Momed80
150
35,046
LS Tractor MT2E Series MT226E MT232E MT242E (with 3TNV88 4TNV88) Parts Catalog
Brand: LS
Model: LS MT2E Series MT226E MT232E MT242E (Roll-bor or Cabin model with 3TNV88 4TNV88 engine(2023)) Tractor
Number of Pages: 724 Pages
01. ENGINE
G010S01-01 ENGINE (25HP)
G010S01-02 ENGINE (32HP,42HP)
G010S02-01 PILOT BEARING (MEC)
Q110S01-06 CYLINDER BLOCK (25HP)
Q110S01-07 CYLINDER BLOCK (32HP)
Q110S01-08 CYLINDER BLOCK (42HP)
Q115S01-06 CAMSHAFT & DRIVING GEAR (25HP)
Q115S01-07 CAMSHAFT & DRIVING GEAR (32HP)
Q115S01-08 CAMSHAFT & DRIVING GEAR (42HP)
Q116S01-02 CYLINDER HEAD & BONNET (25HP)
Q116S01-03 CYLINDER HEAD & BONNET (32HP)
Q116S01-04 CYLINDER HEAD & BONNET (42HP)
Q120S02-03 CRANKSHAFT & PISTON (25HP)
Q120S02-04 CRANKSHAFT & PISTON (32HP)
Q120S02-05 CRANKSHAFT & PISTON (42HP)
Q125S01-10 FUEL INJECTION PUMP (25HP)
Q125S01-11 FUEL INJECTION PUMP (32HP,42HP)
Q125S01-12 GOVERNOR (25HP)
Q125S01-13 FUEL PIPE (32HP)
Q125S01-14 FUEL PIPE (42HP)
Q125S02-02 FUEL PUMP & FILTER (25HP)
Q125S02-03 FUEL PUMP & FILTER (32HP)
Q125S02-04 FUEL PUMP & FILTER (42HP)
Q125S03-01 FUEL INJECTION VALVE (25HP)
Q125S03-02 FUEL INJECTION VALVE (32HP)
Q125S03-03 FUEL INJECTION VALVE (42HP)
Q130S01-03 GEAR HOUSING (25HP)
Q130S01-04 GEAR HOUSING (32HP,42HP)
Q135S01-01 COOLING WATER SYSTEM (25HP)
Q135S01-02 COOLING WATER SYSTEM (32HP)
Q135S01-03 COOLING WATER SYSTEM (42HP)
Q140S01-07 LUB. OIL SYSTEM (25HP)
Q140S01-08 LUB. OIL SYSTEM (32HP)
Q140S01-09 LUB. OIL SYSTEM (42HP)
Q145S01-02 OIL SUMP (25HP)
Q145S01-03 OIL SUMP (32HP)
Q145S01-04 OIL SUMP (42HP)
Q145S01-05 STARTER MOTOR (25HP,32HP)
Q145S01-06 STARTER MOTOR (42HP)
Q146S01-01 BALANCER (42HP)
Q150S01-03 FLYWHEEL HOUSING (25HP)
Q150S01-04 FLYWHEEL HOUSING (32HP,42HP)
Q160S02-01 SUCTION MANIFOLD (25HP)
Q160S02-02 SUCTION MANIFOLD (32HP)
Q160S02-03 SUCTION MANIFOLD (42HP)
Q165S01-01 EXHAUST MANIFOLD (25HP)
Q165S01-03 EXHAUST MANIFOLD (32HP)
Q165S01-04 EXHAUST MANIFOLD (42HP)
Q167S01-01 DOC&DPF (32HP)
Q167S01-02 DOC&DPF (42HP)
Q175S01-03 GENERATOR (25HP)
Q175S01-04 GENERATOR (32HP)
Q175S01-05 GENERATOR (42HP)
Q180S01-08 ELECTRONIC CONTROL UNIT(ECU) (25HP)
Q180S01-09 ELECTRONIC CONTROL UNIT(ECU) (32HP)
Q180S01-10 ELECTRONIC CONTROL UNIT(ECU) (42HP)
Q180S01-11 ELECTRIC PARTS (32HP)
Q180S01-12 ELECTRIC PARTS (42HP)
02. ENGINE APPLICATION
G040S01-01 FUEL TANK (F,W-DIA KIT)
G040S01-02 FUEL TANK (C,W-DIA KIT)
G040S02-02 FUEL LINE (32HP,42HP,F)
