LS Tractor XJ Series XJ2025-Electronic governor Parts Catalog
Brand: LS
Model: LS XJ Series XJ2025-Electronic governor Tractor
Number of Pages: 326 Pages
01. ENGINE
G010S01-04 ENGINE (S3L2-18.4KW)
Q065S01-02 OVERHAUL GASKET KIT
Q110S01-02 CRANKCASE ASSY
Q110S01-03 CRANKCASE ASSY
Q110S01-05 CRANKCASE ASSY (25HP)
Q110S01-10 CRANKCASE ASSY
Q115S01-02 ROCKER COVER & CAMSHAFT
Q115S01-05 ROCKER COVER (25HP)
Q115S02-01 AIR BREATHER
Q116S01-05 CYLINDER HEAD (25HP)
Q116S02-01 LIFTING EYE
Q120S02-02 PISTON (25HP)
Q120S03-02 CONNECTION ROD
Q120S04-03 CRANKSHAFT (25HP)
Q121S01-04 VALVE MECHANISM (25HP)
Q125S01-05 FUEL SYSTEM
Q125S01-06 INJECTION PUMP (25HP)
Q125S01-07 GOVERNOR (25HP)
Q125S01-09 FUEL SYSTEM (25HP)
Q125S01-15 INJECTION PUMP ASSY (25HP)
Q125S02-01 FUEL PUMP & FILTER (25HP)
Q130S01-02 TIMING GEAR & CASE
Q130S01-05 TIMING GEAR & CASE (25HP)
Q135S01-01 COOLING SYSTEM (S3L,S3L2)
Q140S01-01 OIL SYSTEM
Q140S01-05 OIL STRAINER (25HP)
Q140S01-06 OIL SYSTEM (25HP)
Q145S01-01 OIL PAN
Q150S01-01 FLYWHEEL (S3L,S3L2)
Q155S02-02 REAR PLATE (25HP)
Q160S01-01 INLET & OUTLET MANIFOLD
Q165S01-02 EXHAUST MANIFOLD (25HP)
Q170S01-01 STARTER
Q175S01-02 ALTERNATOR (25HP)
Q180S01-03 ELECTRIC PARTS
Q180S01-04 ELECTRIC PARTS (S3L2-18.4KW)
Q180S01-06 GLOW PLUG & WIRE (25HP)
Q180S01-07 ELECTRIC PARTS (25HP)
02. ENGINE APPLICATION
G040S01-01 FUEL TANK
G100S01-05 THROTTLE LEVER (S3L2-18.4KW)
G150S01-01 MUFFLER-SVC OFF (HST)
G170S01-01 RADIATOR (HST)
G190S01-01 AIR CLEANER
G210S01-07 ENGINE FRAME (XJ-HST)
G210S01-09 ENGINE SUB FRAME (S3L2-18.4KW,HST)
G215S10-01 FRONT BALLAST DIA KIT (4-BALLAST, DIA KIT)
03. TRANSMISSION
G270S01-01 HST UNIT (HST)
G270S01-03 HST PUMP ROTATING KIT (HST, 40254231 SVC KIT)
G270S01-04 HST MOTOR ROTATING KIT (HST, 40254231 SVC KIT)
G270S01-05 HST SEAL KIT (HST, 40254231 SVC KIT)
G280S01-02 TRANSMISSION CASE (25,27,HST)
G281S01-01 MAIN SHAFT (HST)
G285S01-03 RANGE GEAR SHAFT (HST,11.5MPH)
G310S01-02 REAR DIFFERENTIAL (HST,11.5MPH)
04. PTO DRIVE
G287S01-02 PTO DRIVE SHAFT (TIER4,HST,INDP)
G287S02-01 MID PTO SHAFT & LEVER (HST,M-PTO)
G287S03-01 HYD PUMP DRIVE PTO (HST,Pump Drive PTO)
G287S04-01 PTO SHAFT CAP
05. FOUR WHEEL DRIVE (4WD)
G288S01-01 4WD SHAFT (universal)
G288S01-03 4WD SHAFT (HST,11.5MPH)
G400S01-01 FRONT AXLE ASSY
G400S02-01 FRONT AXLE CASE
G400S02-02 FRONT AXLE CASE
G400S03-01 FRONT DIFFERENTIAL
G400S04-01 FRONT DRIVE
