New Idea Harvest Boss Combine 8900 Parts Catalog W448081C
Brand: New Idea
Type of Machine: Harvest Boss Combine
Model: New Idea 8900 Harvest Boss Combine
Part Number: W448081C
Number of Pages: 360 Pages
Publication Information
Ready Reference Chart - Drives, Left Hand Side
Drives, Right Hand Side
Head Body
Knife And Guards, Fixed Cut Bar
Sickle Pitman And Drive
Head Countershaft And Drive
Head Auger
Auger Drive And Supports
Plain Bat Reel
Pick-Up Reel, Heavy Duty
Reel Drive
Sprocket And Slip Clutch - Heavy Duty Reel
Sheave And Hub, Heavy Duty Reel
Feeder Drive
Feeder Housing
Feeder Conveyor
Rasp Bar Cylinder
Cylinder Cover And Seals
Spike Tooth Cylinder
Rasp Bar Concave And Controls
Spike Tooth Concave And Finger Grate
Stone Trap
Beater
Straw Walkers And Drive
Walker Return Pan And Pitman
Grain Pan
Shaker Pitman And Drive
Shoe
Fan And Housing
Fan Drive And Controls
Grain Elevator (Lower Section)
Grain Elevator (Upper Section) - (Used S.N. -45600)
Grain Elevator Drive
Return Elevator
Return Elevator Drive
Beater Drive Idler
Unloader Declutch
Grain Bin
Main Unloading Auger
Bin Unloading Augers And Drive
Turret Unloader Tube
Horizontal Unloader Tube
Motor Cover
Right Hand Platform
Battery, Battery Tray And Cables
Left Hand Platform And Ladder
Control Box
Seat And Frame
Cab Roof
Glass Specifications
Instrument Panel And Wiring - (Used S.N. -34100)
Instrument Panel And Wiring - (Used Serial 34101-)
Monitor Unit And Wiring - (Used Serial -21100)
Monitor Unit And Wiring - (Used Serial 21101-)
Gear Shifting Controls
Throttle Control And Fuel Stop
Reel, Head, Unloader Swing Control Lever
Propulsion Control Linkage, Hydrostatic
Brake Pedals, Linkage And Supports
Brake Cylinders And Lines
Disc Brakes, Levers And Parking Brake
Master Cylinder
Wheel Cylinders (Used Serial -21100)
Wheel Cylinders (Used Serial 21101-)
Hydraulic Reservoir And Hoses
Control Valve, Flow Divider - Mechanical Propulsion Drive
Main Control Valve
Hydraulic Pump Drive
Basic Hydraulic Pump
Head Cylinders And Lines
Automatic Head Height Control
Cylinders And Lines - Mechanical Propulsion
Hyd. Unloader Cylinder, Lines & Supports
Power Steering Wheel, Lines & Mounting
Power Steering Hydraguide
Power Steering Cylinder And Lines
Hydraulic Lines - Reel Lift (Used Serial -23400)
Hydraulic Lines - Reel Lift (Used Serial 23401-)
Master Cylinder - Reel Lift
Slave Cylinder - Reel Lift
Drives - Variable Speed Reel
Hydraulic Pump And Reservoir - Variable Speed Reel & Pick-Up
Hydraulic Lines - Variable Speed Reel
Hydraulic Lines - Variable Speed Pick-Up
Orbit Motor (Char-Lyn) - Variable Speed Pick-Up
Orbit Motor - Variable Speed Reel
Orbit Motor (Char-Lyn) - Variable Speed Reel
Manual Control - Variable Speed Reel, Pick-Up
Automatic Control - Variable Speed Reel & Pick-Up
Rotary Screen
Air Box And Core Frame
Radiator And Frame
Radiator Fan Drive
Thermostart
Cylinder Head Cover
Crankshaft And Pistons
Timing Gear And Auxiliary Drive
Oil Pump And Fan
Oil Filter, Cooler And Lines
Fuel Lift Pump
Fuel Filters And Lines
Fuel Inject. Lines, Injector & Fittings
Fuel Injection Pump
Water Pump And Thermostat Housing
Solenoid
Starter
Alternator (72 Amp.) - (Used Serial -34100)
Alternator (90 Amp.) - (Used Serial -34101)
Air Intake And Precleaner
