New Idea Harvest Boss Axial Combine 9700 Parts Catalog W448088B
Brand: New Idea
Type of Machine: Harvest Boss Axial Combine
Model: New Idea 9700 Harvest Boss Axial Combine
Part Number: W448088B
Number of Pages: 433 Pages
Publication Information
Drives, Left Hand Side - (Serial No. 1-)
Drives, Right Hand Side - (Serial No. 1-)
Drives, Engine - (Serial No. 1-)
Head Body - (15', 18', 20', 22', 24'), (Serial No. 1-)
Knife And Guards (Fixed Cut Bar) - (15', 18', 20', 22' Grain, 18' Rice), (Serial No. 1-)
Knife And Guards (Fixed Cut Bar) - (24' Grain, 20' Rice), (Serial No. 1-)
Sickle Pitman And Drive - (15', 18', 20', 22', 24'), (Serial No. 1-)
Head Auger - (Suffix N In Head Serial No.), (15', 18', 20', 22', 24'), (Serial No. 1-)
Auger Drive And Supports - (Serial No. 1-)
Plain Bat Reel - (15', 18', 20', 22', 24'), (Serial No. 1-)
Pick-Up Reel (Heavy-Duty) - (15', 18', 20', 22', 24'), (Serial No. 1-)
Reel Drive - (Serial No. 1-)
Sprocket And Slip Clutch - Heavy-Duty Reel (Serial No. 1-)
Sheave And Hub - Heavy-Duty Reel (Serial No. 1-)
Reel Drive Shields - (Serial No. 1-)
Feeder Housing - (Serial No. 1-)
Feeder Conveyor - (Serial No. 1-)
Head Countershaft And Drive - (Serial No. 1-)
Head Countershaft Drive Shield - (Serial No. 1-)
Feeder Drive - (Used Serial No. -30100)
Feeder Drive - (Used Serial No. 30101-)
Feeder Drive Shield - (Serial No. 1-)
Inlet Housing - (Used Serial -20100)
Inlet Housing And Stone Trap - (Used Serial No. 20101-)
Feed Impeller - (Serial No. 1-)
Feed Impeller Drive Idler - (Serial No. 1-)
Grain Rotor - (Serial No. 1-)
Rice Rotor - (Serial No. 1-)
Rotor Transmission - (Used Serial -30100)
Rotor Transmission - (Used Serial 30101-)
Main Countershaft - (Used Serial -20100)
Main Countershaft - (Used Serial 20101-30100)
Main Countershaft - (Used Serial 30101-)
Thresher Declutch - (Serial No. 1-)
Main Countershaft Gear Box - (Serial No. 1-)
Grain Pan - (Serial No. 1-)
Separator Pan And Pitman - (Serial No. 1-)
Chaffer - (Serial No. 1-)
Concaves And Concave Shell - (Serial No. 1-)
Concave Adjusting - (Serial No. 1-)
Concave Deflector Plate - (Serial No. 1-)
Separator Deflector Plates - (Serial No. 1-)
Separator Shell And Grates - (Serial No. 1-)
Rotor Exhaust Housing And Rear Bulkhead - (Serial No. 1-)
Shoe - (Serial No. 1-)
Fan And Housing - (Serial No. 1-)
Fan Drive - (Used Serial -30100)
Fan Drive - (Used Serial 30101-)
Actuator - (Serial No. 1-)
Return Elevator (Lower Section) - (Serial No. 1-)
Return Elevator (Upper Section) - (Serial No. 1-)
Return Elevator Drive - (Serial No. 1-)
Grain Elevator (Lower Section) - (Serial No. 1-)
Grain Elevator (Upper Section) - (Used Serial -20700)
Grain Elevator (Upper Section) - (Used Serial 20701-)
Grain Elevator Drive - (Serial No. 1-)
Grain Bin - (Serial No. 1-)
Main Unloading Auger & Grain Bin Saddles - (Serial No. 1-)
Turret Unloader - (Serial No. 1-)
Unloader Elbow And Gear Box - (Serial No. 1-)
Horizontal Unloader Tube - (Serial No. 1-)
Unloader Declutch - (Serial No. 1-)
Secondary Unloader Drive Gear Box - (Serial No. 1-)
Secondary Unloader Drive - (Serial No. 1-)
Glass Specifications - (Serial No. 1-)
Cab - (Serial No. 1-)
Cab Roof - (Serial No. 1-)
Control Tower - (Serial No. 1-)
Seat Assembly - (Serial No. 1-)
Seat Suspension - (Serial No. 1-)
Gear Shifting Controls - (Serial No. 1-)
Hydrostatic Control Linkage - (Serial No. 1-)
Hydrostatic Clutch - (Serial No. 1-)
Throttle Control - (Serial No. 1-)
Reel And Rotor Control Levers - (Serial No. 1-)
Head Height Control Lever - (Serial No. 1-)
