New Idea Hydraulic Loaders Attachments Parts Catalog 986355
Brand: New Idea
Type of Machine: Hydraulic Loaders Attachments
Part Number: 986355
Number of Pages: 388 Pages
Directions For Ordering
Horn Row Crop Cable Loader, Model 1144 (Years Built
Horn Row Crop Cable Loader, Model Hdcs-1
Horn Conversion Cable Loader Frame, No. H2cs-1, For Tractors
Cylinders For Horn Cable, Row Crop Loaders, Left - Hdcs-215,
Cylinders For Horn Cable, Conversion Loaders,
Cylinders For Horn Cable, Row Crop, Hdcs-215-L (Left),
Model Scl-80 Scoop, Used With 1133 Row Crop Cable Frame,
Front Bracket For Horn Cable Loader
Rear Brackets For Horn Cable Loaders
Model 1144 Square Bucket, Used With Model 1144 Loader Frame,
Baker Loader
Baker Row Crop Loader Blcs-1 (Built 1945 To 1951)
Front Brackets For Baker Loaders
Baker Loader Cylinders Blcs-2156, Blcs-215 Left (Built 1945
Horn Rear End Loader For Ford, Ferguson, Ford Ferguson
Horn Rear End Loader Model R-36, For Ford, Ferguson, Ford
Small Standard Or Ford-Draulic Loader 505 Loader
Fordraulic Loader Frame, No. H36cs-1, For Small Standard
New Idea Horn 505 Loader Frame, No. Ehcs-3, For Small
Cylinders For Ford, Ford-Ferguson, Ferguson, 505 And Small
Cylinders For, 505 And Small Standard Loaders (Low Pressure)
Radius Arms For Small Standard Tractors
Grill Guards For Small Standard Tractors
Or Small Standard Mounting Brackets For Allis Chalmers
Or Small Standard Mounting Brackets For Case Vai And
Or Small Standard Mounting Brackets For Case Vac
Or Small Standard Mounting Brackets For John Deere Mt
Or Small Standard Mounting Brackets For John Deere Mc
Or Small Standard Mounting Brackets For International C
Or Small Standard Mounting Brackets For Massey-Harris 22
Or Small Standard Mounting Brackets For Oliver
Or Small Standard Mounting Brackets For Oliver 66
Or Small Standard Mounting Brackets For Oliver 60
Mounting Crate Me-36a, Valve Kit E36cs-726 And E38cs For
Valve Kit E38cs-726 Ford Naa 1953 And Up
Valve Kit E36cs-726 For, Ford-Ferguson, Ferguson Up To And
Mounting Bracket For Ford 600 And 800 Tractors
Model 68 Scoop, Used With H36cs-1 Loader Frame (Built
50 Row Crop Loader 50 Conversion Loader
New Idea-Horn 50 Loader Frame, Ahcs-1-A, (Built 1949 To
New Idea-Horn 50 Conversion Frame, No. Ahcs-2-A, For
Radius Arms For 50 Row Crop And Conversion Loaders
Wd-Wpl Cylinders (Used With 50 Row Crop And Conversion
New Idea Horn 50 Cylinders Ahcs-2156, Ahcs-215 Left,
Model D32cs-2156 Cylinders, (Used On Allis-Chalmers Wpl
Single Ram Cylinders For 50 Row Crop And Conversion
Rear Brackets For New Idea-Horn 50 Loaders
50 Loader Mounting Brackets For Allis-Chalmers Ca (Wpl)
50 Loader Mounting Brackets For Allis-Chalmers Wd ,
50 Loader Mounting Brackets Minneapolis-Moline Ub
50 Loader Mounting Brackets For Minneapolis-Moline Utu
50 Loader Mounting Brackets For Oliver 66, 88
50 Conversion Loader Mounting Brackets For Fordson Major
50 Conversion Loader Mounting Brackets For International
50 Loader Mounting Brackets For Farmall H And Super H ,
50 Loader Mounting Brackets For International 300 And
50 Loader Mounting Brackets For Massey-Harris 30 , 33 ,
50 Loader Mounting Brackets For John Deere A , B , 50
Supply Tank Kit Number A70cs-726 Minneapolis-Moline Ub
Three Way Valve Kit Number H65bcs-726 Minneapolis-Moline
Power Lift Kit Number H2cs-726 International Super H With