G610S01-01 TIE-ROD & STEERING CYLINDER
07. REAR AXLE & BRAKE
G480S01-01 REAR AXLE (HST)
G650S01-01 BRAKE (HST)
G670S01-02 BRAKE PEDALS (HST,2-PEDAL)
G670S02-04 PARKING BRAKE LEVER (XJ-LOOK,HST)
08. SHIFT FORK & LINKAGE
G291S01-01 SHIFT LEVER & FORK(RANGE GEAR) (HST)
G292S01-01 HST CONTROL LINKAGE
G292S01-09 HST CRUISE LEVER (XJ-LOOK,HST)
G292S01-10 HST PEDAL (XJ-LOOK,HST)
G320S01-01 DIFF-LOCK (HST)
G630S01-05 STEERING UNIT SVC KIT (40289688 SVC KIT)
G630S01-06 STEERING CYLINDER & LINES (HST,2-PUMP)
G822S02-03 TM CONTROL VALVE (INDP,HST,LSTA)
G822S02-05 RELIEF VALVE (HST,2-PUMP)
G823S01-03 HYDRAULIC LINES (HST,2-PUMP)
G827S01-04 REMOTE CONTROL VALVE (W-O RCV,LSTA)
G730S01-09 ELECTRICAL WIRING (XJ-LOOK)
G730S02-02 7 POLE CONNECTOR (ASAE)
G730S02-03 MAIN FUSE (40A)
G740S01-01 BATTERY (DO,EXP,CIH(AU))
G750S01-18 RELAYS (HST,ASAE)
G750S01-19 FUSE & FUSE BOX
G750S01-20 METER PANEL (S3L2-18.4KW,XJ-LOOK)
G750S02-01 ELECTRIC COMPONENTS (HST)
G750S02-07 PTO SWITCH (HST)
G760S01-01 COMBI-LAMP (ASAE,AG)
G760S01-02 LAMP (WORK LAMP,BECON OPT)
G760S01-05 LAMP (SMALL-HEADLAMP)
11. HYDRAULIC LIFT UNIT
G820S01-01 HYDRAULIC HOUSING ASSY-SVC OFF
G820S02-01 HYDRAULIC HOUSING
G822S01-01 LIFT CONTROL VALVE & LINK
G825S01-01 HYDRAULIC CONTROL LEVER (HST)
G826S01-01 HYDRAULIC CYLINDER
12. 3-POINT LINKAGE & HITCH
G891S01-02 DRAWBAR HITCH (DRAWBAR)
G896S01-01 UPPER & LOWER LINK (GENERAL)
G896S02-01 LIFT ROD
G896S03-01 CHECK CHAIN
13. SHEET METALS & MOUNTS
G830S01-12 HOOD (SMALL(CR),S-BLUE)
G830S01-13 GRILLE & SIDE COVER (METAL(EXPAND),S-BLUE)
G830S01-15 HOOD (SMALL(CR),DS-BLUE)
G830S01-16 GRILLE & SIDE COVER (METAL(EXPAND),DS-BLUE)
G830S02-03 HOOD SUPPORT(FRONT) (EXP)
G830S02-04 HOOD SUPPORT (S3L2-18.4KW,XJ-LOOK)
G840S01-11 STEP & MOUNT RUBBER (HST,2-PEDAL,S-BLUE)
G840S01-18 STEP & MOUNT RUBBER (1-SUB-STEP,OPTIONAL,LSTA)
G840S01-22 STEP & MOUNT RUBBER (HST,2-PEDAL,DS-BLUE)
14. DRIVER’S STATION
G630S02-07 STEERING WHEEL (OD355)
G630S02-09 STEERING COLUMN (S3L2-18.4KW)
G830S04-03 INSTRUMENT CONSOLE
G850S01-07 SEAT (WOOCHANG(STD))
G860S01-01 CABIN ASSY DIA KIT (C,DIA KIT,S-BLUE)
G860S01-02 CABIN ASSY DIA KIT (C,DIA KIT,DS-BLUE)
G861S01-01 CABIN FRAME & MOUNT (C,DIA KIT)
G862S01-01 DOOR(RH) (C,DIA KIT)
G862S01-02 DOOR(LH) (C,DIA KIT)
G863S01-01 FRONT WINDOW(UPPER) (C,DIA KIT)
G863S01-02 FRONT WINDOW(LOWER) (C,DIA KIT)
G863S01-03 FRONT INSULATION COVER (C,DIA KIT)
