Taylor-Dunn Vehicles TC-080-120 Operation Manual MT-080-120-G
Brand: Taylor-Dunn
Type of Machine: Vehicles
Model: Taylor-Dunn TC-080-120 Vehicles
Part Number: MT-080-120-G
Serial Number: 210316 -
Number of Pages: 60 Pages
Contact Information
Fuse Box, Engine
Storing and Returning to Service
Vehicle Maintenance
Index
Brand: Taylor-Dunn
Contact Information
The Taylor-Dunn Corporation:
IntroductionWho Should Read This Manual
About This Manual
Glossary of Terms
Conventions
Signal Words and Their Definitions:
Safety Alert Message
Responsibilities
Of the Owner...
Of the Operator...
Of the Passengers...
Of the Service Personnel...
Vehicle Modifications
Replacement Parts
Using Non-Taylor-Dunn Replacement Components
About Your VehicleLicensing Requirements
How to Identify Your Vehicle
Data Plate
Where to Find Data Plate and Serial Number
How to Identify Your Engine & Transmission
Taking DeliveryIf a Problem is Found
Operator TrainingDriver Qualifications
Vehicle ControlsSwitch Functions:
Turn Signals
Hazard Light Switch
Steering
Operator Presence Switch
Horn Switch
Transmission Shift Levers
Vehicle OperationGeneral Safety Guidelines
Seat Belts (optional)
All Seat Belt Types
Combination Lap and Shoulder Belts
Lap Belts Only
Seat Belts While Pregnant
Seat Belt Maintenance
Starting the Engine
Diesel:
Stopping the Engine
Jump Starting
Driving
Collisions or Accidents
Engine Fuel
Gasoline
Gasohol
LPG
Diesel
TowingDraw Bar Pull (DBP), Definition
Towing the Vehicle
Circuit Breaker panelFuse Box, Engine
GM ESG V6
Allison 2100 System Circuit BreakerStoring and Returning to Service
Vehicle Maintenance
Daily Visual Inspection
Pre-Operation Inspection
Interlock Switch Inspection
Shift Lever Interlock
Seat Interlock
Brake Shift Interlock
Maintenance Schedule
Maintenance Guidelines for Severe Duty Applications
Fluid Levels
Engine Oil
Engine Dipstick Locations
Engine Coolant
Coolant Specifications
Transmission Fluid
Transmission Dipstick Locations
Brake Fluid
Hydraulic Fluid (Power Steering)
Air Filter
Air Filter Monitor (optional)
Pressure Relief Valve
Battery Maintenance
Cleaning
Watering
Charging
Tires
Air pressure
Under inflated tires result in:
Over inflated tires result in:
Unequal tire inflation may result in:
Tire Tread Wear
Changing a Tire/Wheel assembly
Tire Rotation
Replacing a Tire
Cleaning
Glass
Plastic Windows
Seats / Soft Doors
Interior
Exterior Body
Cleaning the Seat Belts
Under Carriage
Battery
Standard SpecificationsIndex
- Taylor Container Handler TECSP-156H Maintenance Manual
- Taylor Forklift TEC155H Parts Catalog
- Taylor Forklift TEC155H Parts Manual
- Taylor Forklift TX180S–360L to TXB180S–300L Maintenance Manual
- Taylor Forklift TX360L Parts Manual
- Taylor Loaded Container Handlers THDC954 to THDCP975 Maintenance Manual
- Taylor Reach Stackers TS9972 Parts Catalog
- Taylor Reach Stackers TS9985 Parts Catalog
- Taylor Soft Serve Freezer C706 C707 Service Manual
- Taylor Soft Serve Machines 336 338 339 Operation Manual 036029-M
- Taylor-Dunn B5-440-36 B5-440-48 Operation Operation and Replacement Parts Manual
- Taylor-Dunn Bigfoot G-1500 Service and Replacement Parts Manual
- Taylor-Dunn BT-280-36 BT-280-48 Service and Replacement Parts Manual
- Taylor-Dunn Vehicles B0-248-36 to BT-280-48 Service and Replacement Parts Manual
- Taylor-Dunn Vehicles TC-030-60 Service and Replacement Parts Manual
