10 - Ignition Coil And Wires
Engine - Section 10 - Air Cleaner (318) (Serial No. 1-)
Engine - Section 10 - Exhaust System (318) (Serial No. 1-)
Drive - Section 11 - Motor Shaft, Base, And Propulsion Drive
Drive - Section 11 - Main Countershaft - Left Hand
Drive - Section 11 - Main Countershaft - Right Hand
Drive - Section 11 - Cylinder Chain Drive (Serial No. 1-)
Drive - Section 11 - Controls - Cylinder V.S. Belt Drive
Drive - Section 11 - Gear Box - Cylinder V.S. Belt Drive
Drive - Section 11 - Thresher Declutch
Drive - Section 11 - Mechanical Propulsion Drive
Drive - Section 11 - Clutch And V.S. Sheaves - Mechanical
Drive - Section 11 - Clutch Housing And Linkage - Mechanical
Drive - Section 11 - Hydrostatic Drive (Serial No. 1-)
Drive - Section 11 - Charge Pump - Hydrostatic Propulsion
Drive - Section 11 - Hydrostatic Unit
Drive - Section 11 - Tank And Lines - Hydrostatic Propulsion
Drive - Section 11 - Transmission (Serial No. 1-)
Drive - Section 11 - Differential (Serial No. 1-)
Drive - Section 11 - Disc Brakes (Serial No. 1-)
Drive - Section 11 - Final Drive (Serial No. 1-)
Miscellaneous - Section 12 - Non-Adjustable Rear Axle
Miscellaneous - Section 12 - Adjustable Rear Axle (Serial
Miscellaneous - Section 12 - Main Body
Miscellaneous - Section 12 - Shields - Right Hand
Miscellaneous - Section 12 - Shields - Left Hand
Miscellaneous - Section 12 - Lights
Accessories - Section 13 - Chaffers - Shoe (Accessory)
Accessories - Section 13 - Cleaning Screens - Shoe
Accessories - Section 13 - Corn Cob Mix Attachment
Accessories - Section 13 - Straw Spreader (Accessory)
Accessories - Section 13 - Front Axle Extension (Accessory)
Accessories - Section 13 - Rotor Assembly - Crop Chopper
Accessories - Section 13 - Drive Assembly - Crop Chopper
Accessories - Section 13 - Housing And Spreader Assembly -
Accessories - Section 13 - Corn Kit - Crop Chopper
Accessories - Section 13 - Windshield Wiper - Cab
Accessories - Section 13 - Propulsion Drive Shields
Accessories - Section 13 - Engine Hourmeter (Accessory)
Accessories - Section 13 - Tachometer And Rivet Extractor
Accessories - Section 13 - Feeder Stand (Accessory)
Accessories - Section 13 - De-Icer Kit (318 Gas)
Accessories - Section 13 - Muffler Field Kit (Serial No. 1-)
Accessories - Section 13 - Floating Cutter Bar (Rivetted
Accessories - Section 13 - Floating Cutter Bar (Bolted
Accessories - Section 13 - Monitor System (Accessory)
Accessories - Section 13 - Cab Air Conditioner
Accessories - Section 13 - Compressor Mounting And Hoses
Accessories - Section 13 - Compressor & Drive Pulley -
Accessories - Section 13 - Compressor & Drive Pulley - York
Accessories - Section 13 - Wiring (Air Conditioner)
Accessories - Section 13 - Cab Heater (Serial No. 1-)
Accessories - Section 13 - Rear Weights (Serial No. 1-)
Accessories - Section 13 - Rear Ladder (Serial No. 1-)
Paint (Not Illustrated) (Serial No. 1-)
7600 Decals (Not Illustrated) (Serial No. 1-)
Brand: New Idea
- New Idea Air Planter 9000 Series Parts Catalog 988014A
- New Idea Combine 525 2890 Parts Catalog W448076
- New Idea Combine 545 4296 Parts Catalog W448070
- New Idea Combine 5542 Parts Catalog W448068B
- New Idea Combine 555 5555 5297 Parts Catalog W448078
- New Idea Combine 710 Edible Bean Harvester 712 Grain Platform 711 Parts Catalog 986330
- New Idea Combine 7300 Parts Catalog W448069B
- New Idea Combine 7800 Parts Catalog W448067
- New Idea Corn Head 720 723 724 725 728 730 731 733 734 735 738 Parts Catalog US61
- New Idea Corn Picker 300 Two-Row 10 One-Row 302 One-Row Snapper Parts Catalog 986344
- New Idea Corn Picker 6 6A 6 Special 7 8 Parts Catalog 986342
- New Idea Double Frame Pull Type Planter And Row Units 900 Series Parts Catalog 986680
- New Idea Draper Header 5000 18-22-25-30-36 CTR 22-25-30 DBL SW Parts Catalog 00732147
- New Idea Forage Harvester 760 Superchopper 767 Pickup 761 766 Parts Catalog 986334
- New Idea Forward Fold Pull Type Planter 900 Series Parts Catalog 986780
