New Idea Uni-Power Unit 709 Parts Catalog 986171
Brand: New Idea
Type of Machine: Uni-Power Unit
Model: New Idea 709 Uni-Power Unit
Part Number: 986171
Number of Pages: 159 Pages
Publication Information
Directions For Ordering Repair Parts
Main Frame, Lower Side Sheets, Fuel Tank - Motor Mounts And
Top Side Rails, Rear Hood, And Wheel - Shield
Air Cleaner, Aspirator, Fan And - Jackshaft, Exhaust Pipe
Air Cleaner, Aspirator, Fan And - Jackshaft And Exhaust Pipe
Implement Idler
Wheel End, R.H. Shown, L.H. Same
Final Drive - Wheel End And Wheel Brake (L.H. Shown, R.H.
Main Drive Gearbox
Standard Rear Axle, Steering Cylinder, - Tow Bar, Weights And
Optional Powered Guide Axle And Steering - Cylinder
Rear Axle Gear Reduction Unit For Power - Guide Axle
Hydrostatic System - Pump, Motor And Cooler
Oil Cooler And Lines
Hydrostatic Lines - Standard Rear Axle
Hydrostatic Lines, Power Guide Axle
Hydrostatic Lines, Standard And P.G.A.
Reservoir Tank
Charge Pump
Hydrostatic Motor
Hydrostatic Pump
Lift Cylinder
Hydraulic System - Power Steering, Auxiliary Lines, Lift
Hydraulic Valve Block, Three Spool, And - Linkage
Variable Control Valve For Orbital Motor
Automatic Header Control
Auxiliary Lighting
Two Circuit Rear Auxiliary Hydraulic - Outlet
Hydraulic Circuit Valve Third Circuit - Rear Auxiliary Outlet
Orbital Motor For Combine Bin Stretcher - Or Housing Bed
Cab, Gauges, Switches And Ladder
Cab Roof, Air Screen And Wiper
Air Conditioner, Compressor, And Heater - Core
Air Conditioner Compressor
Console
Brake Pedals And Cylinders
Steering Column And Seat
Duals And Ladder Extensions
In Cab Throw Out
Front Drive Axle Extensions
Saddle Extensions
Standard Rear Steering Axle Extension - For Use With 769
Power Guide Axle Extension - For Use With 769 Flail-Mate
Electrical Wiring System
Allis Chalmers, 6 Cylinder, Motor Sect. - Block, Flywheel
Front Cover, Water Pump, Cam Shaft, Oil - Fill And Thermostat
Cylinder Head, Valve Cover And Valve - Train
Oil Pan, Pump, Cooler, And Filters
Hub And Coupler
Crankshaft And Coupler
Connecting Rod And Piston
Fuel Lines, Filter And Injection Pump
Manifolds And Turbo Charger
Oil Pump
Attaching Parts, Right Hand
Attaching Parts, Left Hand
Primer Pump
Alternator, 61 Amp.
Alternator, 72 Amp
Repair For Steel Chain And Paint
Repair For Roller Chain
