Momed80
150
35,046
LS Tractor S Series U5030 (Roll bar or U6000CA cab S4S) Parts Catalog
Brand: LS
Model: LS S Series U5030 (Roll bar or U6000CA cab S4S) Tractor
Number of Pages: 324 Pages
01. ENGINE
Q065S01-05 OVERHAUL GASKET KIT (53)
Q110S01-06 CRANKCASE ASSY (53)
Q110S02-04 CRANKCASE (53,55)
Q110S02-05 CRANKCASE (53,55)
Q115S01-04 ROCKER COVER (53,55)
Q115S01-06 CAM SHAFT (53)
Q115S02-02 AIR BREATHER (53,55)
Q116S01-05 CYLINDER HEAD (53)
Q116S02-01 LIFTING EYE (53,55)
Q120S01-06 MAIN MOVING PARTS (53)
Q120S01-07 MAIN MOVING PARTS (53)
Q121S01-05 VALVE MECHANISM (53)
Q125S01-12 FUEL SYSTEM (53)
Q125S01-13 FUEL SYSTEM (53)
Q125S02-05 FUEL PUMP & FILTER (53)
Q130S01-08 TIMING GEAR & CASE (53)
Q130S01-09 TIMING GEAR & CASE (53)
Q130S02-01 SIDE POWER TAKE-OFF (53,55)
Q130S02-04 SIDE POWER TAKE-OFF (53)
Q135S01-05 COOLING SYSTEM (53)
Q140S01-05 OIL SYSTEM (53,55)
Q140S01-06 RELIEF VALVE (53,55)
Q140S01-08 OIL FILTER (53,55)
Q140S01-12 SIDE COVER (53)
Q145S01-03 OIL PAN (53,55)
Q146S01-03 BALANCER (53,55)
Q160S01-06 EXHAUST MANIFOLD (53,55)
Q160S02-01 INTAKE MANIFOLD (53,55)
Q170S01-01 STARTER (53,55)
Q180S01-07 ELECTRIC PARTS (53)
Q180S01-08 ELECTRIC PARTS (53)
Q180S02-03 ACCESSORY (53)
02. ENGINE APPLICATION
G040S01-01 FUEL TANK (60L)
G100S01-07 THROTTLE CONTROL (53,55)
G150S01-01 MUFFLER (43,47,50,53,55,F,Vertical)
G170S01-03 RADIATOR (53,55,62,U60CA or F)
G170S01-08 RADIATOR (53,55.62,U6000CA)
G190S01-10 AIR CLEANER (53,55)
G210S01-03 ENGINE FRAME (53,55,62)
G215S01-04 FRONT BALLAST (52,53,55,60,62,L4AL,BUMPER ONLY)
03. TRANSMISSION
G250S01-03 CLUTCH (53,55,62,L4AL)
G250S02-04 CLUTCH HOUSING (MEC)
G260S01-01 CLUTCH PEDAL (MEC)
G280S01-01 TRANSMISSION CASE (MEC,NO-Q-T)
G281S01-01 MAIN SHAFT (MEC,INDP,NO-CRP)
G281S02-01 MAIN GEAR SHAFT
G285S01-01 RANGE GEAR SHAFT (STD)
G310S01-01 REAR DIFFERENTIAL (43,47,50,52,53,55,60,62)
04. PTO DRIVE
G287S01-02 PTO GEAR & DRIVE SHAFT (PTO-1)
05. FOUR WHEEL DRIVE (4WD)
G288S01-02 4WD SHAFT & COVER (52,53,55,60,62,NO-Q-T)
G400S01-03 FRONT AXLE ASSY (53,55,62)
G400S02-02 FRONT AXLE CASE(CENTER) (52,53,55,60,62)
G400S02-03 FRONT AXLE CASE(LH) (STD,NO-Q-T)
G400S02-05 FRONT AXLE CASE(RH)
G400S03-01 FRONT DIFFERENTIAL
G400S04-02 FRONT DRIVE
G610S01-02 TIE-ROD
G991S30-03 SVC KIT-FRONT AXLE CASE(LH)
G991S30-04 SVC KIT-FRONT AXLE CASE(RH)
07. REAR AXLE & BRAKE
G480S01-01 REAR AXLE
G650S01-01 BRAKE
G670S01-01 BRAKE PEDALS (WO-SWITCH)
G670S02-01 PARKING BRAKE LEVER
08. SHIFT FORK & LINKAGE
G290S01-03 SHIFT LEVER&FORK(RANGE GEAR) (STD,NO-Q-T)
G290S01-05 CREEPER LEVER COVER (NO-CRP,MEC)
G290S02-01 LEVER&FORK(MAIN GEAR)
G290S03-01 LEVER&FORK(F-R GEAR) (MEC,SHUTTLE)
G291S03-03 LEVER&FORK(RANGE GEAR) (PTO-1)
G320S01-01 DIFF-LOCK
G630S01-03 STEERING CYLINDER & LINES (53,55,62)
G640S01-01 T-M OIL COOLER (W-O COOLER)
G822S02-01 PTO VALVE (INDP,WO-Quick-Turn)
G822S03-02 LOADER VALVE (N60CA or U60CA or F,L-V)
G822S03-03 LOADER VALVE (U6000CA,L-V)
G823S01-04 HYDRAULIC LINES (N60CA or U60CA or F,53,55,62,LOADER VALVE)
G823S01-08 HYDRAULIC LINES (U6000CA,53,55,62,LOADER VALVE)
G827S01-07 REMOTE CONTROL VALVE (N60CA or U60CA or F,SD5-2,ASAE)
G827S01-08 REMOTE CONTROL VALVE (U6000CA,SD5-2)
