New Idea Harvest Boss Combine 8600 Parts Catalog W448063D
Brand: New Idea
Type of Machine: Harvest Boss Combine
Model: New Idea 8600 Harvest Boss Combine
Part Number: W448063D
Number of Pages: 410 Pages
Ready Reference Chart - Drives - Left Hand Side
Section 1 - Cutting - Head Body
Cutting - Section 1 - Knife And Guards - Fixed Cut Bar
Cutting - Section 1 - Sickle Pitman And Drive
Cutting - Section 1 - Head Countershaft And Drive
Cutting - Section 1 - Head Auger (No Suffix N In Head
Cutting - Section 1 - Head Auger (Suffix N In Head Serial
Cutting - Section 1 - Auger Drive And Supports
Cutting - Section 1 - Plain Bat Reel
Cutting - Section 1 - Pick-Up Reed - Medium Duty
Cutting - Section 1 - Pick-Up Reel - Heavy Duty
Cutting - Section 1 - Reel Drive
Cutting - Section 1 - Sprocket And Slip Clutch - Heavy Duty
Cutting - Section 1 - Sheave And Hub - Reel Drive
Cutting - Section 1 - Reel Drive Shields
Feeding - Section 2 - Feeder Drive
Feeding - Section 2 - Feeder Housing
Feeding - Section 2 - Feeder Conveyor
Feeding - Section 2 - Feeder Repair Housing And Kit Of Parts
Feeding - Section 2 - Chain Tension Adjustment - Feeder
Threshing - Section 3 - Rasp Bar Cylinder
Threshing - Section 3 - Spike Tooth Cylinder (Rice Model)
Threshing - Section 3 - Rasp Bar Concave And Controls
Threshing - Section 3 - Spike Tooth Concave And Finger Grate
Threshing - Section 3 - Stone Trap
Separating - Section 4 - Beater
Separating - Section 4 - Rasp Bar Cylinder
Separating - Section 4 - Straw Walkers And Drive .
Separating - Section 4 - Walker Return Pan And Pitman
Cleaning - Section 5 - Grain Pan
Cleaning - Section 5 - Shaker Pitman And Drive
Cleaning - Section 5 - Shoe (Serial No. 1-)
Cleaning - Section 5 - Fan And Housing
Cleaning - Section 5 - Fan Drive And Controls
Elevating - Section 6 - Fan Drive And Controls
Elevating - Section 6 - Return Elevator
Elevating - Section 6 - Return Elevator Drive
Elevating - Section 6 - Beater Drive Idler
Grain Bin - Section 7 - Beater Drive Idler
Grain Bin - Section 7 - Grain Bin And Levelling Auger
Grain Bin - Section 7 - Rotary Valve (Main Unloading Auger)
Grain Bin - Section 7 - Main Unloading Auger
Grain Bin - Section 7 - Bin Unloading Augers And Drive
Grain Bin - Section 7 - Unloader Tube (Serial No. 1-)
Platform And Controls - Section 8 - Motor Cover
Platform And Controls - Section 8 - Battery, Battery Tray,
Platform And Controls - Section 8 - Platform
Platform And Controls - Section 8 - Control Box
Platform And Controls - Section 8 - Instrument Panel And
Platform And Controls - Section 8 - Monitor System
Platform And Controls - Section 8 - Gear Shifting Controls
Platform And Controls - Section 8 - Throttle And Fuel Stop
Platform And Controls - Section 8 - Propulsion Control
Platform And Controls - Section 8 - Brake Linkage
Platform And Controls - Section 8 - Reel And Head Control
Platform And Controls - Section 8 - Cab Roof
Platform And Controls - Section 8 - Glass Specifications
Platform And Controls - Section 8 - Blower
Platform And Controls - Section 8 - Seat, Back Rest & Seat
Platform And Controls - Section 8 - Deluxe Seat And Frame
Platform And Controls - Section 8 - Swing-Away Ladder
