New Idea Harvest Boss Combine 8920 Parts Catalog W448093
Brand: New Idea
Type of Machine: Harvest Boss Combine
Model: New Idea 8920 Harvest Boss Combine
Part Number: W448093
Number of Pages: 301 Pages
Publication Information
Ready Reference Chart - Drives, Left Hand Side
Ready Reference Chart - Drives, Right Hand Side
Cutting - Head Countershaft And Drive
Feeding - Feeder Drive
Feeding - Feeder Housing
Feeding - Feeder Conveyor
Threshing - Rasp Bar Cylinder
Threshing - Cylinder Cover And Seals
Threshing - Spike Tooth Cylinder
Threshing - Rasp Bar Concave And Controls
Threshing - Spike Tooth Concave And Finger Grate
Threshing - Stone Trap
Separating - Beater
Separating - Straw Walkers And Drives
Separating - Walker Return Pan And Pitman
Cleaning - Grain Pan
Cleaning - Shaker Pitman And Drive
Cleaning - Shoe
Cleaning - Fan And Housing
Cleaning - Fan Drive And Controls
Elevating - Grain Elevator (Lower Section)
Elevating - Grain Elevator (Upper Section)
Elevating - Grain Elevator Drive
Elevating - Return Elevator
Elevating - Return Elevator Drive
Elevating - Beater Drive Idler
Grain Bin - Unloader Declutch
Grain Bin
Grain Bin - Main Unloading Auger
Grain Bin - Bin Unloading Augers And Drive
Grain Bin - Turret Unloader Tube
Grain Bin - Horizontal Unloader Tube
Platforms And Controls - Motor Cover
Platforms And Controls - Right Hand Platform
Platforms And Controls - Battery, Battery Tray And Cables
Platforms And Controls - Left Hand Platform And Ladder
Platforms And Controls - Control Box
Platforms And Controls - Seat And Frame (Cloth Seat)
Platforms And Controls - Seat And Frame (Cloth Centre Panel)
Platforms And Controls - Cab Roof
Platforms And Controls - Glass Specifications
Platforms And Controls - Conduit, Wiring
Platforms And Controls - Instrument Panel And Wiring
Platforms And Controls - Monitor Module And Wiring
Platforms And Controls - Wiring, Monitor Sensors And Lights
Platforms And Controls - Gear Shifting Controls
Platforms And Controls - Throttle Control And Fuel Stop
Platforms And Controls - Reel And Head Controls
Platforms And Controls - Hydrostatic Control Linkage
Brakes - Brake Pedals, Linkage And Supports
Brakes - Brake Cylinders And Lines
Brakes - Disc Brakes, Levers And Parking Brake
Brakes - Master Cylinder
Brakes - Wheel Cylinders
Hydraulic - Hydraulic Reservoir And Hoses
Hydraulic - Auger Swing Module
Hydraulic - Head Lift Module
Hydraulic - Reel Lift Module
Hydraulic - Hydraulic Pump Drive
Hydraulic - Basic Hydraulic Pump
Hydraulic - Head Cylinders And Lift Lock
Hydraulic - Head Cylinder Lines
Hydraulic - Hydraulic Unloader Cylinder, Lines, And Supports
Hydraulic - Power Steering Wheel, Lines, And Mounting
Hydraulic - Power Steering Hydraguide
Hydraulic - Power Steering Cylinder And Lines
Engine - Rotary Screen
Engine - Air Box And Core Frame
Engine - Radiator And Frame
Engine - Radiator Fan Drive
Engine - Gaskets
Engine - Cylinder Head Cover
Engine - Cylinder Block
Engine - Crankshaft And Pistons
Engine - Timing Gear And Auxiliary Drive
Engine - Oil Pump And Pan
Engine - Oil Filter, Cooler And Lines
Engine - Fuel Lift Pump
Engine - Fuel Filters And Lines
Engine - Fuel Injection Lines, Injector, And Fittings
Engine - Fuel Injection Pump
Engine - Water Pump And Thermostat Housing
Engine - Solenoid
Engine - Starter
Engine - Alternator (90 Amp.)
