LS Tractor XR3100 Series XR3135 XR3140 (with L3CRTV) Parts Catalog
Brand: LS
Model: LS XR3100 Series XR3135 XR3140 (Roll-bar or Cabin model with L3CRTV engine (STAGE5)) Tractor
Number of Pages: 480 Pages
01. ENGINE
G010S01-07 ENGINE LONG BLOCK ASSY
G010S01-10 ENGINE SHORT BLOCK ASSY
G010S02-01 PILOT BEARING (MEC)
Q110S01-04 CRANKCASE ASSY
Q110S02-03 CRANKCASE
Q115S02-02 BLOW BY GAS HOSE
Q116S01-04 CYLINDER HEAD
Q120S01-02 MAIN MOVING PARTS
Q121S01-03 VALVE MECHANISM
Q125S01-08 FUEL SYSTEM
Q125S02-07 FUEL FILTER
Q125S04-01 INJECTION PUMP
Q130S01-04 TIMING GEAR & CASE
Q135S01-04 COOLING SYSTEM
Q140S01-04 OIL SYSTEM
Q145S01-03 OIL PAN
Q160S01-03 INLET & OUTLET MANIFOLD
Q166S01-01 EGR
Q166S02-01 EGR VV SVC KIT (ERAE to KAMTEC)
Q167S01-02 DOC&DPF
Q167S01-03 DPF SUPPORT (F or WO-AIR-CON)
Q180S01-04 ELECTRIC PARTS
Q180S01-10 ELECTRIC PARTS (L3CRTV)
Q180S02-01 MAF SENSOR
Q185S01-06 TURBOCHARGER
02. ENGINE APPLICATION
G040S01-04 FUEL TANK (F)
G040S01-05 FUEL TANK (C)
G100S01-05 THROTTLE LEVER
G100S01-06 THROTTLE PEDAL (C,MEC)
G100S01-07 THROTTLE PEDAL (F,MEC)
G130S01-01 FUEL COOLER
G150S01-02 MUFFLER
G170S01-03 RADIATOR (W-AIR-CON)
G170S01-04 RADIATOR (WO-AIR-CON)
G190S01-02 AIR CLEANER
G210S01-02 ENGINE FRAME
03. TRANSMISSION
G250S01-01 CLUTCH (MEC,w-damper)
G250S02-03 CLUTCH HOUSING (MEC)
G250S02-04 CLUTCH HOUSING (HST)
G250S03-01 DAMPER (HST)
G260S01-01 CLUTCH PEDAL (MEC)
G270S01-01 HST UNIT (HST)
G270S01-03 HST SEAL KIT (HST)
G270S01-04 HST ROTATING KIT (HST)
G280S01-01 TRANSMISSION CASE (MEC,NO-SPEEDOMETER)
G280S01-02 TRANSMISSION CASE (HST,NO-SPEEDOMETER)
G281S01-01 MAIN SHAFT (MEC)
G285S01-01 RANGE GEAR SHAFT (MEC)
G285S01-02 RANGE GEAR SHAFT (HST)
G310S01-01 REAR DIFFERENTIAL
04. PTO DRIVE
G280S02-01 PTO SHIELD (STD)
G280S02-03 PTO SHIELD (EC)
G283S01-02 PTO CLUTCH & SHAFT (HST)
G283S01-03 PTO CLUTCH & SHAFT (MEC)
G287S01-01 PTO GEAR & SHAFT (PTO1)
G287S01-02 MID PTO DRIVE SHAFT (M-PTO)
G287S02-01 MID PTO LEVER (C,M-PTO,W-DIA KIT)
G287S02-02 MID PTO LEVER (F,M-PTO,W-DIA KIT)
G287S02-03 MID PTO HOUSING (M-PTO,W-DIA KIT)
G287S04-01 PTO SHAFT CAP
05. FOUR WHEEL DRIVE (4WD)
G288S01-02 4WD SHAFT & COVER
G400S01-02 FRONT AXLE ASSY
G400S02-03 FRONT AXLE CASE
G400S02-04 FRONT AXLE CASE(LH,RH)
G400S03-01 FRONT DIFFERENTIAL
G400S04-01 FRONT DRIVE
G610S01-02 TIE-ROD
