New Idea Uni-Power Unit 801 Parts Catalog 986057
Brand: New Idea
Type of Machine: Uni-Power Unit
Model: New Idea 801 Uni-Power Unit
Part Number: 986057
Number of Pages: 132 Pages
Publication Information
General - Allis Chalmers, 6 Cylinder Turbocharged, Diesel
General - Top Rails, Hood, Wheel Shields, Battery, And
General - Fuel Tank And Rear Ladder
General - Implement Idler
General - Aspirator And Air Intake System
General - Engine Cooling System
General - Main Gearbox And Coupler To Engine
General - Transmission
General - Parking Brake
General - Final Drive Wheel End And Wheel Brake, (Left Hand
General - Rear Weight Bracket And Drawbar
General - Rear Axle And Clamping Assembly
General - Standard Rear Axle Hub And Spindle
General - Steering Cylinder (Standard And P.G.A.)
General - Powered Guide Axle Gear Reduction Unit, And Hub
General - Hydraulic Oil Tank, Filters, Supply And, Return
General - Oil Cooler And Lines
General - Variable Flow Control Valve And Lines
General - Hydraulic Pump, Load Sensing Flow, Divider And
General - Hydraulic Control Valve, Return Manifold, And Lines
General - Hydraulic Lines And Ports, (Front And Rear)
General - Header Height Control Valve
General - Load Sensing Flow Divider
General - Header Lift Cylinder Circuit And Lift, Cylinder
General - Steering System And Hydraulics
General - Hydrostatic System
General - Hydrostatic Motor
General - Hydrostatic Pump
General - Charge Pump
General - P.G.A. Control Valve With Solenoid
General - Powered Guide Axle Circuit
General - Cab
General - Cab Roof, Air Screen And Cab Heater
General - Air Conditioning System
General - Steering Column, Steering Motor, Parking, Brake
General - Gear Shift Linkage, Hydrostatic Control, Lever,
General - Hydraulic Control Valve Linkage And, Middle Console
General - Upper Control Console And Cab Blower
General - Cab Wiring Harness, Gauges, Switches And, Lighting
General - Engine Wiring Harness And Battery Cables
General - Auxiliary Lighting,
General - Seat
General - Brake Pedals And Master Cylinder
Allis Chalmers 6 Cylinder Engine - Block, Flywheel Housing
Allis Chalmers 6 Cylinder Engine - Front Cover, Water Pump,
Allis Chalmers 6 Cylinder Engine - Cylinder Head, Valve Cover
Allis Chalmers 6 Cylinder Engine - Oil Pan, Pump, Cooler And
Allis Chalmers 6 Cylinder Engine - Crankshaft And Coupler
Allis Chalmers 6 Cylinder Engine - Connecting Rod And Piston
Allis Chalmers 6 Cylinder Engine - Fuel Lines, Filters And
Allis Chalmers 6 Cylinder Engine - Manifolds And Turbocharger
Allis Chalmers 6 Cylinder Engine - Oil Pump (Lot No. Us 279 -
Allis Chalmers 6 Cylinder Engine - Attaching Parts, Right
Allis Chalmers 6 Cylinder Engine - Attaching Parts, Left Hand
Allis Chalmers 6 Cylinder Engine - Primer Pump
Allis Chalmers 6 Cylinder Engine - Alternator
Allis Chalmers 6 Cylinder Engine - Repair For Steel Chain And
Allis Chalmers 6 Cylinder Engine - Repair For Roller Chain, (Not Illustrated)
Brand: New Idea
Part Number: 986057
General - Cab
General - Seat
- New Idea Air Planter 9000 Series Parts Catalog 988014A
- New Idea Combine 525 2890 Parts Catalog W448076
- New Idea Combine 545 4296 Parts Catalog W448070
- New Idea Combine 5542 Parts Catalog W448068B
- New Idea Combine 555 5555 5297 Parts Catalog W448078
- New Idea Combine 710 Edible Bean Harvester 712 Grain Platform 711 Parts Catalog 986330
- New Idea Combine 7300 Parts Catalog W448069B
- New Idea Combine 7600 Parts Catalog W448064A
- New Idea Combine 7800 Parts Catalog W448067
- New Idea Corn Head 720 723 724 725 728 730 731 733 734 735 738 Parts Catalog US61
- New Idea Corn Picker 300 Two-Row 10 One-Row 302 One-Row Snapper Parts Catalog 986344
- New Idea Corn Picker 6 6A 6 Special 7 8 Parts Catalog 986342
- New Idea Double Frame Pull Type Planter And Row Units 900 Series Parts Catalog 986680
- New Idea Draper Header 5000 18-22-25-30-36 CTR 22-25-30 DBL SW Parts Catalog 00732147
- New Idea Forage Harvester 760 Superchopper 767 Pickup 761 766 Parts Catalog 986334