Hydraulic - Section 9 - Basic Hydraulic Hoses
Hydraulic - Section 9 - Hydraulic Pump Drive (Used Serial
Hydraulic - Section 9 - Basic Hydraulic Pump
Hydraulic - Section 9 - Control Valve - Standard Head
Hydraulic - Section 9 - Head Cylinders And Lines
Hydraulic - Section 9 - Cylinder And Lines - Mechanical
Hydraulic - Section 9 - Power Steering Wheel, Lines And
Hydraulic - Section 9 - Power Steering Hydraguide
Hydraulic - Section 9 - Power Steering Cylinder And Lines
Hydraulic - Section 9 - Hydraulic Lines - Reel Lift
Hydraulic - Section 9 - Master Cylinder (Reel Lift)
Hydraulic - Section 9 - Slave Cylinder (Reel Lift)
Hydraulic - Section 9 - Drives - Variable Speed Reel
Hydraulic - Section 9 - Hydraulic Lines - Variable Speed
Hydraulic - Section 9 - Control Linkage - Variable Speed
Hydraulic - Section 9 - Hydraulic Pump - Variable Speed Reel
Hydraulic - Section 9 - Flow Control Valve - Variable Speed
Hydraulic - Section 9 - Orbit Motor - Variable Speed Reel
Hydraulic - Section 9 - Orbit Motor (Char-Lyn) - Variable
Hydraulic - Section 9 - Automatic Head Height Control
Hydraulic - Section 9 - Control Valve - Automatic Head
Hydraulic - Section 9 - Hydraulic Swing Kit - Unloading
Hydraulic - Section 9 - Cylinder - Hydraulic Swing Unloading
Hydraulic - Section 9 - Valve - Hydraulic Swing Unloading
Engine - Section 10 - Cylinder Head And Camshaft (318 Gas)
Engine - Section 10 - Cylinder Block (318 Gas)
Engine - Section 10 - Pistons (318 Gas)
Engine - Section 10 - Crankshaft (318 Gas) (Serial No. 1-)
Engine - Section 10 - Oil Pump (318 Gas) (Serial No. 1-)
Engine - Section 10 - Water Pump (318 Gas) (Serial No. 1-)
Engine - Section 10 - Fuel Pump, Tanks, Filter And Lines
Engine - Section 10 - Single Fuel Tank, Filter And Lines
Engine - Section 10 - Carburetor (318 Gas)
Engine - Section 10 - Carburetor (318 V-8 Gas)
Engine - Section 10 - Governor (318 Gas) (Serial No. 1-)
Engine - Section 10 - Distributor (318 Gas) (Serial No. 1-)
Engine - Section 10 - Starter (318 Gas) (Used Serial -35880)
Engine - Section 10 - Starter (318 Gas) (Used Serial 35881-)
Engine - Section 10 - Alternator (318 Gas) (No Serial No.)
Engine - Section 10 - Ignition Coil And Wires (318 Gas)
Engine - Section 10 - Air Cleaner (318 Gas)
Engine - Section 10 - Exhaust System (318 Gas)
Engine - Section 10 - Rotary Screen (318 Gas & Diesel)
Engine - Section 10 - Air Box, Radiator, And Frame
Engine - Section 10 - Radiator Fan Drive (318 Gas & Diesel)
Engine - Section 10 - Prescreener And Pre Cleaner
Engine - Section 10a - Gaskets (Diesel) (Serial No. 35101-)
Engine - Section 10a - Cylinder Head Cover (Diesel)
Engine - Section 10a - Cylinder Head (Diesel)
Engine - Section 10a - Cylinder Block (Diesel)
Engine - Section 10a - Crankshaft And Pistons (Diesel)
Engine - Section 10a - Timing Gear Auxiliary Drive (Diesel)
Engine - Section 10a - Oil Pump And Pan (Diesel)
Engine - Section 10a - Oil Filter, Cooler, And Lines
Engine - Section 10a - Fuel Pump, Tanks, Filter And Lines
Engine - Section 10a - Single Fuel Tank, Filter And Lines
Engine - Section 10a - Fuel Pump Lift (Diesel)
Engine - Section 10a - Fuel Tank Filters And Lines (Diesel)
Engine - Section 10a - Fuel Injection Lines, Injector And