Engine - Air Intake And Precleaner
Engine - Air Cleaner
Engine - Turbocharger
Engine - Intake And Exhaust Manifolds
Engine - Exhaust Pipes
Engine - Fuel Tank And Lines
Drive - Rear Engine Drive
Drive - Main Counter Shaft - V.S. Cylinder Drive
Drive - Controls, Cylinders V.S. Belt Drive
Drive - Gear Box, Cylinder V.S. Belt Drive
Drive - Thresher Declutch
Drive - Hydrostatic Propulsion Drive
Drive - Hydrostatic Clutch
Drive - Charge Pump, Hydrostatic Propulsion Drive
Drive - Hydrostatic Unit
Drive - Hydrostatic Oil Cooler And Lines
Drive - Transmission
Drive - Differential
Drive - Final Drive
Drive - Adjustable Rear Axle
Drive - Rear Axle, Hydro Assist
Drive - Hydraulic Lines, Rear Wheel Assist, (Hydrostatic
Drive - Hydraulic Lines, Rear Wheel Assist, (Selector Valves
Drive - Torque Hub, Rear Wheel Assist
Drive - Hydrostatic Motor, Rear Wheel Assist
Drive - Double Selector Valves, Rear Wheel Assist
Miscellaneous - Main Body
Miscellaneous - Shields, Right Hand
Miscellaneous - Shields, Left Hand
Miscellaneous - Lights
Miscellaneous - Propulsion Drive Shields
Miscellaneous - Rear Ladder
Miscellaneous - Chaffers, Shoe
Accessories - Cleaning Screens, Shoe
Accessories - Corn Cob Mix Attachment
Accessories - Dual Straw Spreader
Accessories - Dual Straw Spreader Drive
Accessories - Front Axle Extensions
Accessories - Corn Kit, (Heavy Duty Slide Ahead Crop Chopper)
Accessories - Rotor Assembly, (Heavy Duty Slide Ahead Crop
Accessories - Drive Assembly, (Heavy Duty Slide Ahead Crop
Accessories - Housing And Spreader Assembly, (Heavy Duty
Accessories - Rear View Mirror, Right Hand
Accessories - Windshield Wiper, Cab
Accessories - Feeder Stand
Accessories - Blower
Accessories - Cab Air Conditioner
Accessories - Cab Air Conditioner Hoses
Accessories - Compressor And Drive Pulley, Tecumseh
Accessories - Compressor And Drive Pulley, York
Accessories - Cab Heater
Accessories - Tachometer And Rivet Extractor
Accessories - Rear Weights
Accessories - Grain Loss Monitor
Accessories - Defroster Fan
Accessories - Paint (Not Illustrated)
Accessories - 8920 Decals (Not Illustrated)
Brand: New Idea
Separating - Beater
Cleaning - Shoe
Grain Bin
Engine - Gaskets
Engine - Solenoid
Engine - Starter
Drive - Final Drive
- New Idea Air Planter 9000 Series Parts Catalog 988014A
- New Idea Combine 525 2890 Parts Catalog W448076
- New Idea Combine 545 4296 Parts Catalog W448070
- New Idea Combine 5542 Parts Catalog W448068B
- New Idea Combine 555 5555 5297 Parts Catalog W448078
- New Idea Combine 710 Edible Bean Harvester 712 Grain Platform 711 Parts Catalog 986330
- New Idea Combine 7300 Parts Catalog W448069B
- New Idea Combine 7600 Parts Catalog W448064A
- New Idea Combine 7800 Parts Catalog W448067
- New Idea Corn Head 720 723 724 725 728 730 731 733 734 735 738 Parts Catalog US61
- New Idea Corn Picker 300 Two-Row 10 One-Row 302 One-Row Snapper Parts Catalog 986344
- New Idea Corn Picker 6 6A 6 Special 7 8 Parts Catalog 986342
- New Idea Double Frame Pull Type Planter And Row Units 900 Series Parts Catalog 986680
- New Idea Draper Header 5000 18-22-25-30-36 CTR 22-25-30 DBL SW Parts Catalog 00732147
- New Idea Forage Harvester 760 Superchopper 767 Pickup 761 766 Parts Catalog 986334