Air Cleaner
Turbocharger
Intake And Exhaust Manifolds
Exhaust Pipes
Gaskets
Fuel Tank And Lines - (Used Serial -21100)
Fuel Tank And Lines - (Used Serial 21101-)
Rear Engine Drive
Main Countershaft - V.S. Cylinder Drive
Controls - Cylinder V.S. Belt Drive
Gear Box - Cylinder V.S. Belt Drive
Thresher Declutch
Clutch And V.S. Sheaves - Mechanical Propulsion Drive
Clutch Housing And Linkage - Mechanical Propulsion Drive
Hydrostatic Propulsion Drive
Hydrostatic Clutch - (Used Serial 21101-)
Charge Pump - Hydrostatic Propulsion Drive
Hydrostatic Unit
Hydrostatic Oil Cooler And Lines
Final Drive
Adjustable Rear Axle
Main Body
Shields, Right Hand
Shields, Left Hand
Reel Drive Shields - (Used Serial 21101-)
Lights
Propulsion Drive Shields
Rear Ladder
Chaffers, Shoe - (Accessory)
Cleaning Screens, Shoe - (Accessory)
Straw Spreader - (Accessory)
Front Axle Extension
Corn Kit - (Heavy Duty Slide Ahead Crop Chopper)
Rotor Assembly - (Heavy Duty Slide Ahead Crop Chopper)
Drive Assembly - (Heavy Duty Slide Ahead Crop Chopper)
Housing And Spreader Assembly - (Heavy Duty Slide Ahead Crop
Rear View Mirror, Right Hand
Windshield Wiper, Cab
Feeder Stand (Accessory)
Blower
Cab Air Conditioner
Cab Air Conditioner Hoses
Compressor & Drive Pulley - Tecumseh
Compressor & Drive Pulley - York
Cab Heater
Tachometer & Rivet Extractor
Rear Weights
Grain Loss Monitor - (Accessory) (Used Serial -21100)
Grain Loss Monitor - (Accessory) (Used S.N. 21101-)
Defroster Fan (Accessory)
Paint
8900 Decals
Brand: New Idea
Head Body
Head Auger
Plain Bat Reel
Reel Drive
Feeder Drive
Feeder Housing
Feeder Conveyor
Rasp Bar Cylinder
Stone Trap
Beater
Grain Pan
Shoe
Fan And Housing
Return Elevator
Beater Drive Idler
Unloader Declutch
Grain Bin
Motor Cover
Right Hand Platform
Control Box
Seat And Frame
Cab Roof
Master Cylinder
Main Control Valve
Rotary Screen
Radiator And Frame
Radiator Fan Drive
Thermostart
Cylinder Head Cover
Oil Pump And Fan
Fuel Lift Pump
Fuel Injection Pump
Solenoid
Starter
Air Cleaner
Turbocharger
Exhaust Pipes
Gaskets
Rear Engine Drive
Thresher Declutch
Hydrostatic Unit
Final Drive
Main Body
Shields, Right Hand
Shields, Left Hand
Lights
Rear Ladder
Blower
Cab Air Conditioner
Cab Heater
Rear Weights
Paint
8900 Decals
- New Idea Air Planter 9000 Series Parts Catalog 988014A
- New Idea Combine 525 2890 Parts Catalog W448076
- New Idea Combine 545 4296 Parts Catalog W448070
- New Idea Combine 5542 Parts Catalog W448068B
- New Idea Combine 555 5555 5297 Parts Catalog W448078
- New Idea Combine 710 Edible Bean Harvester 712 Grain Platform 711 Parts Catalog 986330
- New Idea Combine 7300 Parts Catalog W448069B
- New Idea Combine 7600 Parts Catalog W448064A
- New Idea Combine 7800 Parts Catalog W448067
- New Idea Corn Head 720 723 724 725 728 730 731 733 734 735 738 Parts Catalog US61
- New Idea Corn Picker 300 Two-Row 10 One-Row 302 One-Row Snapper Parts Catalog 986344
- New Idea Corn Picker 6 6A 6 Special 7 8 Parts Catalog 986342
- New Idea Double Frame Pull Type Planter And Row Units 900 Series Parts Catalog 986680
- New Idea Draper Header 5000 18-22-25-30-36 CTR 22-25-30 DBL SW Parts Catalog 00732147
- New Idea Forage Harvester 760 Superchopper 767 Pickup 761 766 Parts Catalog 986334