G863S02-01 REAR WINDOW(UPPER) (C,DIA KIT)
G863S02-02 REAR WINDOW(LOWER) (C,DIA KIT)
G864S01-01 INTERIOR(Top ceiling) (C,DIA KIT)
G865S01-01 AIR HEATER (C,DIA KIT)
G865S02-01 HEATER UNIT (C,DIA KIT)
G866S01-01 ELECTRICAL WIRING (C,DIA KIT)
G866S01-02 ELECTRIC SWITCH (C,DIA KIT)
G866S01-03 WORK LAMP (C,DIA KIT)
G866S01-04 BEACON LAMP SOCKET (C,DIA KIT)
G866S02-01 WINDOW WIPER(FRONT) (C,DIA KIT)
G866S02-02 WINDOW WIPER(REAR) (C,DIA KIT)
G866S03-01 AUDIO SYSTEM (C,DIA KIT)
G867S01-01 ROOF (C,DIA KIT,S-BLUE)
G867S01-02 ROOF (C,DIA KIT,DS-BLUE)
G869S01-01 MISCELLANY (C,DIA KIT)
G870S01-01 FENDER (HST,S-BLUE)
G870S01-12 FENDER (HST,DS-BLUE)
G880S01-03 SAFETY FRAME (R-ROPS,FOLDERBLE,W-SVC KIT)
G920S01-02 BACK MIRROR ASSY (C,DIA KIT)
G920S01-03 TOOL BOX (C,DIA KIT)
G980S01-16 SAFETY DECAL (C,DIA KIT)
15. TIRES, WHEELS & REAR BALLAST
G490S01-03 WHEEL BOLTS & NUTS
G490S01-04 WHEEL & TIRE (23x8.5-12,WHITE-IVORY)
G490S01-05 WHEEL & TIRE (12-16.5,WHITE-IVORY)
G490S01-07 REAR AXLE EXTENSION (C,DIA KIT)
G490S01-09 WHEEL & TIRE (23x8.5-12(IND),SILVER)
G490S01-10 WHEEL & TIRE (12-16.5(IND),SILVER)
16. ACCESSORY & ETC
G868S02-02 SLOW MOVING VEHICLES
G920S01-01 TOOL BOX (OPTIONAL)
G920S05-01 BOLT CAP
17. DECALS
G980S01-14 SAFETY DECAL
G980S01-15 MODEL DECAL
18. DIA KIT & SVC KIT
G990S01-01 DIA KIT LIST (LSTA)
Brand: LS
01. ENGINE
Q145S01-01 OIL PAN
Q170S01-01 STARTER
03. TRANSMISSION
04. PTO DRIVE
G896S02-01 LIFT ROD
16. ACCESSORY & ETC
G920S05-01 BOLT CAP
17. DECALS
- LS Tractor J Series J2023H Parts Catalog
- LS Tractor KAI Series K5047 Parts Catalog
- LS Tractor KAI Series K5055 Parts Catalog
- LS Tractor MT1 Series MT125 Parts Catalog
- LS Tractor MT2 Series MT232 MT242 Parts Catalog
- LS Tractor MT2E Series MT225E MT225HE (with S3L2) Parts Catalog
- LS Tractor MT2E Series MT226E (with S3L2) Parts Catalog
- LS Tractor MT2E Series MT226E MT232E MT242E (with 3TNV88 4TNV88) Parts Catalog
- LS Tractor MT2E Series MT230E MT230HE MT235E MT235HE (with L3C19-D) Parts Catalog
- LS Tractor MT2E Series MT230E MT230HE MT235E MT235HE (with L3CRNV) Parts Catalog
- LS Tractor MT2E Series MT235E MT235HE MT240HE (with L3CRTV) Parts Catalog
- LS Tractor MT2E Series MT240E MT240HE (with L3C19-T) Parts Catalog
- LS Tractor MT2E Series MT240E MT240HE (with L3CRTV) Parts Catalog
- LS Tractor MT2S Series MT225S Parts Catalog
- LS Tractor MT3 Series MT335H MT335HC MT340HC (STAGE5) Parts Catalog