Power Lift Kit Number A1cs-726 International Super M
Power Lift Kit No. H10cs-726 Internaitonal 300 And 400
Seven Way Valve Kit No. Po1acs-726 Farmall Super And
Seven Way Valve Kit No. Po2acs-726 Farmall Super H With
St-18 Power Lift Kit Parts List John Deere 50 Or 60
50 Loader Supply Tank Kit Number St-16-D John Deere Models
50 Loader Supply Tank Kits H62cs-726 (1950 Down)
50 Loader Supply Tank Kits H62cs-726 (1950 Down) - 50 Loader Supply Tank Kits H62cs-726 (1950 Down)
Supply Tank And Hose Connections Allis-Chalmers Ca
Three-Way Valve Kit Number A75bcs-726 Massey Harris
Seven Way Valve Massey-Harris 30 , 33 , 44 , 44-6
40 Conversion Loader, Model D32cs-2156 Cylinders (Used On
50 Cylinders Used On 40 Loader, Left Ahcs-215, Right
Glcs-2155, 40 Loader Cylinders, Left Or Right, Glcs-215
40 Loader Frame And Connecting Parts Cgcs-1
40 Loader Mounting Brackets For Allis-Chalmers Ca
40 Loader Mounting Brackets For Case Vac-14 With Eagle
40 Loader Mounting Bracket Case Dc-4 1953 And Up
40 Loader Mounting Brackets John Deere 40 Tractor
40 Loader Mounting Brackets Farmall Super C
Valve Kit No. Gk45cs-726 Case Vac And Vac-14 With Eagle
Power Lift Kit Number G31cs-726 Allis-Chalmers Ca (Wpl)
Power Lift Kit No. A44cs-726 Case Dc-4 1953 And Up
Power Lift Kit No. G5fhcs-726 Farmall Super C With Fast
Power Lift Kit No. G5cs-726 Super C 40 Loader Without Fast
Power Lift Kit Number G23cs-726 - John Deere 40
Valve Kit No. Gk23cs-726 John Deere 40
Large Standard
New Idea Horn Large Standard Stub Frame With Frame Arms And
Cylinders For New Idea-Horn, Large Standard Loaders (Low
Horn Large Standard Cylinders Blcs-2156-L, With T Type Ram
Horn Large Standard Cylinders Blcs-2156-J, With T Ram And
Radius Arms For Large Standard Tractors
Large Standard Mounting Brackets For International W-9
Large Standard Mounting Brackets For Oliver 70
Large Standard Mounting Brackets For Oliver 90 And 99
Large Standard Mounting Brackets For Massey-Harris 30 And
Large Standard Mounting Brackets For Oliver 77-78
Large Standard Mounting Brackets For International W-6
Large Standard Mounting Brackets For Oliver 80
Large Standard Mounting Brackets For John Deere Br
Large Standard Mounting Brackets For John Deere Ar Ao
Large Standard Mounting Brackets For John Deere D 1941
Large Standard Mounting Brackets For John Deere D 1942
Large Standard Mounting Brackets For Case D
Large Standard Mounting Brackets For Case S
Large Standard Mounting Brackets For Case La
Large Standard Mounting Brackets For Allis Chalmers (Wide
Large Standard Mounting Brackets For Minneapolis-Moline
Large Standard Mounting Brackets For Field Marshall
Large Standard Mounting Brackets For Massey-Harris 30,33, Or
Large Standard Mounting Brackets For Massey-Harris 55 1950
Ls Loader Mounting Brackets, International Super W-6,
Valve And Tank Kit No. H7cs-726 International W9 And Wd9
Power Lift Kit, Number H8cs-726, International Super W-6,
Horn Buck Rake Model Br-4011-Hd-Fd, Used With Hdcs-1 And
New Idea-Horn Buck Rake Model Brcs-1068, Used With All New
Gear Controlled Push Off Stacker, Model Poh-40001-Hd (Built
Poh-500 Cylinder, For Gear Controlled Push Off Stacker,
Cable Controlled Push Off Stacker Model 483 (Built 1948)
Pocs-215 Cylinder For Cable Controlled Push Off Stacker
