Hyundai
86
176,834
Taylor-Dunn Vehicles B0-248-36 to BT-280-48 Service and Replacement Parts Manual
Brand: Taylor-Dunn
Type of Machine: Vehicle
Type of Manual: Service and Replacement Parts Manual
Model: Taylor-Dunn
B0-248-36 (B 2-48, 36-volt)
B0-248-48 (B 2-48, 48-volt)
B0-254-36 (B 2-54, 36 volt)
B0-254-48 (B 2-54, 48 volt)
BT-248-36 (36-volt Back to Back Tram)
BT-248-48 (48-volt Back to Back Tram)
BT-280-36 (36-volt 10-passenger Tram)
BT-280-48 (48-volt 10-passenger Tram)
Serial Number: 197830 - 205962
Number of Pages: 158 Pages
Introduction
About This Manual​
Who Should Read This Manual​
Replacement Parts​
How To Use This Manual​
Responsibilities​
How to Identify Your Vehicle​
Web Site Registration​
Front Axle
Remove​
Install​
Disassemble​
Inspect Front Wheel Bearings​
Adjust Front Wheel Bearings​
Front Wheel Alignment​
Replace Front Wheel Bearings​
Replace Steering Knuckle​
Replace King Pin/Bushings​
Service Limits and Specifications​
Hardware Torque​
Drive Axle
Check Oil Level​
Change Oil​
Transmission Assembly​
Axle Shaft​
Rear Hub, Rotor & Bearings​
Motor Removal/ Installation​
Primary Gear Case​
Secondary Gear Case​
Pinion Bearing Preload​
Hardware Torque​
Steering
Inspect Ball Joints​
Inspect Rod Ends​
Adjust Steering Gear​
Replace Ball Joint​
Replace Rod End​
Replace Steering Shaft​
Replace Steering Wheel​
Steering Gear​
Hardware Torque​
Brakes
General Guidelines and Safety​
Front Brake​
Rear Brake​
Rebuild Disc Brake Body​
Bleed System​
Flush System​
Master Cylinder​
Parking Brake​
Service Limits​
Hardware Torque​
Motor
Remove/Install​
Disassemble​
Inspect​
Repair​
Service Limits​
Motor Controller
Remove/Install​
Inspect​
Repair/Programming​
Troubleshooting​
Hardware Torque​
Batteries
Cleaning​
Watering​
Charging​
Testing​
Storing​
Remove/Install​
Hardware Torque​
Suspension
Replace the Rear Springs​
Replace the Front Springs​
Replace the Spring Bushings​
Replace the Shocks​
Hardware Torque​
Wire Diagram
Diagram Part Numbers​
Replacement Parts
Ordering Parts for Your Vehicle​
Taylor-Dunn Web Site Information​
Axle Assembly, Front​
Axle Shaft Assembly, Rear​
TransAxle Assembly, Rear​
Battery​
Brakes, Brake Lines​
Brakes, Master Cylinder​
Brakes, Brake Linkage​
Brakes, Front Axle​
Brakes, Rear Axle​
Charger, Lestronic​
Charger, Signet​
Charger, X-Series​
Control System, Motor Speed Control​
Control System, Instrument Panel​
Decals​
Electrical, Miscellaneous​
Frame and Body​
Lights​
Mirrors​
Mounting Hardware​
Motor​
Motor Mount​
Seats​
Steering Gear​
Steering Linkage​
Steering Column​
Suspension, Front​
Suspension, Rear​
Wheels and Tires​
Windshield Wiper​
Turn Signals​
Hardware Information
Torque Guidelines for Standard hardware​
Replacing Hardware​
