New Idea Uni-Power Unit 803A Parts Catalog 986321
Brand: New Idea
Type of Machine: Uni-Power Unit
Model: New Idea 803A Uni-Power Unit
Part Number: 986321
Number of Pages: 134 Pages
Publication Information
Main Frame, Lower Side Sheets, Engine - Doors And Engine
Top Rails, Wheel Shields, Battery And - Hydraulic Tank Mounts (Lot No. Us 377-)
Fuel Tank, Rear Ladder And Fuel System - - Tank To Pump (Lot No. Us 377-)
Air Cleaner And Air Intake - (Lot No. Us 377-)
Radiator, Fan Shaft And Engine Cooling - System (Lot No. Us 377-)
Main Drive Gear Box And Coupler To - Engine (Lot No. Us 377-)
Implement Idler (Lot No. Us 377-)
Transmission (Lot No. Us 377-)
Brakes (Lot No. Us 377-)
Wheel End, Axles, Spacers And Rims
Rear Axle (Lot No. Us 377-)
Hub And Spindle For Standard Rear Axle - (Lot No. Us 377-)
Steering Cylinder Standard And Power - Guide Axle (Lot No. Us 377-)
Hub And Spindle, Power Guide Axle - (Lot No. Us 377-)
Power Guide Axle, Hydraulic Circuit - (Lot No. Us 377-)
Power Guide Axle Solenoids (P.G.A. - Control Valve With Solenoid) (P.G.A., Control Valve Without Solenoid) (Lot No., Us 377-)
Charge Pump (Lot No. Us 377-)
Hydrostatic Pump (Lot No. Us 377-)
Hydrostatic Motor (Lot No. Us 377-)
Hydrostatic System (Lot No. Us 377-)
Hydraulic Tank And Drain - (Lot No. Us 377-)
Hydraulic Air Cooler (Lot No. Us 377-)
Standard Hydraulic Circuit - Tank To Standard Hydraulic Pump
Standard Hydraulic System - Pump To Front Lift Cylinder (Lot No. Us 377-)
Standard Hydraulic System With Optional - Automatic Header Height Control To, Front Lift Cylinder (Lot No. Us 377-)
Standard 3 Spool Valve (Lot No. Us 377-)
Load Sensing Flow Divider - (Lot No. Us 377-)
Front Lift Cylinder Circuit - (Lot No. Us 377-)
Hydraulic Steering Circuit - (Lot No. Us 377-)
Optional Hydraulic Circuit - Tank To Standard And Optional
Optional 2 Spool Valve And Rear Outlets - (Lot No. Us 377-)
Hydraulic Pumps Standard And Optional - (Lot No. Us 377-)
Cab, Wiper, Ladder (Lot No. Us 377-)
Cab Roof, Side And Rear Air Screens - (Lot No. Us 377-)
Console (Lot No. Us 377-)
Upper Control Console And Cab Blower - (Lot No. Us 377-)
Steering Column And Motor (Lot No. Us - 377-)
Brake Pedals, Lines And Master Cylinder - (Lot No. Us 377-)
Air Conditioning System (Lot No. Us - 377-)
Air Conditioner Compressor (Lot No. Us - 377-)
Seat (Lot No. Us 377-)
Optional Ladder Extension - (Lot No. Us 377-)
Optional Rear Weight Bracket And Tow Bar - (Lot No. Us 377-)
Cab Lighting And Wiring
Gauge And Sensor Circuit - (Lot No. Us 377-)
Convenience Control Circuit - (Lot No. Us 377-)
Starting And Charging Circuit - (Lot No. Us 377-)
Block, Flywheel Housing And Dip Stick - (Lot No. Us 377-)
Front Cover, Water Pump, Camshaft, Oil - Fill And Thermostat Housing, (Lot No. Us 377-)
Cylinder Head, Valve Cover And Valve - Train (Lot No. Us 377-)
Oil Pan, Pump, Cooler And Filters - (Lot No. Us 377-)
Crankshaft And Coupler (Lot No. Us 377-)
Connecting Rod And Piston - (Lot No. Us 377-)
Oil Pump (Lot No. Us 377-)
Fuel Lines And Injection Pump - (Lot No. Us 377-)
Manifold And Turbocharger (Lot No. Us - 377-)
Alternator (Lot No. Us 377-)
Repair For Roller Chain
Repair For Steel Chain And Paint
