LS Tractor MT2E Series MT226E (with S3L2) Parts Catalog
Brand: LS
Model: LS MT2E Series MT226E (Roll-bor model with S3L2 engine(2023)) Tractor
Number of Pages: 438 Pages
01. ENGINE
G010S01-03 ENGINE (25HP)
Q065S01-02 OVERHAUL GASKET KIT
Q110S01-02 CRANKCASE ASSY
Q110S01-03 CRANKCASE ASSY
Q110S01-05 CRANKCASE ASSY (25HP)
Q110S01-10 CRANKCASE ASSY
Q115S01-02 ROCKER COVER & CAMSHAFT
Q115S01-05 ROCKER COVER (25HP)
Q115S02-01 AIR BREATHER
Q116S01-05 CYLINDER HEAD (25HP)
Q116S02-01 LIFTING EYE
Q120S02-02 PISTON (25HP)
Q120S03-02 CONNECTION ROD
Q120S04-03 CRANKSHAFT (25HP)
Q121S01-04 VALVE MECHANISM (25HP)
Q125S01-05 FUEL SYSTEM
Q125S01-06 INJECTION PUMP (25HP)
Q125S01-07 GOVERNOR (25HP)
Q125S01-09 FUEL SYSTEM (25HP)
Q125S01-15 INJECTION PUMP ASSY (25HP)
Q125S02-01 FUEL PUMP & FILTER (25HP)
Q130S01-02 TIMING GEAR & CASE
Q130S01-05 TIMING GEAR & CASE (25HP)
Q135S01-06 COOLING SYSTEM (25HP)
Q140S01-01 OIL SYSTEM
Q140S01-05 OIL STRAINER (25HP)
Q140S01-06 OIL SYSTEM (25HP)
Q145S01-01 OIL PAN
Q150S01-02 FLYWHEEL & HOUSING (25HP)
Q155S02-02 REAR PLATE (25HP)
Q160S01-01 INLET & OUTLET MANIFOLD
Q165S01-02 EXHAUST MANIFOLD (25HP)
Q170S01-01 STARTER
Q175S01-02 ALTERNATOR (25HP)
Q180S01-03 ELECTRIC PARTS
Q180S01-06 GLOW PLUG & WIRE (25HP)
Q180S01-07 ELECTRIC PARTS (25HP)
02. ENGINE APPLICATION
G040S01-01 FUEL TANK (F,W-DIA KIT)
G040S02-01 FUEL LINE (25HP,F)
G040S04-01 FUEL PUMP & FILTER (25HP)
G100S01-02 THROTTLE PEDAL (MEC)
G100S01-04 THROTTLE LEVER (MEC)
G100S01-05 THROTTLE LEVER (HST)
G150S01-03 MUFFLER (25HP)
G170S01-06 RADIATOR (25HP)
G170S02-06 RADIATOR HOSE (25HP,F)
G190S01-03 AIR CLEANER (25HP)
G210S01-01 ENGINE FRAME (25HP)
G215S10-01 FRONT BALLAST DIA KIT (4 BALLAST,DIA KIT)
03. TRANSMISSION
G250S01-02 CLUTCH (MEC,TM DRVN)
G250S01-04 CLUTCH (MEC,INDP)
G250S02-02 CLUTCH HOUSING (HST)
G250S02-04 CLUTCH HOUSING (MEC)
G250S03-02 DAMPER (HST)
G260S01-02 CLUTH PEDAL (MEC)
G270S01-02 HST UNIT (HST)
G270S02-01 HST SEAL KIT (HST)
G270S02-02 HST ROTATING KIT (HST)
G270S02-03 HST RELIEF VALVE KIT (HST)
G280S01-01 TRANSMISSION CASE (HST,ECO-Version)
G280S01-02 TRANSMISSION CASE (MEC)
G281S01-02 MAIN SHAFT (MEC,TM DRVN)
G281S01-04 MAIN SHAFT (MEC,INDP)
G285S01-01 RANGE GEAR SHAFT (MEC)
G285S01-02 RANGE GEAR SHAFT (HST,ECO-Version)
G310S01-01 REAR DIFFERENTIAL
04. PTO DRIVE
G280S02-02 PTO SHIELD (ECO-Version)
G283S01-01 PTO CLUTCH & SHAFT (HST,ECO-Version)
G283S01-02 PTO SHAFT (MEC,TM DRVN)
G283S01-03 PTO CLUTCH & SHAFT (MEC,INDP)
G287S01-01 PTO GEAR & SHAFT (HST,ECO-Version)
G287S01-02 PTO GEAR & SHAFT (MEC,TM DRVN)
G287S01-03 MID PTO DRIVE SHAFT (M-PTO,DIA KIT)
G287S01-04 PTO GEAR & SHAFT (MEC,INDP)
G287S02-01 MID PTO LEVER (INDP,M-PTO,DIA KIT)
G287S02-02 MID PTO LEVER (TM DRVN,M-PTO,DIA KIT)
G287S02-03 MID PTO HOUSING (M-PTO,DIA KIT)