G040S02-03 FUEL LINE (25HP,C)
G040S02-04 FUEL LINE (C,32HP)
G040S02-05 FUEL LINE (C,42HP)
G040S04-02 FUEL PUMP & FILTER (25HP)
G040S04-03 FUEL PUMP & FILTER (32HP)
G040S04-04 FUEL PUMP & FILTER (42HP)
G100S01-01 THROTTLE LEVER (MEC)
G100S01-02 THROTTLE PEDAL (MEC)
G100S01-03 THROTTLE LEVER (HST)
G130S01-01 FUEL COOLER (32HP.42HP)
G150S01-01 MUFFLER (25HP)
G150S01-02 MUFFLER (32HP,42HP)
G170S01-01 RADIATOR (25HP)
G170S01-02 RADIATOR (32HP)
G170S01-03 RADIATOR (42HP)
G170S02-01 RADIATOR HOSE (25HP,C)
G170S02-02 RADIATOR HOSE (32HP,F)
G170S02-03 RADIATOR HOSE (32HP,C)
G170S02-04 RADIATOR HOSE (42HP,C)
G170S02-05 RADIATOR HOSE (42HP,F)
G190S01-01 AIR CLEANER (32HP,42HP)
G190S01-02 AIR CLEANER (25HP)
G210S01-02 ENGINE FRAME (25HP)
G210S01-03 ENGINE FRAME (32HP)
G210S01-04 ENGINE FRANE (42HP)
G215S10-01 FRONT BALLAST DIA KIT (4 BALLAST,DIA KIT)
03. TRANSMISSION
G250S01-01 CLUTCH (MEC,TM DRVN)
G250S01-03 CLUTCH (MEC,INDP)
G250S02-01 CLUTCH HOUSING (HST)
G250S02-03 CLUTCH HOUSING (MEC)
G250S03-01 DAMPER (HST,ECO-Version)
G260S01-01 CLUTH PEDAL (MEC)
G270S01-01 HST UNIT (HST)
G270S02-01 HST SEAL KIT (HST)
G270S02-02 HST ROTATING KIT (HST)
G270S02-03 HST RELIEF VALVE KIT (HST)
G280S01-01 TRANSMISSION CASE (HST,ECO-Version)
G280S01-02 TRANSMISSION CASE (MEC)
G281S01-01 MAIN SHAFT (MEC,TM DRVN)
G281S01-03 MAIN SHAFT (MEC,INDP)
G285S01-01 RANGE GEAR SHAFT (MEC)
G285S01-02 RANGE GEAR SHAFT (HST,ECO-Version)
G310S01-01 REAR DIFFERENTIAL
04. PTO DRIVE
G280S02-02 PTO SHIELD (ECO-Version)
G283S01-01 PTO CLUTCH & SHAFT (HST,ECO-Version)
G283S01-02 PTO SHAFT (MEC,TM DRVN)
G283S01-04 PTO CLUTCH & SHAFT (MEC,INDP)
G287S01-01 PTO GEAR & SHAFT (HST,ECO-Version)
G287S01-02 PTO GEAR & SHAFT (MEC,TM DRVN)
G287S01-03 MID PTO DRIVE SHAFT (M-PTO,DIA KIT)
G287S01-04 PTO GEAR & SHAFT (MEC,INDP)
G287S02-01 MID PTO LEVER (INDP,M-PTO,DIA KIT)
G287S02-02 MID PTO LEVER (TM DRVN,M-PTO,DIA KIT)
G287S02-03 MID PTO HOUSING (M-PTO,DIA KIT)
G287S04-01 PTO SHAFT CAP
05. FOUR WHEEL DRIVE (4WD)
G288S01-01 4WD SHAFT (25HP,32HP,ECO-Version)
G288S01-02 4WD SHAFT (42HP,ECO-Version)
G400S01-01 FRONT AXLE ASSY (ECO-Version)
G400S02-01 FRONT AXLE CASE (ECO-Version)
G400S02-02 FRONT AXLE CASE (ECO-Version)
G400S03-01 FRONT DIFFERENTIAL (ECO-Version)
G400S04-01 FRONT DRIVE (ECO-Version)
G610S01-01 TIE-ROD
G630S01-08 STEERING CYLINDER (ECO-Version)
07. REAR AXLE & BRAKE
G480S01-01 REAR AXLE
G650S01-02 BRAKE
