Momed80
150
35,046
LS Tractor XR3000 Series XR3032 XR3032H XR3037 XR3037H Parts Catalog
Brand: LS
Model: LS XR3000 Series XR3032 XR3032H XR3037 XR3037H Tractor
Number of Pages: 451 Pages
01. ENGINE
G010S01-01 ENGINE
Q110S01-01 CRANKCASE ASSY
Q115S01-01 ROCKER COVER
Q116S01-01 CYLINDER HEAD
Q120S01-01 MAIN MOVING PARTS
Q125S01-01 FUEL SYSTEM
Q130S01-01 TIMING GEAR & CASE
Q135S01-01 COOLING SYSTEM
Q135S01-02 COOLING FAN (Dia.380)
Q165S01-01 EXHAUST MANIFOLD
Q165S02-01 OIL MIST SEPARATOR
Q167S01-01 DOC&DPF
Q167S02-01 BUNRER
Q167S02-02 INJECTOR
Q167S03-01 AIR PUMP
Q180S01-01 ELECTRIC PARTS
02. ENGINE APPLICATION
G040S01-01 FUEL TANK (C)
G040S01-02 FUEL TANK (F,LSTA)
G100S01-01 THROTTLE LEVER (C)
G100S01-02 THROTTLE PEDAL (C,MEC)
G100S01-03 THROTTLE LEVER (F)
G100S01-04 THROTTLE PEDAL (F,MEC)
G150S01-01 MUFFLER
G170S01-01 RADIATOR (F)
G170S01-02 RADIATOR (C)
G190S01-01 AIR CLEANER
G210S01-01 ENGINE FRAME (LSTA)
03. TRANSMISSION
G250S01-01 CLUTCH (MEC,w-damper)
G250S02-01 CLUTCH HOUSING (MEC)
G250S02-02 CLUTCH HOUSING (HST)
G250S03-01 DAMPER (HST)
G260S01-01 CLUTCH PEDAL (MEC)
G270S01-01 HST UNIT (HST)
G270S01-03 HST SEAL KIT (HST)
G270S01-04 HST ROTATING KIT (HST)
G280S01-01 TRANSMISSION CASE (MEC,NO-SPEEDOMETER)
G280S01-02 TRANSMISSION CASE (HST,NO-SPEEDOMETER)
G281S01-01 MAIN SHAFT (MEC)
G285S01-01 RANGE GEAR SHAFT (MEC)
G285S01-02 RANGE GEAR SHAFT (HST)
G310S01-01 REAR DIFFERENTIAL
04. PTO DRIVE
G280S02-01 PTO SHIELD (STD)
G283S01-01 PTO CLUTCH & SHAFT (MEC)
G283S01-02 PTO CLUTCH & SHAFT (HST)
G287S01-01 PTO GEAR & SHAFT (PTO1)
G287S01-02 MID PTO DRIVE SHAFT (M-PTO)
G287S02-01 MID PTO LEVER (C,M-PTO,W-DIA KIT)
G287S02-02 MID PTO LEVER (F,M-PTO,W-DIA KIT)
G287S02-03 MID PTO HOUSING (M-PTO,W-DIA KIT)
G287S04-01 PTO SHAFT CAP
05. FOUR WHEEL DRIVE (4WD)
G288S01-01 4WD SHAFT & COVER
G400S01-01 FRONT AXLE ASSY
G400S02-01 FRONT AXLE CASE
G400S02-02 FRONT AXLE CASE
G400S03-01 FRONT DIFFERENTIAL
G400S04-01 FRONT DRIVE
G610S01-02 TIE-ROD
G630S01-03 STEERING CYLINDER
07. REAR AXLE & BRAKE
G480S01-01 REAR AXLE(RH)
G480S01-02 REAR AXLE(LH)
G650S01-01 BRAKE
G670S01-01 BRAKE ROD AND LINKAGE (MEC)
G670S01-02 BRAKE ROD AND LINKAGE (HST)
G670S01-05 BRAKE PEDALS (C-HST,S-HST)
G670S01-06 BRAKE PEDALS (MEC)
G670S02-01 PARKING BRAKE LEVER (C,MEC)
G670S02-02 PARKING BRAKE LEVER (C,HST)
G670S02-03 PARKING BRAKE LEVER (F,HST)
G670S02-04 PARKING BRAKE LEVER (F,MEC)
08. SHIFT FORK & LINKAGE
G290S02-01 LEVER&FORK(MAIN GEAR) (C,WOOCHANG,MEC)
G290S02-02 LEVER&FORK(MAIN GEAR) (F,MEC)