G630S01-03 STEERING CYLINDER
07. REAR AXLE & BRAKE
G480S01-01 REAR AXLE(RH)
G480S01-02 REAR AXLE(LH)
G650S01-01 BRAKE
G670S01-01 BRAKE ROD AND LINKAGE (MEC)
G670S01-02 BRAKE ROD AND LINKAGE (HST)
G670S01-05 BRAKE PEDALS (C-HST,S-HST)
G670S01-06 BRAKE PEDALS (MEC)
G670S02-01 PARKING BRAKE LEVER (C,MEC)
G670S02-02 PARKING BRAKE LEVER (C,HST)
G670S02-03 PARKING BRAKE LEVER (F,HST)
G670S02-04 PARKING BRAKE LEVER (F,MEC)
08. SHIFT FORK & LINKAGE
G290S02-02 LEVER&FORK(MAIN GEAR) (F,MEC)
G290S02-03 LEVER&FORK(MAIN GEAR) (C,GRAMMER,MEC)
G290S03-01 LEVER&FORK(F-R GEAR) (C,MEC)
G290S03-02 LEVER&FORK(F-R GEAR) (F,MEC)
G291S01-01 LEVER&FORK(RANGE GEAR) (MEC)
G291S01-02 LEVER&FORK(RANGE GEAR) (HST)
G291S02-01 LEVER&FORK(4WD)
G291S03-01 LEVER&FORK(PTO) (PTO1,M-PTO)
G292S01-01 HST CONTROL (C,HST)
G292S01-02 HST CONTROL (F,HST)
G320S01-01 DIFF-LOCK (MEC)
G320S01-02 DIFF-LOCK (HST)
G630S01-06 STEERING LINES (F)
G630S01-07 STEERING RESONATOR (C)
G630S01-10 STEERING LINES (C)
G630S01-11 STR.DRAIN PIPE (MEC,(F or C,USNH,USCI))
G630S01-12 STR.DRAIN PIPE (MEC,C,LSTA,DO)
G640S01-03 T-M OIL COOLER (HST)
G822S02-01 INDP PTO VALVE (HST or (MEC,USNH,USCI))
G822S02-02 INDP PTO VALVE (MEC,LSTA,DO)
G822S03-01 LOADER VALVE ((C,MEC,C-HST,L-V,W-COUPLER) or Non-EU)
G822S03-04 JOYSTICK LEVER (F,L-V)
G822S03-07 LOADER VALVE (F,L-V,W-COUPLER)
G822S03-09 LOADER VALVE COUPLER (F,L-V)
G822S03-11 LOADER VALVE COUPLER (C,MEC,C-HST,L-V)
G822S03-12 JOYSTICK LEVER (C,L-V)
G823S01-09 HYD. SUCTION LINES
G823S02-03 HYD. F-PRESSURE LINES (C,L-V,(HST or MEC,USNH,USCI))
G823S02-04 HYD. F-PRESSURE LINES (F,L-V)
G823S02-06 HYD. F-PRESSURE LINES (C,L-V,MEC,LSTA,DO)
G823S03-02 HYD. M-PRESSURE LINES (F,L-V,SD5-2)
G823S03-04 HYD. M-PRESSURE LINES (C,L-V,W-AUX)
G827S01-01 REMOTE CONTROL LEVER (C,SD5-2)
G827S01-02 REMOTE CONTROL LINES (C,SD5-2)
G827S01-04 REMOTE CONTROL LINES (F,SD5-2)
G827S02-01 REMOTE CONTROL VALVE (C,SD5-2)
G827S02-03 REMOTE CONTROL VALVE (F,SD5-2)
G730S01-05 ELECTRICAL WIRING
G730S02-01 7 POLE CONNECTOR (C)
G730S02-02 7 POLE CONNECTOR (F)
G730S03-01 HORN (Optional)
G730S04-01 MAIN FUSE
G740S01-07 BATTERY (80A)
G750S01-18 ECU
G750S01-20 METER PANEL
G750S01-21 RH CONSOLE SWITCH (C)
G750S01-22 RELAY & FUSE (C,C-HST,NO-SPEEDOMETER)
G750S01-23 RELAY & FUSE (F,C-HST,NO-SPEEDOMETER)
