New Idea Power Unit 800C 802C 803C Parts Catalog 988002
Brand: New Idea
Type of Machine: Power Unit
Model:
New Idea 800C Power Unit
New Idea 802C Power Unit
New Idea 803C Power Unit
Part Number: 988002
Number of Pages: 169 Pages
Directions For Ordering
Main Frame, Lower Side Sheets,
Top Rails, Wheel Shields, Battery And Hydraulic Tank Mounts
Fuel Tank, Rear Ladder And Fuel System-Tank To Pump
Air Cleaner And Air Intake
Air Cleaner And Air Intake (Lot No. Us 420 -)
Air Cleaner And Air Intake (Lot No. Us 423 -)
Radiator, Fan Shaft And Engine Cooling System
Main Drive Gear Box And Coupler To Engine
Implement Idler
Brakes
Wheel End, Axles, Spacers And Rims
Rear Axle
Hub And Spindle For Standard Rear Axle (Lot No. Us 395 -)
Steering Cylinder For Standard Axle And Power Guide Axle
Hydrostatic Motor And Reduction Hub For 13.5 - 16.1 Guide
Hydrostatic Motor For 18.4 - 16.1 Guide Wheels
Reduction Hub - Power Guide Axle For 18.4 Guide Wheel Tires
Power Guide Axle, Hydrualic Circuit
Power Guide Axle Solenoids (P.G.A. Control Valve W Solenoid)
Charge Pump (Lot No. Us 395 -)
Hydrostatic Pump
Hydrostatic Pump (Fixed Clearance - 5421-229)
Hydrostatic Motor (5430-031) (Lot No. Us 395 -)
Hydrostatic Motor (5430-031) (Lot No. Us 489 -)
Hydrostatic System
Hydraulic Tank And Drain
Hydraulic Oil Cooler (Lot No. Us 395 -)
Standard Hydraulic Circuit
Standard Hydraulic System - Pump To Front Lift Cylinder
Standard Hydraulic System With Optional Automatic Header
Standard 3 Spool Valve (Lot No. Us 395 -)
Load-Sensing Flow Divider (Earlier Type) (Lot No. Us 395 -
Load-Sensing Flow Divider (Later Type) (Lot No. Us 489 -)
Front Lift Cylinder Circuit (Lot No. Us 395 -)
Hydraulic Steering Circuit
Optional Hydraulic Circuit - Tank To Standard And Optional
Optional 2 Spool Valve And Rear Outlets (Lot No. Us 395 -)
Hydraulic Pumps Standard And Optional
Cab, Wiper, Ladder (Lot No. Us 395 -)
Cab Roof, Side And Rear Air Screens (Lot No. Us 395 -)
Console
Upper Control Console And Cab Blower (Lot No. Us 395 -)
Seat (Lot No. Us 395 -)
Steering Column And Motor
Steering Motor (Later Type)
Brake Pedals, Lines And Master Cylinder
Air Conditioning System
Air Conditioning Compressor (Lot No. Us 395 -)
Optional Ladder Extension (Lot No. Us 395 -)
Cab Lighting And Wiring (Lot No. Us 395 -)
Gauge And Sensor Circuit
Convenience Control Circuit
Starting And Charging Circuit (Lot No. Us 423 -)
Crankshaft Coupler
Optional Rear Weight Bracket And Tow Bar (Lot No. Us 395 -)
Alternator (Lot No. Us 395 -)
Lower Windshield Wiper (Lot No. Us 395 -)
S.M.V. Sign
Paint (Not Illustrated) - Repair For Steel Chain And Paint