G290S03-01 LEVER&FORK(F-R GEAR) (C,MEC)
G290S03-02 LEVER&FORK(F-R GEAR) (F,MEC)
G291S01-01 LEVER&FORK(RANGE GEAR) (MEC)
G291S01-02 LEVER&FORK(RANGE GEAR) (HST)
G291S02-01 LEVER&FORK(4WD)
G291S03-01 LEVER&FORK(PTO) (PTO1,M-PTO)
G292S01-01 HST CONTROL (C,HST)
G292S01-02 HST CONTROL (F,HST)
G320S01-01 DIFF-LOCK (MEC)
G320S01-02 DIFF-LOCK (HST)
G630S01-01 STEERING LINES (C,MEC)
G630S01-02 STEERING LINES (C,HST)
G630S01-04 STEERING LINES (F,MEC)
G630S01-05 STEERING LINES (F,HST)
G640S01-01 T-M OIL COOLER (C,HST)
G640S01-02 T-M OIL COOLER (F,HST)
G822S02-01 INDP PTO VALVE (HST or (MEC,USNH,USCI))
G822S02-02 INDP PTO VALVE (MEC,LSTA,DO)
G822S03-01 LOADER VALVE ((C,MEC,C-HST,L-V,W-COUPLER) or Non-EU)
G822S03-02 LOADER VALVE COUPLER (C,L-V)
G822S03-04 JOYSTICK LEVER (F,L-V)
G822S03-05 LOADER VALVE COUPLER (F,L-V)
G822S03-07 LOADER VALVE (F,L-V,W-COUPLER)
G822S03-12 JOYSTICK LEVER (C,L-V)
G823S01-01 HYD. SUCTION LINES
G823S02-01 HYD. F-PRESSURE LINES (C,L-V)
G823S02-02 HYD. F-PRESSURE LINES (F,L-V)
G823S03-01 HYD. M-PRESSURE LINES (F,L-V,SD5-1)
G823S03-02 HYD. M-PRESSURE LINES (F,L-V,SD5-2)
G823S03-04 HYD. M-PRESSURE LINES (C,L-V,W-AUX)
G827S01-01 REMOTE CONTROL LEVER (C,SD5-2)
G827S01-02 REMOTE CONTROL LINES (C,SD5-2)
G827S01-04 REMOTE CONTROL LINES (F,SD5-2)
G827S02-01 REMOTE CONTROL VALVE (C,SD5-2)
G827S02-03 REMOTE CONTROL VALVE (F,SD5-2)
G730S01-01 ELECTRICAL WIRING
G730S02-01 7 POLE CONNECTOR (C)
G730S02-02 7 POLE CONNECTOR (F)
G730S03-01 HORN (Optional)
G740S01-01 BATTERY (C,80A)
G740S01-02 BATTERY (F,80A)
G750S01-01 METER PANEL
G750S01-02 RELAY & FUSE (C,MEC)
G750S01-03 RELAY & FUSE (C,HST)
G750S01-04 ECU BRACKET (C)
G750S01-05 RH CONSOLE SWITCH (C)
G750S01-06 RELAY & FUSE (F,MEC)
G750S01-07 RELAY & FUSE (F,HST)
G750S01-08 RH CONSOLE COVER (F)
G750S01-10 ECU BRACKET (F)
G760S01-01 REAR COMBINATION LAMP (C)
G760S01-02 REAR WORK LAMP (C,W-DIA KIT)
G760S01-03 HEAD LAMP
G760S01-04 REAR LAMP (F,STD)
G760S01-05 TURN SIGNAL LAMP (F)
G760S01-18 WORK LAMP (C)
G760S01-19 TURN SIGNAL LAMP (C,EXP)
G760S03-01 BEACON LAMP (C,W-DIA KIT)
G760S03-03 BEACON LAMP (C,W-DIA KIT)
11. HYDRAULIC LIFT UNIT
G820S01-01 HYD. HOUSING ASSY (C,W-DRAFT,STD)
G820S01-03 HYD. HOUSING ASSY (F,W-DRAFT)
G820S01-05 HYD. HOUSING ASSY (C,W-DRAFT,EXT CTRL)
G820S02-01 HYDRAULIC HOUSING
G822S01-01 LIFT CTRL. VALVE & LINK
G824S01-01 POSITION & DRAFT LINK (W-DRAFT)
G825S01-01 HYD. HOUSING LEVER (C)
G825S01-03 HYD. CONTROL LEVER (F,W-DRAFT)
G825S01-09 HYD. CONTROL LEVER (C,W-DRAFT)