G670S01-01 BRAKE PEDALS (F,MEC)
G670S01-04 BRAKE PEDALS (C,HST)
G670S01-06 BRAKE PEDALS (F,HST)
G670S01-07 REAR BRAKE LINKAGE (C,HST)
G670S02-01 PARKING BRAKE LEVER (MEC)
G670S02-03 PARKING BRAKE LEVER (C,HST)
G670S02-04 PARKING BRAKE LEVER (F,HST)
08. SHIFT FORK & LINKAGE
G290S02-01 LEVER&FORK(MAIN GEAR) (MEC)
G290S03-01 LEVER&FORK(F-R GEAR) (MEC)
G291S01-01 LEVER&FORK(RANGE GEAR) (MEC)
G291S01-02 LEVER&FORK(RANGE GEAR) (C,HST)
G291S01-03 LEVER&FORK(RANGE GEAR) (F,HST)
G291S02-01 LEVER&FORK(4WD) (C)
G291S02-02 LEVER&FORK(4WD) (F)
G291S03-01 LEVER&FORK(PTO) (TM DRVN)
G291S03-02 LEVER&FORK(PTO) (INDP)
G292S01-01 HST PEDAL (C,HST,NO-Linked Pedal)
G292S01-03 HST PEDAL (25HP,F,HST)
G292S01-04 HST PEDAL (32HP,42HP,F,HST)
G292S01-06 HST CONTROL LINKAGE (HST)
G320S01-01 DIFF-LOCK (C,HST,ECO-Version)
G320S01-02 DIFF-LOCK (F,HST,ECO-Version)
G320S01-03 DIFF-LOCK (F,MEC)
G630S01-02 STEERING LINES (32HP,F,MEC)
G630S01-03 STEERING LINES (42HP,F,MEC)
G630S01-04 STEERING LINES (C,HST)
G630S01-06 STEERING LINES (32HP,F,HST)
G630S01-07 STEERING LINES (42HP,F,HST)
G640S01-01 T-M OIL COOLER (C,HST)
G640S01-03 T-M OIL COOLER (F,HST)
G640S02-01 HST FILTER & LINE (HST)
G822S02-01 INDP PTO VALVE (HST,INDP)
G822S02-02 INDP PTO VALVE (MEC,INDP)
G822S02-03 PTO VALVE PIPE LINE (MEC,INDP)
G822S03-01 LOADER VALVE (2-SPOOL)
G822S05-04 LOADER V-V EXTENSION PIPE (3TNV,4TNV,DIA KIT)
G822S07-01 JOYSTICK LEVER (F,2-SPOOL)
G822S07-02 JOYSTICK LEVER (C,2-SPOOL)
G823S01-01 HYD. SUCTION LINES (ECO-Version)
G823S02-01 HYD. F-PRESSURE LINES (C,HST)
G823S02-02 HYD. F-PRESSURE LINES (F,HST)
G823S02-03 HYD. F-PRESSURE LINES (F,MEC)
G823S02-06 LOADER VALVE INET PIPE (HST)
G823S03-01 HYD. M-PRESSURE LINES (F,WO-RCV)
G823S03-02 HYD. M-PRESSURE LINES (C,W-RCV)
G827S01-02 REMOTE CONTROL VALVE (F,2-QC,DIA KIT)
G827S01-03 REMOTE CONTROL VALVE (C,4-QC,DIA KIT)
G827S01-04 REMOTE CONTROL VALVE (F,4-QC,DIA KIT)
G827S01-05 REMOTE CONTROL LEVER (C,SD5-1)
G827S01-07 REMOTE CONTROL VALVE (C,SD5-1)
G827S02-02 REMOTE CONTROL VALVE (C,SD5-1)
G730S01-02 ELECTRICAL WIRING(ENGINE) (25HP)
G730S01-03 ELECTRICAL WIRING(ENGINE) (32HP)
G730S01-04 ELECTRICAL WIRING(ENGINE) (42HP)
G730S01-05 ELECTRICAL WIRING(FRONT)
G730S01-06 ELECTRICAL WIRING(REAR) (F)
G730S01-07 ELECTRICAL WIRING(REAR) (C)
G730S01-08 HARNESS BRACKET (32HP,42HP,F)
G730S01-09 HARNESS BRACKET (32HP,42HP,C)
G730S01-11 CABIN EARTH CABLE (C)
G730S02-02 7 POLE CONNECTOR (DIA KIT)
