LS Tractor MT2E Series MT240E MT240HE (with L3CRTV) Parts Catalog
Brand: LS
Model: LS MT2E Series MT240E MT240HE (Roll-bar model with L3CRTV engine (STAGE5)) Tractor
Number of Pages: 302 Pages
01. ENGINE
G010S01-06 ENGINE LONG BLOCK ASSY
G010S01-10 ENGINE SHORT BLOCK ASSY
G010S02-01 PILOT BEARING (MEC)
Q110S01-04 CRANKCASE ASSY
Q110S02-03 CRANKCASE
Q115S01-04 ROCKER COVER & CAMSHAFT
Q115S02-02 BLOW BY GAS HOSE
Q116S01-04 CYLINDER HEAD
Q120S01-02 MAIN MOVING PARTS
Q121S01-03 VALVE MECHANISM
Q125S01-08 FUEL SYSTEM
Q125S02-07 FUEL FILTER
Q125S04-01 INJECTION PUMP
Q130S01-03 TIMING GEAR & CASE
Q135S01-04 COOLING SYSTEM
Q140S01-03 OIL SYSTEM
Q145S01-03 OIL PAN
Q160S01-03 INLET & OUTLET MANIFOLD
Q166S01-01 EGR
Q166S02-01 EGR VV SVC KIT (ERAE to KAMTEC)
Q167S01-02 DOC&DPF
Q167S01-03 DPF SUPPORT (F or WO-AIR-CON)
Q180S01-05 ELECTRIC PARTS
Q180S01-09 ELECTRIC PARTS
Q180S02-01 MAF SENSOR
Q185S01-06 TURBOCHARGER
02. ENGINE APPLICATION
G040S01-02 FUEL TANK
G100S01-04 THROTTLE PEDAL (MEC)
G100S01-05 THROTTLE LEVER
G130S01-01 FUEL COOLER
G150S01-02 MUFFLER
G170S01-02 RADIATOR
G190S01-02 AIR CLEANER
G210S01-02 ENGINE FRAME
03. TRANSMISSION
G250S01-01 CLUTCH (MEC,w-damper)
G250S02-03 CLUTCH HOUSING (MEC)
G250S02-04 CLUTCH HOUSING (HST)
G250S03-01 DAMPER (HST)
G260S01-02 CLUTCH PEDAL (MEC,EXP)
G270S01-01 HST UNIT (HST)
G270S01-03 HST SEAL KIT (HST)
G270S01-04 HST ROTATING KIT (HST)
G280S01-01 TRANSMISSION CASE (MEC)
G280S01-02 TRANSMISSION CASE (HST)
G285S01-01 RANGE GEAR SHAFT (HST)
G285S01-02 RANGE GEAR SHAFT (MEC)
G310S01-01 REAR DIFFERENTIAL
04. PTO DRIVE
G280S02-01 PTO SHIELD (STD)
G283S01-01 PTO CLUTCH & SHAFT (HST)
G283S01-03 PTO CLUTCH & SHAFT (MEC)
G287S01-02 MID PTO DRIVE SHAFT (M-PTO)
G287S02-01 MID PTO LEVER (M-PTO,W-DIA KIT)
G287S02-02 MID PTO HOUSING (M-PTO)
G287S04-01 PTO SHAFT CAP
05. FOUR WHEEL DRIVE (4WD)
G288S01-02 4WD SHAFT & COVER
G400S01-02 FRONT AXLE ASSY
G400S02-03 FRONT AXLE CASE
G400S02-04 FRONT AXLE CASE(LH,RH)
G400S03-01 FRONT DIFFERENTIAL
G400S04-01 FRONT DRIVE
G610S01-02 TIE-ROD
G630S01-03 STEERING CYLINDER
07. REAR AXLE & BRAKE
G480S01-01 REAR AXLE(RH)
G480S01-02 REAR AXLE(LH)
G650S01-01 BRAKE
G670S01-01 BRAKE PEDALS (HST)
G670S01-02 BRAKE PEDALS (MEC)
G670S02-01 PARKING BRAKE LEVER (MEC,W-SWITCH)
G670S02-03 PARKING BRAKE LEVER (HST,W-SWITCH)
08. SHIFT FORK & LINKAGE
G290S02-01 LEVER&FORK(MAIN GEAR) (MEC)
G290S03-01 LEVER&FORK(F-R GEAR) (MEC)
G291S01-01 LEVER&FORK(RANGE GEAR)
G291S02-06 LEVER&FORK(4WD) (PTO1,M-PTO)
G292S01-01 HST PEDAL (HST)
G292S01-02 HST CONTROL LINK (HST)
G292S01-03 HST CRUISE LEVER (HST)
G320S01-01 DIFF-LOCK (MEC)
G320S01-02 DIFF-LOCK (HST)
G630S01-04 PTO HYD. PIPES (MEC)
G630S01-05 PTO HYD. PIPES (HST)
G630S01-07 STEERING LINES
G630S01-13 STEERING HOSE GUIDE (MEC)
G640S01-02 HST FILTER & PIPES (HST)
G640S01-03 T-M OIL COOLER (HST)
G822S02-01 INDP PTO VALVE
G822S03-03 LOADER VALVE (L-V)
G823S01-06 HYD. SUCTION LINES
G823S02-03 HYD. F-PRESSURE LINES (L-V)
G823S03-01 HYD. M-PRESSURE LINES (L-V,W-O-RCV)
