New Idea Harvest Boss Axial Combine 9720 Parts Catalog W448095
Brand: New Idea
Type of Machine: Harvest Boss Axial Combine
Model: New Idea 9720 Harvest Boss Axial Combine
Part Number: W448095
Number of Pages: 347 Pages
Publication Information
Drives, Left Hand Side - (Serial No. 1-)
Drives, Right Hand Side - (Serial No. 1-)
Drives, Engine - (Serial No. 1-)
Feeder Housing - (Serial No. 1-)
Feeder Conveyor - (Serial No. 1-)
Head Countershaft And Drive - (Serial No. 1-)
Head Countershaft Drive Shield - (Serial No. 1-)
Feeder Drive - (Serial No. 1-)
Feeder Drive Shield - (Serial No. 1-)
Inlet Housing And Stone Trap - (Serial No. 1-)
Feed Impeller - (Serial No. 1-)
Feed Impeller Drive Idler - (Serial No. 1-)
Rice Rotor - (Serial No. 1-)
Rotor Transmission - (Serial No. 1-)
Main Countershaft - (Serial No. 1-)
Thresher Declutch - (Serial No. 1-)
Main Countershaft Gear Box - (Serial No. 1-)
Grain Pan - (Serial No. 1-)
Separator Pan And Pitman - (Serial No. 1-)
Shaker Pitman And Drive - (Serial No. 1-)
Chaffer - (Serial No. 1-)
Concaves And Concave Shell - (Serial No. 1-)
Concave Adjusting - (Serial No. 1-)
Concave Deflector Plate - (Serial No. 1-)
Separator Deflector Plates - (Serial No. 1-)
Separator Shell And Grates - (Serial No. 1-)
Rotor Exhaust Housing And Rear Bulkhead - (Serial No. 1-)
Shoe - (Serial No. 1-)
Fan And Housing - (Serial No. 1-)
Fan Drive - (Serial No. 1-)
Actuator - (Serial No. 1-)
Return Elevator (Lower Section) - (Serial No. 1-)
Return Elevator (Upper Section) - (Serial No. 1-)
Return Elevator Drive - (Serial No. 1-)
Grain Elevator (Lower Section) - (Serial No. 1-)
Grain Elevator (Upper Section) - (Serial No. 1-)
Grain Elevator Drive - (Serial No. 1-)
Grain Bin - (Serial No. 1-)
Main Unloading Auger - And Grain Bin Saddles, (Serial No. 1-)
Turret Unloader - (Serial No. 1-)
Unloader Elbow And Gear Box - (Serial No. 1-)
Horizontal Unloader Tube - (Serial No. 1-)
Unloader Declutch - (Serial No. 1-)
Secondary Unloader Drive Gear Box - (Serial No. 1-)
Secondary Unloader Drive - (Serial No. 1-)
Glass Specifications - (Serial No. 1-)
Cab - (Serial No. 1-)
Cab Roof - (Serial No. 1-)
Control Tower - (Serial No. 1-)
Seat Assembly - (Serial No. 1-)
Seat Suspension - (Serial No. 1-)
Gear Shifting Controls - (Serial No. 1-)
Hydrostatic Control Linkage - (Serial No. 1-)
Reel And Head Controls - (Serial No. 1-)
Hydrostatic Clutch - (Serial No. 1-)
Throttle Control - (Serial No. 1-)
Rotor Speed Control Lever - (Serial No. 1-)
Unloader Controls - (Serial No. 1-)
Steering Wheel And Mounting - (Serial No. 1-)
Instrument Panel Wiring - (Serial No. 1-)
Wiring (Basic Controls) - (Serial No. 1-)
Wiring (Cab Roof) - (Serial No. 1-)
Wiring Harness, Engine Area - (Serial No. 1-)
Monitor Module And Wiring
Monitor Sensors And Wiring - (Serial No. 1-)
Grain Loss Monitor - (Serial No. 1-)
Battery, Battery Tray And Cables - (Serial No. 1-)
Lights - (Serial No. 1-)
Wiring Harness, Mounting Brackets - And Clamps, (Serial No. 1-)
Disc Brakes, Levers And Parking Brake - (Serial No. 1-)
Brake Pedals, Linkage And Supports - (Serial No. 1-)
Brake Valve - (Serial No. 1-)
Brake Actuator - (Serial No. 1-)
Hydraulic Brake Lines - (Serial No. 1-)
Hydraulic Pump Drive - (Serial No. 1-)
Hydrostatic Pump Drive - (Serial No. 1-)
Hydraulic Pump - (Serial No. 1-)
Hydraulic Reservoir - (Serial No. 1-)
Hydraulic Oil Filter - (Serial No. 1-)
Basic Hydraulic Hoses - (Cab Platform Area), (Serial No. 1-)
Basic Hydraulic Lines (Engine Area) - (Serial No. 1-)
Main Control Valve - (Serial No. 1-)
Hydraulic Unloader Cylinder And Lines - (Serial No. 1-)
Cylinders And Lines - Variable Speed Rotor, (Serial No. 1-)
