Momed80
150
35,046
LS Tractor S Series U55 Parts Catalog
Brand: LS
Model: LS S Series U55 Tractor
Number of Pages: 378 Pages
01. ENGINE
Q065S01-03 OVERHAUL GASKET KIT (55)
Q110S01-03 CRANKCASE ASSY (55)
Q110S02-04 CRANKCASE (53,55)
Q110S02-05 CRANKCASE (53,55)
Q115S01-04 ROCKER COVER (53,55)
Q115S01-05 ROCKER COVER & CAMSHAFT (55)
Q115S02-02 AIR BREATHER (53,55)
Q116S01-03 CYLINDER HEAD (55)
Q116S02-01 LIFTING EYE (53,55)
Q120S01-04 MAIN MOVING PARTS (55)
Q120S01-05 MAIN MOVING PARTS (55)
Q121S01-03 VALVE MECHANISM (55)
Q125S01-04 FUEL SYSTEM (55)
Q125S01-05 FUEL SYSTEM (55)
Q125S01-06 FUEL SYSTEM (55)
Q125S01-09 FUEL SYSTEM (55)
Q125S02-03 FUEL PUMP & FILTER (55)
Q125S03-01 INJECTOR (55)
Q130S01-04 TIMING GEAR & CASE (55)
Q130S01-05 TIMING GEAR & CASE (55)
Q130S02-01 SIDE POWER TAKE-OFF (53,55)
Q130S02-02 SIDE POWER TAKE-OFF (55)
Q135S01-03 COOLING SYSTEM (55)
Q140S01-05 OIL SYSTEM (53,55)
Q140S01-06 RELIEF VALVE (53,55)
Q140S01-07 OIL SYSTEM (55)
Q140S01-08 OIL FILTER (53,55)
Q145S01-03 OIL PAN (53,55)
Q146S01-03 BALANCER (53,55)
Q160S01-06 EXHAUST MANIFOLD (53,55)
Q160S02-01 INTAKE MANIFOLD (53,55)
Q170S01-01 STARTER (53,55)
Q175S01-01 ALTERNATOR (55)
Q180S01-04 ELECTRIC PARTS (55)
Q180S01-05 ELECTRIC PARTS (55)
Q180S02-01 ACCESSORY (55)
02. ENGINE APPLICATION
G040S01-01 FUEL TANK (60L)
G040S01-02 FUEL TANK (RESERVER,20L)
G100S01-02 THROTTLE CONTROL (55)
G150S01-01 MUFFLER (43,47,50,53,55,F,Vertical)
G150S01-09 MUFFLER (43,47,50,53,55,C,Vertical)
G170S01-03 RADIATOR (53,55,62,U60CA or F)
G190S01-03 AIR CLEANER (53,55)
G210S01-03 ENGINE FRAME (53,55,62)
G215S01-01 FRONT BALLAST (52,53,55,60,L4AL,4-BALLAST)
03. TRANSMISSION
G250S01-03 CLUTCH (53,55,62,L4AL)
G250S02-02 CLUTCH HOUSING (52,55,60,62,L4AL,MEC,DO)
G250S02-05 CLUTCH HOUSING (PST)
G260S01-01 CLUTCH PEDAL (MEC)
G260S01-02 CLUTCH PEDAL (PST)
G280S01-01 TRANSMISSION CASE (MEC,NO-Q-T)
G280S01-02 TRANSMISSION CASE (MEC,Q-T)
G280S01-04 TRANSMISSION CASE (PST,NO-Q-T)
G281S01-01 MAIN SHAFT (MEC,INDP,NO-CRP)
G281S01-02 MAIN SHAFT (MEC,INDP,CRP)
G281S01-03 MAIN SHAFT (PST)
G281S02-01 MAIN GEAR SHAFT
G285S01-01 RANGE GEAR SHAFT (STD)
G310S01-01 REAR DIFFERENTIAL (43,47,50,52,53,55,60,62)
04. PTO DRIVE
G283S01-01 PTO CLUTCH & SHAFT (MEC,INDP)
G283S01-03 PTO CLUTCH & SHAFT (PST,INDP)
G287S01-05 PTO GEAR & DRIVE SHAFT (PTO-3)
05. FOUR WHEEL DRIVE (4WD)
G288S01-02 4WD SHAFT & COVER (52,53,55,60,62,NO-Q-T)
G288S01-04 4WD SHAFT & COVER (52,53,55,60,62,L4AL,Q-T)
G400S01-03 FRONT AXLE ASSY (53,55,62)