Unloader Controls - (Serial No. 1-)
Steering Wheel And Mounting - (Serial No. 1-)
Instrument Panel Wiring - Illustrated Index, Wiring
Instrument Panel Wiring - (Used Serial -20100)
Instrument Panel Wiring - (Used Serial 20101-)
Wiring, Basic Controls - (Serial No. 1-)
Wiring, Cab Roof - (Serial No. 1-)
Wiring Harness, Engine Area - (Serial No. 1-)
Monitor Module And Wiring - (Used Serial -20100)
Monitor Module And Wiring - (Used Serial 20101-30100)
Monitor Module And Wiring - (Used Serial 30101-)
Monitor Sensors And Wiring - (Used Serial -30100)
Monitor Sensors And Wiring - (Used Serial 30101-)
Grain Loss Monitor - (Serial No. 1-)
Battery, Battery Tray And Cables - (Serial No. 1-)
Lights - (Serial No. 1-)
Wiring Harness Mount. Brackets & Clamps - (Serial No. 1-)
Disc Brakes, Levers And Parking Brake - (Serial No. 1-)
Brake Pedals, Linkage And Supports - (Serial No. 1-)
Master Cylinder - (Serial No. 1-)
Hydraulic Brake Lines - (Used Serial 30101-)
Hydraulic Pump Drives - (Serial No. 1-)
Hydraulic Pump - (Serial No. 1-)
Hydraulic Reservoir - (Serial No. 1-)
Basic Hydraulic Hoses - (Used Serial -30100)
Basic Hydraulic Hoses - (Used Serial 30101-)
Main Control Valve - (Serial No. 1-)
Hydraulic Unloader Cylinder And Lines - (Serial No. 1-)
Cylinder & Lines, Variable Speed Rotor - (Serial No. 1-)
Hydraulic Lines, Reel Lift - (Serial No. 1-)
Master Cylinder, Reel Lift - (Serial No. 1-)
Slave Cylinder, Reel Lift - (Serial No. 1-)
Power Steering Hydraulic Lines - (Serial No. 1-)
Power Steering Hydraguide - (Serial No. 1-)
Power Steering Cylinder - (Serial No. 1-)
Drives, Variable Speed Reel - (Serial No. 1-)
Hydraulic Pump & Reservoir - Variable Speed Reel & Pick-Up Drive, (Serial No. 1-)
Hydraulic Lines, Variable Speed Reel - (Serial No. 1-)
Hydraulic Lines, Variable Speed Pick-Up - (Serial No. 1-)
Orbit Motor, Variable Speed Reel - (Serial No. 1-)
Orbit Motor (Char-Lyn) - Variable Speed Pick-Up, (Serial No.
Orbit Motor (Char-Lyn) - Variable Speed Pick-Up And Reel,
Orbit Motor (Trw) - Variable Speed Pick-Up And Reel, (Serial No. 1-)
Manual Control - Variable Speed Reel And Pick-Up, (Serial No. 1-)
Automatic Control - Variable Speed Reel And Pick-Up, (Serial No. 1-)
Head Cylinders, Counterbalance Springs & - Lift Lock, (Serial No. 1-)
Head Cylinder Lines - (Serial No. 1-)
Head Height Control Valve - (Serial No. 1-)
Automatic Head Height Control - (Serial No. 1-)
Cylinder Head Covers - (Serial No. 1-)
Thermostart - (Used Serial -30100)
Ether Start - (Used Serial -30101)
Cylinder Head - (Serial No. 1-)
Water Pump And Thermostat Housing - (Serial No. 1-)
Cylinder Block - (Serial No. 1-)
Crankshaft And Pistons - (Serial No. 1-)
Oil Pan - (Serial No. 1-)
Oil Pump, Pressure Relief And Dump Valve - (Serial No. 1-)
Oil Filters And Cooler - (Serial No. 1-)
Oil Breather - (Serial No. 1-)
Timing Gears And Covers - (Serial No. 1-)
Fuel Filters And Lift Pump - (Used Serial -30109)
Fuel Filters And Lines - (Used Serial 30110-)
Fuel Inject. Lines, Injector & Fittings - (Used Serial
Fuel Inject. Lines, Injector & Fittings - (Used Serial 30110-)
Fuel Injection Pump (Cav) - (Used Serial -30109)
Fuel Injection Pump (Bosch) - (Used Serial 30110-)
Fuel Lines (Fuel Tank To Engine) - (Cav Fuel Injection System), (Serial No. 1-)
Fuel Lines (Fuel Tank To Engine) - (Bosch Fuel Injection System), (Serial No. 1-)
Fuel Tank And Support - (Used Serial -30100)
Air Intake Hoses - (Serial No. 1-)
Air Cleaner - (Serial No. 1-)
Intake Manifolds - (Serial No. 1-)
Exhaust Manifolds - (Serial No. 1-)