G825S01-15 HYD. HOUSING LEVER (C)
G825S02-01 EXTERNAL POSITION CONTROL LEVER (C, Optional)
G825S02-02 EXTERNAL POSITION CONTROL LEVER (F, Optional)
G826S01-01 HYDRAULIC CYLINDER
G828S01-01 UPPER LINK BRACKET (C,W-DRAFT)
G828S01-02 UPPER LINK BRACKET (F,W-DRAFT)
12. 3-POINT LINKAGE & HITCH
G891S01-02 DRAWBAR & HITCH (TELESCOPIC)
G896S01-02 LOWER LINK (TELESCOPIC)
G896S01-04 TOP LINK HOOK (F)
G896S01-05 TOP LINK HOOK (C,STD TOP LINK)
G896S01-10 UPPER LINK (STD TOP LINK)
G896S02-02 LIFT ROD (NO-LEVEL,LSTA)
G896S03-02 CHECK LINK (C,TELESCOPIC)
G896S03-03 CHECK LINK (TELESCOPIC,BALL TYPE)
13. SHEET METALS & MOUNTS
G830S01-01 GRILLE ASSY
G830S01-02 HOOD
G830S02-01 HOOD SUPPORT
G840S01-01 MOUNT RUBBER (C)
G840S01-02 SUB STEP (C)
G840S01-03 MOUNT RUBBER (F,DO,LSTA)
G840S01-04 SUB STEP (F)
14. DRIVER’S STATION
G630S02-01 STEERING COLUMN (C)
G630S02-02 STEERING WHEEL
G630S02-05 STEERING COLUMN (F)
G825S01-02 HYD. LEVER GUIDE (C,W-DRAFT)
G825S01-05 HYD. LEVER GUIDE (F)
G835S01-01 PEDAL FRAME (C,HST)
G835S01-02 PEDAL FRAME (C,MEC)
G835S01-03 PEDAL FRAME (F,HST)
G835S01-04 PEDAL FRAME (F,MEC)
G850S01-01 SEAT (C,WOOCHANG,GRAY)
G850S01-02 SEAT (F,WOOCHANG,BLACK)
G861S01-01 FRAME (C,MEC,WOOCHANG)
G861S01-02 FRAME (C,HST,WOOCHANG)
G861S01-03 FRAME (F)
G862S01-01 DOOR(LH) (C)
G862S01-02 DOOR(RH) (C)
G863S01-01 FRONT & SIDE WINDOW (C)
G863S01-02 FRONT & SIDE WINDOW (F)
G863S02-02 REAR WINDOW (C,WO-WIPER)
G864S01-01 INTERIOR(RH) (C)
G864S01-02 INTERIOR(LH) (C)
G864S01-03 INTERIOR(TOP) (C)
G864S01-04 INTERIOR(FRONT)
G864S01-05 JOYSTICK COVER (C)
G864S01-06 INTERIOR(RH,LH) (F)
G864S01-11 JOYSTICK COVER (F,L-V)
G865S01-01 AIR-CON BLOWER (C)
G865S01-02 AIR-CON COMPRESSOR (C)
G865S01-03 AIR CONDITIONER LINE (C)
G865S02-01 AIR-CON UNIT (C)
G866S01-01 ELECTRICAL WIRING (C)
G866S01-02 ELECTRICAL WIRING (F)
G866S02-01 WINDOW WIPER(FRONT) (C,COOL-GRAY)
G866S03-01 AUDIO ASSY (C)
G866S03-03 AUDIO SYSTEM (C,GRAY)
G866S03-06 AUDIO ASSY (C,DIA KIT)
G867S01-01 ROOF (C)
G868S01-01 EXTERIOR (C)
G869S01-01 REAR VEIW MIRROR (C)
G869S01-04 MISCELLANY (C,HST)
G869S01-05 MISCELLANY (C,MEC)
G869S01-06 MISCELLANY (F)
G870S01-01 FENDER (F)
G880S01-01 SAFETY FRAME (F,REAR FOLDABLE,W-SVC KIT)
15. TIRES, WHEELS & REAR BALLAST
G490S01-01 WHEEL BOLTS & NUTS
16. ACCESSORY & ETC
G868S02-01 SLOW MOVING VEHICLES (C)
G868S02-02 SLOW MOVING VEHICLES (F)
G920S02-01 TOOL BOX (F,DIA KIT)
G920S05-01 BOLT CAP
G920S05-02 RUBBER PLUGS
17. DECALS
G980S01-01 DECAL
18. DIA KIT & SVC KIT
G990S01-01 DIA KIT LIST (LSTA)