Power Steering Hydraulic Lines - (Serial No. 1-)
Power Steering Hydraguide - (Serial No. 1-)
Power Steering Cylinder - (Serial No. 1-)
Head Cylinder, Counterbalance Springs - And Lift Lock, (Serial No. 1-)
Hydraulic Lines - Head And Reel Lift - (Serial No. 1-)
Head Lift Module - (Serial No. 1-)
Reel Lift Module - (Serial No. 1-)
Cylinder Head Covers - (Serial No. 1-)
Ether Start - (Serial No. 1-)
Cylinder Head - (Serial No. 1-)
Water Pump And Thermostat Housing - (Serial No. 1-)
Cylinder Block - (Serial No. 1-)
Crankshaft And Pistons - (Serial No. 1-)
Oil Pan - (Serial No. 1-)
Oil Pump, Pressure Relief And Dump Valve - (Serial No. 1-)
Oil Filters And Cooler - (Serial No. 1-)
Oil Breather - (Serial No. 1-)
Timing Gears And Covers - (Serial No. 1-)
Fuel Filters And Lines - (Serial No. 1-)
Fuel Injection Lines, Injector - And Fittings, (Serial No. 1-)
Fuel Injection Pump - (Serial No. 1-)
Fuel Lift Pump - (Serial No. 1-)
Fuel Lines (Fuel Tank To Engine) - (Serial No. 1-)
Fuel Tank And Support - (Serial No. 1-)
Air Intake Hoses - (Serial No. 1-)
Air Cleaner - (Serial No. 1-)
Intake Manifolds - (Serial No. 1-)
Exhaust Manifolds - (Serial No. 1-)
Turbocharger - (Serial No. 1-)
Exhaust Pipes - (Serial No. 1-)
Engine Gasket Sets - (Serial No. 1-)
Alternator - (Serial No. 1-)
Starter - (Serial No. 1-)
Rotor Screen And Air Box - (Serial No. 1-)
Radiator Air Box And Core Frame - (Serial No. 1-)
Radiator And Frame - (Serial No. 1-)
Radiator Fan Drive - (Serial No. 1-)
Engine Mounting - (Serial No. 1-)
Rear Engine Drive - (Serial No. 1-)
Oil Pump - Transmission - (Serial No. 1-)
Differential - (Serial No. 1-)
Hydrostatic Unit - (Serial No. 1-)
Hydrostatic Pump - (Serial No. 1-)
Hydrostatic Lines - Engine Area - (Serial No. 1-)
Hydrostatic Lines (Lower) - (Serial No. 1-)
Standard Rear Axle - (Serial No. 1-)
Rear Axle - Hydro Assist - (Serial No. 1-)
Hydrostatic Motor - Rear Wheel Assist - (Serial No. 1-)
Torque Hub, Rear Wheel Assist - (Serial No. 1-)
Hydraulic Lines, Rear Wheel Assist - (Hydrostatic Lines To Selector Valves), (Serial No. 1-)
Hydraulic Lines, Rear Wheel Assist - (Selector Valves To Wheels), (Serial No. 1-)
Double Selector Valves - Rear Wheel Assist, (Serial No. 1-)
Main Body - (Serial No. 1-)
Cab Platform - (Serial No. 1-)
Front Left Hand Platform And Ladder - (Serial No. 1-)
Main Countershaft Gear Box Cover - (Serial No. 1-)
Motor Cover - (Serial No. 1-)
Right Hand Catwalk, Shields - And Handrails, (Serial No. 1-)
Left Hand Catwalk - Shield And Handrails - (Serial No. 1-)
Shields, V S Rotor Drive - (Serial No. 1-)
Shields, Right Hand - (Serial No. 1-)
Shields, Left Hand - (Serial No. 1-)
Mud Shields, Right Hand - (Serial No. 1-)
Mud Shields, Left Hand - (Serial No. 1-)
Windshield Wiper, Cab - (Serial No. 1-)
Shoe Cleaning Screens - (Serial No. 1-)
Defroster Fan (Accessory) - (Serial No. 1-)
Blower - (Serial No. 1-)
Cab Air Conditioner - (Serial No. 1-)
Cab Air Conditioner Hoses - (Serial No. 1-)
Compressor And Drive Pulley - Tecumseh, (Serial No. 1-)
Compressor And Drive Pulley - York, (Serial No. 1-)
Cab Heater - (Serial No. 1-)
Crop Chopper Drive - (Serial No. 1-)
Gear Box, Crop Chopper - (Serial No. 1-)
Housing And Spreader Assembly - (Heavy Duty Slide Ahead Crop Chopper), (Serial No. 1-)
Rotor Assembly (Crop Chopper) - (Serial No. 1-)
Dual Straw Spreader - (Serial No. 1-)
Dual Straw Spreader Drive - (Serial No. 1-)
Gearbox, Straw Spreader Drive - (Serial No. 1-)
Hydraulic Lines, Reel Fore Aft - (Serial No. 1-)
Reel Fore Aft Module - (Serial No. 1-)
Paint (Not Illustrated) - (Serial No. 1-)
Decals (Not Illustrated) - (Serial No. 1-)