G827S01-11 REMOTE CONTROL LEVER (U6000CA,SD5-2)
G829S01-06 AUTO LEVELING HYD. LINE (U6000CA,MHL,NO-LEVELING,SD5-2)
G730S01-06 ELECTRICAL WIRING (U-TWIN,43,47,52,55,62,F)
G730S01-26 ELECTRICAL WIRING (U-TWIN,43,47,52,55,62,U6000CA)
G730S02-01 7 POLE CONNECTOR-SVC OFF
G740S01-01 BATTERY (43,47,50,52,53,55,60,62,100AH)
G750S01-06 METER PANEL (U-53,55,C,F,US-PTO,AG,EX,LSTA)
G750S06-01 E-PTO PLUG (NO-EPTO)
G760S01-10 LAMP (U-TWIN,F,LSTA)
G760S01-12 LAMP (U6000CA)
G760S01-14 HEAD LAMP (U-TWIN)
11. HYDRAULIC LIFT UNIT
G820S01-01 HYD. HOUSING ASSY (MHL)
G820S02-01 HYDRAULIC HOUSING (MHL)
G822S01-01 LIFT CTRL. VALVE & LINK (MHL)
G824S01-01 POSITION & DRAFT LINK (MHL)
G825S01-01 HYD. CONTROL LEVER (U60CA or F,L-V,MHL)
G825S01-07 HYD. CONTROL LEVER (U6000CA,MHL)
G825S01-08 HYD. LEVER GUIDE (U6000CA,MHL)
G825S02-01 AUTO LIFT. (N60CA or U60CA or F,MHL)
G825S02-03 AUTO LIFT (U6000CA,MHL)
G825S02-05 EXTERNAL CONTROL (F,MEC,DO)
G826S01-01 HYDRAULIC CYLINDER (MHL)
G828S01-01 UPPER LINK BRACKET (STD)
12. 3-POINT LINKAGE & HITCH
G891S01-02 DRAWBAR & HITCH (TELESCOPIC DRAWBAR)
G896S01-04 UPPER & LOWER LINK (TELESCOPIC,CAT1,2)
G896S02-01 LIFT ROD (NO-LEVEL)
G896S03-01 CHECK LINK (F,C-LINK)
G896S03-02 CHECK LINK (C,C-LINK)
13. SHEET METALS & MOUNTS
G830S01-26 HOOD (U-TWIN,RHT,S-BLUE)
G830S01-33 HOOD UNDER COVER (U6000CA,Dark Gray)
G830S01-34 HOOD UNDER COVER (F or U60CA,Dark Gray)
G830S02-05 HOOD SUPPORT (U-LOOK,U6000CA or F)
G840S01-01 STEP & MOUNT RUBBER (F,S-BLUE)
G840S01-05 MOUNT RUBBER (C)
G840S01-16 SUB STEP (U60CA or U6000CA,60L)
G840S01-17 SUB STEP (F,FUEL-60L)
14. DRIVER’S STATION
G630S02-01 STEERING WHEEL & COLUMN (F,LS-CAP)
G630S02-02 STEERING WHEEL & COLUMN (C,LS-CAP)
G630S02-18 STEERING WHEEL (LS-CAP)
G835S01-01 PEDAL FRAME (F,MEC)
G835S01-04 PEDAL FRAME (U6000CA)
G850S01-01 SEAT (F,WOOCHANG)
G850S01-07 SEAT (U6000CA,WOOCHANG)
G861S01-03 FRAME (U6000CA,TAEKWANG,WOOCHANG)
G862S01-01 DOOR(LH) (U60CA or U6000CA)
G862S01-02 DOOR(RH) (U60CA or U6000CA)
G863S01-03 FRONT WINDOW (U6000CA)
G863S01-04 SIDE WINDOW (U6000CA)
G863S02-03 REAR WINDOW (U6000CA)
G864S01-04 INTERIOR (U6000CA)
G864S01-05 INTERIOR(TOP) (U6000CA)
G864S01-07 MAT (U6000CA)
G865S01-05 AIR-CON COMPRESSOR (53,55,62,C)
G865S01-16 AIR-CON BLOWER (U6000CA)
G865S01-18 AIR-CON LINE (U6000CA,53,55,62)
G865S02-01 AIR-CON UNIT (C,HVAC-40351207)
G866S01-06 ELECTRICAL WIRING (U6000CA,STD)
G866S02-02 WINDOW WIPER(REAR) (U6000CA)
G866S02-03 WINDOW WIPER(FRONT) (U6000CA)
G866S03-02 AUDIO SYSTEM (U6000CA)
G867S01-09 ROOF (U6000CA,S-BLUE)
G868S01-09 EXTERIOR (U60CA(L4AL) or U6000CA,S-BLUE)
G869S01-06 MISCELLANY (F)
G869S01-12 MISCELLANY (U6000CA)
G869S01-13 MISCELLANY (U6000CA)
G869S01-14 MISCELLANY (U6000CA)
G869S01-15 GROMMET(FENDER) (U6000CA)
G870S01-01 FENDER (43,47,50,52,53,55,60,62,F,S-BLUE)
G880S01-01 SAFETY FRAME (F,R-ROPS,FOLDABLE)
15. TIRES, WHEELS & REAR BALLAST
G490S01-08 WHEEL BOLTS & NUTS
16. ACCESSORY & ETC
G868S02-01 SLOW MOVING VEHICLES (LSTA)
G920S03-04 NUMBER PLATE BRACKET (F,STD)
G920S05-01 BOLT CAP
17. DECALS
G980S01-25 DECAL (F,LSTA)
G980S01-39 DECAL (47,53,U6000CA,LSTA)
18. DIA KIT & SVC KIT
G991S01-01 SVC KIT LIST
