New Idea Windrower Tractor 5830 5830X Parts Catalog 00721022
Brand: New Idea
Type of Machine: Windrower Tractor
Model:
New Idea 5830 Windrower Tractor
New Idea 5830X Windrower Tractor
Part Number: 00721022
Number of Pages: 329 Pages
Publication Information
Engine - Engine (Front)
Engine - U-Joint Assembly (Front), (700708536 U-Joint Assembly)
Engine - Engine (Rear)
Engine - U-Joint Assembly (Rear), (700708535 U-Joint Assembly)
Engine - Engine, Air Cleaner And Hoses (80hp), (5830)
Engine - Engine Exhaust And Mounting (5830 80hp)
Engine - Engine, Air Cleaner And Hoses (110hp), (5830x)
Engine - Engine Exhaust And Mounting (110hp), (5830x)
Engine - Air Cleaner Assembly, (700716744 Air Cleaner Assembly)
Engine - Radiator, Hoses And Mounting
Engine - Throttle, Linkage And Mounting (80hp), (5830)
Engine - Throttle, Linkage And Mounting (110hp), (5830x)
Fuel And Air - Fuel Tank And Mounting
Fuel And Air - Fuel Line (5830 80hp)
Fuel And Air - Fuel Line (5830x 110hp)
Electrical - Steering Column And Gauge (5830x)
Electrical - Console (Gauges)
Electrical - Control Housing And Harness
Electrical - Console Wire Harness
Electrical - Console Panel Wiring Assembly
Electrical - Control Frame And Ground Speed Cable
Electrical - Console Wiring Harness
Electrical - Control Handle And Mounting
Electrical - Control Handle Assembly
Electrical - Control Panel Assembly
Electrical - Cab Light (Upper Front)
Electrical - Cab Lights (Rear)
Electrical - Engine Wiring
Electrical - Engine Wiring-Continued
Electrical - Hydraulic Valve Wiring Harness
Electrical - Hydraulic Valve Wiring Harness (Hay), (110 Hp)
Electrical - Valve Wiring Harness (2 Speed Grain)
Electrical - Flasher Light
Electrical - Electrical Harness Service Parts
Electrical - Electrical Harness Service Parts-Continued
Electrical - Electrical Harness Service Parts-Cont.
Brake And Steering - Brake And Neutral Lock
Brake And Steering - Neutral Lock Assembly
Brake And Steering - Transmission Controls
Brake And Steering - Brake (Left And Right)
Brake And Steering - Tensioner Assembly
Brake And Steering - Hydraulic Servo-Control Assembly, (700715442 Servo-Control Assembly)
Brake And Steering - Transmission Controls (Continued)
Brake And Steering - Steering Assembly, (700726288 U-Joint Assembly-Steering)
Power Train - Chaincase Assembly (Left)
Power Train - Chaincase Assembly (Right)
Power Train - Hub And Axle Assembly
Mainframe, Cab, Wheels And Shields - Front Shield And Link
Mainframe, Cab, Wheels And Shields - Header Link Assembly (Upper)
Mainframe, Cab, Wheels And Shields - Platform, And Handrail (Right)
Mainframe, Cab, Wheels And Shields - Tool Box
Mainframe, Cab, Wheels And Shields - Platform, Handrail And Step (Left)
Mainframe, Cab, Wheels And Shields - Cab Frame, Mirror And Shield
Mainframe, Cab, Wheels And Shields - Cab Windshield And Mounting, (700150295 Cab And Glass Assembly)
Mainframe, Cab, Wheels And Shields - Cab Door
Mainframe, Cab, Wheels And Shields - Cab Glass (Right And Rear)
Mainframe, Cab, Wheels And Shields - Cab Roof Cap
Mainframe, Cab, Wheels And Shields - Cab Headliner And Hinge
Mainframe, Cab, Wheels And Shields - Steering Column Shields And Mounting
