Momed80
151
35,863
LS Tractor R Series R4010 R4010H R4020 R4020H Parts Catalog
Brand: LS
Model: LS R Series R4010 R4010H R4020 R4020H Tractor
Number of Pages: 260 Pages
01. ENGINE
Q065S01-02 OVERHAUL GASKET KIT (39,41,43,45,47,48,50)
Q110S01-03 CRANKCASE ASSY (39,41,43,45,47,48,50)
Q110S02-04 CRANKCASE (39,41,43,45,47,48,50)
Q115S01-03 ROCKER COVER & CAMSHAFT (39,41,43,45,47,48,50)
Q116S01-02 CYLINDER HEAD (39,41)
Q116S01-03 CYLINDER HEAD (43,45,47,48,50)
Q120S01-04 MAIN MOVING PARTS (39,41)
Q120S01-05 MAIN MOVING PARTS (43,45,47,48,50)
Q121S01-02 VALVE MECHANISM (39,41,43,45,47,48,50)
Q125S01-07 FUEL SYSTEM (39,41)
Q125S01-08 FUEL SYSTEM (43,45,47,48,50)
Q125S02-01 FUEL FILTER (S4QL,S4QT)
Q130S01-03 TIMING GEAR & CASE (39,41,43,45,47,48,50)
Q135S01-02 COOLING SYSTEM (39,41,43,45,47,48,50)
Q140S01-04 OIL SYSTEM (39,41,43,45,47,48,50)
Q145S01-01 OIL PAN (39,41,43,45,47,48,50)
Q146S01-01 BALANCER (39,41,43,45,47,48,50)
Q160S01-02 INLET & OUTLET MANIFOLD (39,41,43,45,47,48,50)
Q180S01-04 ELECTRIC PARTS (39,41,43,45,47,48,50)
02. ENGINE APPLICATION
G040S01-04 FUEL TANK (39,41,43,45,47,48,53,60,LARGE)
G100S01-02 THROTTLE LEVER
G100S01-03 THROTTLE PEDAL (MEC)
G150S01-02 MUFFLER (39,41,43,45,47,48,50)
G170S01-06 RADIATOR (39,41,43,45,47,48,50)
G190S01-06 AIR CLEANER (39,41,43,45,47,48,50)
G210S01-06 ENGINE FRAME (39,41,43,45,47,48,50)
03. TRANSMISSION
G250S01-02 CLUTCH (MEC or EZ-shift)
G250S02-03 CLUTCH HOUSING (MEC)
G250S03-02 DAMPER (HST)
G260S01-01 CLUTCH PEDAL (MEC)
G270S01-02 HST UNIT (HST)
G270S01-03 HST ROTATING KIT (HST)
G270S01-04 HST SEAL KIT (HST)
G280S01-03 TRANSMISSION CASE (MEC,M-PTO)
G280S01-05 TRANSMISSION CASE (HST,M-PTO)
G281S01-01 MAIN SHAFT (MEC,INDP,NO-CRP)
G281S02-01 MAIN GEAR SHAFT (MEC or EZ-shift)
G281S02-02 MAIN GEAR SHAFT (HST)
G285S01-02 RANGE GEAR SHAFT (MEC or EZ-shift,NO-GSP)
G285S01-04 RANGE GEAR SHAFT (HST,NO-GSP)
G310S01-01 REAR DIFFERENTIAL
04. PTO DRIVE
G280S02-01 PTO SHIELD (STD or EC)
G283S01-01 PTO CLUTCH & SHAFT (MEC or EZ-shift,INDP,NO-GSP)
G283S01-02 PTO CLUTCH & SHAFT (HST,INDP,NO-GSP)
G287S01-03 PTO GEAR & DRIVE SHAFT (PTO-1,M-PTO)
G287S02-01 MID PTO LEVER (M-PTO)
G287S02-02 MID PTO HOUSING (M-PTO)
G287S04-01 PTO SHAFT CAP
05. FOUR WHEEL DRIVE (4WD)
G288S01-02 4WD SHAFT & COVER (NO-Q-T)
G400S01-01 FRONT AXLE ASSY
G400S02-01 FRONT AXLE CASE(CENTER)
G400S02-02 FRONT AXLE CASE(RH)
G400S02-03 FRONT AXLE CASE(LH) (NO-Q-T)
G400S03-01 FRONT DIFFERENTIAL
G400S04-01 FRONT DRIVE
G610S01-01 TIE-ROD
G630S01-01 STEERING CYLINDER
07. REAR AXLE & BRAKE
G480S01-01 REAR AXLE
