Hyundai
86
176,834
Taylor-Dunn Vehicles TC-030-60 Service and Replacement Parts Manual
Brand: Taylor-Dunn
Type of Machine: Vehicles
Type of Manual: Service and Replacement Parts Manual
Model: Taylor-Dunn TC-030-60 Vehicles
Serial Number: 210000 -
Number of Pages: 198 Pages
Introduction
About this manual​
Who Should Read This Manual​
Replacement Parts​
How To Use This Manual​
How to Identify Your Vehicle​
Web Site Registration​
Service/Maintenance Guidelines
READ ME FIRST-Maintenance Guidelines and General instructions​
Vehicle Modifications​
Preventative Maintenance
Daily Visual Inspection​
Pre-Operation Inspection​
Maintenance Schedule​
Lubrication
Lubrication and Fluids Chart​
Hazardous Waste Disposal​
Storing/Returning to Service
Storing and Returning to Service​
Front Axle
Inspect the Front Wheel Bearings and King Pin​
Adjust Front Wheel Bearings (new bearings)​
Adjust Front Wheel Bearings (used bearings)​
Align Front Wheels​
Front Hub, Steering Knuckle, King Pin​
Replace Front Wheel Bearings​
Rebuild the Steering Cylinder​
Replace Ball Joint​
Replace the Steering Cylinder​
Hardware Torque​
Steering
Hydraulic System-Operation​
Hydraulic Flow Diagrams​
Steering Control Valve​
Troubleshooting, Hydrostatic Steering​
Replace Ball Joint​
Hydraulic Pressure​
Wheel Alignment​
Hardware Torque​
Brakes
Power Brakes-Operation​
Master Cylinder​
Bleed Brake System​
Front Brake​
Rear Brake - Axle TA267​
Adjust Parking Brake (drive shaft brake drum)​
Adjust Parking Brake (drive shaft disc brake)​
Hardware Torque​
DIAGNOSIS AND TESTING​
GENERAL INFORMATION​
Service​
Removal and Installation​
Cleaning and Inspection​
Specifications​
Repair​
Diagnosis and Testing​
Adjustments​
Control Valve Assembly​
Intermediate Servo​
Governor​
Disassembly and Assembly​
Specifications​
Tires/Wheels
Tire Inflation​
Tire Inspection​
Tire/Wheel Assembly​
Hardware Torque​
Battery
Cleaning​
Testing​
Watering​
Storing​
Remove/install​
Hardware Torque​
Suspension
Front​
Rear​
Hardware Torque​
Wiring and Hydraulic Diagrams
Wire Diagrams​
Hydraulic diagram with External Reservoir​
Hydraulic Diagram with Integral Reservoir​
Adjust Pressure, Cummins B3.3 Engine​
Hardware Torque​
Hardware Information
Torque Guidelines for Standard hardware​
Replacing Hardware​
Replacement Parts
Ordering Parts for Your Vehicle​
Taylor-Dunn Web Site Information​
Axle Assembly, Front​
Axle Assembly, Rear​
Axle Assembly, Rear Primary Gears​
Axle Assembly, Rear Axle & Hubs​
Brakes, Pedal Linkage​
Brakes, Brake Lines​
Brakes, Front Axle​
Brakes, Parking Brake​
Brakes, Rear Axle​
Decals​
Electrical, Circuit Breaker Panel​
Electrical, Miscellaneous​
Engine, Cummins B3.3​
Engine, GM 3.0 (PSI)​
Engine, Cooling System PSI GM 3.0L​
Engine, Cooling System, Cummins B3.3​
Engine, Intake, Air Cleaner​
Exhaust, PSI GM 3.0L​
Exhaust, Cummins B3.3​
Frame and Body​
Fuel System, Cummins B3.3​
Fuel System, PSI GM 3.0L Gasoline​
Heater (optional)​
Hitches​
Instrument Panel​
Lights​
Linkage, Cummins B3.3 Throttle​
Steering Hydrostatic​
Steering, Hydrostatic, Mechanical​
Steering, Manual​
Suspension, Front​
Suspension/Axle Mount, Rear​
Transmission Assembly / Drive Shaft​
Transmission, Hydraulic Hoses​
Wheels and Tires​
Optional Equipment
Cab​
Cab Heater (TT-140-62)​
Cab Doors​
Hitches​
Remote Hitch Release (cab)​
Lights​
Shift Inhibitor (Full Range Shifter)​
Rear View Mirrors, Cab Door​