Turbocharger - (Serial No. 1-)
Exhaust Pipes - (Serial No. 1-)
Engine Gasket Sets - (Used Serial -30109)
Engine Gasket Sets - (Used Serial 30110-)
Alternator - (Serial No. 1-)
Starter - (Serial No. 1-)
Rotary Screen And Air Box - (Serial No. 1-)
Radiator Air Box And Core Frame - (Serial No. 1-)
Radiator And Frame - (Serial No. 1-)
Radiator Fan Drive - (Serial No. 1-)
Engine Mounting - (Serial No. 1-)
Rear Engine Drive - (Serial No. 1-)
Transmission - (Serial No. 1-)
Oil Pump - Transmission - (Serial No. 1-)
Differential - (Serial No. 1-)
Final Drive - (Serial No. 1-)
Hydrostatic Unit - (Serial No. 1-)
Hydrostatic Pump - (Serial No. 1-)
Hydraulic Lines, Hydrostatic - (Used Serial -30100)
Hydraulic Lines, Hydrostatic - (Used Serial 30101-)
Standard Rear Axle - (Serial No. 1-)
Rear Axle, Hydro Assist - (Serial No. 1-)
Hydrostatic Motor, Rear Wheel Assist - (Serial No. 1-)
Torque Hub, Rear Wheel Assist (Grain) - (Serial No. 1-)
Torque Hub, Rear Wheel Assist (Grain) - Serial No. 1-)
Torque Hub, Rear Wheel Assist (Rice) - (Serial No. 1-)
Hydraulic Lines, Rear Wheel Assist - (Hydrostatic Lines To Selector Valves), (Serial No. 1-)
Hydraulic Lines, Rear Wheel Assist - (Selector Valves To Wheels), (Serial No. 1-)
Double Selector Valves - Rear Wheel Assist, (Serial No. 1-)
Main Body - (Serial No. 1-)
Cab Platform - (Serial No. 1-)
Front Left Hand Platform And Ladder - (Serial No. 1-)
Main Countershaft Gear Box Cover - (Serial No. 1-)
Motor Cover - (Serial No. 1-)
Right Hand Catwalk, Shields & Handrails - (Serial No. 1-)
Left Hand Catwalk, Shields & Handrails - (Serial No. 1-)
Shields, V S Rotor Drive - (Serial No. 1-)
Shields, Right Hand - (Serial No. 1-)
Shields, Left Hand - (Serial No. 1-)
Mud Shields, Right Hand - (Serial No. 1-)
Mud Shields, Left Hand - (Serial No. 1-)
Windshield Wiper, Cab - (Serial No. 1-)
Shoe Cleaning Screens - (Serial No. 1-)
Defroster Fan (Accessory) - (Serial No. 1-)
Blower - (Serial No. 1-)
Cab Air Conditioner - (Serial No. 1-)
Cab Air Conditioner Hoses - (Serial No. 1-)
Compressor And Drive Pulley, Tecumseh - (Serial No. 1-)
Compressor And Drive Pulley, York - (Serial No. 1-)
Cab Heater - (Serial No. 1-)
Crop Chopper Drive - (Used Serial -30100)
Crop Chopper Drive - (Used Serial 30101-)
Gear Box, Crop Chopper - (Used Serial -30100)
Gear Box, Crop Chopper - (Used Serial 30101-)
Housing & Spreader Assembly - (Heavy Duty Slide Ahead Crop Chopper), (Serial No. 1-)
Rotor Assembly (Crop Chopper) - (Serial No. 1-)
Paint - (Serial No. 1-)
Decals - 9700 Combine - (Serial No. 1-)
Brand: New Idea
- New Idea Air Planter 9000 Series Parts Catalog 988014A
- New Idea Combine 525 2890 Parts Catalog W448076
- New Idea Combine 545 4296 Parts Catalog W448070
- New Idea Combine 5542 Parts Catalog W448068B
- New Idea Combine 555 5555 5297 Parts Catalog W448078
- New Idea Combine 710 Edible Bean Harvester 712 Grain Platform 711 Parts Catalog 986330
- New Idea Combine 7300 Parts Catalog W448069B
- New Idea Combine 7600 Parts Catalog W448064A
- New Idea Combine 7800 Parts Catalog W448067
- New Idea Corn Head 720 723 724 725 728 730 731 733 734 735 738 Parts Catalog US61
- New Idea Corn Picker 300 Two-Row 10 One-Row 302 One-Row Snapper Parts Catalog 986344
- New Idea Corn Picker 6 6A 6 Special 7 8 Parts Catalog 986342
- New Idea Double Frame Pull Type Planter And Row Units 900 Series Parts Catalog 986680
- New Idea Draper Header 5000 18-22-25-30-36 CTR 22-25-30 DBL SW Parts Catalog 00732147
- New Idea Forage Harvester 760 Superchopper 767 Pickup 761 766 Parts Catalog 986334
