New Idea Uni-Power Unit 800 Parts Catalog 986269
Brand: New Idea
Type of Machine: Uni-Power Unit
Model: New Idea 800 Uni-Power Unit
Part Number: 986269
Number of Pages: 150 Pages
Publication Information
Directions For Ordering Repair Parts
Main Frame, Lower Side Sheets, Engine
Top Rails, Hood, Wheel Shields, Fan - Shaft Mounts, Batter
Implement Idler - (Lot Us 321-)
Fuel Tank, Line, Fuels And Rear Ladder - (Lot Us 321-331)
Fuel Tank, Line, Fuels And Rear Ladder - (Lot Us 349-)
Engine Cooling System - (Lot Us 321-)
Engine Air Intake System - (Lot Us 321-)
Transmission - (Lot Us 321-)
Parking Brake - (Lot Us 321-)
Wheel End, Left Hand Shown, Right Hand - Same, (Lot Us 321-)
Rear Weight Bracket And Tow Bar - (Lot Us 321-)
Main Drive Gear Box - (Lot Us 321-)
Standard And Power Guide Axle Steering - Cylinder, (Lot Us 321-)
Rear Axle And Clamping Assembly Standard - And Power Guide Axles, (Lot Us 321-)
Power Guide Axle Circuit - (Lot Us 321-)
Rear Wheel Motor, Gear Reduction Unit, - Hub And Spindle Assembly And Rim---Power, Guide Axle, (Lot Us 321-)
Hub And Spindle Assembly, Rim, Standard - Rear Axle, (Lot Us 321-)
Charge Pump - (Lot Us 321-)
Hydrostatic Motor - (Lot Us 321-)
Hydrostatic Pump
Hydrostatic System
Steering Circuit - (Lot Us 321-)
Hydraulic Tank - Supply And Return Lines (Lot Us 321-)
Hydraulic Oil Cooler
Hydraulic Tank Filters And Drain - (Lot Us 321-)
Hydraulic 3 Spool Valve Block
Hydraulic Pump - (Lot Us 321-)
Variable Speed Hydraulic Control Valve - (Lot Us 321-)
Header Lift Cylinder And Lift Cylinder - (Lot Us 321-)
Hydraulic Supply Lines, Auxiliary Lines - And Front Ports, (Lot Us 321-)
Cab Wiper And Ladder - (Lot Us 321-)
Cab Roof, Side And Rear Air Screens
Steering Column And Motor - (Lot Us 321-)
Seats - (Lot Us 321-)
Air Conditioning System - (Lot Us 321-)
Air Conditioner Compressor
Hydraulic Control Levers - (Lot Us 321-)
Brake Pedals And Master Cylinders - (Lot Us 321-)
Upper Control Console And Cab Blower - (Lot Us 321-)
Gear Shift Linkage, Hydrostatic Control - Lever, Flow Control Valve Linkage, Lower, Console And Decals
Duals And Ladder Extensions - (Lot Us 321-)
Front Drive Axle Extensions - (Lot Us 321-)
Automatic Header Height Hydraulic - Circuit, (Lot Us 321-)
Optional Rear Hydraulic Lines - (Lot Us 321-)
Optional Two Spool Valve - (Lot Us 321-)
Console Switches, Tachometer And - Automatic Header Height Wiring Harness, (Lot Us 321-)
Cab Lighting
Console Gauges, Light Switches, Circuit - Breakers And Wiring
Engine Wiring Harness
Perkins, 6 Cylinder, Turbocharged Engine - Section, (Lot Us
Front Cover, Injector Pump Drive, Tone - Wheel And Pump Coupler, (Lot Us 321-)
Head, Thermostat Housing, Valves And - Block Heater, (Lot Us 321-)
Oil Pan And Oil Pump - (Lot Us 321-)
Engine Oil Cooler And Oil Filters - (Lot Us 321-)
Manifolds And Turbocharger - (Lot Us 321-)
Valve Cover - (Lot Us 321-)
Water Pump And Alternator - (Lot Us 321-)
Starter And Flywheel Housing - (Lot Us 321-)
Rocker Arm Shaft - (Lot Us 321-)
Injection Pump Linkage
Injection Pump, Injectors And Lines - (Lot Us 321-)
Fuel Filters And Lift Pump
Ether Starting Aid - (Lot Us 321-)
Starter - (Lot Us 331-)
Repair For Steel Chain And Paint - (Not Illustrated)
Repair For Roller Chain - (Not Illustrated)
Brand: New Idea
Part Number: 986269
Hydrostatic Pump
Hydrostatic System
Cab Lighting
- New Idea Air Planter 9000 Series Parts Catalog 988014A
- New Idea Combine 525 2890 Parts Catalog W448076
- New Idea Combine 545 4296 Parts Catalog W448070
- New Idea Combine 5542 Parts Catalog W448068B
- New Idea Combine 555 5555 5297 Parts Catalog W448078
- New Idea Combine 710 Edible Bean Harvester 712 Grain Platform 711 Parts Catalog 986330
- New Idea Combine 7300 Parts Catalog W448069B
- New Idea Combine 7600 Parts Catalog W448064A
- New Idea Combine 7800 Parts Catalog W448067
- New Idea Corn Head 720 723 724 725 728 730 731 733 734 735 738 Parts Catalog US61
- New Idea Corn Picker 300 Two-Row 10 One-Row 302 One-Row Snapper Parts Catalog 986344
- New Idea Corn Picker 6 6A 6 Special 7 8 Parts Catalog 986342
- New Idea Double Frame Pull Type Planter And Row Units 900 Series Parts Catalog 986680
- New Idea Draper Header 5000 18-22-25-30-36 CTR 22-25-30 DBL SW Parts Catalog 00732147
- New Idea Forage Harvester 760 Superchopper 767 Pickup 761 766 Parts Catalog 986334