G750S01-24 RELAY & FUSE (C,MEC,NO-SPEEDOMETER)
G750S01-25 RELAY & FUSE (F,MEC,NO-SPEEDOMETER)
G750S01-26 DIAGNOSIS CONNECTOR
G750S01-55 RH CONSOLE SWITCH (F)
G760S01-01 REAR COMBINATION LAMP (C)
G760S01-03 HEAD LAMP
G760S01-04 REAR LAMP (F,STD)
G760S01-05 TURN SIGNAL LAMP (F)
G760S01-12 REAR WORK LAMP (C,W-DIA KIT)
G760S01-18 WORK LAMP (C)
G760S01-19 TURN SIGNAL LAMP (C,EXP)
G760S03-01 BEACON LAMP (C,W-DIA KIT)
G760S03-03 BEACON LAMP (C,W-DIA KIT)
11. HYDRAULIC LIFT UNIT
G820S01-03 HYD. HOUSING ASSY (F,W-DRAFT)
G820S01-05 HYD. HOUSING ASSY (C,W-DRAFT,EXT CTRL)
G820S02-01 HYDRAULIC HOUSING
G822S01-01 LIFT CTRL. VALVE & LINK
G824S01-01 POSITION & DRAFT LINK (W-DRAFT)
G825S01-03 HYD. CONTROL LEVER (F,W-DRAFT)
G825S01-09 HYD. CONTROL LEVER (C,W-DRAFT)
G825S01-15 HYD. HOUSING LEVER (C)
G825S02-01 EXTERNAL POSITION CONTROL LEVER (C, Optional)
G825S02-02 EXTERNAL POSITION CONTROL LEVER (F, Optional)
G826S01-01 HYDRAULIC CYLINDER
G828S01-01 UPPER LINK BRACKET (C,W-DRAFT)
G828S01-02 UPPER LINK BRACKET (F,W-DRAFT)
12. 3-POINT LINKAGE & HITCH
G891S01-02 DRAWBAR & HITCH (TELESCOPIC)
G896S01-02 LOWER LINK (TELESCOPIC)
G896S01-04 TOP LINK HOOK (F)
G896S01-05 TOP LINK HOOK (C,STD TOP LINK)
G896S01-10 UPPER LINK (STD TOP LINK)
G896S02-02 LIFT ROD (NO-LEVEL,LSTA)
G896S03-03 CHECK LINK (TELESCOPIC,BALL TYPE)
13. SHEET METALS & MOUNTS
G830S01-07 HOOD
G830S01-09 GRILLE ASSY (S-BLUE)
G830S02-02 HOOD SUPPORT
G840S01-01 MOUNT RUBBER (C)
G840S01-02 SUB STEP (C)
G840S01-03 MOUNT RUBBER (F,DO,LSTA)
G840S01-04 SUB STEP (F)
14. DRIVER’S STATION
G630S02-01 STEERING COLUMN (C)
G630S02-02 STEERING WHEEL
G630S02-05 STEERING COLUMN (F)
G825S01-02 HYD. LEVER GUIDE (C,W-DRAFT)
G825S01-05 HYD. LEVER GUIDE (F)
G835S01-01 PEDAL FRAME (C,HST)
G835S01-02 PEDAL FRAME (C,MEC)
G835S01-03 PEDAL FRAME (F,HST)
G835S01-04 PEDAL FRAME (F,MEC)
G850S01-02 SEAT (F,WOOCHANG,BLACK)
G850S01-05 SEAT (C,GRMMER,LS-GRAY)
G861S01-03 FRAME (F)
G861S01-04 FRAME (C,GRAMMER)
G862S01-01 DOOR(LH) (C)
G862S01-02 DOOR(RH) (C)
G863S01-01 FRONT & SIDE WINDOW (C)
G863S01-02 FRONT & SIDE WINDOW (F)
G863S02-01 REAR WINDOW (C,W-WIPER)
G863S02-02 REAR WINDOW (C,WO-WIPER)
G864S01-01 INTERIOR(RH) (C)
G864S01-02 INTERIOR(LH) (C)
G864S01-03 INTERIOR(TOP) (C)
G864S01-04 INTERIOR(FRONT)
G864S01-05 JOYSTICK COVER (C)
G864S01-06 INTERIOR(RH,LH) (F)
