702,019
New Idea Uni-Power Unit 701 702 702D Parts Catalog 986364
Brand: New Idea
Type of Machine: Uni-Power Unit
Model:
New Idea 701 Uni-Power Unit
New Idea 702 Uni-Power Unit
New Idea 702D Uni-Power Unit
Part Number: 986364
Number of Pages: 350 Pages
Directions For Ordering
Lower Main Frame
Top Channels And Screens
Platform, Ladder
Platform And Ladder And Hand Brake
Radiator And Air Cleaner
Gas Tank And Top Sheet
Fuel Tank And Hood
Fuel Tank And Top Sheet
Fuel Tank And Hood (Lot No. Us 108 Only)
Rear Wheels And Bolster
Rear Wheels And Bolsters
Rear Wheels And Axle Tube Assembly
Seat And Hand Brake
Seat - Hand Brake - Battery Box (Lot No. Us 35 - 108)
Traction Drive Jack Shaft
Traction Drive Jackshaft
Variable Drive
Lift Cylinder (Regular) (Lot No. Us 2 - 13)
Lift Cylinder (Heavy Duty) (Lot No. Us 14 - 121)
Gear Shift Mechanism
Master Cylinders, Brake And Clutch Pedals
Hydraulic Clutch (Lot No. Us 47 - 1-121)
Main Drive Gear Box (Lot No. Us 2 - 121)
Hydraulic Pump (Lot No. Us 2 - 121)
Control Valve (Lot No. Us 2 -121)
Lift Cylinder (Use With No. 730 Corn Head)
Steering Column And Motor (Lot No. Us 2 - 121)
Wheel Ends, R.H. Shown - L.H. Same
P.T.O Drive Shafts (Lot No. 47 - 1 - 121)
Wheel End Extension (Lot N0. Us 2 - 121)
Traction Clutch
Clutch
Traction Clutch (#701 - Lot No. Us 47 - 1- 121) (#702-702d -
Transmission (Heavy Duty) (#701 - Lot No. Us 47 - 1 - 121)
Bundle 709965 - Heavy Duty Transmissions W Attaching Parts
Hydraulic System (Lot No. Us 2- 121)
Hydraulic System (Lot No. Us 28 - 121)
Rotating Screen (Lot No. Us 13 - 121)
Cab (Lot No. Us 2 - 14)
Cab (Lot No. Us 28 - 121)
Cab Rubber Trim (Lot No. Us 28 - 121)
Windshield Wiper Assembly (Lot No. Us 28 - 121)
Heater - High Capacity (Lot No. Us 2 - 121)
External Engine Parts (Lot No. Us 2 - 9)
Camshaft And Valve (Lot No. Us 2 - 9)
Gear Cover (Lot No. Us 2 - 9)
Water Pump (Lot No. Us 2 - 9)
Manifold And Oilpan (Lot No. Us 2 - 9)
Carburetor - Zenith (Lot No. Us 2 - 9)
Distributor - Delco Remy (Lot No. Us 2 - 9)
Governor - Novi (Lot No. Us 2 - 9)
Oil Pump (Lot No. Us 2 - 9)
Electrical Wiring (Lot No. Us 2 - 9)
Motor Mount And External - Governor Parts (Lot No. Us 2 - 9)
Internal Engine Parts (Lot No. Us 2 - 9)
Generator, Starting Motor And Coil - No. 701 Power Unit
Chevrolet Motor Section - Cylinder Head And Manifold
Carburetor - Marvel - Schebler (Lot No. Us 13 - 121)
Block And Internal Motor Parts (Lot No. Us 13 - 121)
Motor Attaching Parts - Left Side (Lot No. Us 13 - 121)
Attaching Motor Part - Right Side (Lot No. Us 13 - 121)
Starting Motor (Lot No. Us 13 - 121)
Distributor - Delco Remy (Lot No. Us 2 - 121)
Internal Basis Motor Parts (Lot No. Us 14 - 110)
Cylinder Head And Manifold (Lot No. Us 14 - 110)
Camshaft, Crankshaft, And Oil Pan (Lot Us 14 - 110)
Distributor (Lot No. Us 14 - 110)
Distributor (Lot No. Us 102 - 110)
Oil Filter (Lot No. Us 14 - 110)
Carburetor - Stromberg (Lot No. Us 14 - 110)
Oil Pump (Lot No. Us 14 - 110)
Starting Motor (Lot No. Us 14 - 110)
Attaching Motor Parts - Left Side
Attaching Motor Parts - Right Side (Lot No. Us 14 - 110)
Electrical System (Lot No. Us 14 - 110)
Gmc V-6 Diesel Motor Section - Camshaft, Crankshaft And Oil
Cylinder Block And Internal Parts (Lot No. Us 35 - 108)
Oil Pump (Lot No. Us 35 - 108)
Oil Filter (Lot No. Us 35 - 108)
Starting Motor (Lot No. Us 35 - 108)
Attaching Motor Parts - Right Side (Lot No. Us 35 - 108)
Attaching Motor Part - Left Side (Lot No. Us 35 - 108)
Electrical System (Lot No. Us 35 - 108)
Fuel System (Lot No. Us 35 - 108)
Repair Parts For Roller Chain, Single Links & Paint - Steel Chain Detachable Plain Links
Decals (701 - 702 - 702d) - Repair Parts For Roller Chain, Single Links & Paint