Engine - Section 10a - Pump - Fuel Injection, Contains
Engine - Section 10a - Water Pump And Thermostat Housing
Engine - Section 10a - Starter And Solenoid (Diesel)
Engine - Section 10a - Alternator (72 Amp) (Diesel)
Engine - Section 10a - Alternator (90 Amp.) (Diesel)
Engine - Section 10a - Air Cleaner (Diesel)
Engine - Section 10a - Manifolds And Exhaust System (Diesel)
Engine - Section 10a - Thermostart (Serial No. 1-)
Engine - Section 10a - Quick Start (Accessory) (Diesel)
Drive - Section 11 - Rear Engine Drive (Gas & Diesel)
Drive - Section 11 - Main Countershaft - Chain Drive
Drive - Section 11 - Main Countershaft (Variable Speed
Drive - Section 11 - Controls - Cylinder V.S. Belt Drive
Drive - Section 11 - Gear Box - Cylinder V.S. Belt Drive
Drive - Section 11 - Thresher Declutch (Serial No. 35101-)
Drive - Section 11 - Mechanical Propulsion Drive
Drive - Section 11 - Clutch And V.S. Sheaves - Mechanical
Drive - Section 11 - Clutch Housing And Linkage - Mechanical
Drive - Section 11 - Hydrostatic Propulsion Drive
Drive - Section 11 - Charge Pump - Hydrostatic Propulsion
Drive - Section 11 - Hydrostatic Unit (Serial No. 1-)
Drive - Section 11 - Hydrostatic Oil Cooler And Lines
Drive - Section 11 - Transmission (Serial No. 1-)
Drive - Section 11 - Differential (Serial No. 1-)
Drive - Section 11 - Disc Brakes (Serial No. 1-)
Drive - Section 11 - Final Drive (Serial No. 1-)
Miscellaneous - Section 12 - Non-Adjustable Rear Axle
Miscellaneous - Section 12 - Adjustable Rear Axle
Miscellaneous - Section 12 - Main Body (Serial No. 1-)
Miscellaneous - Section 12 - Shields, Right Hand
Miscellaneous - Section 12 - Shields, Left Hand
Miscellaneous - Section 12 - Lights
Accessories - Section 13 - Chaffers - Shoe (Serial No. 1-)
Accessories - Section 13 - Cleaning Screens - Shoe
Accessories - Section 13 - Corn Cob Mix Attachment
Accessories - Section 13 - Floating Cutter Bar (Rivetted
Accessories - Section 13 - Floating Cutter Bar (Bolted
Accessories - Section 13 - Straw Spreader (Accessory)
Accessories - Section 13 - Front Axle Extension (Accessory)
Accessories - Section 13 - Rotor Assembly - Standard Fixed
Accessories - Section 13 - Housing & Spreader Ass'y -
Accessories - Section 13 - Standard Fixed Position Crop
Accessories - Section 13 - Corn Kit - Heavy Duty Slide Ahead
Accessories - Section 13 - Rotor Assembly - Heavy Duty Slide
Accessories - Section 13 - Drive Assembly - Heavy Duty Slide
Accessories - Section 13 - Windshield Wiper - Cab
Accessories - Section 13 - Propulsion Drive Shields
Accessories - Section 13 - Tachometer, Rivet Extractor
Accessories - Section 13 - Engine Hourmeter
Accessories - Section 13 - Feeder Stand (Serial No. 1-)
Accessories - Section 13 - Rear Ladder (Serial No. 1-)
Accessories - Section 13 - Cab Air Conditioner
Accessories - Section 13 - Compressor Mounting And Hoses
Accessories - Section 13 - Compressor And Drive Pulley
Accessories - Section 13 - Cab Heater (Serial No. 1-)
Accessories - Section 13 - Wiring (Air Conditioner)
Accessories - Section 13 - Rear Weights (Serial No. 1-)
Accessories - Section 13 - Bean Slow Down Kit - Grain
Paint (Not Illustrated)
8600 Decals (Not Illustrated)