G864S01-11 JOYSTICK COVER (F,L-V)
G865S01-08 AIR-CON BLOWER (C)
G865S01-09 AIR-CON COMPRESSOR (C)
G865S01-10 AIR-CON LINE (C)
G865S02-02 AIR-CON UNIT (C)
G866S01-03 ELECTRICAL WIRING (C,NO-SPEEDOMETER)
G866S01-05 ELECTRICAL WIRING (F,NO-SPEEDOMETER)
G866S02-01 WINDOW WIPER(FRONT) (C,COOL-GRAY)
G866S02-07 WINDOW WIPER(REAR) (C,DIA KIT)
G866S03-01 AUDIO ASSY (C)
G866S03-03 AUDIO SYSTEM (C,GRAY)
G866S03-06 AUDIO ASSY (C,DIA KIT)
G867S01-01 ROOF (C)
G868S01-01 EXTERIOR (C)
G869S01-01 REAR VEIW MIRROR (C)
G869S01-04 MISCELLANY (C,HST)
G869S01-05 MISCELLANY (C,MEC)
G869S01-06 MISCELLANY (F)
G870S01-01 FENDER (F)
G880S01-01 SAFETY FRAME (F,REAR FOLDABLE,W-SVC KIT)
15. TIRES, WHEELS & REAR BALLAST
G490S01-01 WHEEL BOLTS & NUTS
16. ACCESSORY & ETC
G868S02-01 SLOW MOVING VEHICLES (C)
G868S02-02 SLOW MOVING VEHICLES (F)
G920S02-01 TOOL BOX (F,DIA KIT)
G920S05-01 BOLT CAP
G920S05-02 RUBBER PLUGS
G920S07-01 CUP HOLDER (F,OPTIONAL)
17. DECALS
G980S01-04 MODEL DECAL
G980S01-16 SAFETY DECAL (C)
G980S01-17 SAFETY DECAL (F)
18. DIA KIT & SVC KIT
G990S01-01 DIA KIT LIST (LSTA)
G991S01-03 SVC KIT LIST (ERAE to KAMTEC)
Brand: LS
01. ENGINE
Q145S01-03 OIL PAN
Q166S01-01 EGR
Q167S01-02 DOC&DPF
G150S01-02 MUFFLER
03. TRANSMISSION
04. PTO DRIVE
G610S01-02 TIE-ROD
G650S01-01 BRAKE
G750S01-18 ECU
G830S01-07 HOOD
G867S01-01 ROOF (C)
16. ACCESSORY & ETC
G920S05-01 BOLT CAP
17. DECALS
- LS Tractor J Series J2023H Parts Catalog
- LS Tractor KAI Series K5047 Parts Catalog
- LS Tractor KAI Series K5055 Parts Catalog
- LS Tractor MT1 Series MT125 Parts Catalog
- LS Tractor MT2 Series MT232 MT242 Parts Catalog
- LS Tractor MT2E Series MT225E MT225HE (with S3L2) Parts Catalog
- LS Tractor MT2E Series MT226E (with S3L2) Parts Catalog
- LS Tractor MT2E Series MT226E MT232E MT242E (with 3TNV88 4TNV88) Parts Catalog
- LS Tractor MT2E Series MT230E MT230HE MT235E MT235HE (with L3C19-D) Parts Catalog
- LS Tractor MT2E Series MT230E MT230HE MT235E MT235HE (with L3CRNV) Parts Catalog
- LS Tractor MT2E Series MT235E MT235HE MT240HE (with L3CRTV) Parts Catalog
- LS Tractor MT2E Series MT240E MT240HE (with L3C19-T) Parts Catalog
- LS Tractor MT2E Series MT240E MT240HE (with L3CRTV) Parts Catalog
- LS Tractor MT2S Series MT225S Parts Catalog
- LS Tractor MT3 Series MT335H MT335HC MT340HC (STAGE5) Parts Catalog