G400S02-02 FRONT AXLE CASE(CENTER) (52,53,55,60,62)
G400S02-03 FRONT AXLE CASE(LH) (STD,NO-Q-T)
G400S02-04 FRONT AXLE CASE(LH) (Q-T or EHL)
G400S02-05 FRONT AXLE CASE(RH)
G400S03-01 FRONT DIFFERENTIAL
G400S04-02 FRONT DRIVE
G610S01-02 TIE-ROD
07. REAR AXLE & BRAKE
G480S01-01 REAR AXLE
G650S01-01 BRAKE
G670S01-01 BRAKE PEDALS (WO-SWITCH)
G670S02-01 PARKING BRAKE LEVER
08. SHIFT FORK & LINKAGE
G290S01-02 LEVER&FORK(CREEPER) (CRP)
G290S01-03 SHIFT LEVER&FORK(RANGE GEAR) (STD,NO-Q-T)
G290S01-04 SHIFT LEVER&FORK (OPT,Q-T)
G290S01-05 CREEPER LEVER COVER (NO-CRP,MEC)
G290S02-01 LEVER&FORK(MAIN GEAR)
G290S03-01 LEVER&FORK(F-R GEAR) (MEC,SHUTTLE)
G290S03-02 LEVER&FORK(F-R GEAR) (PST)
G291S03-01 LEVER & FORK(PTO) (PTO-3,NO-GSP)
G320S01-01 DIFF-LOCK
G630S01-03 STEERING CYLINDER & LINES (53,55,62)
G640S01-01 T-M OIL COOLER (W-O COOLER)
G640S01-02 T-M OIL COOLER (W-COOLER,Q-T or PST)
G640S02-01 OIL COOLER VALVE & LINE (MEC,INDP,Q-T)
G640S02-02 OIL COOLER VALVE & LINE (PST,INDP)
G822S02-01 PTO VALVE (INDP,WO-Quick-Turn)
G822S02-04 INDP PTO VALVE (INDP,Q-T)
G822S02-08 POWER SHUTTLE VALVE (PST,INDP)
G822S03-02 LOADER VALVE (N60CA or U60CA or F,L-V)
G823S01-04 HYDRAULIC LINES (N60CA or U60CA or F,53,55,62,LOADER VALVE)
G827S01-04 REMOTE CTRL. VALVE&LINE (N60CA or U60CA or F,SD5-2)
G829S01-01 AUTO LEVELING HYD. LINE (U60CA or F,LEVELING,MHL)
G829S01-02 AUTO LEVELING HYD. LINE (U60CA or F,LEVELING,EHL)
G730S01-01 ELECTRICAL WIRING (U-LOOK,43,47,52,55,62,F)
G730S01-03 ELECTRICAL WIRING (U-LOOK,43,47,52,55,62,U60CA)
G730S02-01 7 POLE CONNECTOR-SVC OFF
G740S01-01 BATTERY (43,47,50,52,53,55,60,62,100AH)
G750S01-02 METER PANEL (55,62,C,F,MHL,MEC)
G750S01-11 METER PANEL (55,62,C,F,EHL or PST)
G750S02-01 ELECTRIC COMPONENTS (U60CA,MHL,LEVELING)
G750S02-02 ELECTRIC COMPONENTS (U60CA,EHL,LEVELING)
G750S02-03 ELECTRIC COMPONENTS (PST)
G750S02-05 AUTO PTO ON-OFF SWITCH (MHL,INDP,W-SWITCH)
G750S02-06 ELECTRIC COMPONENTS (Q-T)
G750S06-01 E-PTO PLUG (NO-EPTO)
G760S01-01 LAMP (U-LOOK,F)
G760S01-02 LAMP (U-LOOK,C)
G760S01-13 HEAD LAMP (U-LOOK)
G760S03-01 BEACON LAMP (F)
G760S03-02 BEACON LAMP (C)
11. HYDRAULIC LIFT UNIT
G820S01-01 HYD. HOUSING ASSY (MHL)
G820S01-02 HYD. HOUSING ASSY (EHL)
G820S02-01 HYDRAULIC HOUSING (MHL)
G820S02-02 HYDRAULIC HOUSING (EHL)
G822S01-01 LIFT CTRL. VALVE & LINK (MHL)
G822S01-02 LIFT CTRL. VALVE & LINK (EHL)
G824S01-01 POSITION & DRAFT LINK (MHL)
G824S01-02 POSITION & DRAFT LINK (EHL)
G824S01-04 DEPTH CTRL. SENSOR & CABLE (EHL)