Mainframe, Cab, Wheels And Shields - Steering Column Assembly
Mainframe, Cab, Wheels And Shields - Cab Upholstery
Mainframe, Cab, Wheels And Shields - Cab Insulation
Mainframe, Cab, Wheels And Shields - Seat Assembly (Air Ride)
Mainframe, Cab, Wheels And Shields - Air Conditioner
Mainframe, Cab, Wheels And Shields - Air Conditioner And Heater
Mainframe, Cab, Wheels And Shields - Condenser And Compressor
Mainframe, Cab, Wheels And Shields - Cab Filter
Mainframe, Cab, Wheels And Shields - Radiator Support
Mainframe, Cab, Wheels And Shields - Fan Shroud And Cooler Support
Mainframe, Cab, Wheels And Shields - Hood
Mainframe, Cab, Wheels And Shields - Hood (Continued)
Mainframe, Cab, Wheels And Shields - Door Mounting
Mainframe, Cab, Wheels And Shields - Door, (700152508 Door Assembly)
Mainframe, Cab, Wheels And Shields - Fixed Screen
Mainframe, Cab, Wheels And Shields - Rotary Screen (1 Inch Shaft)
Mainframe, Cab, Wheels And Shields - Rotary Screen (Continued)
Mainframe, Cab, Wheels And Shields - Battery Boxes And Mounting
Mainframe, Cab, Wheels And Shields - Lift Arm And Flotation-Left (Hay)
Mainframe, Cab, Wheels And Shields - Lift Arm And Flotation-Right (Hay)
Mainframe, Cab, Wheels And Shields - Lift Arm And Flotation-Left (Grain)
Mainframe, Cab, Wheels And Shields - Lift Arm And Flotation-Right (Grain)
Mainframe, Cab, Wheels And Shields - Tail Wheel And Step-Left (Hay)
Mainframe, Cab, Wheels And Shields - Tail Wheel And Axle-Right (Hay)
Mainframe, Cab, Wheels And Shields - Tail Wheel And Step-Left (Grain)
Mainframe, Cab, Wheels And Shields - Tail Wheel And Axle-Right (Grain)
Mainframe, Cab, Wheels And Shields - Wheel And Tire (Left And Right)
Hydraulics - Hydraulic Drive-Left
Hydraulics - Hydraulic Drive-Right
Hydraulics - Pump Assembly (Double), (700719771 Hydraulic Pump Assembly)
Hydraulics - Hydraulic Gear Pump Assembly, (700718753 Hydraulic Gear Pump Assembly)
Hydraulics - Motor-Left
Hydraulics - Motor-Right
Hydraulics - Hydraulic Motor Assembly (Wheel Drive), (700716762 Hydraulic Motor Assembly)
Hydraulics - Hydraulic Drive (2 Speed), (S.N. Hk08173 Thru Hl08100)
Hydraulics - Hydraulic Drive-Continued (2 Speed), (S.N. Hk08173 Thru Hl08100)
Hydraulics - Hydraulic Drive (2 Speed), (S.N. Hl08101 And Later)
Hydraulics - Hydraulic Cylinder Assembly (2-Speed), (700726495 Hydraulic Cylinder Assembly), (S.N. Hk08173 And Hl08100)
Hydraulics - Transmission Controls And Brake (2 Speed), (S.N Hk08173 Thru Hl08100)
Hydraulics - Brake (2 Speed), (S.N. Hl08101 And Later)
Hydraulics - Variable Motor Assembly-Left, (700718762 Variable Motor Assembly), (S.N. Hk08173 Thur Hl08100)
Hydraulics - Variable Motor Assembly-Right, (700715450 Variable Motor Assembly), (S.N. Hk08173 Thru Hl08100)
Hydraulics - Hydraulic Motor Assembly (2 Speed), (700725726 Hydraulic Motor Assembly), (S.N. Hl08101 And Later)
Hydraulics - Hydraulic Valve Assembly (2 Speed), (700725727 Valve Assembly-2 Speed)
Hydraulics - Hydraulic Cooler, Filter And Manifold
Hydraulics - Hydraulic Reservoir
Hydraulics - Manifold And Oil Filter
Hydraulics - Header Lift Hydraulic
Hydraulics - Hydraulic Header Lift (Continued)
Hydraulics - Hydraulic Accumulator Assembly, (700713363 Hydraulic Accumulator Asm.)
