Momed80
150
35,046
LS Tractor XR4100 Series XR4140 XR4145 XR4150 XR4155 Parts Catalog
Brand: LS
Model: LS XR4100 Series XR4140 XR4145 XR4150 XR4155 Tractor
Number of Pages: 552 Pages
01. ENGINE
G010S01-05 ENGINE LONG BLOCK ASSY
G010S01-20 ENGINE SHORT BLOCK ASSY
G010S02-01 PILOT BEARING
Q110S01-08 CRANKCASE ASSY
Q110S02-03 CRANKCASE
Q115S01-04 ROCKER COVER & CAMSHAFT
Q115S02-04 BLOW BY GAS HOSE
Q116S01-07 CYLINDER HEAD
Q120S01-04 MAIN MOVING PARTS
Q121S01-03 VALVE MECHANISM
Q125S01-07 FUEL SYSTEM
Q125S02-03 FUEL FILTER
Q125S04-01 INJECTION PUMP
Q130S01-05 TIMING GEAR & CASE
Q135S01-06 COOLING SYSTEM
Q140S01-04 OIL SYSTEM
Q145S01-03 OIL PAN
Q160S01-05 INLET & OUTLET MANIFOLD
Q166S01-02 EGR
Q166S02-06 EGR VV SVC KIT (ERAE to KAMTEC)
Q167S01-04 DOC&DPF
Q167S01-05 DPF SUPPORT (Frame only)
Q180S01-05 ELECTRIC PARTS
Q180S01-11 ELECTRIC PARTS
Q180S02-02 MAF SENSOR
Q185S01-05 TURBOCHARGER
02. ENGINE APPLICATION
G040S01-04 FUEL TANK (F)
G040S01-05 FUEL TANK (C)
G100S01-07 THROTTLE PEDAL (C,MEC)
G100S01-13 THROTTLE LEVER
G100S01-14 THROTTLE PEDAL (L3C-T1,T2,T3,T4,F,MEC)
G130S01-01 FUEL COOLER (L3C)
G150S01-05 MUFFLER
G170S01-04 RADIATOR (C,MEC,C-HST)
G170S01-05 RADIATOR (F,MEC,C-HST)
G190S01-04 AIR CLEANER (MEC,C-HST)
G210S01-03 ENGINE FRAME
03. TRANSMISSION
G250S01-01 CLUTCH (MEC)
G250S02-05 CLUTCH HOUSING (C-HST)
G250S02-06 CLUTCH HOUSING (MEC)
G250S03-01 DAMPER (C-HST,S-HST)
G260S01-01 CLUTCH PEDAL (MEC)
G270S01-01 HST UNIT (40,42,45,47HP,C-HST,28cc)
G270S01-03 HST ROTATING KIT (40,42,45,47HP,C-HST,28cc)
G270S01-04 HST SEAL KIT (40,42,45,47HP,C-HST,28cc)
G270S01-05 HST UNIT (50,52,55,57HP,C-HST,33cc)
G270S01-06 HST ROTATING KIT (50,52,55,57HP,C-HST,33cc)
G270S01-07 HST SEAL KIT (50,52,55,57HP,C-HST,33cc)
G280S01-01 TRANSMISSION CASE (MEC,STD,NO-SPEEDOMETER)
G280S01-02 TRANSMISSION CASE (C-HST,STD,NO-SPEEDOMETER)
G281S01-04 MAIN SHAFT (MEC,INDP,NO-CRP)
G281S02-01 MAIN GEAR SHAFT (MEC,MPC)
G281S02-02 MAIN GEAR SHAFT (C-HST,S-HST)
G285S01-01 RANGE GEAR SHAFT (MEC,MPC,NO-GSP,STD,NO-SPEEDOMETER)
G285S01-02 RANGE GEAR SHAFT (C-HST,NO-GSP,NO-SPEEDOMETER)
G310S01-02 REAR DIFFERENTIAL
04. PTO DRIVE
G280S02-01 PTO SHIELD (STD or EC,EXP)
G283S01-02 PTO CLUTCH & SHAFT (C-HST,S-HST,INDP,NO-GSP)
G283S01-04 PTO CLUTCH & SHAFT (MEC,MPC,INDP,NO-GSP)
G287S01-01 PTO GEAR & DRIVE SHAFT (PTO1,M-PTO)
G287S02-01 MID PTO LEVER (C,M-PTO,W-DIA KIT)
G287S02-02 MID PTO LEVER (F,M-PTO,DIA KIT)
G287S02-03 MID PTO HOUSING (M-PTO)