New Idea-Horn Push-Off Stacker Model 491, Used With All New
Pocs-215-A Cylinder For Model Pocs-491 Push Off Stacker
Kit For Mounting Push-Off Stacker Model 491 On International
New Idea-Horn Bulldozer Blade, 60 Bbcs-1071, 80 Bbcs-1072,
Horn Bulldozer Blade (Built 1947 To 1949), Model Bb-574-Hd
V-Type Snow Plow Model Mvp-300, (Built 1949 To 1950), For
New Idea-Horn Angle Blade, Abcs-1073 (Without Cutting Edge),
Angle Blade, Abcs-2073 (Without Cutting Blade), Abcs-2073a
Semi-Round Loader Bucket Used With Frames No. Hdcs-1 And
New Idea-Horn Tine Bucket Htcs-300, (Built 1949 To ----),
New Idea-Horn Dirt Buckets, Hncs-300 Small, (Built 1949 To
New Idea Horn Tine Bucket Htcs-301, Built 1958 To
New Idea-Horn Scoops For 50 , 505 And Large Standard
New Idea-Horn Pitch Control, Model Pccs-5012 For 505, 40 And
New Idea-Horn Pitch Control, Model Pccs-5010, (Built 1949
Hydraulic Cylinder, Model `1000', Used With Pitch Control
Horn Draulic Utility Cylinder Uccs-215-C, (Built 1949 To --)
Pipe And Hose Kits, Gfcs-726, Gfrc-726-X, Gfls-726-X, For
New Idea-Horn Universal Boom, Umcs-1500c Cable Row Crop &
Grapple Fork Model Gfcs-300-A, Used With Universal Boom,
Utility Cylinder Uccs-215, For International F-20 Cultivator
Throttle Valve For John Deere A Or B (1943 To 1945)
Four-Way Valve, Models Hdcs 1006, Hdcs 1007, Hdcs 1008, Used
Model 900 Valve, Used On International H Or M (1945 To
P-300 Hydraulic Control Valve (Built 1948 To ----)
P-400 Hydraulic Control Valve (Built 1948 To ----)
Baker Multi-Valve For John Deere A, Gm (Wpt), Model
P-700 Hydraulic Control Valve
Baker Control, John Deere A, Row Crop Or
Supply Tanks For Various Tractors
Supply Tank And Valve Brackets For Various Loaders
Miscellaneous Power Lift Kit Parts For Various Loaders
Miscellaneous Parts For Power Lift Kits For Various Loaders
Roper Pump Brackets
Hdcs-1000 Hydraulic Power Unit, 500 Series Model Ee
Hdcs-1000 Hydraulic Power Unit, 600 Series Model Ee
Mounting Brackets For Hdcs-1000 Pumps
Pump Couplings For Hdcs-1000 Pumps
Hdcs-1000 Pump Couplings
Miscellaneous Parts For All Loaders
Fps-1000 Front End Pump Kit
Pump Package Fp-36 For Ford 8n
Pump Package Fp-39 For Ferguson To-30
Pump Package Fp-38 For Ford Naa
Supply Tank Kit Fp38cs-726 For Ferguson To-30, Ford 8n, And
Brand: New Idea
Part Number: 986355
Baker Loader
Large Standard
Roper Pump Brackets
- New Idea Air Planter 9000 Series Parts Catalog 988014A
- New Idea Combine 525 2890 Parts Catalog W448076
- New Idea Combine 545 4296 Parts Catalog W448070
- New Idea Combine 5542 Parts Catalog W448068B
- New Idea Combine 555 5555 5297 Parts Catalog W448078
- New Idea Combine 710 Edible Bean Harvester 712 Grain Platform 711 Parts Catalog 986330
- New Idea Combine 7300 Parts Catalog W448069B
- New Idea Combine 7600 Parts Catalog W448064A
- New Idea Combine 7800 Parts Catalog W448067
- New Idea Corn Head 720 723 724 725 728 730 731 733 734 735 738 Parts Catalog US61
- New Idea Corn Picker 300 Two-Row 10 One-Row 302 One-Row Snapper Parts Catalog 986344
- New Idea Corn Picker 6 6A 6 Special 7 8 Parts Catalog 986342
- New Idea Double Frame Pull Type Planter And Row Units 900 Series Parts Catalog 986680
- New Idea Draper Header 5000 18-22-25-30-36 CTR 22-25-30 DBL SW Parts Catalog 00732147
- New Idea Forage Harvester 760 Superchopper 767 Pickup 761 766 Parts Catalog 986334
