Taylor-Dunn BT-280-36 BT-280-48 Service and Replacement Parts Manual
Brand: Taylor-Dunn
Type of Machine: Commercial Vehicles
Type of Manual: Service and Replacement Parts Manual, Electric Diagram
Model: Taylor-Dunn BT-280-36, BT-280-48
Serial Number: 205963 -
Number of Pages: 140 Pages
Introduction
Brand: Taylor-Dunn
Introduction
About This Manual
Who Should Read This Manual
Replacement Parts
How To Use This Manual
Responsibilities
How to Identify Your Vehicle
Web Site Registration
Service/Maintenance GuidelinesRead Me First:
Maintenance Guidelines and General InstructionsVehicle Modifications
Special Tool ListTool List
Troubleshooting Guide
LubricationLubrication and Fluids Chart
Hazardous Waste Disposal
Lubrication Diagram
Front AxleRemove
Install
Disassemble
Inspect Front Wheel Bearings
Adjust Front Wheel Bearings
Front Wheel Alignment
Replace Front Wheel Bearings
Replace Steering Knuckle
Replace King Pin/Bushings
Service Limits and Specifications
Hardware Torque
Transaxle-GTCheck Oil Level
Change Oil
Transmission Assembly
Axle Shaft
Rear Hub, Rotor & Bearings
Motor Removal/ Installation
Primary Gear Case
Secondary Gear Case
Pinion Bearing Preload
Hardware Torque
SteeringInspect Ball Joints
Inspect Rod Ends
Adjust Steering Gear
Replace Ball Joint
Replace Rod End
Replace Steering Shaft
Replace Steering Wheel
Steering Gear
Hardware Torque
BrakesGeneral Guidelines and Safety
Front Brake
Rear Brake
Rebuild Disc Brake Body
Bleed System
Flush System
Master Cylinder
Service Limits
Hardware Torque
MotorRemove/Install
Disassemble
Inspect
Repair
Service Limits
Motor ControllerRemove/Install
Inspect
Repair/Programming
Troubleshooting
Hardware Torque
Tires & WheelsInflation
Tread Wear
Rotation
Changing Tire/Wheel Assembly
Replace the Tire (pneumatic)
Repair the Tire (pneumatic)
Hardware Torque
BatteriesGeneral Guidelines and Safety
Cleaning
Watering
Charging
Testing
Storing
Remove/Install
Hardware Torque
SuspensionReplace the Rear Springs
Replace the Front Springs
Replace the Spring Bushings
Replace the Shocks
Hardware Torque
Wire DiagramDiagram Part Numbers
Replacement PartsOrdering Parts for Your Vehicle
Taylor-Dunn Web Site Information
Axle Assembly, Front
Axle Shaft Assembly, Rear
GT TransAxle Assembly, Rear
SD TransAxle Assembly, Rear 3rd Member
SD TransAxle Assembly, Rear Primary Reduction
Battery
Brakes, Brake Lines
Brakes, Brake Linkage
Brakes, Front Axle
Brakes, Rear Axle
Charger, Summit
Charger, Signet
Control System, Motor Speed Control
Electrical, Miscellaneous
Lights
Hitches
Motor
Seats
Steering Gear
Steering Linkage
Steering Column
Suspension, Front
Suspension, Rear
Wheels and Tires
Windshield Wiper
Turn Signals
Hardware InformationTorque Guidelines for Standard hardware
Replacing Hardware
- Taylor Container Handler TECSP-156H Maintenance Manual
- Taylor Forklift TEC155H Parts Catalog
- Taylor Forklift TEC155H Parts Manual
- Taylor Forklift TX180S–360L to TXB180S–300L Maintenance Manual
- Taylor Forklift TX360L Parts Manual
- Taylor Loaded Container Handlers THDC954 to THDCP975 Maintenance Manual
- Taylor Reach Stackers TS9972 Parts Catalog
- Taylor Reach Stackers TS9985 Parts Catalog
- Taylor Soft Serve Freezer C706 C707 Service Manual
- Taylor Soft Serve Machines 336 338 339 Operation Manual 036029-M
- Taylor-Dunn B5-440-36 B5-440-48 Operation Operation and Replacement Parts Manual
- Taylor-Dunn Bigfoot G-1500 Service and Replacement Parts Manual
- Taylor-Dunn Vehicles B0-248-36 to BT-280-48 Service and Replacement Parts Manual
- Taylor-Dunn Vehicles TC-030-60 Service and Replacement Parts Manual
- Taylor-Dunn Vehicles TC-080-120 Operation Manual MT-080-120-G