Hydraulics - Hydraulic Valve Assembly (5830x), (Single Speed Grain), (700716748 Hydraulic Valve Assembly)
Hydraulics - Hydraulic Valve Assembly (5830), (700715512 Hydraulic Valve Assembly), (Single Speed)
Hydraulics - Hydraulic Manifold Assembly, (700715497 Hydraulic Manifold Assembly)
Hydraulics - Hydraulic Manifold Assembly, (700715325 Hydraulic Manifold Assembly)
Hydraulics - Hydraulic Valve Assembly (5830x), (2-Speed Grain), (700719512 Hydraulic Valve Assembly)
Hydraulics - Hydraulic Valve Assembly (5830x), (700715639 Hydraulic Valve Assembly), (2 Speed Hay)
Hydraulics - Hydraulic Slave Cylinder Assembly-Right, (700719601 Hydraulic Cylinder Assembly)
Hydraulics - Hydraulic Master Cylinder Assembly-Left, (700719600 Hydraulic Cylinder Assembly)
Hydraulics - Hydraulic Cylinder Assembly-Left, (700728108 Hydraulic Cylinder Assembly)
Hydraulics - Hydraulic Cylinder Assembly-Right, (700728107 Hydraulic Cylinder Assembly)
Hydraulics - Oil Reservoir And Mounting
Hydraulics - Hydraulic Header Drive
Hydraulics - Hydraulic Header Drive (Continued)
Hydraulics - Header Drive Hydraulic Pump Assembly, (700706979 Header Drive Pump Assembly)
Hydraulics - Header Drive Motor Assembly, (700706977 Header Drive Motor Assembly)
Hydraulics - Header Control (Standard)
Hydraulics - Hydraulic Two Speed Control Valve Asm., (700715996 Two Speed Control Valve Asm.)
Hydraulics - Actuator Assembly
Hydraulics - Hydraulic Cylinder Assembly (Actuator), (700725130 Hydraulic Cylinder Assembly)
Hydraulics - Draper Hydraulic
Hydraulics - Hydraulic Header Angle Tilt (5830x)
Hydraulics - Hydraulic Cylinder Assembly-Header Tilt, (700728106 Hydraulic Cylinder Assembly), (Energy)
Hydraulics - Hydraulic Cylinder Assembly (Energy), (700721577 Hydraulic Cylinder Assembly)
Decals And Kits - Decals And Location Diagram (5830)
Decals And Kits - Decals And Location Diagram (5830x)
Decals And Kits - Decals And Location Diagram (Operational)
Decals And Kits - Decals And Location Diagram Continued, (Operational)
Decals And Kits - Decals And Location Diagram (Control Panel)
Decals And Kits - Windshield Wiper Kit, (Nk60908 Windshield Wiper Kit), (Earlier)
Decals And Kits - Windshield Wiper Kit, (Nk61083 Windshield Wiper Kit), (Later)
Decals And Kits - Auxiliary Seat Kit, (Nk60916 Auxiliary Seat Kit Assembly)
Decals And Kits - Rotary Screen Kit (5 8 Inch Shaft), (Nk60949 Rotary Screen Kit), (Earlier)
Decals And Kits - Rotary Screen Kit (1 Inch Shaft), (Nk61025 Rotary Screen Kit), (Later)
Decals And Kits - Speedometer Kit, (Nk60950 Speedometer Kit)
Decals And Kits - Weight Kit, (Nk61154 Weight Kit)
Decals And Kits - Guard Angle Tilt Kit, (Nk60946 Guard Angle Tilt Kit)
Decals And Kits - Hydraulic Manifold Assembly, (700715497 Hydraulic Manifold Assembly)
Decals And Kits - Actuator Assembly
Decals And Kits - Hydraulic Cylinder Assembly-Header Tilt, (700728106 Hydraulic Cylinder Assembly), (Energy)
Decals And Kits - Hydraulic Cylinder Assembly (Energy), (700721577 Hydraulic Cylinder Assembly)
Decals And Kits - Draper Adapter Kit, (Nk60922 Draper Adapter Kit)
Decals And Kits - Header Reverse Kit, (Nk60907 Header Reverse Kit)
Decals And Kits - Hydraulic Header Neutral Valve Assembly, (700718658 Header Neutral Valve Asm.)
Decals And Kits - Hydraulic Two Speed Control Valve Asm., (700715996 Two Speed Control Valve Asm.)
Decals And Kits - Noise Reduction Kit, (Nk60999 Noise Reduction Kit)
Decals And Kits - 5000 Header Adapter Kit, (Nk61035 5000 Header Apapter Kit)
Decals And Kits - 5000 Header Adapter Kit-Continued, (Header Pump Stop Assembly)
Decals And Kits - Manifold Assembly, (700726384 Manifold Assembly)
Decals And Kits - Recommended Dealer Stock
