Momed80
150
35,046
LS Tractor S Series U5020 (Roll bar or U60CA cab S4Q) Parts Catalog
Brand: LS
Model: LS S Series U5020 (Roll bar or U60CA cab S4Q) Tractor
Number of Pages: 262 Pages
01. ENGINE
G010S01-01 ENGINE LONG BLOCK ASSY (S4QL)
G010S01-03 ENGINE SHORT BLOCK ASSY (43,47,50,52,60)
Q065S01-01 OVERHAUL GASKET KIT (43,47,50)
Q110S01-01 CRANKCASE ASSY (43,47,50)
Q110S02-01 CRANKCASE (43,47,50)
Q115S01-01 ROCKER COVER & CAMSHAFT (43,47,50)
Q116S01-01 CYLINDER HEAD (43,47,50)
Q120S01-01 MAIN MOVING PARTS (43,47,50)
Q121S01-01 VALVE MECHANISM (43,47,50)
Q125S01-01 FUEL SYSTEM (43,47,50)
Q125S02-01 FUEL FILTER (S4QL,S4QT)
Q130S01-01 TIMING GEAR & CASE (43,47,50)
Q135S01-01 COOLING SYSTEM (43,47,50)
Q140S01-01 OIL SYSTEM (43,47,50)
Q145S01-01 OIL PAN (43,47,50)
Q146S01-01 BALANCER (43,47,50)
Q160S01-01 INLET & OUTLET MANIFOLD (43,47,50)
Q180S01-01 ELECTRIC PARTS (43,47,50)
02. ENGINE APPLICATION
G040S01-01 FUEL TANK (60L)
G100S01-01 THROTTLE CONTROL
G150S01-01 MUFFLER (43,47,50,53,55,F,Vertical)
G150S01-09 MUFFLER (43,47,50,53,55,C,Vertical)
G170S01-01 RADIATOR (43,47,50,U60CA or F)
G190S01-08 AIR CLEANER (43,47,50)
G210S01-01 ENGINE FRAME (43,47,50)
03. TRANSMISSION
G250S01-01 CLUTCH (43,47,50)
G250S02-03 CLUTCH HOUSING (43,47,50,MEC)
G260S01-01 CLUTCH PEDAL (MEC)
G280S01-01 TRANSMISSION CASE (MEC,NO-Q-T)
G281S01-01 MAIN SHAFT (MEC,INDP,NO-CRP)
G281S02-01 MAIN GEAR SHAFT
G285S01-01 RANGE GEAR SHAFT (STD)
G310S01-01 REAR DIFFERENTIAL (43,47,50,52,53,55,60,62)
04. PTO DRIVE
G283S01-01 PTO CLUTCH & SHAFT (MEC,INDP)
G287S01-02 PTO GEAR & DRIVE SHAFT (PTO-1)
05. FOUR WHEEL DRIVE (4WD)
G288S01-01 4WD SHAFT & COVER (43,47,50,NO-Q-T)
G400S01-01 FRONT AXLE ASSY (43,47,50)
G400S02-01 FRONT AXLE CASE(CENTER) (43,47,50)
G400S02-03 FRONT AXLE CASE(LH) (STD,NO-Q-T)
G400S02-05 FRONT AXLE CASE(RH)
G400S03-01 FRONT DIFFERENTIAL
G400S04-01 FRONT DRIVE (43,47,50)
G610S01-01 TIE-ROD (43,47,50)
G991S30-03 SVC KIT-FRONT AXLE CASE(LH)
G991S30-04 SVC KIT-FRONT AXLE CASE(RH)
07. REAR AXLE & BRAKE
G480S01-01 REAR AXLE
G650S01-01 BRAKE
G670S01-01 BRAKE PEDALS (WO-SWITCH)
G670S02-01 PARKING BRAKE LEVER
08. SHIFT FORK & LINKAGE
G290S01-03 SHIFT LEVER&FORK(RANGE GEAR) (STD,NO-Q-T)
G290S01-05 CREEPER LEVER COVER (NO-CRP,MEC)
G290S02-01 LEVER&FORK(MAIN GEAR)
G290S03-01 LEVER&FORK(F-R GEAR) (MEC,SHUTTLE)
G291S03-03 LEVER&FORK(RANGE GEAR) (PTO-1)
G320S01-01 DIFF-LOCK
G630S01-01 STEERING CYLINDER & LINES (43,47,50)
G640S01-01 T-M OIL COOLER (W-O COOLER)
G822S02-01 PTO VALVE (INDP,WO-Quick-Turn)
G822S03-02 LOADER VALVE (N60CA or U60CA or F,L-V)
G823S01-03 HYDRAULIC LINES (N60CA or U60CA or F,43,47,50,52,60,L4AL,LOADER VALVE)