G825S01-01 HYD. CONTROL LEVER (U60CA or F,L-V,MHL)
G825S01-03 HYD. LEVER GUIDE (U60CA or F,L-V,EHL)
G825S02-01 AUTO LIFT. (N60CA or U60CA or F,MHL)
G826S01-01 HYDRAULIC CYLINDER (MHL)
G826S01-02 HYDRAULIC CYLINDER (EHL)
G828S01-01 UPPER LINK BRACKET (STD)
12. 3-POINT LINKAGE & HITCH
G891S01-01 DRAWBAR & HITCH (GENERAL)
G891S01-03 DRAWBAR & HITCH (TELESCOPIC DRAWBAR W-CLEVIS(EC))
G896S01-07 UPPER & LOWER LINK (52,55,60,62,L4AL.AUTO HITCH)
G896S02-01 LIFT ROD (NO-LEVEL)
G896S02-02 LIFT ROD (LEVELING)
G896S02-05 LEVELING CYLINDER ASSY (LEVELING)
G896S03-01 CHECK LINK (F,C-LINK)
G896S03-02 CHECK LINK (C,C-LINK)
13. SHEET METALS & MOUNTS
G830S01-02 HOOD (U-LOOK,S-BLUE)
G830S01-34 HOOD UNDER COVER (F or U60CA,Dark Gray)
G830S02-03 HOOD SUPPORT (U-LOOK,U60CA or F)
G840S01-01 STEP & MOUNT RUBBER (F,S-BLUE)
G840S01-05 MOUNT RUBBER (C)
G840S01-16 SUB STEP (U60CA or U6000CA,60L)
G840S01-17 SUB STEP (F,FUEL-60L)
14. DRIVER’S STATION
G630S02-01 STEERING WHEEL & COLUMN (F,LS-CAP)
G630S02-02 STEERING WHEEL & COLUMN (C,LS-CAP)
G630S02-18 STEERING WHEEL (LS-CAP)
G835S01-01 PEDAL FRAME (F,MEC)
G850S01-01 SEAT (F,WOOCHANG)
G850S01-02 SEAT (F,TAEKWANG)
G850S01-03 SEAT (U60CA,WOOCHANG)
G850S01-04 SEAT (U60CA or U6000CA,TAEKWANG)
G861S01-01 FRAME (U60CA)
G862S01-01 DOOR(LH) (U60CA or U6000CA)
G862S01-02 DOOR(RH) (U60CA or U6000CA)
G862S02-01 DOOR (U60CA,DOOR OPENING STRUT OPTION)
G863S01-01 FRONT & SIDE WINDOW (U60CA)
G863S02-01 REAR WINDOW (U60CA)
G864S01-01 INTERIOR (U60CA,MEC)
G864S01-03 INTERIOR (U60CA,PST)
G864S01-06 MAT (U60CA)
G865S01-01 AIR-CON BLOWER (U60CA,43,47,50,53,55,62)
G865S01-05 AIR-CON COMPRESSOR (53,55,62,C)
G865S01-08 AIR-CON LINE (U60CA,53,55,62)
G865S01-13 AIR-CON BLOWER (U60CA,52,60,L4AL)
G866S01-01 ELECTRICAL WIRING (U60CA,DO)
G866S02-01 WINDOW WIPER (U60CA,N60CA)
G866S03-01 AUDIO SYSTEM (U60CA)
G867S01-01 ROOF (U60CA,S-BLUE)
G868S01-01 EXTERIOR (U60CA(43,47,50,52,53,55,60,62),S-BLUE)
G869S01-01 MISCELLANY (U60CA)
G869S01-02 MISCELLANY (U60CA)
G869S01-03 MISCELLANY (F)
G870S01-01 FENDER (43,47,50,52,53,55,60,62,F,S-BLUE)
G880S01-01 SAFETY FRAME (F,R-ROPS,FOLDABLE)
G880S01-02 CANOPY (F)
15. TIRES, WHEELS & REAR BALLAST
G490S01-03 WHEEL & TIRE (11.2-20-14.9-28)
G490S01-08 WHEEL BOLTS & NUTS
16. ACCESSORY & ETC
G830S03-01 REAR VIEW MIRROR (U-LOOK,F,MIRROR,OPTION)
G920S01-01 REAR VIEW MIRROR (F,W-CANOPY)
G920S03-01 NUMBER PLATE
G920S05-01 BOLT CAP
17. DECALS
G980S01-09 DECAL (43,47,52,55,62,F,DO)
G980S01-10 DECAL (43,47,52,55,62,U60CA,DO)