G650S01-01 BRAKE (STD)
G670S01-01 BRAKE PEDALS (MEC or EZ-shift,STD)
G670S01-02 BRAKE PEDALS (HST,STD)
G670S02-01 PARKING BRAKE LEVER (STD)
08. SHIFT FORK & LINKAGE
G290S01-01 LEVER&FORK(F-R GEAR) (MEC)
G290S01-04 LEVER&FORK (HST)
G290S01-07 LEVER&FORK(PTO) (PTO-1)
G290S02-02 LEVER&FORK(MAIN GEAR) (MEC)
G291S01-03 LEVER&FORK(RANGE GEAR) (MEC)
G291S02-01 LEVER&FORK(4WD) (4WD,NO-Q-T)
G292S01-01 HST CONTROL (HST)
G320S01-01 DIFF-LOCK (MEC or EZ-shift)
G320S01-03 DIFF-LOCK (HST)
G630S01-03 STEERING LINES (MEC or EZ-shift)
G630S01-04 STEERING LINES (HST)
G630S01-05 STEERING UNIT SVC KIT (40289688 SVC KIT)
G640S01-04 T-M OIL COOLER (HST,M,C-LOOK)
G822S02-01 PTO VALVE (MEC,INDP)
G822S02-06 PTO VALVE (HST,INDP)
G822S03-17 FRONT OUTLET VALVE (F-O)
G823S01-01 HYD. SUCTION LINES
G823S02-02 HYD. PRESSURE LINES (MEC,F-O,W-AUX VV)
G823S02-06 HYD. PRESSURE LINES (HST,F-O,W-AUX VV)
G827S01-02 REMOTE CONTROL VALVE (SD5-2)
G730S01-02 ELECTRICAL WIRING (MEC or HST)
G730S02-01 7 POLE CONNECTOR
G740S01-02 BATTERY (80A)
G750S01-03 METER PANEL (MEC)
G750S01-06 METER PANEL (HST)
G750S03-06 F-R SENSOR PLUG (MEC)
G760S01-05 LAMP (MC-LOOK)
11. HYDRAULIC LIFT UNIT
G820S01-01 HYD. HOUSING ASSY (NO-LEVEL,W-DRAFT)
G820S02-01 HYDRAULIC HOUSING (NO-LEVEL,W-DRAFT or DRAFT DEALER OPT)
G822S01-01 LIFT CTRL. VALVE & LINK (W-DRAFT or DRAFT DEALER OPT)
G824S01-01 POSITION & DRAFT CTRL. LINK (W-DRAFT)
G825S01-05 HYD. CONTROL LEVER (NO-LEVEL,W-DRAFT)
G825S01-08 HYD. LEVER GUIDE (NO-LEVEL,W-DRAFT,DARK GRAY)
G826S01-01 HYDRAULIC CYLINDER
G828S01-01 UPPER LINK BRACKET (W-DRAFT)
12. 3-POINT LINKAGE & HITCH
G891S01-02 DRAWBAR & HITCH (TELESCOPIC)
G896S01-01 UPPER & LOWER LINK (GENERAL)
G896S01-07 TOP LINK HOOK (F)
G896S02-01 LIFT ROD (NO-LEVEL)
G896S03-02 CHECK LINK (TELESCOPIC)
13. SHEET METALS & MOUNTS
G830S01-03 HOOD (C-LOOK,S-BLUE)
G830S02-02 HOOD SUPPORT
G840S01-08 SUB STEP
G840S01-09 WIND SHIELD
G840S01-12 MOUNT RUBBER (NO-LEVEL)
G840S01-13 STEP (MEC)
G840S01-14 STEP (HST)
14. DRIVER’S STATION
G630S02-01 STEERING WHEEL & COLUMN (MEC or HST,LS-CAP)
G830S04-01 INTERIOR(FRONT) (MEC or HST)
G835S01-01 PEDAL FRAME (MEC)
G835S01-02 PEDAL FRAME (HST)
G840S01-16 MAT
G850S01-02 SEAT (MEC or EZ-shift)
G850S01-03 SEAT (HST)
G870S01-07 FENDER (S-BLUE,WO-N-BRKT)
G880S01-01 SAFETY FRAME (R-ROPS,FOLDERBLE)
15. TIRES, WHEELS & REAR BALLAST
G490S01-06 WHEEL BOLTS & NUTS
16. ACCESSORY & ETC
G868S02-01 SLOW MOVING VEHICLES
G920S05-01 RUBBER PLUGS
G920S05-03 BOLT CAP
17. DECALS
G980S01-07 DECAL (C-LOOK)
18. DIA KIT & SVC KIT
G840S01-08 SUB STEP