G287S04-02 PTO SHAFT CAP
05. FOUR WHEEL DRIVE (4WD)
G288S01-02 4WD SHAFT & COVER
G400S01-03 FRONT AXLE ASSY
G400S02-01 FRONT AXLE CASE(CENTER)
G400S02-02 FRONT AXLE CASE(RH)
G400S02-03 FRONT AXLE CASE(LH) (NO-Q-T)
G400S03-01 FRONT DIFFERENTIAL
G400S04-01 FRONT DRIVE
G610S01-02 TIE-ROD
G630S01-14 STEERING CYLINDER
07. REAR AXLE & BRAKE
G480S01-01 REAR AXLE
G650S01-01 BRAKE (STD)
G670S01-01 BRAKE ROD AND LINKAGE (HST)
G670S01-02 BRAKE ROD AND LINKAGE (MEC,MPC)
G670S01-05 BRAKE PEDALS (C-HST,S-HST)
G670S01-06 BRAKE PEDALS (MEC)
G670S02-01 PARKING BRAKE LEVER (C,C-HST,S-HST)
G670S02-02 PARKING BRAKE LEVER (C,MEC)
G670S02-04 PARKING BRAKE LEVER (F,C-HST)
G670S02-05 PARKING BRAKE LEVER (F,MEC)
08. SHIFT FORK & LINKAGE
G290S01-03 CREEPER LEVER COVER (NO-CRP)
G290S02-03 LEVER&FORK(MAIN GEAR) (F,MEC,STD)
G290S02-04 LEVER&FORK(MAIN GEAR) (C,MEC,STD,GRAMMER)
G290S03-01 LEVER&FORK(F-R GEAR) (C,MEC)
G290S03-02 LEVER&FORK(F-R GEAR) (F,MEC,STD)
G291S01-01 LEVER&FORK(RANGE GEAR) (MEC,W-NEUTRAL,I-RANGE)
G291S01-03 LEVER&FORK(RANGE GEAR) (F,C-HST)
G291S01-04 LEVER&FORK(RANGE GEAR) (C,C-HST,GRAMMER)
G291S02-01 LEVER&FORK(4WD) (4WD,NO-Q-T)
G291S03-01 LEVER&FORK(PTO) (PTO1)
G291S03-04 LEVER&FORK(GSP) (NO-GSP)
G292S01-01 HST CONTROL (C,C-HST)
G292S01-02 HST CONTROL (F,C-HST)
G320S01-01 DIFF-LOCK (C,C-HST,S-HST)
G320S01-02 DIFF-LOCK (C,MEC)
G320S01-03 DIFF-LOCK (F,C-HST)
G320S01-04 DIFF-LOCK (F,MEC,MPC)
G630S01-10 STEERING RESONATOR (C)
G630S01-17 STEERING LINES (F,C-HST,LSTA)
G630S01-18 STEERING LINES (F,MEC,LSTA)
G630S01-19 STEERING LINES (C)
G640S01-07 T-M OIL COOLER (C-HST)
G640S01-08 T-M OIL COOLER (MEC)
G822S02-01 INDP PTO VALVE (MEC,INDP,NO-Q-T)
G822S02-02 INDP PTO VALVE (C-HST,S-HST,INDP)
G822S03-01 LOADER VALVE ((C,MEC,C-HST,L-V,W-COUPLER) or Non-EU)
G822S03-04 JOYSTICK LEVER (F,L-V)
G822S03-09 LOADER VALVE (F,L-V,W-COUPLER)
G822S03-10 LOADER VALVE COUPLER (F,L-V)
G822S03-11 LOADER VALVE COUPLER (C,MEC,C-HST,L-V)
G822S03-12 JOYSTICK LEVER (C,L-V)
G822S03-22 LOADER VALVE (C,L-V,SDM104,DIA KIT)
G822S03-23 LOADER VALVE (F,SD5-2,L-V,SDM104,DIA KIT)
G822S03-24 LOADER VALVE (F,SD5-3,L-V,SDM104,DIA KIT)
G823S01-20 HYD. SUCTION LINES (MEC,MPC,C-HST)
G823S02-14 HYD. F-PRESSURE LINES (F,C-HST,L-V)
G823S02-16 HYD. F-PRESSURE LINES (C,C-HST,L-V)
G823S02-17 HYD. F-PRESSURE LINES (F,MEC,L-V)
G823S02-19 HYD. F-PRESSURE LINES (C,MEC,L-V)
G823S03-12 HYD. M-PRESSURE LINES (F,L-V,NO LEVELING,SD5-2)