G827S01-01 REMOTE CONTROL VALVE KIT (2-QC,L-V,SPR-N,DIA KIT)
G827S01-03 REMOTE CONTROL VALVE KIT (4-QC,L-V,DIA KIT)
G730S01-03 ELECTRICAL WIRING
G730S01-10 MAIN HARNESS
G730S01-11 REAR HARNESS
G730S04-02 MAIN FUSE
G740S01-07 BATTERY (80A)
G750S01-05 METER PANEL
G750S01-06 RELAYS & FUSE
G750S01-07 ECU BRACKET
G750S01-26 DIAGNOSIS CONNECTOR
G760S01-01 LAMP (F)
G760S01-03 HEAD LAMP
11. HYDRAULIC LIFT UNIT
G820S01-01 HYD. HOUSING ASSY
G820S02-01 HYDRAULIC HOUSING
G822S01-01 LIFT CTRL. VALVE & LINK
G824S01-01 POSITION & DRAFT LINK
G825S01-03 HYD. CONTROL LEVER
G825S01-04 LEVER STOPPER
G826S01-01 HYDRAULIC CYLINDER
G828S01-01 UPPER LINK BRACKET (W-O DRAFT)
12. 3-POINT LINKAGE & HITCH
G891S01-02 DRAWBAR & HITCH (TELESCOPIC DRAWBAR)
G896S01-02 LOWER LINK (GENERAL)
G896S01-05 UPPER LINK
G896S01-07 TOP LINK HOOK
G896S02-01 LIFT ROD (NO-NEVEL,CAT1)
G896S03-02 CHECK LINK (TELESCOPIC STABILIZER)
13. SHEET METALS & MOUNTS
G830S01-07 GRILLE ASSY (S-BLUE)
G830S01-08 HOOD (S-BLUE)
G830S02-02 HOOD SUPPORT (LSTA)
G840S01-01 STEP & MOUNT RUBBER (HST,S-BLUE)
G840S01-02 STEP & MOUNT RUBBER (MEC,S-BLUE)
G840S01-06 STEP MAT (MEC)
G840S01-07 STEP MAT (HST)
G840S01-12 SUB STEP
14. DRIVER’S STATION
G630S02-01 STEERING COLUMN
G630S02-02 STEERING WHEEL
G825S01-01 HYD. LEVER GUIDE
G830S04-01 INTERIOR(FRONT)
G835S01-01 PEDAL FRAME
G850S01-03 SEAT (WOOCHANG,BLACK)
G870S01-01 FENDER (S-BLUE,PTO1)
G880S01-01 SAFETY FRAME (R-ROPS(FOLDERBLE),W-SVC KIT)
15. TIRES, WHEELS & REAR BALLAST
G490S01-01 WHEEL BOLTS & NUTS
16. ACCESSORY & ETC
G868S02-01 SLOW MOVING VEHICLES
G920S02-01 TOOL BOX (LSTA with DIA KIT)
G920S05-01 BOLT CAP
G920S05-02 RUBBER PLUGS
G920S07-01 CUP HOLDER (F,OPTIONAL)
17. DECALS
G980S01-21 MODEL DECAL
G980S01-22 SAFETY DECAL
18. DIA KIT & SVC KIT
G990S01-01 DIA KIT LIST (LSTA)
G991S01-01 SVC KIT LIST (ERAE to KAMTEC)
Brand: LS
01. ENGINE
Q145S01-03 OIL PAN
Q166S01-01 EGR
Q167S01-02 DOC&DPF
G150S01-02 MUFFLER
G170S01-02 RADIATOR
03. TRANSMISSION
04. PTO DRIVE
G610S01-02 TIE-ROD
G650S01-01 BRAKE
G760S01-01 LAMP (F)
G840S01-12 SUB STEP
16. ACCESSORY & ETC
G920S05-01 BOLT CAP
17. DECALS
- LS Tractor J Series J2023H Parts Catalog
- LS Tractor KAI Series K5047 Parts Catalog
- LS Tractor KAI Series K5055 Parts Catalog
- LS Tractor MT1 Series MT125 Parts Catalog
- LS Tractor MT2 Series MT232 MT242 Parts Catalog
- LS Tractor MT2E Series MT225E MT225HE (with S3L2) Parts Catalog
- LS Tractor MT2E Series MT226E (with S3L2) Parts Catalog
- LS Tractor MT2E Series MT226E MT232E MT242E (with 3TNV88 4TNV88) Parts Catalog
- LS Tractor MT2E Series MT230E MT230HE MT235E MT235HE (with L3C19-D) Parts Catalog
- LS Tractor MT2E Series MT230E MT230HE MT235E MT235HE (with L3CRNV) Parts Catalog
- LS Tractor MT2E Series MT235E MT235HE MT240HE (with L3CRTV) Parts Catalog
- LS Tractor MT2E Series MT240E MT240HE (with L3C19-T) Parts Catalog
- LS Tractor MT2S Series MT225S Parts Catalog
- LS Tractor MT3 Series MT335H MT335HC MT340HC (STAGE5) Parts Catalog
- LS Tractor MT3 Series MT342 MT347 MT352 MT355 (STAGE5) Parts Catalog