G730S03-01 HORN (DIA KIT)
G730S04-01 MAIN FUSE
G740S01-01 BATTERY
G750S01-01 METER PANEL (25HP,ECO-Version)
G750S01-02 METER PANEL (32HP,42HP)
G750S02-01 PTO SWITCH (INDP)
G750S03-01 PTO SHIFT SENSOR (TM DRVN)
G750S03-02 PTO SENSOR PLUG (INDP)
G750S03-03 F-R GEAR NEUTRAL SENSOR (MEC)
G750S03-05 LINKED PEDAL SENSOR (32HP,42HP,HST(Linked Pedal),DIA KIT,ECO-Version)
G750S11-01 RELAY & FUSE (25HP,C,ECO-Version)
G750S11-02 RELAY & FUSE (32HP,42HP,C)
G750S11-03 RELAY & FUSE (F,MEC)
G750S11-04 RELAY & FUSE (F,HST)
G750S21-01 ECU BRACKET (25HP,C)
G750S21-02 ECU BRACKET (32HP,42HP)
G750S31-02 RH CONSOLE SWITCH (C,ECO-Version)
G750S31-03 RH CONSOLE SWITCH (F,HST,INDP)
G750S31-04 RH CONSOLE SWITCH (F,MEC,INDP)
G750S41-01 DIAGNOSIS CONNECTOR
G750S51-01 EXTERNAL EG SHUTDOWN SWITCH (OPTIONAL,W-DIA KIT)
G760S01-03 HEAD LAMP
G760S01-04 REAR COMBINATION LAMP (C)
G760S01-05 REFLECTOR SHEET (C)
G760S01-06 TURN SIGNAL LAMP (C)
G760S01-07 TURN SIGNAL LAMP (F)
G760S01-08 SIDE LAMP & SWTICH (32HP,42HP,C,W-SIDE LAMP,W-DIA KIT)
G760S01-09 REFLECTOR (F)
G760S01-10 FRONT WORK LAMP (C,DIA KIT)
G760S01-11 REAR WORK LAMP (C,DIA KIT)
G760S01-12 WORK LAMP (F,DIA KIT)
G760S03-01 BEACON LAMP SOCKET (C)
G760S03-02 BEACON LAMP (C,DIA KIT)
11. HYDRAULIC LIFT UNIT
G820S01-03 HYD. HOUSING ASSY (C,ECO-Version)
G820S01-04 HYD. HOUSING ASSY (F,ECO-Version)
G820S02-01 HYDRAULIC HOUSING (ECO-Version)
G822S01-01 LIFT CTRL. VALVE & LINK
G824S01-01 POSITION & DRAFT CTRL. LINK
G825S01-01 HYD. CONTROL LEVER (F,ECO-Version)
G825S01-02 HYD. HOUSING LEVER (C)
G825S01-03 HYD. CONTROL LEVER (C)
G825S30-01 EXTERNAL POSITION CONTROL LEVER (F, Optional,W-DIA KIT)
G825S30-02 EXTERNAL POSITION CONTROL LEVER (C, Optional,W-DIA KIT)
G826S01-01 HYDRAULIC CYLINDER
G828S01-01 UPPER LINK BRACKET
12. 3-POINT LINKAGE & HITCH
G891S01-01 DRAWBAR HITCH (DRAWBAR HITCH)
G891S01-02 DRAWBAR HITCH (CLEVIS DRAWBAR,DIA KIT)
G896S01-01 LOWER LINK (TELESCOPIC,W-DIA KIT)
G896S01-02 LOWER LINK (STD)
G896S01-03 TOP LINK HOOK
G896S01-04 UPPER LINK
G896S02-01 LIFT ROD
G896S03-01 CHECK LINK (C-LINK)
G896S03-02 CHECK LINK (TELESCOPIC,W-DIA KIT)
13. SHEET METALS & MOUNTS
G830S01-01 HOOD
G830S01-02 GRILLE ASSY
G830S01-03 SAFETY COVER (OPTIONAL)
G830S02-01 HOOD SUPPORT (C)
G830S02-03 HOOD SUPPORT (32HP,42HP,F)
G840S01-01 MOUNT RUBBER (C)
G840S01-03 STEP & MOUNT RUBBER (F,MEC)
G840S01-05 STEP & MOUNT RUBBER (F,HST)
G840S03-01 SUB STEP(LH) (F)