G287S04-01 PTO SHAFT CAP
05. FOUR WHEEL DRIVE (4WD)
G288S01-03 4WD SHAFT (25HP)
G400S01-01 FRONT AXLE ASSY (ECO-Version)
G400S02-01 FRONT AXLE CASE (ECO-Version)
G400S02-02 FRONT AXLE CASE (ECO-Version)
G400S03-01 FRONT DIFFERENTIAL (ECO-Version)
G400S04-01 FRONT DRIVE (ECO-Version)
G610S01-01 TIE-ROD
G630S01-08 STEERING CYLINDER (ECO-Version)
07. REAR AXLE & BRAKE
G480S01-01 REAR AXLE
G650S01-01 BRAKE
G650S01-02 BRAKE
G670S01-01 BRAKE PEDALS (F,MEC)
G670S01-06 BRAKE PEDALS (F,HST)
G670S02-02 PARKING BRAKE LEVER (MEC)
G670S02-05 PARKING BRAKE LEVER (F,HST)
08. SHIFT FORK & LINKAGE
G290S02-01 LEVER&FORK(MAIN GEAR) (MEC)
G290S03-01 LEVER&FORK(F-R GEAR) (MEC)
G291S01-01 LEVER&FORK(RANGE GEAR) (MEC)
G291S01-03 LEVER&FORK(RANGE GEAR) (F,HST)
G291S02-02 LEVER&FORK(4WD) (F)
G291S03-01 LEVER&FORK(PTO) (TM DRVN)
G291S03-02 LEVER&FORK(PTO) (INDP)
G292S01-03 HST PEDAL (25HP,F,HST)
G292S01-06 HST CONTROL LINKAGE (HST)
G292S01-08 HST CRUISE LEVER DIA KIT (S3L2,F,HST,DIA KIT)
G320S01-02 DIFF-LOCK (F,HST,ECO-Version)
G320S01-03 DIFF-LOCK (F,MEC)
G630S01-01 STEERING LINES (F,MEC)
G630S01-05 STEERING LINES (F,HST)
G640S01-02 T-M OIL COOLER (F,HST)
G640S02-01 HST FILTER & LINE (HST)
G822S02-01 INDP PTO VALVE (HST,INDP)
G822S02-02 INDP PTO VALVE (MEC,INDP)
G822S02-03 PTO VALVE PIPE LINE (MEC,INDP)
G822S03-01 LOADER VALVE (2-SPOOL)
G822S05-03 LOADER V-V EXTENSION PIPE (S3L2,DIA KIT)
G822S07-01 JOYSTICK LEVER (F,2-SPOOL)
G823S01-02 HYD. SUCTION LINES (25HP)
G823S02-04 HYD. F-PRESSURE LINES (F,HST)
G823S02-05 HYD. F-PRESSURE LINES (F,MEC)
G823S02-06 LOADER VALVE INET PIPE (HST)
G823S03-01 HYD. M-PRESSURE LINES (F,WO-RCV)
G827S01-02 REMOTE CONTROL VALVE (F,2-QC,DIA KIT)
G827S01-04 REMOTE CONTROL VALVE (F,4-QC,DIA KIT)
G730S01-01 ELECTRICAL WIRING(ENGINE) (25HP)
G730S01-05 ELECTRICAL WIRING(FRONT)
G730S01-06 ELECTRICAL WIRING(REAR) (F)
G730S02-02 7 POLE CONNECTOR (DIA KIT)
G730S03-01 HORN (DIA KIT)
G740S01-02 BATTERY
G750S01-03 METER PANEL (25HP)
G750S02-01 PTO SWITCH (INDP)
G750S03-01 PTO SHIFT SENSOR (TM DRVN)
G750S03-02 PTO SENSOR PLUG (INDP)
G750S03-03 F-R GEAR NEUTRAL SENSOR (MEC)
G750S11-03 RELAY & FUSE (F,MEC)
G750S11-04 RELAY & FUSE (F,HST)
G750S31-03 RH CONSOLE SWITCH (F,HST,INDP)
G750S31-04 RH CONSOLE SWITCH (F,MEC,INDP)
G750S41-01 DIAGNOSIS CONNECTOR
G750S51-01 EXTERNAL EG SHUTDOWN SWITCH (OPTIONAL,W-DIA KIT)
G760S01-03 HEAD LAMP
G760S01-07 TURN SIGNAL LAMP (F)
G760S01-09 REFLECTOR (F)
G760S01-12 WORK LAMP (F,DIA KIT)
11. HYDRAULIC LIFT UNIT
G820S01-04 HYD. HOUSING ASSY (F,ECO-Version)
G820S02-01 HYDRAULIC HOUSING (ECO-Version)
G822S01-01 LIFT CTRL. VALVE & LINK
G824S01-01 POSITION & DRAFT CTRL. LINK
G825S01-01 HYD. CONTROL LEVER (F,ECO-Version)
G825S30-01 EXTERNAL POSITION CONTROL LEVER (F, Optional,W-DIA KIT)
