New Idea Uni-Power Unit 708 Parts Catalog 986161
Brand: New Idea
Type of Machine: Uni-Power Unit
Model: New Idea 708 Uni-Power Unit
Part Number: 986161
Number of Pages: 154 Pages
Directions For Ordering Repair Parts
Lower Main Frame, Side Sheets And Fuel Tank
Side Rails And Rear Hood
Air Cleaner, Fan Jackshaft, Radiator And Exhaust Stack
Implement Idler (Lot No. Us 221-291)
Wheel End R.H. Shown - L.H. Same (Lot No. Us 221-270)
Final Drive - Wheel End And Wheel Brake (Lot No. 277-291)
Main Drive Gearbox (Lot No. Us 221-291)
Standard Rear Axle, Steering Cylinder, Tow Bar, Weights And
Optional Powered Guide Axle And Steering Cylinder (Lot No.
Rear Axle Gear Reduction Unit For Power Guide Axle (Lot No.
Lift Cylinder (Lot No. Us 221-291)
Hydraulic Pump (Lot No. Us 221-291)
Hydraulic Valve Block Three Spool, And Linkage (Lot No. Us
Variable Control Valve For Orbital Motor (Lot No Us 221-260)
Variable Control Valve For Orbital Motor (Lot No Us 270-291)
Hydraulic System - Power Steering, Auxiliary Lines, Lift
Hydrostatic System - Pump, Motor And Cooler (Lot No. Us 221-
Oil Cooler And Lines
Hydrostatic Lines - Standard Rear Axle (Lot No. Us 243 Only)
Hydrostatic Lines, Powered Guide Axle (Lot No. Us 243 Only)
Hydrostatic Lines (Lot No. Us 260-291)
Reservoir Tank (Lot No Us 221-291)
Charge Pump (Lot No Us 221-291)
Hydrostatic Motor (Lot No Us 221-291)
Hydrostatic Pump (Lot No Us 221-291)
Automatic Header Control For Complete Package, Order Number
Auxiliary Lighting Package For Complete Package, Order
Two Circuit Rear Auxiliary Hydraulic Outlet For Complete
Hydraulic Circuit Valve Third Circuit Rear Auxillary Outlet
Orbital Motor For Combine Bin Stretcher Or Husking Bed
Cab, Gauges, Switches And Ladder (Lot No. Us 221-291)
Cab Roof, Air Screen, Wiper And Cab Blower
Air Conditioner System
Air Conditioner Compressor
Console
Brake Pedals And Cylinders (Lot No. Us 221-291)
Seats
Steering Column And Seat
Auxiliary Lighting (For Complete Package Order No. 709386)
Duals And Ladder Extensions (Lot No. Us 221-291)
In Cab Throw Out
Front Drive Axle Extensions
Saddle Extension
Standard Rear Steering Axle Extention For Use With 769
Power Guide Axle Entension For Use With 769 Flail-Mate
Electrical Wiring System (Lot No. Us 221-291)
Perkins, 6 Cylinder, Turgocharged Engine Sectiion - Block
Head And Valve Train (Lot No. Us 221-291)
Front Cover (Lot No. Us 221-291)
Hub And Coupler (Lot No. Us 221-291)
Crankshaft, Flywheel And Coupler (Lot No. Us 221-291)
Piston And Liner (Lot No. Us 221-291)
Water Pump (Lot No. Us 221-291)
Manifolds And Turbocharger (Lot No. Us 221-291)
Oil Pan And Pump (Lot No. Us 221-291)
Valve Cover (Lot No. Us 221-291)
Injection Pump And Injector (Lot No. Us 221-291)
Ether Starting Aid (For Complete Package Order 732301)
Attaching Parts, Right Hand (Lot No. Us 221-291)
Attaching Parts, Left Hand (Lot No. Us 221-291)
Alternator 72 Amp
Repair For Steel Chain And Paint - Repair For Roller Chain
Brand: New Idea
Part Number: 986161
Console
Seats
In Cab Throw Out
Saddle Extension
Alternator 72 Amp
- New Idea Air Planter 9000 Series Parts Catalog 988014A
- New Idea Combine 525 2890 Parts Catalog W448076
- New Idea Combine 545 4296 Parts Catalog W448070
- New Idea Combine 5542 Parts Catalog W448068B
- New Idea Combine 555 5555 5297 Parts Catalog W448078
- New Idea Combine 710 Edible Bean Harvester 712 Grain Platform 711 Parts Catalog 986330
- New Idea Combine 7300 Parts Catalog W448069B
- New Idea Combine 7600 Parts Catalog W448064A
- New Idea Combine 7800 Parts Catalog W448067
- New Idea Corn Head 720 723 724 725 728 730 731 733 734 735 738 Parts Catalog US61
- New Idea Corn Picker 300 Two-Row 10 One-Row 302 One-Row Snapper Parts Catalog 986344
- New Idea Corn Picker 6 6A 6 Special 7 8 Parts Catalog 986342
- New Idea Double Frame Pull Type Planter And Row Units 900 Series Parts Catalog 986680
- New Idea Draper Header 5000 18-22-25-30-36 CTR 22-25-30 DBL SW Parts Catalog 00732147
- New Idea Forage Harvester 760 Superchopper 767 Pickup 761 766 Parts Catalog 986334