G823S03-23 HYD. M-PRESSURE LINES (C,MEC,MPC,C-HST,L-V,NO-LEVEL)
G823S03-30 HYD. M-PRESSURE LINES (F,L-V,NO LEVELING,SD5-3)
G827S01-01 REMOTE CONTROL LEVER (C,SD5-2)
G827S01-02 REMOTE CONTROL LINE (C,SD5-2)
G827S01-04 REMOTE CONTROL LINE (F,SD5-2)
G827S01-13 REMOTE CONTROL LINE (C,SD5-3)
G827S01-14 REMOTE CONTROL LEVER (C,SD5-3)
G827S01-21 REMOTE CONTROL LINE (F,SD5-3)
G827S01-32 REMOTE CONTROL VALVE (C,6-QC,DIA KIT)
G827S01-33 REMOTE CONTROL VALVE (F,6-QC,L-V,SDM104,DIA KIT)
G827S02-02 REMOTE CONTROL VALVE (C,SD5-2)
G827S02-04 REMOTE CONTROL VALVE (F,SD5-2)
G827S02-05 REMOTE CONTROL VALVE (C,SD5-3)
G827S02-06 REMOTE CONTROL LINE (F,SD5-3)
G730S01-07 ELECTRICAL WIRING
G730S02-01 7 POLE CONNECTOR (C)
G730S02-02 7 POLE CONNECTOR (F)
G730S03-01 HORN (Optional)
G730S04-01 MAIN FUSE
G740S01-12 BATTERY (80A)
G750S01-18 ECU (L3C)
G750S01-20 METER PANEL
G750S01-21 RH CONSOLE SWITCH (C)
G750S01-22 RELAY & FUSE (C,C-HST,NO-SPEEDOMETER)
G750S01-23 RELAY & FUSE (F,C-HST,NO-SPEEDOMETER)
G750S01-24 RELAY & FUSE (C,MEC,NO-SPEEDOMETER)
G750S01-25 RELAY & FUSE (F,MEC,NO-SPEEDOMETER)
G750S01-26 DIAGNOSIS CONNECTOR
G750S01-55 RH CONSOLE SWITCH (F)
G750S02-06 F-R NEUTRAL SWITCH (MEC)
G750S03-08 PTO SENSOR PLUG (NO-EPTO,NO-REV-PTO)
G760S01-01 REAR COMBINATION LAMP (C,STD)
G760S01-03 HEAD LAMP
G760S01-06 REAR LAMP (F,STD)
G760S01-08 TURN SIGNAL LAMP (F)
G760S01-12 REAR WORK LAMP (C,W-DIA KIT)
G760S01-18 WORK LAMP (C)
G760S01-19 TURN SIGNAL LAMP (C,EXP)
G760S03-01 BEACON LAMP (C,W-DIA KIT)
G760S03-03 BEACON LAMP (C,W-DIA KIT)
G991S50-01 SCV KIT-ENGINE HARNESS
G991S50-02 SCV KIT-EARTH HARNESS
11. HYDRAULIC LIFT UNIT
G820S01-01 HYD. HOUSING ASSY (C,W-DRAFT,NO-LEVEL)
G820S01-03 HYD. HOUSING ASSY (F,W-DRAFT,NO-LEVEL)
G820S02-05 HYDRAULIC HOUSING (NO-LEVEL,W-DRAFT)
G822S01-02 LIFT CTRL. VALVE & LINK (W-DRAFT)
G824S01-01 POSITION & DRAFT CONTROL LINK (W-DRAFT)
G825S01-01 HYD. HOUSING LEVER (C)
G825S01-03 HYD. CONTROL LEVER (F,W-DRAFT)
G825S01-09 HYD. CONTROL LEVER (C,W-DRAFT)
G825S01-17 HYD. HOUSING LEVER (C)
G825S02-01 EXTERNAL POSITION CONTROL LEVER (C, Optional)
G825S02-02 EXTERNAL POSITION CONTROL LEVER (F, Optional)
G826S01-03 HYDRAULIC CYLINDER
G828S01-02 UPPER LINK BRACKET (F,W-DRAFT)
G828S01-06 UPPER LINK BRACKET (C,W-DRAFT)
12. 3-POINT LINKAGE & HITCH
G891S01-07 DRAWBAR & HITCH (TELESCOPIC DRAWBAR,LSTA)
G896S01-05 TOP LINK HOOK (C,STD TOP LINK)
G896S01-06 TOP LINK HOOK (F,STD TOP LINK)
G896S01-10 UPPER & LOWER LINK (TELESCOPIC,CAT2)