G826S01-01 HYDRAULIC CYLINDER
G828S01-01 UPPER LINK BRACKET
12. 3-POINT LINKAGE & HITCH
G891S01-01 DRAWBAR HITCH (DRAWBAR HITCH)
G891S01-02 DRAWBAR HITCH (CLEVIS DRAWBAR,DIA KIT)
G896S01-01 LOWER LINK (TELESCOPIC,W-DIA KIT)
G896S01-02 LOWER LINK (STD)
G896S01-03 TOP LINK HOOK
G896S01-04 UPPER LINK
G896S02-01 LIFT ROD
G896S03-01 CHECK LINK (C-LINK)
G896S03-02 CHECK LINK (TELESCOPIC,W-DIA KIT)
13. SHEET METALS & MOUNTS
G830S01-01 HOOD
G830S01-02 GRILLE ASSY
G830S02-02 HOOD SUPPORT (F)
G840S01-02 STEP & MOUNT RUBBER (F,MEC)
G840S01-04 STEP & MOUNT RUBBER (F,HST)
G840S03-01 SUB STEP(LH) (F)
G840S03-02 SUB STEP(RH) (F,OPTIONAL,W-DIA KIT)
14. DRIVER’S STATION
G630S02-03 STEERING COLUMN (F)
G630S03-01 STEERING WHEEL & CAP
G825S01-05 HYD. LEVER GUIDE (F)
G835S01-02 PEDAL FRAME (F)
G850S01-01 SEAT (WOOCHANG(MEC),ARM REST)
G850S01-02 SEAT (WOOCHANG(NO-SUSPENSION))
G850S01-03 SEAT (WOOCHANG(MEC),NO ARM)
G850S01-04 SEAT ARMREST (DIA KIT)
G850S01-05 SEAT SUSPENSION ASSY (DIA KIT)
G850S02-01 SEAT BRACKET (F)
G864S01-04 INTERIOR(FRONT) (25HP,F)
G866S01-04 ELECTRICAL WIRING (F)
G868S02-01 REAR MUD GUARD (F, DIA KIT)
G870S01-01 FENDER (F)
G880S01-01 SAFETY FRAME (F)
15. TIRES, WHEELS & REAR BALLAST
G490S01-01 WHEEL BOLTS & NUTS
16. ACCESSORY & ETC
G868S02-02 SLOW MOVING VEHICLES (F)
G920S02-01 TOOL BOX (W-DIA KIT,STD-Version)
G920S05-02 RUBBER PLUG
G920S07-02 CUP HOLDER (F, optional)
17. DECALS
G980S01-03 MODEL DECAL (ECO-Version)
G980S01-06 SAFETY DECAL (F)
18. DIA KIT & SVC KIT
G040S01-02 FUEL TANK (C,W-DIA KIT)
G990S01-01 DIA KIT LIST (LSTA)
Brand: LS
01. ENGINE
Q145S01-01 OIL PAN
Q170S01-01 STARTER
03. TRANSMISSION
04. PTO DRIVE
G610S01-01 TIE-ROD
G650S01-01 BRAKE
G650S01-02 BRAKE
G740S01-02 BATTERY
G896S02-01 LIFT ROD
G830S01-01 HOOD
16. ACCESSORY & ETC
17. DECALS
- LS Tractor J Series J2023H Parts Catalog
- LS Tractor KAI Series K5047 Parts Catalog
- LS Tractor KAI Series K5055 Parts Catalog
- LS Tractor MT1 Series MT125 Parts Catalog
- LS Tractor MT2 Series MT232 MT242 Parts Catalog
- LS Tractor MT2E Series MT225E MT225HE (with S3L2) Parts Catalog
- LS Tractor MT2E Series MT226E MT232E MT242E (with 3TNV88 4TNV88) Parts Catalog
- LS Tractor MT2E Series MT230E MT230HE MT235E MT235HE (with L3C19-D) Parts Catalog
- LS Tractor MT2E Series MT230E MT230HE MT235E MT235HE (with L3CRNV) Parts Catalog
- LS Tractor MT2E Series MT235E MT235HE MT240HE (with L3CRTV) Parts Catalog
- LS Tractor MT2E Series MT240E MT240HE (with L3C19-T) Parts Catalog
- LS Tractor MT2E Series MT240E MT240HE (with L3CRTV) Parts Catalog
- LS Tractor MT2S Series MT225S Parts Catalog
- LS Tractor MT3 Series MT335H MT335HC MT340HC (STAGE5) Parts Catalog
- LS Tractor MT3 Series MT342 MT347 MT352 MT355 (STAGE5) Parts Catalog