G840S03-02 SUB STEP(RH) (F,OPTIONAL,W-DIA KIT)
G840S03-03 SUB STEP(LH) (C)
G840S03-04 SUB STEP(RH) (C,OPTIONAL,W-DIA KIT)
14. DRIVER’S STATION
G630S02-01 STEERING COLUMN (C)
G630S02-02 STEERING COLUMN (F)
G630S03-01 STEERING WHEEL & CAP
G825S01-04 HYD. LEVER GUIDE (C)
G825S01-05 HYD. LEVER GUIDE (F)
G835S01-01 PEDAL FRAME (C)
G835S01-03 PEDAL FRAME (F)
G850S01-01 SEAT (WOOCHANG(MEC),ARM REST)
G850S01-02 SEAT (WOOCHANG(NO-SUSPENSION))
G850S01-03 SEAT (WOOCHANG(MEC),NO ARM)
G850S01-04 SEAT ARMREST (DIA KIT)
G850S01-05 SEAT SUSPENSION ASSY (DIA KIT)
G850S02-01 SEAT BRACKET (F)
G850S02-02 SEAT BRACKET (C)
G861S01-01 FRAME (C)
G862S01-01 DOOR(LH) (C,SIDE LAMP)
G862S01-02 DOOR(LH) (C,NO-SIDE LAMP)
G862S01-03 DOOR(RH) (C)
G862S02-01 DOOR HANDLE ASSY (C)
G863S01-01 FRONT WINDOW (C)
G863S01-02 SIDE WINDOW (C)
G863S02-01 REAR WINDOW (C)
G864S01-01 INTERIOR(FRONT) (32HP,42HP,C)
G864S01-02 INTERIOR(FRONT) (25HP,C,ECO-Version)
G864S01-03 INTERIOR(FRONT) (32HP,42HP,F)
G864S02-01 INTERIOR(RH) (C)
G864S03-01 INTERIOR(LH) (C)
G864S04-01 INTERIOR(TOP) (C)
G864S07-01 JOYSTICK COVER (C)
G865S01-01 AIR-CON BLOWER (25HP,C)
G865S01-02 AIR-CON BLOWER (32HP,C)
G865S01-03 AIR-CON BLOWER (42HP,C)
G865S01-04 AIR-CON COMPRESSOR (25HP,C)
G865S01-05 AIR-CON COMPRESSOR (32HP,C)
G865S01-06 AIR-CON COMPRESSOR (42HP,C)
G865S01-07 AIR-CON LINE (25HP,C)
G865S01-08 AIR-CON LINE (32HP,C)
G865S01-09 AIR-CON LINE (42HP,C)
G865S02-01 AIR-CON UNIT (C)
G866S01-01 ELECTRICAL WIRING (C,ECO-Version)
G866S01-03 ELECTRICAL WIRING (F)
G866S02-01 WINDOW WIPER(FRONT) (C)
G866S02-02 WINDOW WIPER(REAR) (C,W-WIPER,W-DIA KIT)
G866S02-03 WINDOW WIPER(REAR) (C,NO-WIPER)
G866S03-01 AUDIO (C,W-DIA KIT)
G866S03-02 SPEAKER & ANTENNA (C)
G867S01-01 ROOF (C)
G868S01-01 EXTERIOR (C)
G868S02-01 REAR MUD GUARD (F, DIA KIT)
G869S01-01 MISCELLANY (C)
G869S01-02 REAR VIEW MIRROR (C,STD-Version,W-DIA KIT)
G869S01-03 ROOM MIRROR (C)
G870S01-01 FENDER (F)
G880S01-01 SAFETY FRAME (F)
15. TIRES, WHEELS & REAR BALLAST
G490S01-01 WHEEL BOLTS & NUTS
16. ACCESSORY & ETC
G868S02-01 SLOW MOVING VEHICLES (C)
G868S02-02 SLOW MOVING VEHICLES (F)
G920S02-01 TOOL BOX (W-DIA KIT,STD-Version)
G920S05-01 BOLT CAP (C)
G920S05-02 RUBBER PLUG
G920S07-01 CUP HOLDER (C, optional)
G920S07-02 CUP HOLDER (F, optional)
17. DECALS
G980S01-02 MODEL DECAL (ECO-Version)
G980S01-04 SAFETY DECAL (F)
G980S01-05 SAFETY DECAL (C)
18. DIA KIT & SVC KIT
G990S01-01 DIA KIT LIST (LSTA)