G896S01-14 UPPER & LOWER LINK (TELESCOPIC,CAT1)
G896S02-05 LIFT ROD (NO-LEVEL,CAT1or2)
G896S03-04 CHECK LINK (C,TELESCOPIC,Ball type)
G896S03-07 CHECK LINK (F,TELESCOPIC,Ball type)
13. SHEET METALS & MOUNTS
G830S01-08 HOOD (S-BLUE)
G830S01-09 GRILLE ASSY (S-BLUE)
G830S02-06 HOOD SUPPORT (C)
G830S02-07 HOOD SUPPORT (F)
G840S01-02 SUB STEP (C)
G840S01-04 MOUNT RUBBER (F,NO-LEVEL,MEC,C-HST)
G840S01-05 SUB STEP (F,OPTIONAL)
G840S01-09 MOUNT RUBBER (C)
14. DRIVER’S STATION
G630S02-01 STEERING COLUMN (C)
G630S02-02 STEERING WHEEL
G630S02-03 STEERING COLUMN (F,STD WHEEL)
G825S01-02 HYD. LEVER GUIDE (C,W-DRAFT,LS-GRAY,EXP)
G825S01-05 HYD. LEVER GUIDE (F)
G835S01-01 PEDAL FRAME (C,C-HST,S-HST)
G835S01-02 PEDAL FRAME (C,MEC)
G835S01-05 PEDAL FRAME (F,C-HST)
G835S01-06 PEDAL FRAME (F,MEC)
G850S01-02 SEAT (F,WOOCHANG,BLACK)
G850S01-05 SEAT (C,GRMMER,LS-GRAY)
G861S01-03 FRAME (F,MEC,C-HST)
G861S01-04 FRAME (C,GRAMMER)
G862S01-01 DOOR(LH) (C)
G862S01-02 DOOR(RH) (C)
G863S01-01 FRONT & SIDE WINDOW (C)
G863S01-02 FRONT & SIDE WINDOW (F)
G863S02-01 REAR WINDOW (C,W-WIPER)
G863S02-02 REAR WINDOW (C,WO-WIPER)
G864S01-01 INTERIOR(RH) (C)
G864S01-02 INTERIOR(LH) (C)
G864S01-03 INTERIOR(TOP) (C)
G864S01-04 INTERIOR(FRONT)
G864S01-05 JOYSTICK COVER (C)
G864S01-06 INTERIOR(RH,LH) (F,LSTA,DO)
G864S01-11 JOYSTICK COVER (F,L-V)
G865S01-08 AIR-CON BLOWER (C)
G865S01-09 AIR-CON COMPRESSOR (C)
G865S01-10 AIR-CON LINE (C)
G865S02-02 AIR-CON UNIT (C)
G866S01-04 ELECTRICAL WIRING (C,NO-SPEEDOMETER)
G866S01-05 ELECTRICAL WIRING (F,NO-SPEEDOMETER)
G866S02-01 WINDOW WIPER(FRONT) (C,COOL-GRAY)
G866S02-07 WINDOW WIPER(REAR) (C,DIA KIT)
G866S03-01 AUDIO ASSY (C)
G866S03-02 AUDIO SYSTEM (C)
G866S03-06 AUDIO ASSY (C,DIA KIT)
G867S01-01 ROOF (C,S-BLUE)
G868S01-08 EXTERIOR (C,STD,S-BLUE)
G869S01-01 MIRROR ASSY (C)
G869S01-04 MISCELLANY (C,C-HST)
G869S01-05 MISCELLANY (C,MEC,I-RANGE)
G869S01-06 MISCELLANY (F)
G870S01-01 FENDER (F)
G880S01-01 SAFETY FRAME (R-ROPS,FOLDABLE)
15. TIRES, WHEELS & REAR BALLAST
G490S01-15 WHEEL BOLTS & NUTS
16. ACCESSORY & ETC
G868S02-01 SLOW MOVING VEHICLES (C)
G868S02-02 SLOW MOVING VEHICLES (F)
G920S02-01 TOOL BOX (F,DIA KIT)
G920S05-03 RUBBER PLUGS
G920S05-04 BOLT CAP
G920S07-01 CUP HOLDER (F,OPTIONAL)
17. DECALS
G980S01-07 MODEL DECAL
G980S01-08 SAFETY DECAL (C)
G980S01-09 SAFETY DECAL (F)
18. DIA KIT & SVC KIT
G990S01-01 DIA KIT LIST (LSTA)
G991S01-01 SVC KIT LIST
G991S01-03 SVC KIT LIST (ERAE to KAMTEC)