G827S01-07 REMOTE CONTROL VALVE (N60CA or U60CA or F,SD5-2,ASAE)
G730S01-06 ELECTRICAL WIRING (U-TWIN,43,47,52,55,62,F)
G730S01-08 ELECTRICAL WIRING (U-TWIN,43,47,52,55,62,U60CA)
G730S02-01 7 POLE CONNECTOR-SVC OFF
G740S01-01 BATTERY (43,47,50,52,53,55,60,62,100AH)
G750S01-05 METER PANEL (U-43,47,C,F,US-PTO,AG,EX,LSTA)
G750S06-01 E-PTO PLUG (NO-EPTO)
G760S01-10 LAMP (U-TWIN,F,LSTA)
G760S01-11 LAMP (U-TWIN,U60CA,LSTA)
G760S01-14 HEAD LAMP (U-TWIN)
11. HYDRAULIC LIFT UNIT
G820S01-01 HYD. HOUSING ASSY (MHL)
G820S02-01 HYDRAULIC HOUSING (MHL)
G822S01-01 LIFT CTRL. VALVE & LINK (MHL)
G824S01-01 POSITION & DRAFT LINK (MHL)
G825S01-01 HYD. CONTROL LEVER (U60CA or F,L-V,MHL)
G825S02-01 AUTO LIFT. (N60CA or U60CA or F,MHL)
G826S01-01 HYDRAULIC CYLINDER (MHL)
G828S01-01 UPPER LINK BRACKET (STD)
12. 3-POINT LINKAGE & HITCH
G891S01-02 DRAWBAR & HITCH (TELESCOPIC DRAWBAR)
G896S01-04 UPPER & LOWER LINK (TELESCOPIC,CAT1,2)
G896S02-01 LIFT ROD (NO-LEVEL)
G896S03-01 CHECK LINK (F,C-LINK)
G896S03-02 CHECK LINK (C,C-LINK)
13. SHEET METALS & MOUNTS
G830S01-26 HOOD (U-TWIN,RHT,S-BLUE)
G830S01-34 HOOD UNDER COVER (F or U60CA,Dark Gray)
G830S02-03 HOOD SUPPORT (U-LOOK,U60CA or F)
G840S01-01 STEP & MOUNT RUBBER (F,S-BLUE)
G840S01-05 MOUNT RUBBER (C)
G840S01-16 SUB STEP (U60CA or U6000CA,60L)
G840S01-17 SUB STEP (F,FUEL-60L)
14. DRIVER’S STATION
G630S02-01 STEERING WHEEL & COLUMN (F,LS-CAP)
G630S02-02 STEERING WHEEL & COLUMN (C,LS-CAP)
G630S02-18 STEERING WHEEL (LS-CAP)
G835S01-01 PEDAL FRAME (F,MEC)
G850S01-01 SEAT (F,WOOCHANG)
G850S01-03 SEAT (U60CA,WOOCHANG)
G861S01-01 FRAME (U60CA)
G862S01-01 DOOR(LH) (U60CA or U6000CA)
G862S01-02 DOOR(RH) (U60CA or U6000CA)
G862S02-01 DOOR (U60CA,DOOR OPENING STRUT OPTION)
G863S01-01 FRONT & SIDE WINDOW (U60CA)
G863S02-01 REAR WINDOW (U60CA)
G864S01-01 INTERIOR (U60CA,MEC)
G864S01-06 MAT (U60CA)
G865S01-01 AIR-CON BLOWER (U60CA,43,47,50,53,55,62)
G865S01-03 AIR-CON COMPRESSOR (47,50,C)
G865S01-07 AIR-CON LINE (U60CA,43,47,50)
G866S01-02 ELECTRICAL WIRING (U60CA,EXP)
G866S02-01 WINDOW WIPER (U60CA,N60CA)
G866S03-01 AUDIO SYSTEM (U60CA)
G867S01-01 ROOF (U60CA,S-BLUE)
G868S01-01 EXTERIOR (U60CA(43,47,50,52,53,55,60,62),S-BLUE)
G869S01-01 MISCELLANY (U60CA)
G869S01-03 MISCELLANY (U60CA,EXP)
G869S01-06 MISCELLANY (F)
G870S01-01 FENDER (43,47,50,52,53,55,60,62,F,S-BLUE)
G880S01-01 SAFETY FRAME (F,R-ROPS,FOLDABLE)
15. TIRES, WHEELS & REAR BALLAST
G490S01-08 WHEEL BOLTS & NUTS
16. ACCESSORY & ETC
G868S02-01 SLOW MOVING VEHICLES (LSTA)
G920S03-04 NUMBER PLATE BRACKET (F,STD)
G920S05-01 BOLT CAP
17. DECALS
G980S01-15 DECAL (47,53,U60CA,LSTA)
G980S01-25 DECAL (F,LSTA)
18. DIA KIT & SVC KIT
G991S01-01 SVC KIT LIST
