Hyundai
86
176,834
Taylor-Dunn Bigfoot G-1500 Service and Replacement Parts Manual
Brand: Taylor-Dunn
Type of Machine: Vehicle
Type of Manual: Service and Replacement Parts Manual, Electric Diagrams
Model: Taylor-Dunn Bigfoot G-1500
Serial Number: 204278 -
Number of Pages: 118 Pages
Introduction
About this manual​
Who Should Read This Manual​
How To Use This Manual​
Responsibilities​
How to Identify Your Vehicle​
Web Site Registration​
Service/Maintenance Guidelines
READ ME FIRST-Maintenance Guidelines and General instructions​
Vehicle Modifications​
Replacement Parts​
Preventative Maintenance
Daily Visual Inspection​
Pre-Operation Inspection​
Maintenance Schedule​
Lubrication
Lubrication and Fluids Chart​
Lubrication Diagram​
Hazardous Waste Disposal​
Front Axle
Remove​
Install​
Assemble Complete Axle​
Inspect Front Wheel Bearings​
Adjust Front Wheel Bearings​
Front Wheel Alignment​
Replace Steering Knuckle​
Replace King Pin/Bushings​
Replace Front Wheel Bearings​
Service Limits and Specifications​
Hardware Torque​
Steering
Inspect Ball Joints​
Replace Ball Joint​
Replace Upper Steering Shaft​
Replace Lower Steering Shaft​
Replace 90° Steering Gear​
Replace Steering Rack​
Replace Steering Wheel​
Hardware Torque​
Check Oil Level​
Change Oil​
Air Filter Service​
Spark Plug Service​
Transaxle
Disassemble​
Assemble​
Differential​
Axle Shaft​
CVT Transmission
Operation​
Driver Pulley​
Driven Pulley​
Drive Belt​
Brakes
General Guidelines and Safety​
Front Disc Brake​
Brake Adjustment​
Master Cylinder​
Rear Brake, Inspect/Replace​
Rebuild Disc Brake Body​
Bleed System​
Flush System​
Service Limits​
Hardware Torque​
Throttle Cables
Adjust, Throttle / Choke​
Shift Linkage
Adjustment​
Tires & Wheels
Inflation​
Tread Wear​
Rotation​
Changing Tire/Wheel Assembly​
Replace the Tire (pneumatic)​
Repair the Tire (pneumatic)​
Hardware Torque​
Suspension
Front Springs​
Rear Springs​
Battery
Cleaning​
Watering​
Testing​
Storing​
Remove/Install​
Hardware Torque​
Wire Diagram
Diagram​
Hardware Information
Torque Guidelines for Standard hardware​
Replacing Hardware​
Replacement Parts
Ordering Parts for Your Vehicle​
Taylor-Dunn Web Site Information​
Axle Assembly, Front​
Axle Assembly, Rear​
Brakes, Brake Lines​
Brakes, Front Axle​
Brakes, Rear Axle​
Decals​
Electrical, Miscellaneous​
Engine / Exhaust​
Frame and Body​
Frame, Deck​
Fuel System​
Hitches​
Instrument Panel​
Lights​
Linkage, Park Brake​
Linkage, Shift​
Linkage, Throttle​
Seats​
Steering Linkage​
Suspension, Front​
Suspension, Rear​
Transmission, CVT​
Wheels and Tires​
