Momed80
150
35,046
LS Tractor XG3135 XG3140 XG3135H XG3140H Parts Catalog
Brand: LS
Model: LS XG3135 XG3140 XG3135H XG3140H Tractor
Number of Pages: 153 Pages
Engine Long Block Assy
Engine Short Block Assy
Pilot Bearing (Mec)
Crankcase Assy
Crankcase
Rocker Cover & Camshaft
Blow By Gas Hose
Main Moving Parts
Valve Mechanism
Fuel System
Timing Gear & Case
Oil System
Oil Pan
Inlet & Outlet Manifold
Egr
Egr Vv Svc Kit (Erae To Kamtec)
Doc&Dpf
Dpf Support (F Or Wo_Air-Con)
Electric Parts
Electric Parts
Maf Sensor
Turbocharger
Throttle Pedal (Mec)
Throttle Lever
Fuel Cooler
Muffler
Air Cleaner
Engine Frame
Front Ballast Dia Kit (4 Ballast,Dia Kit)
Clutch (Mec,W_Damper)
Clutch Housing (Mec)
Clutch Housing (Hst)
Damper (Hst)
Clutch Pedal (Mec,Exp)
Hst Unit (Hst)
Hst Seal Kit (Hst)
Hst Rotating Kit (Hst)
Transmission Case (Mec)
Transmission Case (Hst)
Main Shaft (Mec(Std))
Range Gear Shaft (Hst)
Range Gear Shaft (Mec)
Rear Differential
Pto Shield (Std)
Pto Clutch & Shaft (Hst)
Pto Clutch & Shaft (Mec)
Mid Pto Drive Shaft (M_Pto)
Pto Gear & Shaft (Indp,Pto1)
Pto Drive Shaft Cover (Wo_M Pto)
Mid Pto Lever (M_Pto,W_Dia Kit)
Mid Pto Housing (M_Pto)
Pto Shaft Cap
4wd Shaft & Cover
Front Axle Assy
Front Axle Case
Front Axle Case(Lh,Rh)
Front Differential
Front Drive
Tie-Rod
Steering Cylinder
Rear Axle(Rh)
Rear Axle(Lh)
Brake
Brake Pedals (Hst)
Brake Pedals (Mec)
Parking Brake Lever (Mec,W_Switch)
Parking Brake Lever (Hst,W_Switch)
Lever&Fork(Main Gear) (Mec)
Lever&Fork(F_R Gear) (Mec)
Lever&Fork(Range Gear)
Lever&Fork(4wd) (Pto1,No-M_Pto)
Lever&Fork(4wd) (Pto1,M_Pto)
Lever&Fork(Pto) (Pto1)
Hst Pedal (Hst)
Hst Control Link (Hst)
Hst Cruise Lever (Hst)
Diff-Lock (Mec)
Diff-Lock (Hst)
Pto Hyd. Pipes (Mec)
Pto Hyd. Pipes (Hst)
Steering Lines
Steering Hose Guide (Mec)
Hst Filter & Pipes (Hst)
T_M Oil Cooler (Hst)
Indp Pto Valve
Loader Valve (L_V)
Hyd. Suction Lines
Hyd. F_Pressure Lines (L_V)
Hyd. M_Pressure Lines (L_V,W_O-Rcv)
Remote Control Valve Kit (2-Qc,L_V,Spr-N,Dia Kit)
Remote Control Valve Kit (4-Qc,L_V,Dia Kit)
Electrical Wiring
Main Harness
Rear Harness
Horn (Dia Kit)
Main Fuse
Battery (80a)
Meter Panel
Relays & Fuse
Ecu Bracket
Diagnosis Connector
Lamp (F)
Head Lamp
Hyd. Housing Assy
Hydraulic Housing
Lift Ctrl. Valve & Link
Position & Draft Link
Hyd. Control Lever
Lever Stopper
Hydraulic Cylinder
Upper Link Bracket (W_O Draft)
Drawbar & Hitch (Telescopic Drawbar)
Lower Link (General)
Upper Link
Top Link Hook
Lift Rod (No-Nevel,Cat1)
Check Link (Telescopic Stabilizer)
Grille Assy (S-Blue)
Hood (S-Blue)
Hood Support (Lsta)
Step & Mount Rubber (Hst,S-Blue)
Step & Mount Rubber (Mec,S-Blue)
Step Mat (Mec)
Step Mat (Hst)
Sub Step
Steering Column
Steering Wheel
Hyd. Lever Guide
Interior(Front)
Pedal Frame
Seat (Woochang,Black)
Fender (S-Blue,Pto1)
Safety Frame (R_Rops(Folderble),W_Svc Kit)
Wheel Bolts & Nuts
Slow Moving Vehicles
Tool Box (Lsta With Dia Kit)
Bolt Cap
Rubber Plugs
Cup Holder (F,Optional)
Model Decal
Safety Decal (Lsta)
