New Idea Uni-Power Unit 802 Parts Catalog 986272
Brand: New Idea
Type of Machine: Uni-Power Unit
Model: New Idea 802 Uni-Power Unit
Part Number: 986272
Number of Pages: 147 Pages
Publication Information
Directions For Ordering Repair Parts
Main Frame, Lower Side Sheets, Engine - Doors And Engine
Top Rails, Hood, Wheel Shields, Fan - Shaft Mounts, Battery
Implement Idler - (Lot No. Us 323-)
Fuel Tank, Fuel Lines And Rear Ladder - (Lot No. Us 323 Only)
Fuel Tank, Fuel Lines And Rear Ladder - (Lot No. Us 350-)
Engine Cooling System - (Lot No. Us 323-)
Engine Air Intake System - (Lot No. Us 323-)
Transmission - (Lot No. Us 323-)
Parking Brake - (Lot No. Us 323-)
Wheel End, Left Hand Shown, Right Hand - Same, (Lot No. Us 323-)
Rear Weight Bracket And Tow Bar - (Lot No. Us 323-)
Main Drive Gear Box (Lot No. 323-)
Standard And Power Guide Axle Steering - Cylinder, (Lot No. Us 323-)
Rear Axle And Clamping Assembly Standard - And Power Guide Axles (Lot No. Us 323-)
Power Guide Axle Circuit - (Lot No. Us 323-)
Rear Wheel Motor, Gear Reduction Unit, - Hub And Spindle Assembly And Rim - Power, Guild Axle, (Lot No. Us 323-)
Hub And Spindle Assembly, Rim, Standard - Rear Axle, (Lot No. Us 323-)
Charge Pump - (Lot No. Us 323-)
Hydrostatic Motor - (Lot No. Us 323-)
Hydrostatic Pump - (Lot No. Us 323-)
Hydrostatic System (Lot No. Us 323 -) - (Lot No. Us 323-)
Steering Circuit - (Lot No. Us 323-)
Hydraulic Tank - Supply And Return Lines (Lot No. Us 323-)
Hydraulic Oil Cooler - (Lot No. Us 323-)
Hydraulic Tank Filter And Drain - (Lot No. Us 323-)
Hydraulic 3 Spool Valve Block - (Lot No. Us 323-)
Hydraulic Pump - (Lot No. Us 323 -)
Variable Speed Hydraulic Control Valve - (Lot No. Us 323 -)
Header Lift Cylinder And Lift Cylinder - Hydraulic Circuit, (Lot No. Us 323 -)
Hydraulic Supply Lines, Auxiliary Lines - And Front Ports, (Lot No. Us 323 -)
Cab Wiper And Ladder - (Lot No. Us 323 -)
Cab Roof, Side And Rear Air Screens - (Lot No. Us 323-)
Steering Column And Motor - (Lot No. Us 323-)
Seat - (Lot No. Us 323-)
Upper Control Console And Cab Blower - (Lot No. Us 323-)
Air Conditioning System - (Lot No. Us 323-)
Air Conditioning Compressor - (Lot No. Us 323-)
Hydraulic Control Levers - (Lot No. Us 323-)
Brake Pedals And Master Cylinder - (Lot No. Us 323-)
Gear Shift Linkage, Hydrostatic Control - Lever, Flow Control Valve Linkage, Lower Console And Decals, (Lot No. Us 323-)
Duals And Ladder Extensions - (Lot No. Us 323-)
Front Drive Axle Extensions - (Lot No. Us 323-)
Front Drive Axle Spacer - (Lot No. Us 323-)
Automatic Header Height Hydraulic - Circuit (Lot No. Us 323-)
Optional Rear Hydraulic Lines - (Lot No. Us 323-)
Optional Two Spool Valve - (Lot No. Us 323-)
Console Switches, Tachometer And - Automatic Header Height Wiring Harness, (Lot No. Us 323-)
Cab Lighting (Lot No. Us 323 -)
Console Gauges, Light Switches, Circuit - Breakers And Wiring
Engine Wiring Harness - (Lot No. Us 323-)
Block, Flywheel Housing And Dip Stick - (Lot No. Us 323-)
Cylinder Head, Valve Cover And Valve - Train, (Lot No. Us 323-)
Oil Pan, Pump Cooler, And Filters - (Lot No. Us 323-)
Crankshaft And Coupler - (Lot No. Us 323-)
Connecting And Piston - (Lot No. Us 323-)
Fuel Lines, Filters And Injection Pump - (Lot No. Us 323
Fuel Lines And Injection Pump - (Lot No. Us 350-)
Manifolds And Turbocharger - (Lot No. Us 323-)
Oil Pump - (Lot No. Us 323-)
Oil Pump - (Lot No. Us 350-)
Attaching Parts, Right Hand - (Lot No. Us 323-)
Attaching Parts, Left Hand - (Lot No. Us 323-)
Alternator - (Lot No. Us 323-)
Hand Primer Pump - (Lot No. Us 323 Only)
Repair For Roller Chain
Repair For Steel Chain And Paint
Brand: New Idea
Part Number: 986272
- New Idea Air Planter 9000 Series Parts Catalog 988014A
- New Idea Combine 525 2890 Parts Catalog W448076
- New Idea Combine 545 4296 Parts Catalog W448070
- New Idea Combine 5542 Parts Catalog W448068B
- New Idea Combine 555 5555 5297 Parts Catalog W448078
- New Idea Combine 710 Edible Bean Harvester 712 Grain Platform 711 Parts Catalog 986330
- New Idea Combine 7300 Parts Catalog W448069B
- New Idea Combine 7600 Parts Catalog W448064A
- New Idea Combine 7800 Parts Catalog W448067
- New Idea Corn Head 720 723 724 725 728 730 731 733 734 735 738 Parts Catalog US61
- New Idea Corn Picker 300 Two-Row 10 One-Row 302 One-Row Snapper Parts Catalog 986344
- New Idea Corn Picker 6 6A 6 Special 7 8 Parts Catalog 986342
- New Idea Double Frame Pull Type Planter And Row Units 900 Series Parts Catalog 986680
- New Idea Draper Header 5000 18-22-25-30-36 CTR 22-25-30 DBL SW Parts Catalog 00732147
- New Idea Forage Harvester 760 Superchopper 767 Pickup 761 766 Parts Catalog 986334
